[Darshan-commits] [Git][darshan/darshan][dev-no-mpi] 2 commits: updated generated configure script
Philip Carns
xgitlab at cels.anl.gov
Tue Jul 30 11:12:10 CDT 2019
Philip Carns pushed to branch dev-no-mpi at darshan / darshan
Commits:
ea5ed00a by Phil Carns at 2019-07-30T16:05:34Z
c866a0af by Phil Carns at 2019-07-30T16:05:53Z
add darshan_core_wtime_absolute() helper
- works for both mpi and non-mpi builds
- unlike darshan_core_time(), it does not compute relative timestamp and
thus doesn't require darshan core to be initialized
3 changed files:
- darshan-runtime/configure
- darshan-runtime/darshan-runtime-config.h.in
- darshan-runtime/lib/darshan-core.c
Changes:
@@ -623,6 +623,15 @@ ac_subst_vars='LTLIBOBJS
LIBOBJS
DARSHAN_MDHIM_LD_OPTS
BUILD_MDHIM_MODULE
+BUILD_DXT_MODULE
+DARSHAN_STDIO_LD_OPTS
+BUILD_STDIO_MODULE
+DARSHAN_PNETCDF_LD_OPTS
+BUILD_PNETCDF_MODULE
+DARSHAN_MPIIO_LD_OPTS
+BUILD_MPIIO_MODULE
+DARSHAN_POSIX_LD_OPTS
+BUILD_POSIX_MODULE
DARSHAN_HDF5_LD_OPTS
BUILD_HDF5_MODULE
DARSHAN_USE_LUSTRE
@@ -690,10 +699,16 @@ SHELL'
ac_subst_files=''
ac_user_opts='
enable_option_checking
+with_mpi
with_zlib
enable_ld_preload
enable_cuserid
enable_group_readable_logs
+enable_posix_mod
+enable_mpiio_mod
+enable_stdio_mod
+enable_pnetcdf_mod
+enable_dxt_mod
enable_bgq_mod
enable_lustre_mod
enable_mmap_logs
@@ -1340,6 +1355,13 @@ Optional Features:
--disable-cuserid Disables attempted use of cuserid() at run time
--enable-group-readable-logs
Set log files to be group readable
+ --disable-posix-mod Disables compilation and use of POSIX module
+ --disable-mpiio-mod Disables compilation and use of MPI-IO module
+ (requires MPI)
+ --disable-stdio-mod Disables compilation and use of STDIO module
+ --disable-pnetcdf-mod Disables compilation and use of PnetCDF module
+ (requires MPI)
+ --disable-dxt-mod Disables compilation and use of DXT module
--disable-bgq-mod Disables compilation and use of BG/Q module (for BG/Q systems)
--disable-lustre-mod Disables compilation and use of the Lustre module
--enable-mmap-logs Enables ability to mmap I/O data to log file
@@ -1352,6 +1374,7 @@ Optional Features:
Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
--without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
+ --without-mpi Build without support for MPI
--with-zlib=DIR root directory path of zlib installation defaults to
/usr/local or /usr if not found in /usr/local
--without-zlib to disable zlib usage completely
@@ -2173,6 +2196,7 @@ ac_config_sub="$SHELL $ac_aux_dir/config.sub" # Please don't use this var.
ac_configure="$SHELL $ac_aux_dir/configure" # Please don't use this var.
ac_config_headers="$ac_config_headers darshan-runtime-config.h"
@@ -2270,8 +2294,22 @@ test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the mpicc compiler works" >&5
-$as_echo_n "checking whether the mpicc compiler works... " >&6; }
+ENABLE_MPI=1
+# Check whether --with-mpi was given.
+if test "${with_mpi+set}" = set; then :
+ withval=$with_mpi;
+fi
+if test "x$with_mpi" = "xno"; then :
+ ENABLE_MPI=
+else
+$as_echo "#define HAVE_MPI /**/" >>confdefs.h
+fi
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
@@ -3062,7 +3100,10 @@ ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $
ac_compiler_gnu=$ac_cv_c_compiler_gnu
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+if test "x$ENABLE_MPI" = "x1"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the mpicc compiler works" >&5
+$as_echo_n "checking whether the mpicc compiler works... " >&6; }
+ cat confdefs.h - <<_ACEOF >conftest.$ac_ext
/* end confdefs.h. */
#include <mpi.h>
int
@@ -3079,10 +3120,13 @@ $as_echo "yes" >&6; }
else
{ $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
$as_echo "no" >&6; }
- as_fn_error $? "CC doesn't appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line." "$LINENO" 5
+ as_fn_error $? "CC doesn't appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line." "$LINENO" 5
fi
rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: not checking whether the mpicc compiler works" >&5
+$as_echo "$as_me: not checking whether the mpicc compiler works" >&6;}
+fi
ac_ext=c
@@ -3593,6 +3637,72 @@ fi
fi
+# Check for specific module enable/disable options
+# POSIX module
+BUILD_POSIX_MODULE=1
+DARSHAN_POSIX_LD_OPTS="@${darshan_share_path}/ld-opts/darshan-posix-ld-opts"
+# Check whether --enable-posix-mod was given.
