[Darshan-commits] [Git][darshan/darshan][master] 4 commits: omit outputting with old-style fopen counters
Shane Snyder
xgitlab at cels.anl.gov
Mon Jun 11 15:26:33 CDT 2018
Shane Snyder pushed to branch master at darshan / darshan
Commits:
615f5396 by Phil Carns at 2018-04-02T16:59:35-04:00
- these cannot be easily translated into Darshan 3.1.x format
- fixes #241
b4ec5840 by Shane Snyder at 2018-06-11T15:22:34-05:00
Merge branch 'master' into 'issue-241-fopen-upconvert'
# Conflicts:
# ChangeLog
1980d236 by Shane Snyder at 2018-06-11T15:25:47-05:00
add another comment for more details
2c40940f by Shane Snyder at 2018-06-11T15:26:32-05:00
Merge branch 'issue-241-fopen-upconvert' into 'master'
Closes #241
See merge request darshan/darshan!22
2 changed files:
- ChangeLog
- darshan-util/darshan-posix-logutils.c
Changes:
ChangeLog
--- a/ChangeLog
+++ b/ChangeLog
@@ -4,6 +4,9 @@ Darshan Release Change Log
Darshan-3.1.7
+* bug fix for darshan-parser backwards compatibility: Darshan logs generated
+ by Darshan versions prior to 3.1.0 may have included stdio counters that
+ were not properly up-converted. Reported by Teng Wang.
* bug fix to MiB reported in I/O performance estimate of
darshan-job-summary.pl when both posix and stdio access is present
--- a/darshan-util/darshan-posix-logutils.c
+++ b/darshan-util/darshan-posix-logutils.c
@@ -86,13 +86,27 @@ static int darshan_log_get_posix_file(darshan_fd fd, void** posix_buf_p)
if(fd->mod_ver[DARSHAN_POSIX_MOD] == 1)
rec_len = DARSHAN_POSIX_FILE_SIZE_1;
- ret = darshan_log_get_mod(fd, DARSHAN_POSIX_MOD, scratch, rec_len);
+ int64_t *fopen_counter;
+ /* This version of the posix module had some stdio counters
+ * mixed in with the posix counters. If the fopen counters are
+ * 0, then we can simply update the record format to skip those
+ * counters. If the fopen counters are non-zero, then we omit
+ * the entire record because there is no clean way to properly
+ * up-convert it.
+ dest_p = scratch + (sizeof(struct darshan_base_record) +
+ (6 * sizeof(int64_t)));
+ fopen_counter = (int64_t*)dest_p;
+ do
+ /* pull POSIX records until we find one that doesn't have STDIO data */
+ ret = darshan_log_get_mod(fd, DARSHAN_POSIX_MOD, scratch, rec_len);
+ } while(ret == rec_len && *fopen_counter > 0);
if(ret != rec_len)
goto exit;
/* upconvert version 1 to version 2 in-place */
- dest_p = scratch + (sizeof(struct darshan_base_record) +
- (6 * sizeof(int64_t)));
src_p = dest_p + (4 * sizeof(int64_t));
len = rec_len - (src_p - scratch);
memmove(dest_p, src_p, len);
@@ -230,9 +244,9 @@ static void darshan_log_print_posix_description(int ver)
if(ver <= 1)
printf("\n# WARNING: POSIX module log format version 1 has the following limitations:\n");
- printf("# - Partial instrumentation of stdio stream I/O functions not parsable by Darshan versions >= 3.1.0\n");
- printf("# * Using darshan-logutils versions < 3.1.0, this data can be found in the following POSIX counters:\n");
- printf("# * POSIX_FOPENS, POSIX_FREADS, POSIX_FWRITES, POSIX_FSEEKS\n");
+ printf("# - Darshan version 3.1.0 and earlier had only partial instrumentation of stdio stream I/O functions.\n");
+ printf("# File records with stdio counters present will be omitted from output.\n");
+ printf("# Use darshan-logutils < 3.1.0 to retrieve those records.\n");
if(ver <= 2)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/81683bb50128ef220a8be8d52fa6d85cbb686ed6...2c40940ff465c5d0822cb099e8273102d30e2748
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20180611/fd5b80c7/attachment-0001.html>
More information about the Darshan-commits
