[Darshan-commits] [Git][darshan/darshan][master] 3 commits: updated changelog for 3.1.7
Shane Snyder
xgitlab at cels.anl.gov
Fri Jan 18 14:48:49 CST 2019
Shane Snyder pushed to branch master at darshan / darshan
Commits:
60dc97f3 by Shane Snyder at 2019-01-18T19:22:57Z
29c044e6 by Shane Snyder at 2019-01-18T20:38:31Z
updated docs for new POSIX/STDIO operations
e023abff by Shane Snyder at 2019-01-18T20:45:53Z
more doc updates
4 changed files:
- ChangeLog
- darshan-posix-log-format.h
- darshan-stdio-log-format.h
- darshan-util/doc/darshan-util.txt
Changes:
ChangeLog
@@ -11,6 +11,9 @@ Darshan-3.1.7
darshan-job-summary.pl when both posix and stdio access is present
* added wrapper for __open_2(), bug reported by Cormac Garvey in which open
calls are not intercepted with some versions of glibc/gcc
+* added an instrumentation module for the MDHIM key/val storage system
+* added support for properly instrumenting dup(), fileno(), fdopen(), and
+ rename() calls
Darshan-3.1.6
@@ -10,7 +10,7 @@
#define DARSHAN_POSIX_VER 4
#define POSIX_COUNTERS \
- /* count of posix opens */\
+ /* count of posix opens (INCLUDING fileno and dup operations) */\
X(POSIX_OPENS) \
/* count of number of filenos */\
X(POSIX_FILENOS) \
@@ -11,7 +11,7 @@
#define DARSHAN_STDIO_VER 2
#define STDIO_COUNTERS \
- /* count of fopens */\
+ /* count of fopens (INCLUDING fdopen operations) */\
X(STDIO_OPENS) \
/* count of fdopens */\
X(STDIO_FDOPENS) \
@@ -234,7 +234,9 @@ otherwise noted, counters include all variants of the call in question, such as
[cols="40%,60%",options="header"]
| counter name | description
-| POSIX_OPENS | Count of how many times the file was opened
+| POSIX_OPENS | Count of how many times the file was opened (INCLUDING `fileno` and `dup` operations)
+| POSIX_FILENOS| Count of POSIX fileno operations
+| POSIX_DUPS| Count of POSIX dup operations
| POSIX_READS | Count of POSIX read operations
| POSIX_WRITES | Count of POSIX write operations
| POSIX_SEEKS | Count of POSIX seek operations
@@ -242,6 +244,9 @@ otherwise noted, counters include all variants of the call in question, such as
| POSIX_MMAPS | Count of POSIX mmap operations
| POSIX_FSYNCS | Count of POSIX fsync operations
| POSIX_FDSYNCS | Count of POSIX fdatasync operations
+| POSIX_RENAME_SOURCES| Number of times this file was the source of a rename operation
+| POSIX_RENAME_TARGETS| Number of times this file was the target of a rename operation
+| POSIX_RENAMED_FROM | If this file was a rename target, the Darshan record ID of the first rename source
| POSIX_MODE | Mode that the file was last opened in
| POSIX_BYTES_READ | Total number of bytes that were read from the file
| POSIX_BYTES_WRITTEN | Total number of bytes written to the file
@@ -314,12 +319,8 @@ value of 1 MiB for optimal file alignment.
| MPIIO_FASTEST_RANK_BYTES | The number of bytes transferred by the rank with smallest time spent in MPI I/O
| MPIIO_SLOWEST_RANK | The MPI rank with largest time spent in MPI I/O
| MPIIO_SLOWEST_RANK_BYTES | The number of bytes transferred by the rank with the largest time spent in MPI I/O
-| MPIIO_F_OPEN_TIMESTAMP | Timestamp of first time that the file was opened at MPI level
-| MPIIO_F_READ_START_TIMESTAMP | Timestamp that the first MPI read operation began
-| MPIIO_F_WRITE_START_TIMESTAMP | Timestamp that the first MPI write operation begin
-| MPIIO_F_READ_END_TIMESTAMP | Timestamp that the last MPI read operation ended
-| MPIIO_F_WRITE_END_TIMESTAMP | Timestamp that the last MPI write operation ended
-| MPIIO_F_CLOSE_TIMESTAMP | Timestamp of the last time that the file was closed at MPI level
+| MPIIO_F_*_START_TIMESTAMP | Timestamp that the first MPIIO file open/read/write/close operation began
+| MPIIO_F_*_END_TIMESTAMP | Timestamp that the last MPIIO file open/read/write/close operation ended
| MPIIO_READ_TIME | Cumulative time spent reading at MPI level
| MPIIO_WRITE_TIME | Cumulative time spent write and sync at MPI level
| MPIIO_META_TIME | Cumulative time spent in open and close at MPI level
@@ -336,7 +337,8 @@ value of 1 MiB for optimal file alignment.
-| STDIO_OPENS | Count of how many times the file was opened using the stdio interface (e.g., `fopen()`)
+| STDIO_OPENS | Count of stdio file open operations (INCLUDING `fdopen` operations)
+| STDIO_FDOPENS| Count of stdio fdopen operations
| STDIO_READS | Count of stdio read operations
| STDIO_WRITES | Count of stdio write operations
| STDIO_SEEKS | Count of stdio seek operations
@@ -365,8 +367,8 @@ value of 1 MiB for optimal file alignment.
| HDF5_OPENS | Count of HDF5 opens
-| HDF5_F_OPEN_TIMESTAMP | Timestamp of first time that the file was opened at HDF5 level
-| HDF5_F_CLOSE_TIMESTAMP | Timestamp of the last time that the file was closed at HDF5 level
+| HDF5_F_*_START_TIMESTAMP | Timestamp that the first HDF5 file open/close operation began
+| HDF5_F_*_END_TIMESTAMP | Timestamp that the last HDF5 file open/close operation ended
.PnetCDF module
@@ -375,8 +377,8 @@ value of 1 MiB for optimal file alignment.
| PNETCDF_INDEP_OPENS | Count of PnetCDF independent opens
| PNETCDF_COLL_OPENS | Count of PnetCDF collective opens
-| PNETCDF_F_OPEN_TIMESTAMP | Timestamp of first time that the file was opened at PnetCDF level
-| PNETCDF_F_CLOSE_TIMESTAMP | Timestamp of the last time that the file was closed at PnetCDF level
+| PNETCDF_F_*_START_TIMESTAMP | Timestamp that the first PNETCDF file open/close operation began
+| PNETCDF_F_*_END_TIMESTAMP | Timestamp that the last PNETCDF file open/close operation ended
===== Additional modules
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/3a5d82c61c524e4856065a401ff146d68b39953c...e023abffd5e46dcf907adacb21a7301d64a157e2
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20190118/24a4e5a0/attachment-0001.html>
More information about the Darshan-commits