+if test "${enable_posix_mod+set}" = set; then :
+ enableval=$enable_posix_mod;
+fi
+if test "x$enable_posix_mod" = "xno"; then :
+ BUILD_POSIX_MODULE=
+ DARSHAN_POSIX_LD_OPTS=
+fi
+# MPI-IO module
+BUILD_MPIIO_MODULE=1
+DARSHAN_MPIIO_LD_OPTS="@${darshan_share_path}/ld-opts/darshan-mpiio-ld-opts"
+# Check whether --enable-mpiio-mod was given.
+if test "${enable_mpiio_mod+set}" = set; then :
+ enableval=$enable_mpiio_mod;
+fi
+if test "x$enable_mpiio_mod" = "xno" || test "x$ENABLE_MPI" = "x"; then :
+ BUILD_MPIIO_MODULE=
+ DARSHAN_MPIIO_LD_OPTS=
+fi
+# STDIO module
+BUILD_STDIO_MODULE=1
+DARSHAN_STDIO_LD_OPTS="@${darshan_share_path}/ld-opts/darshan-stdio-ld-opts"
+# Check whether --enable-stdio-mod was given.
+if test "${enable_stdio_mod+set}" = set; then :
+ enableval=$enable_stdio_mod;
+fi
+if test "x$enable_stdio_mod" = "xno"; then :
+ BUILD_STDIO_MODULE=
+ DARSHAN_STDIO_LD_OPTS=
+fi
+# PNETCDF module
+BUILD_PNETCDF_MODULE=1
+DARSHAN_PNETCDF_LD_OPTS="@${darshan_share_path}/ld-opts/darshan-pnetcdf-ld-opts"
+# Check whether --enable-pnetcdf-mod was given.
+if test "${enable_pnetcdf_mod+set}" = set; then :
+ enableval=$enable_pnetcdf_mod;
+fi
+if test "x$enable_pnetcdf_mod" = "xno"; then :
+ BUILD_PNETCDF_MODULE=
+ DARSHAN_PNETCDF_LD_OPTS=
+fi
+# DXT module
+BUILD_DXT_MODULE=1
+# Check whether --enable-dxt-mod was given.
+if test "${enable_dxt_mod+set}" = set; then :
+ enableval=$enable_dxt_mod;
+fi
+if test "x$enable_dxt_mod" = "xno"; then :
+ BUILD_DXT_MODULE=
+fi
# Check whether --enable-bgq-mod was given.
if test "${enable_bgq_mod+set}" = set; then :
enableval=$enable_bgq_mod;
@@ -4266,6 +4376,12 @@ done
fi
+# Begin tests for MPI-enabled builds
# determine if the MPI library includes MPI-IO functions or not
{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO support in MPI" >&5
@@ -4282,8 +4398,7 @@ main ()
int amode;
MPI_Info info;
MPI_File fh;
- MPI_File_open(comm, filename, amode, info, &fh);
+ MPI_File_open(comm, filename, amode, info, &fh);
return 0;
@@ -4293,7 +4408,6 @@ if ac_fn_c_try_link "$LINENO"; then :
else
as_fn_error $? "Darshan requires a version of MPI with MPI-IO support" "$LINENO" 5
fi
rm -f core conftest.err conftest.$ac_objext \
conftest$ac_exeext conftest.$ac_ext
@@ -4432,6 +4546,12 @@ else
MPICH_LIB_OLD=0
fi
+fi
+# End of MPI-only checks
DARSHAN_VERSION="3.1.7"
@@ -4444,6 +4564,15 @@ DARSHAN_VERSION="3.1.7"
@@ -5744,3 +5873,75 @@ if test -n "$ac_unrecognized_opts" && test "$enable_option_checking" != no; then
$as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2;}
fi
+{ $as_echo "$as_me:${as_lineno-$LINENO}: Building Darshan with the following features:" >&5
+$as_echo "$as_me: Building Darshan with the following features:" >&6;}
+if test "x$BUILD_POSIX_MODULE" = "x"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: POSIX module support: no" >&5
+$as_echo "$as_me: POSIX module support: no" >&6;}
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: POSIX module support: yes" >&5
+$as_echo "$as_me: POSIX module support: yes" >&6;}
+fi
+if test "x$BUILD_MPIIO_MODULE" = "x"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: MPIIO module support: no" >&5
+$as_echo "$as_me: MPIIO module support: no" >&6;}
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: MPIIO module support: yes" >&5
+$as_echo "$as_me: MPIIO module support: yes" >&6;}
+fi
+if test "x$BUILD_STDIO_MODULE" = "x"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: STDIO module support: no" >&5
+$as_echo "$as_me: STDIO module support: no" >&6;}
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: STDIO module support: yes" >&5
+$as_echo "$as_me: STDIO module support: yes" >&6;}
+fi
+if test "x$BUILD_PNETCDF_MODULE" = "x"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: PnetCDF module support: no" >&5
+$as_echo "$as_me: PnetCDF module support: no" >&6;}
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: PnetCDF module support: yes" >&5
+$as_echo "$as_me: PnetCDF module support: yes" >&6;}
+fi
+if test "x$BUILD_HDF5_MODULE" = "x"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: HDF5 module support: no" >&5
+$as_echo "$as_me: HDF5 module support: no" >&6;}
+elif if test "x$BUILD_HDF5_PRE110" = "x1"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: HDF5 module support: 1.10+" >&5
