[Darshan-users] Darshan installation question
    Kevin Harms
    harms at alcf.anl.gov
    Sat May 21 20:58:59 CDT 2011
Ketan,
  first thing, check that the library was linked in. Try nm exe | grep darshan and see if any darshan symbols are present. If they are, see if there is any output on standard error indicating the darshan log couldn't be opened.
  If darshan isn't being linked in, are you also trying to use Tau or have other libraries that might intercept MPI routines.
kevin
On May 19, 2011, at 6:43 PM, ketan wrote:
> Thanks Kevin for your help and support installing Darshan.
> I now have Darshan installed and using its mpicc to make my application. However, I do not see anything gets touched in the designated Darshan logs when I really run the application.
> Any ideas what to look for when debugging this.
> Also, I do not know what should I send you guys so that you could possibly diagnose the issue.
> Regards,
> Ketan
> On 5/18/11 11:41 AM, ketan wrote:
>> I have now installed MPI, however, the installation stops at:
>> configure: error: must provide --with-jobid-env=<name> argument to configure.
>> From the INSTALL file, I see that if the above option is not provided Darshan uses the job-id.
>> Could you kindly indicate how to get past this. Is there a default value that I could provide here?
>> Ketan
>> On 5/17/11 10:11 AM, Kevin Harms wrote:
>>> Ketan,
>>>   Darshan itself requires MPI. You could add MPI_Init(), MPI_Finalize() in your program main and that would be sufficient to get information about POSIX calls.
>>> kevin
>>> On May 17, 2011, at 10:08 AM, ketan wrote:
>>>> Hello,
>>>> I am new to Darshan. Trying to install on ci login node with the following commandline from the INSTALL file:
>>>> ./configure --with-mem-align=64 --with-log-path=$LOGPATH --prefix=$PREFIX
>>>> However, I get the following:
>>>> configure: error: must provide --with-mpi=<path>  argument to configure if mpicc is not in path.
>>>> The install file does not seem to mention mpi is mandatory. Is it possible to avoid the above flag while installation as our requirement does not include mpi.
>>>> Thanks,
>>>> Ketan
>>>> _______________________________________________
>>>> Darshan-users mailing list
>>>> Darshan-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
