[Darshan-users] darshan-job-summary: errors
Phil Carns
carns at mcs.anl.gov
Wed Jul 14 16:11:50 CDT 2010
Actually, if you are still working with the trunk you can just send the
.gz file itself, if you don't mind sharing it. The .gz files generated
by trunk are (or should be anyway) portable.
I might have already mentioned this, but if not keep in mind that the
.gz files you generate from trunk might only be parsable by tools built
against that same version. We don't really worry about backwards
compatibility until the official releases.
-Phil
On 07/14/2010 02:10 PM, Kevin Harms wrote:
> Noah,
> can you run darshan-parser directly on the log file and send the result? assuming it's not too large.
> /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-parser /path/to/log/file.gz> file.txt
> kevin
> On Jul 14, 2010, at 12:20 PM, Noah Watkins wrote:
>> Hey Darshan,
>> This is being produced using darshan-job-summary in the trunk, r290:
>> -n
>> Use of uninitialized value $file_record{"CP_INDEP_OPENS"} in numeric eq (==) at /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-job-summary.pl line 892,<TRACE> line 23.
>> Use of uninitialized value $file_record{"CP_COLL_OPENS"} in numeric eq (==) at /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-job-summary.pl line 892,<TRACE> line 23.
>> Use of uninitialized value $file_record{"CP_POSIX_OPENS"} in numeric eq (==) at /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-job-summary.pl line 892,<TRACE> line 23.
>> Use of uninitialized value in addition (+) at /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-job-summary.pl line 272.
>> Use of uninitialized value in print at /home/noah/sw/INSTALL/darshan-trunk/bin/darshan-job-summary.pl line 273.
>> Darshan-users mailing list
>> Darshan-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20100714/34716eee/attachment.htm>
More information about the Darshan-users
