[Darshan-commits] [Git][darshan/darshan][master] 7 commits: Darshan Wrapper fixes for Spectrum/OpenMPI 2
    Shane Snyder
    xgitlab at cels.anl.gov
    Fri Oct 13 10:35:53 CDT 2017
Shane Snyder pushed to branch master at darshan / darshan
Commits:
4727d0a1 by cz7 at 2017-09-18T11:27:25-04:00
1dabc539 by Phil Carns at 2017-09-19T11:21:16-04:00
refactor LD_PRELOAD MPI wrappers
- match convention of other modules where possible
- avoid trampoline for non-PMPI calls
- resolve underlying symbols at run time
- use symbol name direclty in wrapper
fc3d349d by Phil Carns at 2017-09-19T11:50:53-04:00
add ld opts for static wrapping of mpiio
910486f8 by Shane Snyder at 2017-10-04T14:39:23+00:00
changes to get new wrappers working for static builds
cac9a0e6 by Shane Snyder at 2017-10-04T11:28:07-05:00
need to declar PMPI wrappers after MPI wrappers
ccddff36 by Shane Snyder at 2017-10-04T16:51:38+00:00
bug fix in mpi-io wrapper prototype
48dbd2e8 by Shane Snyder at 2017-10-13T10:22:50-05:00
Merge branch 'snyder-wrap-mod'
12 changed files:
- darshan-runtime/Makefile.in
- darshan-runtime/darshan.h
- darshan-runtime/lib/darshan-bgq.c
- darshan-runtime/lib/darshan-core-init-finalize.c
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/darshan-pnetcdf.c
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-base-ld-opts.in
- + darshan-runtime/share/ld-opts/darshan-mpiio-ld-opts
Changes:
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -199,6 +199,7 @@ ifdef BUILD_HDF5_MODULE
 endif
 	install -m 644 $(srcdir)/share/ld-opts/darshan-pnetcdf-ld-opts $(datarootdir)/ld-opts/darshan-pnetcdf-ld-opts
 	install -m 644 $(srcdir)/share/ld-opts/darshan-stdio-ld-opts $(datarootdir)/ld-opts/darshan-stdio-ld-opts
+	install -m 644 $(srcdir)/share/ld-opts/darshan-mpiio-ld-opts $(datarootdir)/ld-opts/darshan-mpiio-ld-opts
 ifdef ENABLE_MMAP_LOGS
 	install -m 755 share/darshan-mmap-epilog.sh $(datarootdir)/darshan-mmap-epilog.sh
 endif
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -28,15 +28,27 @@
 #define DARSHAN_DECL(__func) __func
-#define DARSHAN_MPI_CALL(__func) __real_ ## __func
+/* creates P* variant of MPI symbols for LD_PRELOAD so that we can handle
+ * language bindings that map to MPI or PMPI symbols under the covers.
+#define DARSHAN_WRAPPER_MAP(__func,__ret,__args,__fcall) \
+	__ret __func __args { \
+		__ret i; \
+		i = __fcall; \
+		return i; \
+/* Map the desired function call to a pointer called __real_NAME at run
+ * time.  Note that we fall back to looking for the same symbol with a P
+ * prefix to handle MPI bindings that call directly to the PMPI layer.
 #define MAP_OR_FAIL(__func) \
     if (!(__real_ ## __func)) \
         __real_ ## __func = dlsym(RTLD_NEXT, #__func); \
         if(!(__real_ ## __func)) { \
-           fprintf(stderr, "Darshan failed to map symbol: %s\n", #__func); \
-           exit(1); \
+            fprintf(stderr, "Darshan failed to map symbol: %s\n", #__func); \
+            exit(1); \
@@ -47,7 +59,15 @@
 #define DARSHAN_DECL(__name) __wrap_ ## __name
-#define DARSHAN_MPI_CALL(__func) __func
+/* creates P* variant of MPI symbols for static linking so that we can handle
+	__ret __wrap_ ## __func __args { \
+		__ret i; \
+		i = __wrap_ ## __fcall; \
+		return i; \
--- a/darshan-runtime/lib/darshan-bgq.c
+++ b/darshan-runtime/lib/darshan-bgq.c
@@ -196,13 +196,13 @@ static void bgq_shutdown(
         bgq_runtime->record->base_rec.rank = -1;
-        DARSHAN_MPI_CALL(PMPI_Comm_size)(mod_comm, &nprocs);
+        PMPI_Comm_size(mod_comm, &nprocs);
         ion_ids = malloc(sizeof(*ion_ids)*nprocs);
         result = (ion_ids != NULL);
         if(!result)
             bgq_runtime->record->counters[BGQ_INODES] = -1;
-    DARSHAN_MPI_CALL(PMPI_Bcast)(&result, 1, MPI_INT, 0, mod_comm);
+    PMPI_Bcast(&result, 1, MPI_INT, 0, mod_comm);
     /* caclulate the number of I/O nodes */
     if (result)
@@ -210,7 +210,7 @@ static void bgq_shutdown(
         int i, found;
         uint64_t val;
-        DARSHAN_MPI_CALL(PMPI_Gather)(&bgq_runtime->record->counters[BGQ_INODES],
+        PMPI_Gather(&bgq_runtime->record->counters[BGQ_INODES],
                                       1,
                                       MPI_LONG_LONG_INT,
                                       ion_ids,
--- a/darshan-runtime/lib/darshan-core-init-finalize.c
+++ b/darshan-runtime/lib/darshan-core-init-finalize.c
@@ -17,203 +17,17 @@
 #include "darshan-core.h"
 #include "darshan-dynamic.h"
-#ifdef DARSHAN_PRELOAD
-DARSHAN_FORWARD_DECL(PMPI_File_close, int, (MPI_File *fh));
-DARSHAN_FORWARD_DECL(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-DARSHAN_FORWARD_DECL(PMPI_File_iread, int, (MPI_File fh, void  *buf, int  count, MPI_Datatype  datatype, __D_MPI_REQUEST  *request));
-DARSHAN_FORWARD_DECL(PMPI_File_iread_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#ifdef HAVE_MPIIO_CONST
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_open, int, (MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_open, int, (MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_read_all_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
