[Darshan-commits] [Git][darshan/darshan][autoperf-mod-update] fix const ifdefs for mpi routines
Shane Snyder xgitlab at cels.anl.gov
Fri Mar 12 12:19:19 CST 2021
Shane Snyder pushed to branch autoperf-mod-update at darshan / darshan
Commits:
1c703fc6 by Shane Snyder at 2021-03-12T18:18:03+00:00
5 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/darshan-dynamic.h
- darshan-runtime/darshan-runtime-config.h.in
- darshan-runtime/lib/darshan-mpiio.c
Changes:
@@ -4925,11 +4925,11 @@ fi
 rm -f core conftest.err conftest.$ac_objext \
     conftest$ac_exeext conftest.$ac_ext
-# At some point MPI-IO converted most API functions to be const correct.  We
-# need to test for this to determine how to define MPI-IO wrappers in
+# At some point MPI converted most API functions to be const correct.  We
+# need to test for this to determine how to define MPI wrappers in
 # Darshan.  First we try compiling without cost qualifiers.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO prototypes without const qualifier" >&5
-$as_echo_n "checking for MPI-IO prototypes without const qualifier... " >&6; }
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI prototypes without const qualifier" >&5
+$as_echo_n "checking for MPI prototypes without const qualifier... " >&6; }
 cat confdefs.h - <<_ACEOF >conftest.$ac_ext
 /* end confdefs.h.  */
@@ -4955,8 +4955,8 @@ $as_echo "no" >&6; }
     # unable to compile without const qualifiers.  Let's try again with
     # const qualifiers.
-    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO prototypes with const qualifier" >&5
-$as_echo_n "checking for MPI-IO prototypes with const qualifier... " >&6; }
+    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI prototypes with const qualifier" >&5
+$as_echo_n "checking for MPI prototypes with const qualifier... " >&6; }
@@ -4977,7 +4977,7 @@ if ac_fn_c_try_compile "$LINENO"; then :
   { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
 $as_echo "yes" >&6; }
-$as_echo "#define HAVE_MPIIO_CONST 1" >>confdefs.h
+$as_echo "#define HAVE_MPI_CONST 1" >>confdefs.h
 fi
 rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
@@ -450,10 +450,10 @@ AC_TRY_LINK([#include <mpi.h>], [
     AC_MSG_RESULT(yes),
             AC_MSG_ERROR(Darshan requires a version of MPI with MPI-IO support))
-AC_MSG_CHECKING(for MPI-IO prototypes without const qualifier)
+AC_MSG_CHECKING(for MPI prototypes without const qualifier)
