[Darshan-commits] [Git][darshan/darshan][dev-no-mpi] apply no-mpi changes to posix module
Shane Snyder
xgitlab at cels.anl.gov
Tue Jul 30 11:15:34 CDT 2019
Shane Snyder pushed to branch dev-no-mpi at darshan / darshan
Commits:
f67c6ce7 by Shane Snyder at 2019-07-30T16:15:19Z
3 changed files:
- darshan-runtime/darshan.h
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-posix.c
Changes:
@@ -88,6 +88,7 @@
* avoid any reduction steps.
typedef void (*darshan_module_redux)(
+ void *mod_buf, /* input parameter indicating module's buffer address */
MPI_Comm mod_comm, /* MPI communicator to run collectives with */
darshan_record_id *shared_recs, /* list of shared data record ids */
int shared_rec_count /* count of shared data records */
@@ -563,8 +563,9 @@ void darshan_core_shutdown()
/* allow the module an opportunity to reduce shared files */
- if(this_mod->mod_funcs.mod_redux_func)
- this_mod->mod_funcs.mod_redux_func(MPI_COMM_WORLD, mod_shared_recs,
+ if(this_mod->mod_funcs.mod_redux_func && (mod_shared_recs > 0) &&
+ (!getenv("DARSHAN_DISABLE_SHARED_REDUCTION")))
+ this_mod->mod_funcs.mod_redux_func(mod_buf, MPI_COMM_WORLD, mod_shared_recs,
mod_shared_rec_cnt);
#endif
@@ -153,17 +153,23 @@ static struct posix_aio_tracker* posix_aio_tracker_del(
int fd, void *aiocbp);
static void posix_finalize_file_records(
void *rec_ref_p);
+#ifdef HAVE_MPI
static void posix_record_reduction_op(
void* infile_v, void* inoutfile_v, int *len, MPI_Datatype *datatype);
static void posix_shared_record_variance(
MPI_Comm mod_comm, struct darshan_posix_file *inrec_array,
struct darshan_posix_file *outrec_array, int shared_rec_count);
+#endif
static void posix_cleanup_runtime(
void);
+#ifdef HAVE_MPI
+static void posix_mpi_redux(
+ void *posix_buf, MPI_Comm mod_comm,
+ darshan_record_id *shared_recs, int shared_rec_count);
+#endif
static void posix_shutdown(
- MPI_Comm mod_comm, darshan_record_id *shared_recs,
- int shared_rec_count, void **posix_buf, int *posix_buf_sz);
+ void **posix_buf, int *posix_buf_sz);
/* extern DXT function defs */
extern void dxt_posix_write(darshan_record_id rec_id, int64_t offset,
@@ -1479,6 +1485,12 @@ int DARSHAN_DECL(rename)(const char *oldpath, const char *newpath)
static void posix_runtime_initialize()
int psx_buf_size;
+ darshan_module_funcs mod_funcs = {
+#ifdef HAVE_MPI
+ .mod_redux_func = &posix_mpi_redux,
+#endif
+ .mod_shutdown_func = &posix_shutdown
/* try and store a default number of records for this module */
psx_buf_size = DARSHAN_DEF_MOD_REC_COUNT * sizeof(struct darshan_posix_file);
@@ -1486,7 +1498,7 @@ static void posix_runtime_initialize()
/* register the POSIX module with darshan core */
darshan_core_register_module(
DARSHAN_POSIX_MOD,
- &posix_shutdown,
+ mod_funcs,
&psx_buf_size,
&my_rank,
&darshan_mem_alignment);
@@ -1628,6 +1640,7 @@ static void posix_finalize_file_records(void *rec_ref_p)
return;
+#ifdef HAVE_MPI
static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
@@ -1941,6 +1954,7 @@ static void posix_shared_record_variance(MPI_Comm mod_comm,
return;
+#endif
static void posix_cleanup_runtime()
@@ -2043,20 +2057,18 @@ void darshan_posix_shutdown_bench_setup(int test_case)
return;
- * shutdown function exported by this module for coordinating with darshan-core *
+ * shutdown functions exported by this module for coordinating with darshan-core *
-static void posix_shutdown(
- darshan_record_id *shared_recs,
- void **posix_buf,
- int *posix_buf_sz)
+#ifdef HAVE_MPI
+ int posix_rec_count;
struct posix_file_record_ref *rec_ref;
