[Darshan-commits] [Git][darshan/darshan][dev-new-regression-tests] updated regression readme for new test cases
Shane Snyder
xgitlab at cels.anl.gov
Thu Apr 23 15:51:02 CDT 2020
Shane Snyder pushed to branch dev-new-regression-tests at darshan / darshan
Commits:
f5e12462 by Shane Snyder at 2020-04-23T15:50:49-05:00
1 changed file:
- darshan-test/regression/README.txt
Changes:
@@ -8,14 +8,18 @@ The master script must be executed with three arguments:
2) path to temporary directory (for building executables, collecting logs,
etc. during test)
3) platform type; options include:
- - workstation-static (for static instrumentation on a standard workstation)
- - workstation-dynamic (for dynamic instrumentation on a standard workstation)
- - workstation-profile-conf (for static instrumentation using MPI profiling
- configuration hooks on a standard workstation)
- - bg-profile-conf-alcf (for static instrumentation using MPI profiling configuration
- hooks on BGQ platforms @ the ALCF only)
- - cray-module-alcf (for static instrumentation using a Darshan Cray module on
- Cray systems @ the ALCF only)
+ - workstation-cc-wrapper (for static/dynamic instrumentation on a standard
+ workstation using Darshan compiler wrappers)
+ - workstation-profile-conf-static (for static instrumentation using MPI
+ profiling configuration hooks on a standard workstation)
+ - workstation-profile-conf-dynamic (for dynamic instrumentation using MPI
+ - workstation-ld-preload (for dynamic instrumentation via LD_PRELOAD on a
+ standard workstation)
+ - cray-module-alcf (for static/dynamic instrumentation using a Darshan
+ Cray module on Cray systems @ the ALCF only)
+ - cray-module-nersc (for static/dynamic instrumentation using a Darshan
+ Cray module on Cray systems @ NERSC only)
The platform type should map to a subdirectory containing scripts
that describe how to perform platform-specific tasks (like loading or
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/f5e12462f55a1c227ad7bc1bdc7c6ad3300f1419
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200423/c346a7d9/attachment-0001.html>
More information about the Darshan-commits