 AC_TRY_COMPILE(
     #include <mpi.h>
@@ -467,7 +467,7 @@ AC_TRY_COMPILE(
     # const qualifiers.
-    AC_MSG_CHECKING(for MPI-IO prototypes with const qualifier)
+    AC_MSG_CHECKING(for MPI prototypes with const qualifier)
     AC_TRY_COMPILE(
         #include <mpi.h>
@@ -477,7 +477,7 @@ AC_TRY_COMPILE(
         AC_MSG_RESULT(yes)
-        AC_DEFINE(HAVE_MPIIO_CONST, 1, Define if MPI-IO prototypes use const qualifier),
+        AC_DEFINE(HAVE_MPI_CONST, 1, Define if MPI prototypes use const qualifier),
         AC_MSG_ERROR(Darshan is unable to find a compatible MPI_File_open prototype)
@@ -17,22 +17,22 @@ DARSHAN_EXTERN_DECL(PMPI_File_close, int, (MPI_File *fh));
 DARSHAN_EXTERN_DECL(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 DARSHAN_EXTERN_DECL(PMPI_File_iread, int, (MPI_File fh, void  *buf, int  count, MPI_Datatype  datatype, __D_MPI_REQUEST  *request));
 DARSHAN_EXTERN_DECL(PMPI_File_iread_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#ifdef HAVE_MPIIO_CONST
+#ifdef HAVE_MPI_CONST
 DARSHAN_EXTERN_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_iwrite, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_iwrite, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_open, int, (MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_open, int, (MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh));
@@ -46,53 +46,53 @@ DARSHAN_EXTERN_DECL(PMPI_File_read, int, (MPI_File fh, void *buf, int count, MPI
 DARSHAN_EXTERN_DECL(PMPI_File_read_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
 DARSHAN_EXTERN_DECL(PMPI_File_read_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 DARSHAN_EXTERN_DECL(PMPI_File_read_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 DARSHAN_EXTERN_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, const char *datarep, MPI_Info info));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, char *datarep, MPI_Info info));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_sync, int, (MPI_File fh));
 DARSHAN_EXTERN_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_write_all, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_write_all, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_write, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_write, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_write_ordered, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_write_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_File_write_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_EXTERN_DECL(PMPI_File_write_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
@@ -101,41 +101,49 @@ DARSHAN_EXTERN_DECL(PMPI_Finalize, int, ());
 DARSHAN_EXTERN_DECL(PMPI_Init, int, (int *argc, char ***argv));
 DARSHAN_EXTERN_DECL(PMPI_Init_thread, int, (int *argc, char ***argv, int required, int *provided));
 DARSHAN_EXTERN_DECL(PMPI_Wtime, double, ());
 DARSHAN_EXTERN_DECL(PMPI_Allreduce, int, (const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
+#else
+DARSHAN_EXTERN_DECL(PMPI_Allreduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
+#endif
 DARSHAN_EXTERN_DECL(PMPI_Bcast, int, (void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm));
 DARSHAN_EXTERN_DECL(PMPI_Comm_rank, int, (MPI_Comm comm, int *rank));
 DARSHAN_EXTERN_DECL(PMPI_Comm_size, int, (MPI_Comm comm, int *size));
-#if 0
+DARSHAN_EXTERN_DECL(PMPI_Scan, int, (const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
+#else
 DARSHAN_EXTERN_DECL(PMPI_Scan, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_Type_commit, int, (MPI_Datatype *datatype));
 DARSHAN_EXTERN_DECL(PMPI_Type_contiguous, int, (int count, MPI_Datatype oldtype, MPI_Datatype *newtype));
 DARSHAN_EXTERN_DECL(PMPI_Type_extent, int, (MPI_Datatype datatype, MPI_Aint *extent));
 DARSHAN_EXTERN_DECL(PMPI_Type_free, int, (MPI_Datatype *datatype));
+DARSHAN_EXTERN_DECL(PMPI_Type_hindexed, int, (int count, const int *array_of_blocklengths, MPI_Aint *array_of_displacements, MPI_Datatype oldtype, MPI_Datatype *newtype));
+#else
