[Darshan-commits] [Git][darshan/darshan][autoperf-mod-update] pydarshan apxc script
Sudheer Chunduri
xgitlab at cels.anl.gov
Tue Feb 2 10:33:39 CST 2021
Sudheer Chunduri pushed to branch autoperf-mod-update at darshan / darshan
Commits:
c18e3501 by Sudheer Chunduri at 2021-02-02T16:32:44+00:00
6 changed files:
- − .gitmodules
- − darshan-util/pydarshan.py
- darshan-util/pydarshan/darshan/backend/cffi_backend.py
- darshan-util/pydarshan/darshan/report.py
- darshan-util/pydarshan/setup.py
- − modules/autoperf
Changes:
.gitmodules deleted
@@ -1,4 +0,0 @@
-[submodule "modules/autoperf"]
- path = modules/autoperf
- url = git at xgitlab.cels.anl.gov:AutoPerf/autoperf.git
- branch = master
darshan-util/pydarshan.py deleted
@@ -1,268 +0,0 @@
-import cffi
-import numpy
-API_def_c = r"""
-/* from darshan-logutils.h */
-struct darshan_mnt_info
- char mnt_type[3031];
- char mnt_path[3031];
-struct darshan_mod_info
- char *name;
- int len;
- int ver;
- int idx;
-/* from darshan-log-format.h */
-struct darshan_job
- int64_t uid;
- int64_t start_time;
- int64_t end_time;
- int64_t nprocs;
- int64_t jobid;
- char metadata[1024];
-struct darshan_base_record
- uint64_t id;
- int64_t rank;
-struct darshan_posix_file
- struct darshan_base_record base_rec;
- int64_t counters[64];
- double fcounters[17];
-struct darshan_stdio_file
- int64_t counters[13];
- double fcounters[15];
-struct darshan_mpiio_file
- int64_t counters[51];
-struct darshan_hdf5_file
- int64_t counters[1];
- double fcounters[2];
-struct darshan_pnetcdf_file
- int64_t counters[2];
-struct darshan_bgq_record
- int64_t counters[11];
- double fcounters[1];
-/* from darshan-apxc-log-format.h */
-struct darshan_apxc_header_record
- int64_t magic;
- int nblades;
- int nchassis;
- int ngroups;
- int memory_mode;
- int cluster_mode;
-struct darshan_apxc_perf_record
- int64_t counters[396];
-/* counter names */
-char *apxc_counter_names[];
-char *bgq_counter_names[];
-char *bgq_f_counter_names[];
-char *hdf5_counter_names[];
-char *hdf5_f_counter_names[];
-char *mpiio_counter_names[];
-char *mpiio_f_counter_names[];
-char *pnetcdf_counter_names[];
-char *pnetcdf_f_counter_names[];
-char *posix_counter_names[];
-char *posix_f_counter_names[];
-char *stdio_counter_names[];
-char *stdio_f_counter_names[];
-/* Supported Functions */
-void* darshan_log_open(char *);
-int darshan_log_get_job(void *, struct darshan_job *);
-void darshan_log_close(void*);
-int darshan_log_get_exe(void*, char *);
-int darshan_log_get_mounts(void*, struct darshan_mnt_info **, int*);
-void darshan_log_get_modules(void*, struct darshan_mod_info **, int*);
-int darshan_log_get_record(void*, int, void **);
-ffi = cffi.FFI()
-ffi.cdef(API_def_c)
-libdutil = ffi.dlopen("/home/harms/working/darshan/theta/install/lib/libdarshan-util.so")
-modules = {}
-def log_open(filename):
- b_fname = filename.encode()
- log = libdutil.darshan_log_open(b_fname)
- mods = log_get_modules(log)
- return log
-def log_close(log):
- libdutil.darshan_log_close(log)
- modules = {}
- return
-def log_get_job(log):
- job = {}
- jobrec = ffi.new("struct darshan_job *")
- libdutil.darshan_log_get_job(log, jobrec)
- job['jobid'] = jobrec[0].jobid
- job['uid'] = jobrec[0].uid
- job['start_time'] = jobrec[0].start_time
- job['end_time'] = jobrec[0].end_time
- mstr = ffi.string(jobrec[0].metadata).decode("utf-8")
- md = {}
- for kv in mstr.split('\n')[:-1]:
- k,v = kv.split('=', maxsplit=1)
- md[k] = v
- job['metadata'] = md
- return job
-def log_get_exe(log):
- exestr = ffi.new("char[]", 4096)
- libdutil.darshan_log_get_exe(log, exestr)