-DARSHAN_FORWARD_DECL(PMPI_File_read_all, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_read_at_all, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_read_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype));
-DARSHAN_FORWARD_DECL(PMPI_File_read_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_read, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_read_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
-DARSHAN_FORWARD_DECL(PMPI_File_read_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_read_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, const char *datarep, MPI_Info info));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, char *datarep, MPI_Info info));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_sync, int, (MPI_File fh));
-DARSHAN_FORWARD_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_all, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_all, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_ordered, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_File_write_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#else
-DARSHAN_FORWARD_DECL(PMPI_File_write_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
-#endif
 DARSHAN_FORWARD_DECL(PMPI_Finalize, int, ());
 DARSHAN_FORWARD_DECL(PMPI_Init, int, (int *argc, char ***argv));
 DARSHAN_FORWARD_DECL(PMPI_Init_thread, int, (int *argc, char ***argv, int required, int *provided));
-DARSHAN_FORWARD_DECL(PMPI_Wtime, double, ());
-DARSHAN_FORWARD_DECL(PMPI_Allreduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
-DARSHAN_FORWARD_DECL(PMPI_Bcast, int, (void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm));
-DARSHAN_FORWARD_DECL(PMPI_Comm_rank, int, (MPI_Comm comm, int *rank));
-DARSHAN_FORWARD_DECL(PMPI_Comm_size, int, (MPI_Comm comm, int *size));
-DARSHAN_FORWARD_DECL(PMPI_Scan, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
-DARSHAN_FORWARD_DECL(PMPI_Type_commit, int, (MPI_Datatype *datatype));
-DARSHAN_FORWARD_DECL(PMPI_Type_contiguous, int, (int count, MPI_Datatype oldtype, MPI_Datatype *newtype));
-DARSHAN_FORWARD_DECL(PMPI_Type_extent, int, (MPI_Datatype datatype, MPI_Aint *extent));
-DARSHAN_FORWARD_DECL(PMPI_Type_free, int, (MPI_Datatype *datatype));
-DARSHAN_FORWARD_DECL(PMPI_Type_hindexed, int, (int count, int *array_of_blocklengths, MPI_Aint *array_of_displacements, MPI_Datatype oldtype, MPI_Datatype *newtype));
-DARSHAN_FORWARD_DECL(PMPI_Type_get_envelope, int, (MPI_Datatype datatype, int *num_integers, int *num_addresses, int *num_datatypes, int *combiner));
-DARSHAN_FORWARD_DECL(PMPI_Type_size, int, (MPI_Datatype datatype, int *size));
-DARSHAN_FORWARD_DECL(PMPI_Op_create, int, (MPI_User_function *function, int commute, MPI_Op *op));
-DARSHAN_FORWARD_DECL(PMPI_Op_free, int, (MPI_Op *op));
-DARSHAN_FORWARD_DECL(PMPI_Reduce, int, (const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm));
-#else
-DARSHAN_FORWARD_DECL(PMPI_Reduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_Send, int, (const void *buf, int count, MPI_Datatype datatype, int dest, int tag, MPI_Comm comm));
-#else
-DARSHAN_FORWARD_DECL(PMPI_Send, int, (void *buf, int count, MPI_Datatype datatype, int dest, int tag, MPI_Comm comm));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_Recv, int, (void *buf, int count, MPI_Datatype datatype, int source, int tag, MPI_Comm comm, MPI_Status *status));
-DARSHAN_FORWARD_DECL(PMPI_Gather, int, (const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm));
-#else
-DARSHAN_FORWARD_DECL(PMPI_Gather, int, (void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm));
-#endif
-DARSHAN_FORWARD_DECL(PMPI_Barrier, int, (MPI_Comm comm));
-void resolve_mpi_symbols (void)
-     * Overloaded functions
-    MAP_OR_FAIL(PMPI_File_close);
-    MAP_OR_FAIL(PMPI_File_iread_at);
-    MAP_OR_FAIL(PMPI_File_iread);
-    MAP_OR_FAIL(PMPI_File_iread_shared);
-    MAP_OR_FAIL(PMPI_File_iwrite_at);
-    MAP_OR_FAIL(PMPI_File_iwrite);
-    MAP_OR_FAIL(PMPI_File_iwrite_shared);
-    MAP_OR_FAIL(PMPI_File_open);
-    MAP_OR_FAIL(PMPI_File_read_all_begin);
-    MAP_OR_FAIL(PMPI_File_read_all);
-    MAP_OR_FAIL(PMPI_File_read_at_all_begin);
-    MAP_OR_FAIL(PMPI_File_read_at_all);
-    MAP_OR_FAIL(PMPI_File_read_at);
-    MAP_OR_FAIL(PMPI_File_read);
-    MAP_OR_FAIL(PMPI_File_read_ordered_begin);
-    MAP_OR_FAIL(PMPI_File_read_ordered);
-    MAP_OR_FAIL(PMPI_File_read_shared);
-    MAP_OR_FAIL(PMPI_File_set_view);
-    MAP_OR_FAIL(PMPI_File_sync);
-    MAP_OR_FAIL(PMPI_File_write_all_begin);
-    MAP_OR_FAIL(PMPI_File_write_all);
-    MAP_OR_FAIL(PMPI_File_write_at_all_begin);
-    MAP_OR_FAIL(PMPI_File_write_at_all);
-    MAP_OR_FAIL(PMPI_File_write_at);
-    MAP_OR_FAIL(PMPI_File_write);
-    MAP_OR_FAIL(PMPI_File_write_ordered_begin);
-    MAP_OR_FAIL(PMPI_File_write_ordered);
-    MAP_OR_FAIL(PMPI_File_write_shared);
-    MAP_OR_FAIL(PMPI_Finalize);
-    MAP_OR_FAIL(PMPI_Init);
-    MAP_OR_FAIL(PMPI_Init_thread);
-     * These function are not intercepted but are used
-     * by darshan itself.
