[Darshan-commits] [Git][darshan/darshan][autoperf-mod-update] more cleanup to get apxc building
Shane Snyder xgitlab at cels.anl.gov
Thu Mar 11 21:06:55 CST 2021
Shane Snyder pushed to branch autoperf-mod-update at darshan / darshan
Commits:
c48dae80 by Shane Snyder at 2021-03-12T03:06:23+00:00
4 changed files:
- darshan-log-format.h
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/share/ld-opts/darshan-base-ld-opts.in
Changes:
@@ -157,20 +157,20 @@ struct darshan_base_record
 #endif
 #define DARSHAN_MODULE_IDS \
-    X(DARSHAN_NULL_MOD,     "NULL",     DARSHAN_NULL_VER,       NULL) \
-    X(DARSHAN_POSIX_MOD,    "POSIX",    DARSHAN_POSIX_VER,      &posix_logutils) \
-    X(DARSHAN_MPIIO_MOD,    "MPI-IO",   DARSHAN_MPIIO_VER,      &mpiio_logutils) \
-    X(DARSHAN_H5F_MOD,      "H5F",      DARSHAN_H5F_VER,        &hdf5_file_logutils) \
-    X(DARSHAN_H5D_MOD,      "H5D",      DARSHAN_H5D_VER,        &hdf5_dataset_logutils) \
-    X(DARSHAN_PNETCDF_MOD,  "PNETCDF",  DARSHAN_PNETCDF_VER,    &pnetcdf_logutils) \
-    X(DARSHAN_BGQ_MOD,      "BG/Q",     DARSHAN_BGQ_VER,        &bgq_logutils) \
-    X(DARSHAN_LUSTRE_MOD,   "LUSTRE",   DARSHAN_LUSTRE_VER,     &lustre_logutils) \
-    X(DARSHAN_STDIO_MOD,    "STDIO",    DARSHAN_STDIO_VER,      &stdio_logutils) \
-    X(DXT_POSIX_MOD,       "DXT_POSIX",  DXT_POSIX_VER,         &dxt_posix_logutils) \
-    X(DXT_MPIIO_MOD,       "DXT_MPIIO",  DXT_MPIIO_VER,         &dxt_mpiio_logutils) \
-    X(DARSHAN_MDHIM_MOD,   "MDHIM",      DARSHAN_MDHIM_VER,     &mdhim_logutils) \
-    X(APXC_MOD,    "APXC", __APXC_VER,  __apxc_logutils) \
-    X(APMPI_MOD,    "APMPI", __APMPI_VER,  __apmpi_logutils)
+    X(DARSHAN_NULL_MOD,     "NULL",       DARSHAN_NULL_VER,      NULL) \
+    X(DARSHAN_POSIX_MOD,    "POSIX",      DARSHAN_POSIX_VER,     &posix_logutils) \
+    X(DARSHAN_MPIIO_MOD,    "MPI-IO",     DARSHAN_MPIIO_VER,     &mpiio_logutils) \
+    X(DARSHAN_H5F_MOD,      "H5F",        DARSHAN_H5F_VER,       &hdf5_file_logutils) \
+    X(DARSHAN_H5D_MOD,      "H5D",        DARSHAN_H5D_VER,       &hdf5_dataset_logutils) \
+    X(DARSHAN_PNETCDF_MOD,  "PNETCDF",    DARSHAN_PNETCDF_VER,   &pnetcdf_logutils) \
+    X(DARSHAN_BGQ_MOD,      "BG/Q",       DARSHAN_BGQ_VER,       &bgq_logutils) \
+    X(DARSHAN_LUSTRE_MOD,   "LUSTRE",     DARSHAN_LUSTRE_VER,    &lustre_logutils) \
+    X(DARSHAN_STDIO_MOD,    "STDIO",      DARSHAN_STDIO_VER,     &stdio_logutils) \
+    X(DXT_POSIX_MOD,        "DXT_POSIX",  DXT_POSIX_VER,         &dxt_posix_logutils) \
+    X(DXT_MPIIO_MOD,        "DXT_MPIIO",  DXT_MPIIO_VER,         &dxt_mpiio_logutils) \
+    X(DARSHAN_MDHIM_MOD,    "MDHIM",      DARSHAN_MDHIM_VER,     &mdhim_logutils) \
+    X(DARSHAN_APXC_MOD,     "APXC", 	  __APXC_VER,            __apxc_logutils) \
+    X(DARSHAN_APMPI_MOD,    "APMPI",      __APMPI_VER,           __apmpi_logutils)
 /* unique identifiers to distinguish between available darshan modules */
 /* NOTES: - valid ids range from [0...DARSHAN_MAX_MODS-1]
@@ -630,7 +630,7 @@ DARSHAN_HDF5_LD_FLAGS
 DARSHAN_HDF5_ADD_DFLUSH_LD_OPTS
 DARSHAN_HDF5_LD_OPTS
 BUILD_HDF5_MODULE
-AUTOPERF_APMPI_LD_OPTS
+DARSHAN_APMPI_LD_OPTS
 BUILD_APMPI_MODULE
 BUILD_APXC_MODULE
 DARSHAN_PNETCDF_LD_OPTS
@@ -688,7 +688,6 @@ infodir
 docdir
 oldincludedir
 includedir
-runstatedir
 localstatedir
 sharedstatedir
 sysconfdir
@@ -786,7 +785,6 @@ datadir='${datarootdir}'
 sysconfdir='${prefix}/etc'
 sharedstatedir='${prefix}/com'
 localstatedir='${prefix}/var'
