[Darshan-users] Darshan installation question
    ketan
    ketan at mcs.anl.gov
    Thu May 19 18:43:51 CDT 2011
Thanks Kevin for your help and support installing Darshan.
I now have Darshan installed and using its mpicc to make my application.
However, I do not see anything gets touched in the designated Darshan
logs when I really run the application.
Any ideas what to look for when debugging this.
Also, I do not know what should I send you guys so that you could
possibly diagnose the issue.
Ketan
On 5/18/11 11:41 AM, ketan wrote:
> I have now installed MPI, however, the installation stops at:
> configure: error: must provide --with-jobid-env=<name> argument to
> configure.
> From the INSTALL file, I see that if the above option is not provided
> Darshan uses the job-id.
> Could you kindly indicate how to get past this. Is there a default
> value that I could provide here?
> Ketan
> On 5/17/11 10:11 AM, Kevin Harms wrote:
>> Ketan,
>>    Darshan itself requires MPI. You could add MPI_Init(),
>> MPI_Finalize() in your program main and that would be sufficient to
>> get information about POSIX calls.
>> kevin
>> On May 17, 2011, at 10:08 AM, ketan wrote:
>>> Hello,
>>> I am new to Darshan. Trying to install on ci login node with the
>>> following commandline from the INSTALL file:
>>> ./configure --with-mem-align=64 --with-log-path=$LOGPATH
>>> --prefix=$PREFIX
>>> However, I get the following:
>>> configure: error: must provide --with-mpi=<path>  argument to
>>> configure if mpicc is not in path.
>>> The install file does not seem to mention mpi is mandatory. Is it
>>> possible to avoid the above flag while installation as our
>>> requirement does not include mpi.
>>> Thanks,
>>> Ketan
>>> _______________________________________________
>>> Darshan-users mailing list
>>> Darshan-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
More information about the Darshan-users