-    MAP_OR_FAIL(PMPI_Wtime);
-    MAP_OR_FAIL(PMPI_Allreduce);
-    MAP_OR_FAIL(PMPI_Bcast);
-    MAP_OR_FAIL(PMPI_Comm_rank);
-    MAP_OR_FAIL(PMPI_Comm_size);
-    MAP_OR_FAIL(PMPI_Scan);
-    MAP_OR_FAIL(PMPI_Type_commit);
-    MAP_OR_FAIL(PMPI_Type_contiguous);
-    MAP_OR_FAIL(PMPI_Type_extent);
-    MAP_OR_FAIL(PMPI_Type_free);
-    MAP_OR_FAIL(PMPI_Type_hindexed);
-    MAP_OR_FAIL(PMPI_Type_get_envelope);
-    MAP_OR_FAIL(PMPI_Type_size);
-    MAP_OR_FAIL(PMPI_Op_create);
-    MAP_OR_FAIL(PMPI_Op_free);
-    MAP_OR_FAIL(PMPI_Reduce);
-    MAP_OR_FAIL(PMPI_Send);
-    MAP_OR_FAIL(PMPI_Recv);
-    MAP_OR_FAIL(PMPI_Gather);
-    MAP_OR_FAIL(PMPI_Barrier);
-    return;
-#endif
-int MPI_Init(int *argc, char ***argv)
+int DARSHAN_DECL(MPI_Init)(int *argc, char ***argv)
     int ret;
-    resolve_mpi_symbols();
-#endif
+    MAP_OR_FAIL(PMPI_Init);
-    ret = DARSHAN_MPI_CALL(PMPI_Init)(argc, argv);
+    ret = __real_PMPI_Init(argc, argv);
     if(ret != MPI_SUCCESS)
         return(ret);
@@ -231,16 +45,15 @@ int MPI_Init(int *argc, char ***argv)
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_Init, int, (int *argc, char ***argv), MPI_Init(argc,argv))
-int MPI_Init_thread(int *argc, char ***argv, int required, int *provided)
+int DARSHAN_DECL(MPI_Init_thread)(int *argc, char ***argv, int required, int *provided)
     int ret;
-#endif
+    MAP_OR_FAIL(PMPI_Init_thread);
-    ret = DARSHAN_MPI_CALL(PMPI_Init_thread)(argc, argv, required, provided);
+    ret = __real_PMPI_Init_thread(argc, argv, required, provided);
         return(ret);
@@ -258,16 +71,20 @@ int MPI_Init_thread(int *argc, char ***argv, int required, int *provided)
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_Init_thread, int, (int *argc, char ***argv, int required, int *provided), MPI_Init_thread(argc,argv,required,provided))
-int MPI_Finalize(void)
+int DARSHAN_DECL(MPI_Finalize)(void)
     int ret;
+    MAP_OR_FAIL(PMPI_Finalize);
     darshan_core_shutdown();
-    ret = DARSHAN_MPI_CALL(PMPI_Finalize)();
+    ret = __real_PMPI_Finalize();
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_Finalize, int, (void), MPI_Finalize())
  * Local variables:
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -163,14 +163,14 @@ void darshan_core_initialize(int argc, char **argv)
     int tmpval;
     double tmpfloat;
-    DARSHAN_MPI_CALL(PMPI_Comm_size)(MPI_COMM_WORLD, &nprocs);
-    DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank);
+    PMPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+    PMPI_Comm_rank(MPI_COMM_WORLD, &my_rank);
     if(getenv("DARSHAN_INTERNAL_TIMING"))
         internal_timing_flag = 1;
     if(internal_timing_flag)
-        init_start = DARSHAN_MPI_CALL(PMPI_Wtime)();
+        init_start = PMPI_Wtime();
     /* setup darshan runtime if darshan is enabled and hasn't been initialized already */
     if(!getenv("DARSHAN_DISABLE") && !darshan_core)
@@ -236,7 +236,7 @@ void darshan_core_initialize(int argc, char **argv)
         if(init_core)
             memset(init_core, 0, sizeof(*init_core));
-            init_core->wtime_offset = DARSHAN_MPI_CALL(PMPI_Wtime)();
+            init_core->wtime_offset = PMPI_Wtime();
         /* TODO: do we alloc new memory as we go or just do everything up front? */
@@ -325,8 +325,8 @@ void darshan_core_initialize(int argc, char **argv)
-        init_time = DARSHAN_MPI_CALL(PMPI_Wtime)() - init_start;
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&init_time, &init_max, 1,
+        init_time = PMPI_Wtime() - init_start;
+        PMPI_Reduce(&init_time, &init_max, 1,
             MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD);
         if(my_rank == 0)
@@ -371,8 +371,8 @@ void darshan_core_shutdown()
     /* synchronize before getting start time */
-    DARSHAN_MPI_CALL(PMPI_Barrier)(MPI_COMM_WORLD);
-    start_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
+    PMPI_Barrier(MPI_COMM_WORLD);
+    start_log_time = PMPI_Wtime();
     /* disable darhan-core while we shutdown */
     DARSHAN_CORE_LOCK();
@@ -398,9 +398,9 @@ void darshan_core_shutdown()
     final_core->log_job_p->end_time = time(NULL);
     /* reduce to report first start and last end time across all ranks at rank 0 */
-    DARSHAN_MPI_CALL(PMPI_Reduce)(&final_core->log_job_p->start_time, &first_start_time,
+    PMPI_Reduce(&final_core->log_job_p->start_time, &first_start_time,
         1, MPI_INT64_T, MPI_MIN, 0, MPI_COMM_WORLD);
-    DARSHAN_MPI_CALL(PMPI_Reduce)(&final_core->log_job_p->end_time, &last_end_time,
+    PMPI_Reduce(&final_core->log_job_p->end_time, &last_end_time,
         1, MPI_INT64_T, MPI_MAX, 0, MPI_COMM_WORLD);
     if(my_rank == 0)
@@ -433,7 +433,7 @@ void darshan_core_shutdown()
     /* broadcast log file name */
-    DARSHAN_MPI_CALL(PMPI_Bcast)(logfile_name, PATH_MAX, MPI_CHAR, 0,
+    PMPI_Bcast(logfile_name, PATH_MAX, MPI_CHAR, 0,
         MPI_COMM_WORLD);
     if(strlen(logfile_name) == 0)
@@ -456,21 +456,21 @@ void darshan_core_shutdown()
     /* reduce the number of times a module was opened globally and bcast to everyone */
-    DARSHAN_MPI_CALL(PMPI_Allreduce)(local_mod_use, global_mod_use_count,
+    PMPI_Allreduce(local_mod_use, global_mod_use_count,
         DARSHAN_MAX_MODS, MPI_INT, MPI_SUM, MPI_COMM_WORLD);
     /* get a list of records which are shared across all processes */
     darshan_get_shared_records(final_core, &shared_recs, &shared_rec_cnt);
-        open1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
+        open1 = PMPI_Wtime();
     /* collectively open the darshan log file */
     ret = darshan_log_open_all(logfile_name, &log_fh);
-        open2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
+        open2 = PMPI_Wtime();
     /* error out if unable to open log file */
-    DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
+    PMPI_Allreduce(&ret, &all_ret, 1, MPI_INT,
         MPI_LOR, MPI_COMM_WORLD);
     if(all_ret != 0)
@@ -485,7 +485,7 @@ void darshan_core_shutdown()
-        job1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
+        job1 = PMPI_Wtime();
     /* rank 0 is responsible for writing the compressed darshan job information */
     if(my_rank == 0)
@@ -505,7 +505,7 @@ void darshan_core_shutdown()
             /* write the job information, preallocing space for the log header */
             gz_fp += sizeof(struct darshan_header);
-            all_ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, gz_fp,
+            all_ret = PMPI_File_write_at(log_fh, gz_fp,
                 final_core->comp_buf, comp_buf_sz, MPI_BYTE, &status);
             if(all_ret != MPI_SUCCESS)
@@ -520,7 +520,7 @@ void darshan_core_shutdown()
     /* error out if unable to write job information */
-    DARSHAN_MPI_CALL(PMPI_Bcast)(&all_ret, 1, MPI_INT, 0, MPI_COMM_WORLD);
+    PMPI_Bcast(&all_ret, 1, MPI_INT, 0, MPI_COMM_WORLD);
     if(all_ret != 0)
         free(logfile_name);
@@ -528,17 +528,17 @@ void darshan_core_shutdown()
         return;
-        job2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
+        job2 = PMPI_Wtime();
-        rec1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
+        rec1 = PMPI_Wtime();
     /* write the record name->id hash to the log file */
     final_core->log_hdr_p->name_map.off = gz_fp;
     ret = darshan_log_write_name_record_hash(log_fh, final_core, &gz_fp);
     final_core->log_hdr_p->name_map.len = gz_fp - final_core->log_hdr_p->name_map.off;
     /* error out if unable to write the name record hash */
     if(all_ret != 0)
@@ -554,7 +554,7 @@ void darshan_core_shutdown()