- return ffi.string(exestr).decode("utf-8")
-def log_get_mounts(log):
- mntlst = []
- mnts = ffi.new("struct darshan_mnt_info **")
- cnt = ffi.new("int *")
- libdutil.darshan_log_get_mounts(log, mnts, cnt)
- for i in range(0, cnt[0]):
- mntlst.append((ffi.string(mnts[0][i].mnt_path).decode("utf-8"),
- ffi.string(mnts[0][i].mnt_type).decode("utf-8")))
- return mntlst
-def log_get_modules(log):
- mods = ffi.new("struct darshan_mod_info **")
- libdutil.darshan_log_get_modules(log, mods, cnt)
- modules[ffi.string(mods[0][i].name).decode("utf-8")] = \
- {'len': mods[0][i].len, 'ver': mods[0][i].ver, 'idx': mods[0][i].idx}
- return modules
-def log_get_generic_record(log, mod_name, mod_type):
- rec = {}
- buf = ffi.new("void **")
- r = libdutil.darshan_log_get_record(log, modules[mod_name]['idx'], buf)
- if r < 1:
- return None
- rbuf = ffi.cast(mod_type, buf)
- clst = []
- for i in range(0, len(rbuf[0].counters)):
- clst.append(rbuf[0].counters[i])
- rec['counters'] = numpy.array(clst, dtype=numpy.uint64)
- flst = []
- for i in range(0, len(rbuf[0].fcounters)):
- flst.append(rbuf[0].fcounters[i])
- rec['fcounters'] = numpy.array(clst, dtype=numpy.float64)
- return rec
-def counter_names(mod_name, fcnts=False):
- names = []
- i = 0
- if fcnts:
- F = "f_"
- else:
- F1 = ""
- F2 = ""
- end = "{0}_{1}NUM_INDICES".format(mod_name.upper(), F.upper())
- var_name = "{0}_{1}counter_names".format(mod_name.lower(), F.lower())
- while True:
- try:
- var = getattr(libdutil, var_name)
- except:
- var = None
- if not var:
- return None
- name = ffi.string(var[i]).decode("utf-8")
- if name == end:
- break
- names.append(name)
- i += 1
- return names
-def fcounter_names(mod_name):
- return counter_names(mod_name, fcnts=True)
-def log_get_bgq_record(log):
- return log_get_generic_record(log, "BGQ", "struct darshan_bgq_file **")
-def log_get_hdf5_record(log):
- return log_get_generic_record(log, "HDF5", "struct darshan_hdf5_file **")
-def log_get_mpiio_record(log):
- return log_get_generic_record(log, "MPIIO", "struct darshan_mpiio_file **")
-def log_get_pnetcdf_record(log):
- return log_get_generic_record(log, "PNETCDF", "struct darshan_pnetcdf_file **")
-def log_get_posix_record(log):
- return log_get_generic_record(log, "POSIX", "struct darshan_posix_file **")
-def log_get_stdio_record(log):
- return log_get_generic_record(log, "STDIO", "struct darshan_stdio_file **")
-def log_get_apxc_record(log):
- rec = {}
- memory_modes = ['unknown', 'flat', 'equal', 'split', 'cache']
- cluster_modes = ['unknown', 'all2all', 'quad', 'hemi', 'snc4', 'snc2']
- r = libdutil.darshan_log_get_record(log, modules['APXC']['idx'], buf)
- if r < 1:
- return None
- prf = ffi.cast("struct darshan_apxc_perf_record **", buf)
- hdr = ffi.cast("struct darshan_apxc_header_record **", buf)
- if hdr[0].magic == 4707761685111591494:
- mm = hdr[0].memory_mode & ~(1 << 31)
- cm = hdr[0].cluster_mode & ~(1 << 31)
- rec['nblades'] = hdr[0].nblades
- rec['nchassis'] = hdr[0].nchassis
- rec['ngroups'] = hdr[0].ngroups
- rec['memory_mode'] = memory_modes[mm]
- rec['cluster_mode'] = cluster_modes[cm]
- else:
- rec['group'] = prf[0].counters[0]
- rec['chassis'] = prf[0].counters[1]
- rec['blade'] = prf[0].counters[2]
- rec['node'] = prf[0].counters[3]
- clst = []
- for i in range(0, len(prf[0].counters)):
- clst.append(prf[0].counters[i])
- return rec
@@ -16,6 +16,15 @@ from darshan.discover_darshan import check_version
addins = ""
+# Optional APXC module
+try:
+ from darshan.backend.apxc import *
+ addins += get_apxc_defs()
+except:
+ pass
# Optional APMPI module
@@ -50,6 +50,7 @@ _structdefs = {
