[Darshan-commits] [Git][darshan/darshan][carns/dev-dyn-link-updates] propagate darshan-gen* script updates to fortran
Philip Carns
xgitlab at cels.anl.gov
Fri Mar 20 13:46:22 CDT 2020
Philip Carns pushed to branch carns/dev-dyn-link-updates at darshan / darshan
Commits:
fe91e0ff by Phil Carns at 2020-03-20T14:46:03-04:00
1 changed file:
- darshan-runtime/darshan-gen-fortran.pl.in
Changes:
@@ -83,6 +83,7 @@ $FC_from_link=$1;
$link_cmd_prefix=$2;
$base_link_cmd_suffix="\"\$\{allargs\[\@\]\}\" $4";
$link_cmd_suffix="\"\$\{newallargs\[\@\]\}\" \$FMPICH `$PREFIX/bin/darshan-config --pre-ld-flags` $4 `$PREFIX/bin/darshan-config --post-ld-flags`";
+$dyn_link_cmd_suffix="\"\$\{newallargs\[\@\]\}\" \$FMPICH `$PREFIX/bin/darshan-config --dyn-ld-flags` $4";
# repeat the above step for the compilation command line
if(!($compile_cmd =~ /(\S+)(.+)(-c foo.c)\s+(.*)/))
@@ -206,13 +207,6 @@ if [ "$linking" = yes ] ; then
fi
EOF
print OUTPUT<<"EOF";
- # Trial run to generate a symbol listing. We only enable Darshan if:
- # a) MPI is used
- # b) PMPI is _not_ used
- # We want Darshan to get out of the way if the user is doing a runtime
- # test in configure (in which case MPI objects break the executable) or
- # if the user is using another PMPI based tool
# if allargs includes any libraries, then we need to get
# -ldarshan in there first
@@ -252,6 +246,14 @@ print OUTPUT<<"EOF";
used_darshan=0
+ # Perform a test link before the real link. This allows us to check
+ # for two things:
+ # 1) Are MPI symbols present? Technically Darshan should not harm
+ # non-MPI programs, but it may bring in unwanted dependencies or
+ # interfere with autoconf checks.
+ # 2) Is this link command line going to produce a static or dynamic
+ # linked executable? We will adjust Darshan link strategy accordingly.
# create a temporary file
tmpfile=`mktemp`
binfile=`mktemp`
@@ -271,10 +273,9 @@ print OUTPUT<<"EOF";
grep -i MPI \$tmpfile >& /dev/null
rc_mpi=\$?
- # is PMPI being used for PMPI_File_open?
- grep -E PMPI_File_open \$tmpfile | grep -v -E \\(mpich.*\\.a\\) |grep \\(PMPI >& /dev/null
- rc_pmpi=\$?
+ # did the link options produce a dynamic executable?
+ ldd \$binfile >& /dev/null
+ rc_dyn=\$?
# find appropriate fortran library name for profiling
grep -E libmpifort \$tmpfile >& /dev/null
@@ -298,27 +299,17 @@ print OUTPUT<<"EOF";
fi
rm \$tmpfile >& /dev/null
- # is MPI_Init a weak symbol?
- # disable darshan if it is not
- if [ -e \$binfile ];
- then
- nm \$binfile | grep -i "mpi_init" | grep -i "w" >& /dev/null
- rc_weak=\$?
- else
- rc_weak=1
- fi
rm \$binfile >& /dev/null
- # disable darshan if the executable is not an MPI program (this feature
- # mainly allows runtime configure tests to work
- if [ \$rc_mpi -eq 0 ] ; then
- # disable darshan if something else is already using PMPI; we don't
- # want to cause any symbol conflicts
- if [ \$rc_pmpi -ne 0 ] && [ \$compiler_check -eq 0 ] && [ \$rc_weak -eq 0 ]; then
+ # disable darshan if the executable is not an MPI program or we've
+ # detected an incompatible compiler
+ if [ \$rc_mpi -eq 0 ] && [ \$compiler_check -eq 0 ]; then
+ if [ \$rc_dyn -eq 0 ]; then
+ \$Show \$FC $link_cmd_prefix $dyn_link_cmd_suffix
+ else
\$Show \$FC $link_cmd_prefix $link_cmd_suffix
- used_darshan=1
fi
+ used_darshan=1
fi
# otherwise use the normal command line
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/fe91e0ff19a7721e64cc8546bc7fa77bab8e7bc7
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200320/1a225b9c/attachment-0001.html>
More information about the Darshan-commits