         return;
-        rec2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
+        rec2 = PMPI_Wtime();
     mod_shared_recs = malloc(shared_rec_cnt * sizeof(darshan_record_id));
     assert(mod_shared_recs);
@@ -586,7 +586,7 @@ void darshan_core_shutdown()
-            mod1[i] = DARSHAN_MPI_CALL(PMPI_Wtime)();
+            mod1[i] = PMPI_Wtime();
         /* set the shared record list for this module */
         for(j = 0; j < shared_rec_cnt; j++)
@@ -626,7 +626,7 @@ void darshan_core_shutdown()
             free(mod_buf);
         /* error out if the log append failed */
         if(all_ret != 0)
@@ -643,11 +643,11 @@ void darshan_core_shutdown()
-            mod2[i] = DARSHAN_MPI_CALL(PMPI_Wtime)();
+            mod2[i] = PMPI_Wtime();
-        header1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
+        header1 = PMPI_Wtime();
     /* write out log header, after running 2 reductions on header variables:
      *  1) reduce 'partial_flag' variable to determine which modules ran out
      *     of memory for storing data
@@ -659,14 +659,14 @@ void darshan_core_shutdown()
         /* rank 0 is responsible for writing the log header */
         final_core->log_hdr_p->comp_type = DARSHAN_ZLIB_COMP;
+        PMPI_Reduce(
             MPI_IN_PLACE, &(final_core->log_hdr_p->partial_flag),
             1, MPI_UINT32_T, MPI_BOR, 0, MPI_COMM_WORLD);
+        PMPI_Reduce(
             MPI_IN_PLACE, &(final_core->log_hdr_p->mod_ver),
             DARSHAN_MAX_MODS, MPI_UINT32_T, MPI_MAX, 0, MPI_COMM_WORLD);
-        all_ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, 0, final_core->log_hdr_p,
+        all_ret = PMPI_File_write_at(log_fh, 0, final_core->log_hdr_p,
             sizeof(struct darshan_header), MPI_BYTE, &status);
@@ -677,16 +677,16 @@ void darshan_core_shutdown()
     else
+        PMPI_Reduce(
             &(final_core->log_hdr_p->partial_flag), &(final_core->log_hdr_p->partial_flag),
+        PMPI_Reduce(
             &(final_core->log_hdr_p->mod_ver), &(final_core->log_hdr_p->mod_ver),
     /* error out if unable to write log header */
     if(all_ret != 0)
         free(logfile_name);
@@ -694,9 +694,9 @@ void darshan_core_shutdown()
         return;
-        header2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
+        header2 = PMPI_Wtime();
-    DARSHAN_MPI_CALL(PMPI_File_close)(&log_fh);
+    PMPI_File_close(&log_fh);
     /* if we got this far, there are no errors, so rename from *.darshan_partial
      * to *-<logwritetime>.darshan, which indicates that this log file is
@@ -723,7 +723,7 @@ void darshan_core_shutdown()
             if(new_logfile_name)
                 new_logfile_name[0] = '\0';
-                end_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
+                end_log_time = PMPI_Wtime();
                 strcat(new_logfile_name, logfile_name);
                 tmp_index = strstr(new_logfile_name, ".darshan_partial");
                 sprintf(tmp_index, "_%d.darshan", (int)(end_log_time-start_log_time+1));
@@ -749,7 +749,7 @@ void darshan_core_shutdown()
         double mod_tm[DARSHAN_MAX_MODS], mod_slowest[DARSHAN_MAX_MODS];
         double all_tm, all_slowest;
-        tm_end = DARSHAN_MPI_CALL(PMPI_Wtime)();
+        tm_end = PMPI_Wtime();
         open_tm = open2 - open1;
         header_tm = header2 - header1;
@@ -761,17 +761,17 @@ void darshan_core_shutdown()
             mod_tm[i] = mod2[i] - mod1[i];
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&open_tm, &open_slowest, 1,
+        PMPI_Reduce(&open_tm, &open_slowest, 1,
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&header_tm, &header_slowest, 1,
+        PMPI_Reduce(&header_tm, &header_slowest, 1,
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&job_tm, &job_slowest, 1,
+        PMPI_Reduce(&job_tm, &job_slowest, 1,
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&rec_tm, &rec_slowest, 1,
+        PMPI_Reduce(&rec_tm, &rec_slowest, 1,
-        DARSHAN_MPI_CALL(PMPI_Reduce)(&all_tm, &all_slowest, 1,
+        PMPI_Reduce(&all_tm, &all_slowest, 1,
-        DARSHAN_MPI_CALL(PMPI_Reduce)(mod_tm, mod_slowest, DARSHAN_MAX_MODS,
+        PMPI_Reduce(mod_tm, mod_slowest, DARSHAN_MAX_MODS,
         if(my_rank == 0)
@@ -834,11 +834,11 @@ static void *darshan_init_mmap_log(struct darshan_core_runtime* core, int jobid)
     if(my_rank == 0)
-        hlevel=DARSHAN_MPI_CALL(PMPI_Wtime)() * 1000000;
+        hlevel=PMPI_Wtime() * 1000000;
         (void)gethostname(hname, sizeof(hname));
         logmod = darshan_hash((void*)hname,strlen(hname),hlevel);
-    DARSHAN_MPI_CALL(PMPI_Bcast)(&logmod, 1, MPI_UINT64_T, 0, MPI_COMM_WORLD);
+    PMPI_Bcast(&logmod, 1, MPI_UINT64_T, 0, MPI_COMM_WORLD);
     /* construct a unique temporary log file name for this process
      * to write mmap log data to
@@ -1353,7 +1353,7 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
         darshan_get_user_name(cuser);
         /* generate a random number to help differentiate the log */
@@ -1442,7 +1442,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
     uint64_t *global_mod_flags;
     /* broadcast root's number of records to all other processes */
-    DARSHAN_MPI_CALL(PMPI_Bcast)(&tmp_cnt, 1, MPI_INT, 0, MPI_COMM_WORLD);
+    PMPI_Bcast(&tmp_cnt, 1, MPI_INT, 0, MPI_COMM_WORLD);
     /* use root record count to allocate data structures */
     id_array = malloc(tmp_cnt * sizeof(darshan_record_id));
@@ -1466,7 +1466,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
     /* broadcast root's list of records to all other processes */
-    DARSHAN_MPI_CALL(PMPI_Bcast)(id_array, (tmp_cnt * sizeof(darshan_record_id)),
+    PMPI_Bcast(id_array, (tmp_cnt * sizeof(darshan_record_id)),
         MPI_BYTE, 0, MPI_COMM_WORLD);
     /* everyone looks to see if they opened the same records as root */
@@ -1483,7 +1483,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
     /* now allreduce so everyone agrees which records are shared and
      * which modules accessed them collectively
-    DARSHAN_MPI_CALL(PMPI_Allreduce)(mod_flags, global_mod_flags, tmp_cnt,
+    PMPI_Allreduce(mod_flags, global_mod_flags, tmp_cnt,
         MPI_UINT64_T, MPI_BAND, MPI_COMM_WORLD);
     j = 0;
@@ -1562,7 +1562,7 @@ static int darshan_log_open_all(char *logfile_name, MPI_File *log_fh)
     /* open the darshan log file for writing */
-    ret = DARSHAN_MPI_CALL(PMPI_File_open)(MPI_COMM_WORLD, logfile_name,
+    ret = PMPI_File_open(MPI_COMM_WORLD, logfile_name,
         MPI_MODE_CREATE | MPI_MODE_WRONLY | MPI_MODE_EXCL, info, log_fh);
         return(-1);
@@ -1780,7 +1780,7 @@ static int darshan_log_append_all(MPI_File log_fh, struct darshan_core_runtime *
         send_off += *inout_off; /* rank 0 knows the beginning offset */
-    DARSHAN_MPI_CALL(PMPI_Scan)(&send_off, &my_off, 1, MPI_OFFSET,
+    PMPI_Scan(&send_off, &my_off, 1, MPI_OFFSET,
     /* scan is inclusive; subtract local size back out */
     my_off -= comp_buf_sz;
@@ -1788,7 +1788,7 @@ static int darshan_log_append_all(MPI_File log_fh, struct darshan_core_runtime *
     if(ret == 0)
         /* no compression errors, proceed with the collective write */
-        ret = DARSHAN_MPI_CALL(PMPI_File_write_at_all)(log_fh, my_off,
+        ret = PMPI_File_write_at_all(log_fh, my_off,
     else
@@ -1796,7 +1796,7 @@ static int darshan_log_append_all(MPI_File log_fh, struct darshan_core_runtime *
         /* error during compression. preserve and return error to caller,
          * but participate in collective write to avoid deadlock.
