[Darshan-commits] [Git][darshan/darshan][autoperf-mod-update] Revert "update submodule"
Sudheer Chunduri
xgitlab at cels.anl.gov
Tue Feb 2 08:32:44 CST 2021
Sudheer Chunduri pushed to branch autoperf-mod-update at darshan / darshan
Commits:
bc7cafab by Sudheer Chunduri at 2021-02-02T14:31:58+00:00
This reverts commit b197484e76075cde608e88098ec78f66c386cc1c.
1 changed file:
- + darshan-util/pydarshan.py
Changes:
@@ -0,0 +1,268 @@
+import cffi
+import numpy
+API_def_c = r"""
+/* from darshan-logutils.h */
+struct darshan_mnt_info
+ char mnt_type[3031];
+ char mnt_path[3031];
+struct darshan_mod_info
+ char *name;
+ int len;
+ int ver;
+ int idx;
+/* from darshan-log-format.h */
+struct darshan_job
+ int64_t uid;
+ int64_t start_time;
+ int64_t end_time;
+ int64_t nprocs;
+ int64_t jobid;
+ char metadata[1024];
+struct darshan_base_record
+ uint64_t id;
+ int64_t rank;
+struct darshan_posix_file
+ struct darshan_base_record base_rec;
+ int64_t counters[64];
+ double fcounters[17];
+struct darshan_stdio_file
+ int64_t counters[13];
+ double fcounters[15];
+struct darshan_mpiio_file
+ int64_t counters[51];
+struct darshan_hdf5_file
+ int64_t counters[1];
+ double fcounters[2];
+struct darshan_pnetcdf_file
+ int64_t counters[2];
+struct darshan_bgq_record
+ int64_t counters[11];
+ double fcounters[1];
+/* from darshan-apxc-log-format.h */
+struct darshan_apxc_header_record
+ int64_t magic;
+ int nblades;
+ int nchassis;
+ int ngroups;
+ int memory_mode;
+ int cluster_mode;
+struct darshan_apxc_perf_record
+ int64_t counters[396];
+/* counter names */
+char *apxc_counter_names[];
+char *bgq_counter_names[];
+char *bgq_f_counter_names[];
+char *hdf5_counter_names[];
+char *hdf5_f_counter_names[];
+char *mpiio_counter_names[];
+char *mpiio_f_counter_names[];
+char *pnetcdf_counter_names[];
+char *pnetcdf_f_counter_names[];
+char *posix_counter_names[];
+char *posix_f_counter_names[];
+char *stdio_counter_names[];
+char *stdio_f_counter_names[];
+/* Supported Functions */
+void* darshan_log_open(char *);
+int darshan_log_get_job(void *, struct darshan_job *);
+void darshan_log_close(void*);
+int darshan_log_get_exe(void*, char *);
+int darshan_log_get_mounts(void*, struct darshan_mnt_info **, int*);
+void darshan_log_get_modules(void*, struct darshan_mod_info **, int*);
+int darshan_log_get_record(void*, int, void **);
+ffi = cffi.FFI()
+ffi.cdef(API_def_c)
+libdutil = ffi.dlopen("/home/harms/working/darshan/theta/install/lib/libdarshan-util.so")
+modules = {}
+def log_open(filename):
+ b_fname = filename.encode()
+ log = libdutil.darshan_log_open(b_fname)
+ mods = log_get_modules(log)
+ return log
+def log_close(log):
+ libdutil.darshan_log_close(log)
+ modules = {}
+ return
+def log_get_job(log):
+ job = {}
+ jobrec = ffi.new("struct darshan_job *")
+ libdutil.darshan_log_get_job(log, jobrec)
+ job['jobid'] = jobrec[0].jobid
+ job['uid'] = jobrec[0].uid
+ job['start_time'] = jobrec[0].start_time
+ job['end_time'] = jobrec[0].end_time
+ mstr = ffi.string(jobrec[0].metadata).decode("utf-8")
+ md = {}
+ for kv in mstr.split('\n')[:-1]:
+ k,v = kv.split('=', maxsplit=1)
+ md[k] = v
+ job['metadata'] = md
+ return job
+def log_get_exe(log):
+ exestr = ffi.new("char[]", 4096)
+ libdutil.darshan_log_get_exe(log, exestr)
+ return ffi.string(exestr).decode("utf-8")
+def log_get_mounts(log):
+ mntlst = []
+ mnts = ffi.new("struct darshan_mnt_info **")
+ cnt = ffi.new("int *")