struct darshan_posix_file *posix_rec_buf = *(struct darshan_posix_file **)posix_buf;
- int posix_rec_count;
double posix_time;
struct darshan_posix_file *red_send_buf = NULL;
struct darshan_posix_file *red_recv_buf = NULL;
@@ -2069,113 +2081,122 @@ static void posix_shutdown(
posix_rec_count = posix_runtime->file_rec_count;
- /* perform any final transformations on POSIX file records before
- * writing them out to log file
- darshan_iter_record_refs(posix_runtime->rec_id_hash, &posix_finalize_file_records);
+ /* necessary initialization of shared records */
+ for(i = 0; i < shared_rec_count; i++)
+ rec_ref = darshan_lookup_record_ref(posix_runtime->rec_id_hash,
+ &shared_recs[i], sizeof(darshan_record_id));
+ assert(rec_ref);
+ posix_time =
+ rec_ref->file_rec->fcounters[POSIX_F_READ_TIME] +
+ rec_ref->file_rec->fcounters[POSIX_F_WRITE_TIME] +
+ rec_ref->file_rec->fcounters[POSIX_F_META_TIME];
+ /* initialize fastest/slowest info prior to the reduction */
+ rec_ref->file_rec->counters[POSIX_FASTEST_RANK] =
+ rec_ref->file_rec->base_rec.rank;
+ rec_ref->file_rec->counters[POSIX_FASTEST_RANK_BYTES] =
+ rec_ref->file_rec->counters[POSIX_BYTES_READ] +
+ rec_ref->file_rec->counters[POSIX_BYTES_WRITTEN];
+ rec_ref->file_rec->fcounters[POSIX_F_FASTEST_RANK_TIME] =
+ posix_time;
+ /* until reduction occurs, we assume that this rank is both
+ * the fastest and slowest. It is up to the reduction operator
+ * to find the true min and max.
+ rec_ref->file_rec->counters[POSIX_SLOWEST_RANK] =
+ rec_ref->file_rec->counters[POSIX_FASTEST_RANK];
+ rec_ref->file_rec->counters[POSIX_SLOWEST_RANK_BYTES] =
+ rec_ref->file_rec->counters[POSIX_FASTEST_RANK_BYTES];
+ rec_ref->file_rec->fcounters[POSIX_F_SLOWEST_RANK_TIME] =
+ rec_ref->file_rec->fcounters[POSIX_F_FASTEST_RANK_TIME];
+ rec_ref->file_rec->base_rec.rank = -1;
- /* if there are globally shared files, do a shared file reduction */
- /* NOTE: the shared file reduction is also skipped if the
- * DARSHAN_DISABLE_SHARED_REDUCTION environment variable is set.
+ /* sort the array of records so we get all of the shared records
+ * (marked by rank -1) in a contiguous portion at end of the array
- if(shared_rec_count && !getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
+ darshan_record_sort(posix_rec_buf, posix_rec_count,
+ sizeof(struct darshan_posix_file));
+ /* make send_buf point to the shared files at the end of sorted array */
+ red_send_buf = &(posix_rec_buf[posix_rec_count-shared_rec_count]);
+ /* allocate memory for the reduction output on rank 0 */
+ if(my_rank == 0)
- /* necessary initialization of shared records */
- for(i = 0; i < shared_rec_count; i++)
+ red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_posix_file));
+ if(!red_recv_buf)
- rec_ref = darshan_lookup_record_ref(posix_runtime->rec_id_hash,
- &shared_recs[i], sizeof(darshan_record_id));
- assert(rec_ref);
- posix_time =
- rec_ref->file_rec->fcounters[POSIX_F_READ_TIME] +
- rec_ref->file_rec->fcounters[POSIX_F_WRITE_TIME] +
- rec_ref->file_rec->fcounters[POSIX_F_META_TIME];
- /* initialize fastest/slowest info prior to the reduction */
- rec_ref->file_rec->counters[POSIX_FASTEST_RANK] =
- rec_ref->file_rec->base_rec.rank;
- rec_ref->file_rec->counters[POSIX_FASTEST_RANK_BYTES] =
- rec_ref->file_rec->counters[POSIX_BYTES_READ] +
- rec_ref->file_rec->counters[POSIX_BYTES_WRITTEN];
- rec_ref->file_rec->fcounters[POSIX_F_FASTEST_RANK_TIME] =
- posix_time;
- /* until reduction occurs, we assume that this rank is both
- * the fastest and slowest. It is up to the reduction operator
- * to find the true min and max.
