[Darshan-commits] [Git][darshan/darshan][master] 2 commits: brief documentation for spack packages
Philip Carns
xgitlab at cels.anl.gov
Wed Mar 10 15:52:54 CST 2021
Philip Carns pushed to branch master at darshan / darshan
Commits:
1e44c0ae by Phil Carns at 2021-03-10T16:51:38-05:00
8de30ada by Philip Carns at 2021-03-10T15:52:51-06:00
Merge branch 'carns/darshan-runtim-doc-spack' into 'master'
Closes #308
See merge request darshan/darshan!81
1 changed file:
- darshan-runtime/doc/darshan-runtime.txt
Changes:
@@ -51,7 +51,9 @@ http://www.mcs.anl.gov/darshan[Darshan web site].
* C compiler (preferably GCC-compatible)
* zlib development headers and library
-== Compilation
+== Conventional installation
+=== Compilation
.Configure and build example (with MPI support)
@@ -115,7 +117,7 @@ group read access.
* `--disable-lustre-mod`: disables compilation and use of Darshan's Lustre module (default=enabled)
* `--disable-mdhim-mod`: disables compilation and use of Darshan's MDHIM module (default=disabled)
-== Environment preparation
+=== Environment preparation
Once darshan-runtime has been installed, you must prepare a location
in which to store the Darshan log files and configure an instrumentation method.
@@ -164,6 +166,56 @@ administrators group
* recursively set the setgid bit on the log directories
+== Spack installation
+You can also install Darshan via https://spack.io/[Spack] as an alternative
+to manual download, compilation, and installation. This may be
+especially convenient for single-user installs. Darshan is divided
+into two separate packages for the command line utilities and runtime
+instrumentation. You can install either or both as follows:
+spack install darshan-util
+spack install darshan-runtime
+[NOTE]
+Darshan will generally compile and install fine using a variety of
+compilers, but we advise using a gcc compiler in Spack to compile Darshan
+(regardless of what compiler you will use for your applications) to
+ensure maximum runtime compatibility.
+You can use the `spack info darshan-runtime` query to view the full list of
+variants available for the darshan-runtime Spack package. For example, adding a `+slurm` to
+the command line (`spack install darshan-runtime+slurm`) will cause Darshan
+to be compiled with support for gathering job ID information from the Slurm
+scheduler.
+The following commands will load the Darshan packages once they have been
+installed:
+spack load -r darshan-util
+spack load -r darshan-runtime
+Note that the spack install of darshan-runtime will use an environment
+variable named `$DARSHAN_LOG_DIR_PATH` to indicate where it should store log
+files. This variable is set to the user's home directory by default when
+the package is loaded, but it may be overridden.
+On Cray systems, you can also perform an additional step to load a
+Cray-specific module file. This will make a module called `darshan`
+available as described later in this document in the Cray platform recipe.
+It enables automatic instrumentation when using the standard Cray compiler
+wrappers.
+module use `spack location -i darshan-runtime`/share/craype-2.x/modulefiles
== Instrumenting applications
[NOTE]
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/compare/649e3d35eeac81ae6273add1951aa338cf20334f...8de30ada258afda6bab37120bfcb21f8e63ca6c6
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210310/b86aa83b/attachment-0001.html>
More information about the Darshan-commits