-        (void)DARSHAN_MPI_CALL(PMPI_File_write_at_all)(log_fh, my_off,
+        (void)PMPI_File_write_at_all(log_fh, my_off,
@@ -1806,12 +1806,12 @@ static int darshan_log_append_all(MPI_File log_fh, struct darshan_core_runtime *
         if(my_rank == (nprocs-1))
             my_off += comp_buf_sz;
-            DARSHAN_MPI_CALL(PMPI_Send)(&my_off, 1, MPI_OFFSET, 0, 0,
+            PMPI_Send(&my_off, 1, MPI_OFFSET, 0, 0,
                 MPI_COMM_WORLD);
         if(my_rank == 0)
-            DARSHAN_MPI_CALL(PMPI_Recv)(&my_off, 1, MPI_OFFSET, (nprocs-1), 0,
+            PMPI_Recv(&my_off, 1, MPI_OFFSET, (nprocs-1), 0,
                 MPI_COMM_WORLD, &status);
             *inout_off = my_off;
@@ -1886,7 +1886,7 @@ void darshan_shutdown_bench(int argc, char **argv)
     if(my_rank == 0)
         fprintf(stderr, "# 1 unique file per proc\n");
     darshan_core = NULL;
@@ -1901,7 +1901,7 @@ void darshan_shutdown_bench(int argc, char **argv)
     if(my_rank == 0)
         fprintf(stderr, "# 1 shared file per proc\n");
@@ -1916,7 +1916,7 @@ void darshan_shutdown_bench(int argc, char **argv)
     if(my_rank == 0)
         fprintf(stderr, "# 1024 unique files per proc\n");
@@ -1931,7 +1931,7 @@ void darshan_shutdown_bench(int argc, char **argv)
     if(my_rank == 0)
         fprintf(stderr, "# 1024 shared files per proc\n");
@@ -2130,7 +2130,7 @@ double darshan_core_wtime()
     DARSHAN_CORE_UNLOCK();
-    return(DARSHAN_MPI_CALL(PMPI_Wtime)() - darshan_core->wtime_offset);
+    return(PMPI_Wtime() - darshan_core->wtime_offset);
 int darshan_core_excluded_path(const char *path)
--- a/darshan-runtime/lib/darshan-hdf5.c
+++ b/darshan-runtime/lib/darshan-hdf5.c
@@ -449,15 +449,15 @@ static void hdf5_shutdown(
         /* construct a datatype for a HDF5 file record.  This is serving no purpose
          * except to make sure we can do a reduction on proper boundaries
-        DARSHAN_MPI_CALL(PMPI_Type_contiguous)(sizeof(struct darshan_hdf5_file),
+        PMPI_Type_contiguous(sizeof(struct darshan_hdf5_file),
             MPI_BYTE, &red_type);
-        DARSHAN_MPI_CALL(PMPI_Type_commit)(&red_type);
+        PMPI_Type_commit(&red_type);
         /* register a HDF5 file record reduction operator */
-        DARSHAN_MPI_CALL(PMPI_Op_create)(hdf5_record_reduction_op, 1, &red_op);
+        PMPI_Op_create(hdf5_record_reduction_op, 1, &red_op);
         /* reduce shared HDF5 file records */
-        DARSHAN_MPI_CALL(PMPI_Reduce)(red_send_buf, red_recv_buf,
+        PMPI_Reduce(red_send_buf, red_recv_buf,
             shared_rec_count, red_type, red_op, 0, mod_comm);
         /* clean up reduction state */
@@ -473,8 +473,8 @@ static void hdf5_shutdown(
             hdf5_rec_count -= shared_rec_count;
-        DARSHAN_MPI_CALL(PMPI_Type_free)(&red_type);
-        DARSHAN_MPI_CALL(PMPI_Op_free)(&red_op);
+        PMPI_Type_free(&red_type);
+        PMPI_Op_free(&red_op);
     /* update output buffer size to account for shared file reduction */
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -25,6 +25,91 @@
 #include "darshan.h"
+DARSHAN_FORWARD_DECL(PMPI_File_close, int, (MPI_File *fh));
+DARSHAN_FORWARD_DECL(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+DARSHAN_FORWARD_DECL(PMPI_File_iread, int, (MPI_File fh, void  *buf, int  count, MPI_Datatype  datatype, __D_MPI_REQUEST  *request));
+DARSHAN_FORWARD_DECL(PMPI_File_iread_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#ifdef HAVE_MPIIO_CONST
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_open, int, (MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_open, int, (MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_read_all_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
+DARSHAN_FORWARD_DECL(PMPI_File_read_all, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_read_at_all, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_read_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype));
+DARSHAN_FORWARD_DECL(PMPI_File_read_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_read, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_read_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
+DARSHAN_FORWARD_DECL(PMPI_File_read_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_read_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, const char *datarep, MPI_Info info));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, char *datarep, MPI_Info info));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_sync, int, (MPI_File fh));
+DARSHAN_FORWARD_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_all, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_all, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_ordered, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
 /* The mpiio_file_record_ref structure maintains necessary runtime metadata
  * for the MPIIO file record (darshan_mpiio_file structure, defined in
  * darshan-mpiio-log-format.h) pointed to by 'file_rec'. This metadata
@@ -137,7 +222,7 @@ static int enable_dxt_io_trace = 0;
         break; \
     rec_ref->file_rec->counters[MPIIO_MODE] = __mode; \
-    DARSHAN_MPI_CALL(PMPI_Comm_size)(__comm, &comm_size); \
+    PMPI_Comm_size(__comm, &comm_size); \
     if(comm_size == 1) \
         rec_ref->file_rec->counters[MPIIO_INDEP_OPENS] += 1; \
     else \
@@ -160,7 +245,7 @@ static int enable_dxt_io_trace = 0;
     if(__ret != MPI_SUCCESS) break; \
     rec_ref = darshan_lookup_record_ref(mpiio_runtime->fh_hash, &(__fh), sizeof(MPI_File)); \
     if(!rec_ref) break; \
-    DARSHAN_MPI_CALL(PMPI_Type_size)(__datatype, &size);  \
+    PMPI_Type_size(__datatype, &size);  \
     size = size * __count; \
     /* DXT to record detailed read tracing information */ \
     if(enable_dxt_io_trace) { \
@@ -193,7 +278,7 @@ static int enable_dxt_io_trace = 0;
      /* DXT to record detailed write tracing information */ \
@@ -224,9 +309,9 @@ static int enable_dxt_io_trace = 0;
-int MPI_File_open(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh)
+int DARSHAN_DECL(MPI_File_open)(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh)
 #else
-int MPI_File_open(MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh)
+int DARSHAN_DECL(MPI_File_open)(MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh)
 #endif
     int ret;
@@ -234,8 +319,10 @@ int MPI_File_open(MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_F
     char* tmp;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_open);
     tm1 = darshan_core_wtime();
-    ret = DARSHAN_MPI_CALL(PMPI_File_open)(comm, filename, amode, info, fh);
+    ret = __real_PMPI_File_open(comm, filename, amode, info, fh);
     tm2 = darshan_core_wtime();
     /* use ROMIO approach to strip prefix if present */
@@ -255,15 +342,22 @@ int MPI_File_open(MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_F
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_open, int,  (MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh), MPI_File_open(comm,filename,amode,info,fh))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_open, int,  (MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh), MPI_File_open(comm,filename,amode,info,fh))
