[Darshan-users] Darshan and AIX?
Julian Kunkel
juliankunkel at googlemail.com
Wed Dec 22 03:20:47 CST 2010
Thanks guys for your help,
I modified configure by setting cross_compiling=yes
host and build did not work (maybe I have not experience with it, or
it detects that it should compile for the same host and switches to
no). now I was able to run configure properly.
To get around a problem with mpicc (under IBM PE it is called mpcc) I
created a wrapper bash script which just runs mpcc "$@"
On IBMs PE it seems that MPIO_Request should be MPI_Request, otherwise
the compiler argues.
int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf,
int count, MPI_Datatype datatype, MPI_Request *request);
I wonder if this issue will appear with other MPI libraries as well,
as it seems the MPI Standard uses here MPI_Request as Datatype.
There are two C++ style (//) comments in lib/darshan-mpi-io.c
At this point I have issues on compiling the parser with getopt, I
might continue to investigate this issues next year.
As we get a small Power7 Testsystem which runs under RedHat it might
be a better choice to test it there ;-)
Julian
P.S. Have a merry chrismas.
2010/12/22 Rob Latham <robl at mcs.anl.gov>:
> On Tue, Dec 21, 2010 at 11:51:45AM +0100, Julian Kunkel wrote:
>> Hi,
>> has anyone suceeded or experience to compile Darshan on an AIX (6.1)
>> system so far?
>> One problem seems to be that mpicc is used to compile the particular test for:
>> checking size of long int... configure: error: cannot compute sizeof (long int)
>> However, running an MPI executable is not possible (easily) on the login node.
> one way around that is to put configure into cross compile mode with
> the --build and --host flags. kind of icky but will at least use
> compile-time only tests. we might have other configure tests that
> execute code, and cross compile mode will find those as well.
>> I'm not so sure about the wrap (linker) flag used to intercept calls,
>> probably another method is required in AIX, so I would be glad about
>> experience from other AIX users.
> I think you're it, Julian.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
More information about the Darshan-users