 DARSHAN_EXTERN_DECL(PMPI_Type_hindexed, int, (int count, int *array_of_blocklengths, MPI_Aint *array_of_displacements, MPI_Datatype oldtype, MPI_Datatype *newtype));
+#endif
 DARSHAN_EXTERN_DECL(PMPI_Type_get_envelope, int, (MPI_Datatype datatype, int *num_integers, int *num_addresses, int *num_datatypes, int *combiner));
 DARSHAN_EXTERN_DECL(PMPI_Type_size, int, (MPI_Datatype datatype, int *size));
 DARSHAN_EXTERN_DECL(PMPI_Op_create, int, (MPI_User_function *function, int commute, MPI_Op *op));
 DARSHAN_EXTERN_DECL(PMPI_Op_free, int, (MPI_Op *op));
-#if 0
 DARSHAN_EXTERN_DECL(PMPI_Reduce, int, (const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm));
 #else
 DARSHAN_EXTERN_DECL(PMPI_Reduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_Send, int, (const void *buf, int count, MPI_Datatype datatype, int dest, int tag, MPI_Comm comm));
 #else
 DARSHAN_EXTERN_DECL(PMPI_Send, int, (void *buf, int count, MPI_Datatype datatype, int dest, int tag, MPI_Comm comm));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_Recv, int, (void *buf, int count, MPI_Datatype datatype, int source, int tag, MPI_Comm comm, MPI_Status *status));
 DARSHAN_EXTERN_DECL(PMPI_Gather, int, (const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm));
 #else
 DARSHAN_EXTERN_DECL(PMPI_Gather, int, (void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm));
 #endif
 DARSHAN_EXTERN_DECL(PMPI_Barrier, int, (MPI_Comm comm));
-#endif /* if 0 */
 #endif /* HAVE_MPI */
 #endif
@@ -33,8 +33,8 @@
 /* Define if build is MPI-enabled */
 #undef HAVE_MPI
-/* Define if MPI-IO prototypes use const qualifier */
-#undef HAVE_MPIIO_CONST
+/* Define if MPI prototypes use const qualifier */
+#undef HAVE_MPI_CONST
 /* Define if off64_t type is defined */
 #undef HAVE_OFF64_T
@@ -30,22 +30,22 @@ DARSHAN_FORWARD_DECL(PMPI_File_close, int, (MPI_File *fh));
 DARSHAN_FORWARD_DECL(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 DARSHAN_FORWARD_DECL(PMPI_File_iread, int, (MPI_File fh, void  *buf, int  count, MPI_Datatype  datatype, __D_MPI_REQUEST  *request));
 DARSHAN_FORWARD_DECL(PMPI_File_iread_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 DARSHAN_FORWARD_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_iwrite, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_iwrite, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_open, int, (MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_open, int, (MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh));
@@ -59,53 +59,53 @@ DARSHAN_FORWARD_DECL(PMPI_File_read, int, (MPI_File fh, void *buf, int count, MP
 DARSHAN_FORWARD_DECL(PMPI_File_read_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
 DARSHAN_FORWARD_DECL(PMPI_File_read_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 DARSHAN_FORWARD_DECL(PMPI_File_read_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 DARSHAN_FORWARD_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, const char *datarep, MPI_Info info));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, char *datarep, MPI_Info info));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_sync, int, (MPI_File fh));
 DARSHAN_FORWARD_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_write_all, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_write_all, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_write, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_write, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_write_ordered, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_write_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #endif
 DARSHAN_FORWARD_DECL(PMPI_File_write_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
 #else
 DARSHAN_FORWARD_DECL(PMPI_File_write_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
@@ -318,7 +318,7 @@ static int my_rank = -1;
  *        Wrappers for MPI-IO functions of interest       *
 int DARSHAN_DECL(MPI_File_open)(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh)
 #else