- rec_ref->file_rec->counters[POSIX_SLOWEST_RANK] =
- rec_ref->file_rec->counters[POSIX_FASTEST_RANK];
- rec_ref->file_rec->counters[POSIX_SLOWEST_RANK_BYTES] =
- rec_ref->file_rec->counters[POSIX_FASTEST_RANK_BYTES];
- rec_ref->file_rec->fcounters[POSIX_F_SLOWEST_RANK_TIME] =
- rec_ref->file_rec->fcounters[POSIX_F_FASTEST_RANK_TIME];
- rec_ref->file_rec->base_rec.rank = -1;
+ POSIX_UNLOCK();
+ return;
- /* sort the array of records so we get all of the shared records
- * (marked by rank -1) in a contiguous portion at end of the array
- darshan_record_sort(posix_rec_buf, posix_rec_count,
- sizeof(struct darshan_posix_file));
+ /* construct a datatype for a POSIX file record. This is serving no purpose
+ * except to make sure we can do a reduction on proper boundaries
+ PMPI_Type_contiguous(sizeof(struct darshan_posix_file),
+ MPI_BYTE, &red_type);
+ PMPI_Type_commit(&red_type);
- /* make send_buf point to the shared files at the end of sorted array */
- red_send_buf = &(posix_rec_buf[posix_rec_count-shared_rec_count]);
+ /* register a POSIX file record reduction operator */
+ PMPI_Op_create(posix_record_reduction_op, 1, &red_op);
- /* allocate memory for the reduction output on rank 0 */
- if(my_rank == 0)
- red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_posix_file));
- if(!red_recv_buf)
- POSIX_UNLOCK();
- return;
+ /* reduce shared POSIX file records */
+ PMPI_Reduce(red_send_buf, red_recv_buf,
+ shared_rec_count, red_type, red_op, 0, mod_comm);
- /* construct a datatype for a POSIX file record. This is serving no purpose
- * except to make sure we can do a reduction on proper boundaries
- PMPI_Type_contiguous(sizeof(struct darshan_posix_file),
- MPI_BYTE, &red_type);
- PMPI_Type_commit(&red_type);
+ /* get the time and byte variances for shared files */
+ posix_shared_record_variance(mod_comm, red_send_buf, red_recv_buf,
+ shared_rec_count);
- /* register a POSIX file record reduction operator */
- PMPI_Op_create(posix_record_reduction_op, 1, &red_op);
+ /* clean up reduction state */
+ if(my_rank == 0)
+ int tmp_ndx = posix_rec_count - shared_rec_count;
+ memcpy(&(posix_rec_buf[tmp_ndx]), red_recv_buf,
+ shared_rec_count * sizeof(struct darshan_posix_file));
+ free(red_recv_buf);
+ else
+ posix_rec_count -= shared_rec_count;
- /* reduce shared POSIX file records */
- PMPI_Reduce(red_send_buf, red_recv_buf,
- shared_rec_count, red_type, red_op, 0, mod_comm);
+ PMPI_Type_free(&red_type);
+ PMPI_Op_free(&red_op);
- /* get the time and byte variances for shared files */
- posix_shared_record_variance(mod_comm, red_send_buf, red_recv_buf,
- shared_rec_count);
+ POSIX_UNLOCK();
+ return;
+#endif
- /* clean up reduction state */
- if(my_rank == 0)
- int tmp_ndx = posix_rec_count - shared_rec_count;
- memcpy(&(posix_rec_buf[tmp_ndx]), red_recv_buf,
- shared_rec_count * sizeof(struct darshan_posix_file));
- free(red_recv_buf);
- else
- posix_rec_count -= shared_rec_count;
+static void posix_shutdown(
+ void **posix_buf,
+ int *posix_buf_sz)
- PMPI_Type_free(&red_type);
- PMPI_Op_free(&red_op);
+ POSIX_LOCK();
+ assert(posix_runtime);
- /* update output buffer size to account for shared file reduction */
- *posix_buf_sz = posix_rec_count * sizeof(struct darshan_posix_file);
+ posix_rec_count = posix_runtime->file_rec_count;
+ /* perform any final transformations on POSIX file records before
+ * writing them out to log file
+ darshan_iter_record_refs(posix_runtime->rec_id_hash, &posix_finalize_file_records);
/* shutdown internal structures used for instrumenting */
posix_cleanup_runtime();
+ /* update output buffer size to account for shared file reduction */
+ *posix_buf_sz = posix_rec_count * sizeof(struct darshan_posix_file);
POSIX_UNLOCK();
return;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/f67c6ce7945c9e4caed438eed7f69e9a24fd6feb
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20190730/e71da9da/attachment-0001.html>
More information about the Darshan-commits