+#endif
-int MPI_File_read(MPI_File fh, void *buf, int count,
+int DARSHAN_DECL(MPI_File_read)(MPI_File fh, void *buf, int count,
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_read);
-    ret = DARSHAN_MPI_CALL(PMPI_File_read)(fh, buf, count, datatype, status);
+    ret = __real_PMPI_File_read(fh, buf, count, datatype, status);
     MPIIO_PRE_RECORD();
@@ -272,20 +366,24 @@ int MPI_File_read(MPI_File fh, void *buf, int count,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_read, int, (MPI_File fh, void *buf, int count,
+    MPI_Datatype datatype, MPI_Status *status), MPI_File_read(fh,buf,count,datatype,status))
-int MPI_File_write(MPI_File fh, const void *buf, int count,
+int DARSHAN_DECL(MPI_File_write)(MPI_File fh, const void *buf, int count,
 #else
-int MPI_File_write(MPI_File fh, void *buf, int count,
+int DARSHAN_DECL(MPI_File_write)(MPI_File fh, void *buf, int count,
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_write);
-    ret = DARSHAN_MPI_CALL(PMPI_File_write)(fh, buf, count, datatype, status);
+    ret = __real_PMPI_File_write(fh, buf, count, datatype, status);
     MPIIO_PRE_RECORD();
@@ -294,15 +392,24 @@ int MPI_File_write(MPI_File fh, void *buf, int count,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_write, int, (MPI_File fh, const void *buf, int count,
+    MPI_Datatype datatype, MPI_Status *status), MPI_File_write(fh,buf,count,datatype,status))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_write, int, (MPI_File fh, void *buf, int count,
+#endif
-int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf,
+int DARSHAN_DECL(MPI_File_read_at)(MPI_File fh, MPI_Offset offset, void *buf,
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_read_at);
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_at)(fh, offset, buf,
+    ret = __real_PMPI_File_read_at(fh, offset, buf,
@@ -312,20 +419,24 @@ int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_read_at, int, (MPI_File fh, MPI_Offset offset, void *buf,
+    int count, MPI_Datatype datatype, MPI_Status *status), MPI_File_read_at(fh, offset, buf, count, datatype, status))
-int MPI_File_write_at(MPI_File fh, MPI_Offset offset, const void *buf,
+int DARSHAN_DECL(MPI_File_write_at)(MPI_File fh, MPI_Offset offset, const void *buf,
 #else
-int MPI_File_write_at(MPI_File fh, MPI_Offset offset, void *buf,
+int DARSHAN_DECL(MPI_File_write_at)(MPI_File fh, MPI_Offset offset, void *buf,
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_write_at);
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(fh, offset, buf,
+    ret = __real_PMPI_File_write_at(fh, offset, buf,
@@ -335,14 +446,23 @@ int MPI_File_write_at(MPI_File fh, MPI_Offset offset, void *buf,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, const void *buf,
+    int count, MPI_Datatype datatype, MPI_Status *status), MPI_File_write_at(fh, offset, buf, count, datatype, status))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, void *buf,
+#endif
-int MPI_File_read_all(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
+int DARSHAN_DECL(MPI_File_read_all)(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
     int ret;
     double tm1, tm2;
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_all)(fh, buf, count,
+    ret = __real_PMPI_File_read_all(fh, buf, count,
         datatype, status);
@@ -352,18 +472,22 @@ int MPI_File_read_all(MPI_File fh, void * buf, int count, MPI_Datatype datatype,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_read_all, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
+        MPI_File_read_all(fh,buf,count,datatype,status))
-int MPI_File_write_all(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
+int DARSHAN_DECL(MPI_File_write_all)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
 #else
-int MPI_File_write_all(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
+int DARSHAN_DECL(MPI_File_write_all)(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_write_all);
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_all)(fh, buf, count,
+    ret = __real_PMPI_File_write_all(fh, buf, count,
         datatype, status);
@@ -373,15 +497,24 @@ int MPI_File_write_all(MPI_File fh, void * buf, int count, MPI_Datatype datatype
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_write_all, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
+        MPI_File_write_all(fh, buf, count, datatype, status))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_write_all, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
+#endif
-int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void * buf,
+int DARSHAN_DECL(MPI_File_read_at_all)(MPI_File fh, MPI_Offset offset, void * buf,
     int count, MPI_Datatype datatype, MPI_Status * status)
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_read_at_all);
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_at_all)(fh, offset, buf,
+    ret = __real_PMPI_File_read_at_all(fh, offset, buf,
@@ -391,20 +524,25 @@ int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void * buf,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_read_at_all, int, (MPI_File fh, MPI_Offset offset, void * buf,
+    int count, MPI_Datatype datatype, MPI_Status * status),
+        MPI_File_read_at_all(fh,offset,buf,count,datatype,status))
-int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, const void * buf,
+int DARSHAN_DECL(MPI_File_write_at_all)(MPI_File fh, MPI_Offset offset, const void * buf,
 #else
-int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, void * buf,
+int DARSHAN_DECL(MPI_File_write_at_all)(MPI_File fh, MPI_Offset offset, void * buf,
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_write_at_all);
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_at_all)(fh, offset, buf,
+    ret = __real_PMPI_File_write_at_all(fh, offset, buf,
@@ -414,14 +552,25 @@ int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, void * buf,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, const void * buf,
+        MPI_File_write_at_all(fh, offset, buf, count, datatype, status))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, void * buf,
+#endif
-int MPI_File_read_shared(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
+int DARSHAN_DECL(MPI_File_read_shared)(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_read_shared);
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_shared)(fh, buf, count,
+    ret = __real_PMPI_File_read_shared(fh, buf, count,
         datatype, status);
@@ -431,18 +580,22 @@ int MPI_File_read_shared(MPI_File fh, void * buf, int count, MPI_Datatype dataty
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_read_shared, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
+        MPI_File_read_shared(fh, buf, count, datatype, status))
-int MPI_File_write_shared(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