 int DARSHAN_DECL(MPI_File_open)(MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh)
@@ -352,7 +352,7 @@ int DARSHAN_DECL(MPI_File_open)(MPI_Comm comm, char *filename, int amode, MPI_In
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_open, int,  (MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh), MPI_File_open)
 #else
 DARSHAN_WRAPPER_MAP(PMPI_File_open, int,  (MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh), MPI_File_open)
@@ -381,7 +381,7 @@ int DARSHAN_DECL(MPI_File_read)(MPI_File fh, void *buf, int count,
 DARSHAN_WRAPPER_MAP(PMPI_File_read, int, (MPI_File fh, void *buf, int count,
     MPI_Datatype datatype, MPI_Status *status), MPI_File_read)
 int DARSHAN_DECL(MPI_File_write)(MPI_File fh, const void *buf, int count,
 #else
@@ -406,7 +406,7 @@ int DARSHAN_DECL(MPI_File_write)(MPI_File fh, void *buf, int count,
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_write, int, (MPI_File fh, const void *buf, int count,
     MPI_Datatype datatype, MPI_Status *status), MPI_File_write)
 #else
@@ -436,7 +436,7 @@ int DARSHAN_DECL(MPI_File_read_at)(MPI_File fh, MPI_Offset offset, void *buf,
 DARSHAN_WRAPPER_MAP(PMPI_File_read_at, int, (MPI_File fh, MPI_Offset offset, void *buf,
     int count, MPI_Datatype datatype, MPI_Status *status), MPI_File_read_at)
 int DARSHAN_DECL(MPI_File_write_at)(MPI_File fh, MPI_Offset offset, const void *buf,
 #else
@@ -460,7 +460,7 @@ int DARSHAN_DECL(MPI_File_write_at)(MPI_File fh, MPI_Offset offset, void *buf,
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, const void *buf,
     int count, MPI_Datatype datatype, MPI_Status *status), MPI_File_write_at)
 #else
@@ -491,7 +491,7 @@ int DARSHAN_DECL(MPI_File_read_all)(MPI_File fh, void * buf, int count, MPI_Data
 DARSHAN_WRAPPER_MAP(PMPI_File_read_all, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
         MPI_File_read_all)
 int DARSHAN_DECL(MPI_File_write_all)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
 #else
 int DARSHAN_DECL(MPI_File_write_all)(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
@@ -515,7 +515,7 @@ int DARSHAN_DECL(MPI_File_write_all)(MPI_File fh, void * buf, int count, MPI_Dat
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_write_all, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
         MPI_File_write_all)
 #else
@@ -546,7 +546,7 @@ DARSHAN_WRAPPER_MAP(PMPI_File_read_at_all, int, (MPI_File fh, MPI_Offset offset,
     int count, MPI_Datatype datatype, MPI_Status * status),
         MPI_File_read_at_all)
 int DARSHAN_DECL(MPI_File_write_at_all)(MPI_File fh, MPI_Offset offset, const void * buf,
 #else
@@ -570,7 +570,7 @@ int DARSHAN_DECL(MPI_File_write_at_all)(MPI_File fh, MPI_Offset offset, void * b
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, const void * buf,
@@ -603,7 +603,7 @@ int DARSHAN_DECL(MPI_File_read_shared)(MPI_File fh, void * buf, int count, MPI_D
 DARSHAN_WRAPPER_MAP(PMPI_File_read_shared, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
 int DARSHAN_DECL(MPI_File_write_shared)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
 #else
 int DARSHAN_DECL(MPI_File_write_shared)(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
@@ -627,7 +627,7 @@ int DARSHAN_DECL(MPI_File_write_shared)(MPI_File fh, void * buf, int count, MPI_
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_write_shared, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
 #else
@@ -661,7 +661,7 @@ DARSHAN_WRAPPER_MAP(PMPI_File_read_ordered, int, (MPI_File fh, void * buf, int c
         MPI_File_read_ordered)
 int DARSHAN_DECL(MPI_File_write_ordered)(MPI_File fh, const void * buf, int count,
 #else
@@ -687,7 +687,7 @@ int DARSHAN_DECL(MPI_File_write_ordered)(MPI_File fh, void * buf, int count,
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_write_ordered, int, (MPI_File fh, const void * buf, int count,
@@ -719,7 +719,7 @@ int DARSHAN_DECL(MPI_File_read_all_begin)(MPI_File fh, void * buf, int count, MP
 DARSHAN_WRAPPER_MAP(PMPI_File_read_all_begin, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype),