-runstatedir='${localstatedir}/run'
 includedir='${prefix}/include'
 oldincludedir='/usr/include'
 docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
@@ -1039,15 +1037,6 @@ do
   | -silent | --silent | --silen | --sile | --sil)
     silent=yes ;;
-  -runstatedir | --runstatedir | --runstatedi | --runstated \
-  | --runstate | --runstat | --runsta | --runst | --runs \
-  | --run | --ru | --r)
-    ac_prev=runstatedir ;;
-  -runstatedir=* | --runstatedir=* | --runstatedi=* | --runstated=* \
-  | --runstate=* | --runstat=* | --runsta=* | --runst=* | --runs=* \
-  | --run=* | --ru=* | --r=*)
-    runstatedir=$ac_optarg ;;
   -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
     ac_prev=sbindir ;;
   -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
@@ -1185,7 +1174,7 @@ fi
 for ac_var in	exec_prefix prefix bindir sbindir libexecdir datarootdir \
 		datadir sysconfdir sharedstatedir localstatedir includedir \
 		oldincludedir docdir infodir htmldir dvidir pdfdir psdir \
-		libdir localedir mandir runstatedir
+		libdir localedir mandir
 do
   eval ac_val=\$$ac_var
   # Remove trailing slashes.
@@ -1338,7 +1327,6 @@ Fine tuning of the installation directories:
   --sysconfdir=DIR        read-only single-machine data [PREFIX/etc]
   --sharedstatedir=DIR    modifiable architecture-independent data [PREFIX/com]
   --localstatedir=DIR     modifiable single-machine data [PREFIX/var]
-  --runstatedir=DIR       modifiable per-process data [LOCALSTATEDIR/run]
   --libdir=DIR            object code libraries [EPREFIX/lib]
   --includedir=DIR        C header files [PREFIX/include]
   --oldincludedir=DIR     C header files for non-gcc [/usr/include]
@@ -4223,7 +4211,7 @@ fi
 # AUTOPERF MPI module
 BUILD_APMPI_MODULE=
-AUTOPERF_APMPI_LD_OPTS=
+DARSHAN_APMPI_LD_OPTS=
 # Check whether --enable-apmpi-mod was given.
 if test "${enable_apmpi_mod+set}" = set; then :
   enableval=$enable_apmpi_mod;
@@ -4246,7 +4234,7 @@ fi
  # this last part tells it to only check for presence
     BUILD_APMPI_MODULE=1
-    AUTOPERF_APMPI_LD_OPTS="@${darshan_share_path}/ld-opts/autoperf-apmpi-ld-opts"
+    DARSHAN_APMPI_LD_OPTS="@${darshan_share_path}/ld-opts/autoperf-apmpi-ld-opts"
 fi
@@ -222,7 +222,7 @@ AS_IF([test "x$enable_mpiio_mod" = "xno" || test "x$ENABLE_MPI" = "x"],
 BUILD_APMPI_MODULE=
 AC_ARG_ENABLE(apmpi-mod,
               AS_HELP_STRING([--enable-apmpi-mod], [Enables compilation and use of AUTOPERF MPI module (requires MPI)]))
 AS_IF([test "x$enable_apmpi_mod" = "xyes"], [
@@ -235,7 +235,7 @@ AS_IF([test "x$enable_apmpi_mod" = "xyes"], [
                     [AC_MSG_ERROR([The Autoperf MPI module is not present])],
                     [-]) # this last part tells it to only check for presence
 AC_ARG_ENABLE(apmpi-coll-sync,
@@ -573,7 +573,7 @@ AC_SUBST(BUILD_PNETCDF_MODULE)
 AC_SUBST(DARSHAN_PNETCDF_LD_OPTS)
 AC_SUBST(BUILD_APXC_MODULE)
 AC_SUBST(BUILD_APMPI_MODULE)
-AC_SUBST(AUTOPERF_APMPI_LD_OPTS)
+AC_SUBST(DARSHAN_APMPI_LD_OPTS)
 AC_SUBST(BUILD_HDF5_MODULE)
 AC_SUBST(DARSHAN_HDF5_LD_OPTS)
 AC_SUBST(DARSHAN_HDF5_ADD_DFLUSH_LD_OPTS)
@@ -13,4 +13,4 @@
 @DARSHAN_PNETCDF_LD_OPTS@
 @DARSHAN_HDF5_LD_OPTS@
 @DARSHAN_MDHIM_LD_OPTS@
- at AUTOPERF_APMPI_LD_OPTS@
+ at DARSHAN_APMPI_LD_OPTS@
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/commit/c48dae803f8fe418c30765a0729bfcaa1d42903a
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210311/35100a48/attachment-0001.html>
More information about the Darshan-commits mailing list