+int DARSHAN_DECL(MPI_File_write_shared)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
 #else
-int MPI_File_write_shared(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
+int DARSHAN_DECL(MPI_File_write_shared)(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_write_shared);
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_shared)(fh, buf, count,
+    ret = __real_PMPI_File_write_shared(fh, buf, count,
         datatype, status);
@@ -452,15 +605,25 @@ int MPI_File_write_shared(MPI_File fh, void * buf, int count, MPI_Datatype datat
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_write_shared, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
+        MPI_File_write_shared(fh, buf, count, datatype, status))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_write_shared, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
+#endif
-int MPI_File_read_ordered(MPI_File fh, void * buf, int count,
+int DARSHAN_DECL(MPI_File_read_ordered)(MPI_File fh, void * buf, int count,
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_read_ordered);
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_ordered)(fh, buf, count,
+    ret = __real_PMPI_File_read_ordered(fh, buf, count,
         datatype, status);
@@ -470,20 +633,25 @@ int MPI_File_read_ordered(MPI_File fh, void * buf, int count,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_read_ordered, int, (MPI_File fh, void * buf, int count,
+    MPI_Datatype datatype, MPI_Status * status),
+        MPI_File_read_ordered(fh, buf, count, datatype, status))
-int MPI_File_write_ordered(MPI_File fh, const void * buf, int count,
+int DARSHAN_DECL(MPI_File_write_ordered)(MPI_File fh, const void * buf, int count,
 #else
-int MPI_File_write_ordered(MPI_File fh, void * buf, int count,
+int DARSHAN_DECL(MPI_File_write_ordered)(MPI_File fh, void * buf, int count,
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_write_ordered);
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_ordered)(fh, buf, count,
+    ret = __real_PMPI_File_write_ordered(fh, buf, count,
          datatype, status);
@@ -493,14 +661,25 @@ int MPI_File_write_ordered(MPI_File fh, void * buf, int count,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_write_ordered, int, (MPI_File fh, const void * buf, int count,
+        MPI_File_write_ordered(fh, buf, count, datatype, status))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_write_ordered, int, (MPI_File fh, void * buf, int count,
+#endif
-int MPI_File_read_all_begin(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
+int DARSHAN_DECL(MPI_File_read_all_begin)(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_read_all_begin);
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_all_begin)(fh, buf, count, datatype);
+    ret = __real_PMPI_File_read_all_begin(fh, buf, count, datatype);
     MPIIO_PRE_RECORD();
@@ -509,18 +688,22 @@ int MPI_File_read_all_begin(MPI_File fh, void * buf, int count, MPI_Datatype dat
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_read_all_begin, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype),
+        MPI_File_read_all_begin(fh, buf, count, datatype))
-int MPI_File_write_all_begin(MPI_File fh, const void * buf, int count, MPI_Datatype datatype)
+int DARSHAN_DECL(MPI_File_write_all_begin)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype)
 #else
-int MPI_File_write_all_begin(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
+int DARSHAN_DECL(MPI_File_write_all_begin)(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_write_all_begin);
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_all_begin)(fh, buf, count, datatype);
+    ret = __real_PMPI_File_write_all_begin(fh, buf, count, datatype);
     MPIIO_PRE_RECORD();
@@ -529,15 +712,24 @@ int MPI_File_write_all_begin(MPI_File fh, void * buf, int count, MPI_Datatype da
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_write_all_begin, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype),
+        MPI_File_write_all_begin(fh, buf, count, datatype))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_write_all_begin, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype),
+#endif
-int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void * buf,
+int DARSHAN_DECL(MPI_File_read_at_all_begin)(MPI_File fh, MPI_Offset offset, void * buf,
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_read_at_all_begin);
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_at_all_begin)(fh, offset, buf,
+    ret = __real_PMPI_File_read_at_all_begin(fh, offset, buf,
         count, datatype);
@@ -547,20 +739,25 @@ int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void * buf,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_read_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void * buf,
+    int count, MPI_Datatype datatype), MPI_File_read_at_all_begin(fh, offset, buf, count,
+        datatype))
-int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, const void * buf,
+int DARSHAN_DECL(MPI_File_write_at_all_begin)(MPI_File fh, MPI_Offset offset, const void * buf,
 #else
-int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, void * buf,
+int DARSHAN_DECL(MPI_File_write_at_all_begin)(MPI_File fh, MPI_Offset offset, void * buf,
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_write_at_all_begin);
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_at_all_begin)(fh, offset,
+    ret = __real_PMPI_File_write_at_all_begin(fh, offset,
@@ -570,14 +767,23 @@ int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, void * buf,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, const void * buf,
+    int count, MPI_Datatype datatype), MPI_File_write_at_all_begin( fh, offset, buf, count, datatype))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void * buf,
+#endif
-int MPI_File_read_ordered_begin(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
+int DARSHAN_DECL(MPI_File_read_ordered_begin)(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_read_ordered_begin);
-    ret = DARSHAN_MPI_CALL(PMPI_File_read_ordered_begin)(fh, buf, count,
+    ret = __real_PMPI_File_read_ordered_begin(fh, buf, count,
         datatype);
@@ -587,18 +793,22 @@ int MPI_File_read_ordered_begin(MPI_File fh, void * buf, int count, MPI_Datatype
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_read_ordered_begin, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype),
+        MPI_File_read_ordered_begin(fh, buf, count, datatype))
-int MPI_File_write_ordered_begin(MPI_File fh, const void * buf, int count, MPI_Datatype datatype)
+int DARSHAN_DECL(MPI_File_write_ordered_begin)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype)
 #else
-int MPI_File_write_ordered_begin(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
+int DARSHAN_DECL(MPI_File_write_ordered_begin)(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_write_ordered_begin);
-    ret = DARSHAN_MPI_CALL(PMPI_File_write_ordered_begin)(fh, buf, count,