 int DARSHAN_DECL(MPI_File_write_all_begin)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype)
 #else
 int DARSHAN_DECL(MPI_File_write_all_begin)(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
@@ -743,7 +743,7 @@ int DARSHAN_DECL(MPI_File_write_all_begin)(MPI_File fh, void * buf, int count, M
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_write_all_begin, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype),
 #else
@@ -773,7 +773,7 @@ int DARSHAN_DECL(MPI_File_read_at_all_begin)(MPI_File fh, MPI_Offset offset, voi
 DARSHAN_WRAPPER_MAP(PMPI_File_read_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void * buf,
     int count, MPI_Datatype datatype), MPI_File_read_at_all_begin)
 int DARSHAN_DECL(MPI_File_write_at_all_begin)(MPI_File fh, MPI_Offset offset, const void * buf,
 #else
@@ -797,7 +797,7 @@ int DARSHAN_DECL(MPI_File_write_at_all_begin)(MPI_File fh, MPI_Offset offset, vo
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, const void * buf,
     int count, MPI_Datatype datatype), MPI_File_write_at_all_begin)
 #else
@@ -828,7 +828,7 @@ int DARSHAN_DECL(MPI_File_read_ordered_begin)(MPI_File fh, void * buf, int count
 DARSHAN_WRAPPER_MAP(PMPI_File_read_ordered_begin, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype),
 int DARSHAN_DECL(MPI_File_write_ordered_begin)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype)
 #else
 int DARSHAN_DECL(MPI_File_write_ordered_begin)(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
@@ -852,7 +852,7 @@ int DARSHAN_DECL(MPI_File_write_ordered_begin)(MPI_File fh, void * buf, int coun
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_write_ordered_begin, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype),
 #else
@@ -882,7 +882,7 @@ int DARSHAN_DECL(MPI_File_iread)(MPI_File fh, void * buf, int count, MPI_Datatyp
 DARSHAN_WRAPPER_MAP(PMPI_File_iread, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST * request),
         MPI_File_iread)
 int DARSHAN_DECL(MPI_File_iwrite)(MPI_File fh, const void * buf, int count,
 #else
@@ -907,7 +907,7 @@ int DARSHAN_DECL(MPI_File_iwrite)(MPI_File fh, void * buf, int count,
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_iwrite, int, (MPI_File fh, const void * buf, int count,
         MPI_File_iwrite)
@@ -940,7 +940,7 @@ DARSHAN_WRAPPER_MAP(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, vo
     int count, MPI_Datatype datatype, __D_MPI_REQUEST *request),
         MPI_File_iread_at)
 int DARSHAN_DECL(MPI_File_iwrite_at)(MPI_File fh, MPI_Offset offset, const void * buf,
 #else
@@ -964,7 +964,7 @@ int DARSHAN_DECL(MPI_File_iwrite_at)(MPI_File fh, MPI_Offset offset, void * buf,
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, const void * buf,
         MPI_File_iwrite_at)
@@ -999,7 +999,7 @@ DARSHAN_WRAPPER_MAP(PMPI_File_iread_shared, int, (MPI_File fh, void * buf, int c
         MPI_File_iread_shared)
 int DARSHAN_DECL(MPI_File_iwrite_shared)(MPI_File fh, const void * buf, int count,
 #else
@@ -1025,7 +1025,7 @@ int DARSHAN_DECL(MPI_File_iwrite_shared)(MPI_File fh, void * buf, int count,
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_iwrite_shared, int, (MPI_File fh, const void * buf, int count,
@@ -1066,7 +1066,7 @@ int DARSHAN_DECL(MPI_File_sync)(MPI_File fh)
 DARSHAN_WRAPPER_MAP(PMPI_File_sync, int, (MPI_File fh), MPI_File_sync)
 int DARSHAN_DECL(MPI_File_set_view)(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
 #else
@@ -1106,7 +1106,7 @@ int DARSHAN_DECL(MPI_File_set_view)(MPI_File fh, MPI_Offset disp, MPI_Datatype e
     return(ret);
 DARSHAN_WRAPPER_MAP(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
     MPI_Datatype filetype, const char *datarep, MPI_Info info), MPI_File_set_view)
 #else
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/commit/1c703fc620fb6cdb3d5f7bb77b3c1f3249b5e5d9
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210312/78c15862/attachment-0001.html>
More information about the Darshan-commits mailing list
