[Darshan-users] Darshan Calibration
Kevin Harms
harms at alcf.anl.gov
Wed Jun 1 10:09:49 CDT 2011
I suppose there could be a few reasons. If anything is dynamically linked, then you would miss data from that code. There also some code that filters out certain file system types. If you stop by, I can help you take a look.
> 1. Is there a definitive way of finding how Darshan intercepts the program?
The default is static linking and in that method is uses the MPI/PMPI interfaces and for POSIX it uses the linker wrapping option.
> 2. Can I cross verify with some other tool what Darshan has produced is indeed consistent?
Not that I know of.
> 3. Are there any calibration parameters that I can set while using Darshan?
There are options you can change which affect what Darshan does with logs and such but not on how it collects data.
> 4. Has someone tried using Darshan with coreutils programs?
In trunk/test there is a patch for 'cp'.
kevin
More information about the Darshan-users
