[Darshan-commits] [Git][darshan/darshan][dev-new-regression-tests] rename dynamic test case to ld-preload
Shane Snyder
xgitlab at cels.anl.gov
Thu Apr 23 15:33:10 CDT 2020
Shane Snyder pushed to branch dev-new-regression-tests at darshan / darshan
Commits:
0093eb95 by Shane Snyder at 2020-04-23T15:32:51-05:00
1 changed file:
- darshan-test/regression/workstation-dynamic/env.sh → darshan-test/regression/workstation-ld-preload/env.sh
Changes:
@@ -16,11 +16,11 @@
# variables (as in a dynamically linked environment), or generate mpicc
# wrappers (as in a statically linked environment).
-# Notes specific to this platform (workstation-dynamic)_
+# Notes specific to this platform (workstation-ld-preload)
# This particular env script assumes that mpicc and its variants for other
# languages are already in the path, and that they will produce dynamic
-# executables by default. Test programs are compile usign the existing
+# executables by default. Test programs are compiled using the existing
# scripts, and LD_PRELOAD is set to enable instrumentation.
# The runjob command is just mpiexec, no scheduler
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/0093eb95117729c9111a59fd472be0146908b77f
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200423/c9b07ca6/attachment.html>
More information about the Darshan-commits
