[Darshan-users] darshan-job-summary: errors
Noah Watkins jayhawk at soe.ucsc.edu
Wed Jul 14 16:36:19 CDT 2010
Unfortunately, I deleted the .gz files from that run without thinking about using them to debug the problem. However, I haven't ran into the same problem again. I will be sure to push them to the mailing list if it happens again.
Thanks!
-noah
----- Original Message -----
To: darshan-users at lists.mcs.anl.gov
Sent: Wednesday, July 14, 2010 3:11:50 PM GMT -07:00 US/Canada Mountain
Subject: Re: [Darshan-users] darshan-job-summary: errors
Actually, if you are still working with the trunk you can just send the .gz file itself, if you don't mind sharing it. The .gz files generated by trunk are (or should be anyway) portable.
I might have already mentioned this, but if not keep in mind that the .gz files you generate from trunk might only be parsable by tools built against that same version. We don't really worry about backwards compatibility until the official releases.
-Phil
On 07/14/2010 02:10 PM, Kevin Harms wrote:
Noah,
  can you run darshan-parser directly on the log file and send the result? assuming it's not too large.
  /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-parser /path/to/log/file.gz > file.txt
kevin
On Jul 14, 2010, at 12:20 PM, Noah Watkins wrote:
Hey Darshan,
This is being produced using darshan-job-summary in the trunk, r290:
-n
Use of uninitialized value $file_record{"CP_INDEP_OPENS"} in numeric eq (==) at /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-job-summary.pl line 892, <TRACE> line 23.
Use of uninitialized value $file_record{"CP_COLL_OPENS"} in numeric eq (==) at /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-job-summary.pl line 892, <TRACE> line 23.
Use of uninitialized value $file_record{"CP_POSIX_OPENS"} in numeric eq (==) at /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-job-summary.pl line 892, <TRACE> line 23.
Use of uninitialized value in addition (+) at /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-job-summary.pl line 272.
Use of uninitialized value in print at /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-job-summary.pl line 273.
Darshan-users mailing list Darshan-users at lists.mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/darshan-users _______________________________________________
More information about the Darshan-users mailing list