+$as_echo "$as_me: HDF5 module support: 1.10+" >&6;}
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: HDF5 module support: pre-1.10" >&5
+$as_echo "$as_me: HDF5 module support: pre-1.10" >&6;}
+fi; then :
+fi
+if test "x$BUILD_DXT_MODULE" = "x"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: DXT module support: no" >&5
+$as_echo "$as_me: DXT module support: no" >&6;}
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: DXT module support: yes" >&5
+$as_echo "$as_me: DXT module support: yes" >&6;}
+fi
+if test "x$DARSHAN_USE_MDHIM" = "x"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: MDHIM module support: no" >&5
+$as_echo "$as_me: MDHIM module support: no" >&6;}
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: MDHIM module support: yes" >&5
+$as_echo "$as_me: MDHIM module support: yes" >&6;}
+fi
+if test "x$DARSHAN_USE_LUSTRE" = "x"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: Lustre module support: no" >&5
+$as_echo "$as_me: Lustre module support: no" >&6;}
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: Lustre module support: yes" >&5
+$as_echo "$as_me: Lustre module support: yes" >&6;}
+fi
+if test "x$DARSHAN_USE_BGQ" = "x"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: BG/Q module support: no" >&5
+$as_echo "$as_me: BG/Q module support: no" >&6;}
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: BG/Q module support: yes" >&5
+$as_echo "$as_me: BG/Q module support: yes" >&6;}
+fi
@@ -21,6 +21,9 @@
/* Define to 1 if you have the <mntent.h> header file. */
#undef HAVE_MNTENT_H
+/* Define if build is MPI-enabled */
+#undef HAVE_MPI
/* Define if MPI-IO prototypes use const qualifier */
#undef HAVE_MPIIO_CONST
@@ -149,6 +149,7 @@ static int darshan_deflate_buffer(
int *comp_buf_length);
static void darshan_core_cleanup(
struct darshan_core_runtime* core);
+static double darshan_core_wtime_absolute(void);
#define DARSHAN_CORE_LOCK() pthread_mutex_lock(&darshan_core_mutex)
#define DARSHAN_CORE_UNLOCK() pthread_mutex_unlock(&darshan_core_mutex)
@@ -284,7 +285,10 @@ void darshan_core_initialize(int argc, char **argv)
if(init_core)
memset(init_core, 0, sizeof(*init_core));
- init_core->wtime_offset = PMPI_Wtime();
+ /* record absolute start time at startup so that we can later
+ * generate relative times with this as a reference point.
+ init_core->wtime_offset = darshan_core_wtime_absolute();
/* TODO: do we alloc new memory as we go or just do everything up front? */
@@ -718,7 +722,7 @@ static void *darshan_init_mmap_log(struct darshan_core_runtime* core, int jobid)
if(my_rank == 0)
- hlevel=PMPI_Wtime() * 1000000;
+ hlevel = darshan_core_wtime_absolute() * 1000000;
(void)gethostname(hname, sizeof(hname));
logmod = darshan_hash((void*)hname,strlen(hname),hlevel);
@@ -1834,7 +1838,7 @@ void darshan_log_finalize(char *logfile_name, double start_log_time)
if(new_logfile_name)
new_logfile_name[0] = '\0';
- end_log_time = PMPI_Wtime();
+ end_log_time = darshan_core_wtime_absolute();
strcat(new_logfile_name, logfile_name);
tmp_index = strstr(new_logfile_name, ".darshan_partial");
sprintf(tmp_index, "_%d.darshan", (int)(end_log_time-start_log_time+1));
@@ -2242,26 +2246,37 @@ void darshan_instrument_fs_data(int fs_type, const char *path, int fd)
return;
+/* retrieve the wtime relative to execution start time */
double darshan_core_wtime()
+ double wtime_offset;
DARSHAN_CORE_LOCK();
if(!darshan_core)
DARSHAN_CORE_UNLOCK();
return(0);
+ else
+ wtime_offset = darshan_core->wtime_offset;
+ return(darshan_core_wtime_absolute() - wtime_offset);
+/* retrieve absolute wtime */
#ifdef HAVE_MPI
if(using_mpi)
- return(PMPI_Wtime() - darshan_core->wtime_offset);
-#endif
+ return(PMPI_Wtime());
+#else
struct timeval tval;
- double secs;
gettimeofday(&tval, NULL);
- secs = tval.tv_sec + (tval.tv_usec / 1000000.0);
- return(secs - darshan_core->wtime_offset);
+ return(tval.tv_sec + (tval.tv_usec / 1000000.0));
+#endif
#ifdef DARSHAN_PRELOAD
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/54bd3e2d470459f616869b062d9853da18f75be8...c866a0af581236c0991845d5f236bf618b0e79e9
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20190730/c8ce166d/attachment-0001.html>
More information about the Darshan-commits