+ libdutil.darshan_log_get_mounts(log, mnts, cnt)
+ for i in range(0, cnt[0]):
+ mntlst.append((ffi.string(mnts[0][i].mnt_path).decode("utf-8"),
+ ffi.string(mnts[0][i].mnt_type).decode("utf-8")))
+ return mntlst
+def log_get_modules(log):
+ mods = ffi.new("struct darshan_mod_info **")
+ libdutil.darshan_log_get_modules(log, mods, cnt)
+ modules[ffi.string(mods[0][i].name).decode("utf-8")] = \
+ {'len': mods[0][i].len, 'ver': mods[0][i].ver, 'idx': mods[0][i].idx}
+ return modules
+def log_get_generic_record(log, mod_name, mod_type):
+ rec = {}
+ buf = ffi.new("void **")
+ r = libdutil.darshan_log_get_record(log, modules[mod_name]['idx'], buf)
+ if r < 1:
+ return None
+ rbuf = ffi.cast(mod_type, buf)
+ clst = []
+ for i in range(0, len(rbuf[0].counters)):
+ clst.append(rbuf[0].counters[i])
+ rec['counters'] = numpy.array(clst, dtype=numpy.uint64)
+ flst = []
+ for i in range(0, len(rbuf[0].fcounters)):
+ flst.append(rbuf[0].fcounters[i])
+ rec['fcounters'] = numpy.array(clst, dtype=numpy.float64)
+ return rec
+def counter_names(mod_name, fcnts=False):
+ names = []
+ i = 0
+ if fcnts:
+ F = "f_"
+ else:
+ F1 = ""
+ F2 = ""
+ end = "{0}_{1}NUM_INDICES".format(mod_name.upper(), F.upper())
+ var_name = "{0}_{1}counter_names".format(mod_name.lower(), F.lower())
+ while True:
+ try:
+ var = getattr(libdutil, var_name)
+ except:
+ var = None
+ if not var:
+ return None
+ name = ffi.string(var[i]).decode("utf-8")
+ if name == end:
+ break
+ names.append(name)
+ i += 1
+ return names
+def fcounter_names(mod_name):
+ return counter_names(mod_name, fcnts=True)
+def log_get_bgq_record(log):
+ return log_get_generic_record(log, "BGQ", "struct darshan_bgq_file **")
+def log_get_hdf5_record(log):
+ return log_get_generic_record(log, "HDF5", "struct darshan_hdf5_file **")
+def log_get_mpiio_record(log):
+ return log_get_generic_record(log, "MPIIO", "struct darshan_mpiio_file **")
+def log_get_pnetcdf_record(log):
+ return log_get_generic_record(log, "PNETCDF", "struct darshan_pnetcdf_file **")
+def log_get_posix_record(log):
+ return log_get_generic_record(log, "POSIX", "struct darshan_posix_file **")
+def log_get_stdio_record(log):
+ return log_get_generic_record(log, "STDIO", "struct darshan_stdio_file **")
+def log_get_apxc_record(log):
+ rec = {}
+ memory_modes = ['unknown', 'flat', 'equal', 'split', 'cache']
+ cluster_modes = ['unknown', 'all2all', 'quad', 'hemi', 'snc4', 'snc2']
+ r = libdutil.darshan_log_get_record(log, modules['APXC']['idx'], buf)
+ if r < 1:
+ return None
+ prf = ffi.cast("struct darshan_apxc_perf_record **", buf)
+ hdr = ffi.cast("struct darshan_apxc_header_record **", buf)
+ if hdr[0].magic == 4707761685111591494:
+ mm = hdr[0].memory_mode & ~(1 << 31)
+ cm = hdr[0].cluster_mode & ~(1 << 31)
+ rec['nblades'] = hdr[0].nblades
+ rec['nchassis'] = hdr[0].nchassis
+ rec['ngroups'] = hdr[0].ngroups
+ rec['memory_mode'] = memory_modes[mm]
+ rec['cluster_mode'] = cluster_modes[cm]
+ else:
+ rec['group'] = prf[0].counters[0]
+ rec['chassis'] = prf[0].counters[1]
+ rec['blade'] = prf[0].counters[2]
+ rec['node'] = prf[0].counters[3]
+ clst = []
+ for i in range(0, len(prf[0].counters)):
+ clst.append(prf[0].counters[i])
+ return rec
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/commit/bc7cafab82b78fc7928e227fbdf4a81f5aed7f41
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210202/8ce81259/attachment-0001.html>
More information about the Darshan-commits