"PNETCDF": "struct darshan_pnetcdf_file **",
"POSIX": "struct darshan_posix_file **",
"STDIO": "struct darshan_stdio_file **",
+ "APXC": "struct darshan_apxc_perf_record **",
"APMPI": "struct darshan_apmpi_perf_record **",
@@ -6,64 +6,71 @@ import sys
import os
-with open('README.rst') as readme_file:
+with open("README.rst") as readme_file:
readme = readme_file.read()
-requirements = ['cffi', 'numpy', 'pandas', 'matplotlib']
-setup_requirements = ['pytest-runner', ]
-test_requirements = ['pytest']
+requirements = ["cffi", "numpy", "pandas", "matplotlib"]
+setup_requirements = [
+ "pytest-runner",
+test_requirements = ["pytest"]
ext_modules = []
-if '--with-extension' in sys.argv:
- ext_modules.append(Extension(
- 'darshan.extension',
- #optional=True,
- sources=['darshan/extension.c'],
- include_dirs=['/usr/include'],
- libraries=['darshan-util']
- sys.argv.remove('--with-extension')
+if "--with-extension" in sys.argv:
+ ext_modules.append(
+ Extension(
+ "darshan.extension",
+ # optional=True,
+ sources=["darshan/extension.c"],
+ include_dirs=["/usr/include"],
+ libraries=["darshan-util"],
+ sys.argv.remove("--with-extension")
# Find backend python files in modules and copy them into lib
for root, dirs, files in os.walk("../../modules"):
- for f in files:
- if f.endswith("-backend.py"):
- fname = f.replace("-backend", "")
- os.symlink("../../" + os.path.join(root, f), f"darshan/backend/{fname}")
- print("Adding {0} to backends.".format(os.path.join(root,f)))
+ for f in files:
+ if f.endswith("-backend.py"):
+ fname = f.replace("-backend", "")
+ try:
+ os.symlink("../../" + os.path.join(root, f), f"darshan/backend/{fname}")
+ except:
+ pass
+ print("Adding {0} to backends.".format(os.path.join(root, f)))
setup(
- author='',
- author_email='',
+ author="",
+ author_email="",
classifiers=[
- 'Development Status :: 4 - Beta',
- 'Intended Audience :: Developers',
- 'Intended Audience :: Science/Research',
- 'Natural Language :: English',
- 'Programming Language :: Python :: 3',
- 'Programming Language :: Python :: 3.6',
- 'Programming Language :: Python :: 3.7',
- 'Programming Language :: Python :: 3.8',
- 'Programming Language :: Python :: 3.9'
+ "Development Status :: 4 - Beta",
+ "Intended Audience :: Developers",
+ "Intended Audience :: Science/Research",
+ "Natural Language :: English",
+ "Programming Language :: Python :: 3",
+ "Programming Language :: Python :: 3.6",
+ "Programming Language :: Python :: 3.7",
+ "Programming Language :: Python :: 3.8",
+ "Programming Language :: Python :: 3.9",
description="Python tools to interact with darshan log records of HPC applications.",
long_description=readme,
- ext_modules = ext_modules,
+ ext_modules=ext_modules,
install_requires=requirements,
include_package_data=True,
- keywords='darshan',
- name='darshan',
- packages=find_packages(include=['darshan*']),
+ keywords="darshan",
+ name="darshan",
+ packages=find_packages(include=["darshan*"]),
setup_requires=setup_requirements,
- test_suite='tests',
+ test_suite="tests",
tests_require=test_requirements,
- url='https://www.mcs.anl.gov/research/projects/darshan/',
- version='0.0.6',
+ url="https://www.mcs.anl.gov/research/projects/darshan/",
+ version="0.0.6",
zip_safe=False,
modules/autoperf deleted
@@ -1 +0,0 @@
-Subproject commit ae7f4f13b2e3959946b344c3771d046112a0f910
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/commit/c18e3501d055a2caeb8487047bcdc251ae0c07f0
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210202/962bfef3/attachment-0001.html>
More information about the Darshan-commits