+    ret = __real_PMPI_File_write_ordered_begin(fh, buf, count,
         datatype);
@@ -608,14 +818,23 @@ int MPI_File_write_ordered_begin(MPI_File fh, void * buf, int count, MPI_Datatyp
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_write_ordered_begin, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype),
+        MPI_File_write_ordered_begin(fh, buf, count, datatype))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_write_ordered_begin, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype),
+#endif
-int MPI_File_iread(MPI_File fh, void * buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST * request)
+int DARSHAN_DECL(MPI_File_iread)(MPI_File fh, void * buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST * request)
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_iread);
-    ret = DARSHAN_MPI_CALL(PMPI_File_iread)(fh, buf, count, datatype, request);
+    ret = __real_PMPI_File_iread(fh, buf, count, datatype, request);
     MPIIO_PRE_RECORD();
@@ -624,20 +843,24 @@ int MPI_File_iread(MPI_File fh, void * buf, int count, MPI_Datatype datatype, __
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_iread, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST * request),
+        MPI_File_iread(fh, buf, count, datatype, request))
-int MPI_File_iwrite(MPI_File fh, const void * buf, int count,
+int DARSHAN_DECL(MPI_File_iwrite)(MPI_File fh, const void * buf, int count,
 #else
-int MPI_File_iwrite(MPI_File fh, void * buf, int count,
+int DARSHAN_DECL(MPI_File_iwrite)(MPI_File fh, void * buf, int count,
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_iwrite);
-    ret = DARSHAN_MPI_CALL(PMPI_File_iwrite)(fh, buf, count, datatype, request);
+    ret = __real_PMPI_File_iwrite(fh, buf, count, datatype, request);
     MPIIO_PRE_RECORD();
@@ -646,15 +869,26 @@ int MPI_File_iwrite(MPI_File fh, void * buf, int count,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_iwrite, int, (MPI_File fh, const void * buf, int count,
+    MPI_Datatype datatype, __D_MPI_REQUEST * request),
+        MPI_File_iwrite(fh, buf, count, datatype, request))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_iwrite, int, (MPI_File fh, void * buf, int count,
+#endif
-int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void * buf,
+int DARSHAN_DECL(MPI_File_iread_at)(MPI_File fh, MPI_Offset offset, void * buf,
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_iread_at);
-    ret = DARSHAN_MPI_CALL(PMPI_File_iread_at)(fh, offset, buf, count,
+    ret = __real_PMPI_File_iread_at(fh, offset, buf, count,
         datatype, request);
@@ -664,20 +898,25 @@ int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void * buf,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void * buf,
+    int count, MPI_Datatype datatype, __D_MPI_REQUEST *request),
+        MPI_File_iread_at(fh, offset,buf,count,datatype,request))
-int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, const void * buf,
+int DARSHAN_DECL(MPI_File_iwrite_at)(MPI_File fh, MPI_Offset offset, const void * buf,
 #else
-int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, void * buf,
+int DARSHAN_DECL(MPI_File_iwrite_at)(MPI_File fh, MPI_Offset offset, void * buf,
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_iwrite_at);
-    ret = DARSHAN_MPI_CALL(PMPI_File_iwrite_at)(fh, offset, buf,
+    ret = __real_PMPI_File_iwrite_at(fh, offset, buf,
@@ -687,15 +926,26 @@ int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, void * buf,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, const void * buf,
+        MPI_File_iwrite_at(fh, offset, buf, count, datatype, request))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, void * buf,
+#endif
-int MPI_File_iread_shared(MPI_File fh, void * buf, int count,
+int DARSHAN_DECL(MPI_File_iread_shared)(MPI_File fh, void * buf, int count,
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_iread_shared);
-    ret = DARSHAN_MPI_CALL(PMPI_File_iread_shared)(fh, buf, count,
+    ret = __real_PMPI_File_iread_shared(fh, buf, count,
         datatype, request);
@@ -705,20 +955,25 @@ int MPI_File_iread_shared(MPI_File fh, void * buf, int count,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_iread_shared, int, (MPI_File fh, void * buf, int count,
+        MPI_File_iread_shared(fh, buf, count, datatype, request))
-int MPI_File_iwrite_shared(MPI_File fh, const void * buf, int count,
+int DARSHAN_DECL(MPI_File_iwrite_shared)(MPI_File fh, const void * buf, int count,
 #else
-int MPI_File_iwrite_shared(MPI_File fh, void * buf, int count,
+int DARSHAN_DECL(MPI_File_iwrite_shared)(MPI_File fh, void * buf, int count,
 #endif
     int ret;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_iwrite_shared);
-    ret = DARSHAN_MPI_CALL(PMPI_File_iwrite_shared)(fh, buf, count,
+    ret = __real_PMPI_File_iwrite_shared(fh, buf, count,
         datatype, request);
@@ -728,15 +983,26 @@ int MPI_File_iwrite_shared(MPI_File fh, void * buf, int count,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_iwrite_shared, int, (MPI_File fh, const void * buf, int count,
+        MPI_File_iwrite_shared(fh, buf, count, datatype, request))
+#else
+DARSHAN_WRAPPER_MAP(PMPI_File_iwrite_shared, int, (MPI_File fh, void * buf, int count,
+#endif
-int MPI_File_sync(MPI_File fh)
+int DARSHAN_DECL(MPI_File_sync)(MPI_File fh)
     int ret;
     struct mpiio_file_record_ref *rec_ref;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_sync);
-    ret = DARSHAN_MPI_CALL(PMPI_File_sync)(fh);
+    ret = __real_PMPI_File_sync(fh);
     if(ret == MPI_SUCCESS)
@@ -756,12 +1022,13 @@ int MPI_File_sync(MPI_File fh)
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_sync, int, (MPI_File fh), MPI_File_sync(fh))
-int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
+int DARSHAN_DECL(MPI_File_set_view)(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
 #else
 #endif
@@ -769,8 +1036,10 @@ int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_set_view);
-    ret = DARSHAN_MPI_CALL(PMPI_File_set_view)(fh, disp, etype, filetype,
+    ret = __real_PMPI_File_set_view(fh, disp, etype, filetype,
         datarep, info);
@@ -795,16 +1064,25 @@ int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
+    MPI_Datatype filetype, const char *datarep, MPI_Info info), MPI_File_set_view(fh, disp, etype, filetype, datarep, info))
+#else
+    MPI_Datatype filetype, char *datarep, MPI_Info info), MPI_File_set_view(fh, disp, etype, filetype, datarep, info))
+#endif
-int MPI_File_close(MPI_File *fh)
+int DARSHAN_DECL(MPI_File_close)(MPI_File *fh)
     int ret;
     MPI_File tmp_fh = *fh;
     double tm1, tm2;
+    MAP_OR_FAIL(PMPI_File_close);
-    ret = DARSHAN_MPI_CALL(PMPI_File_close)(fh);
+    ret = __real_PMPI_File_close(fh);
     MPIIO_PRE_RECORD();
@@ -824,6 +1102,7 @@ int MPI_File_close(MPI_File *fh)
     return(ret);
+DARSHAN_WRAPPER_MAP(PMPI_File_close, int, (MPI_File *fh), MPI_File_close(fh))
  * Internal functions for manipulating MPI-IO module state *
@@ -1112,11 +1391,11 @@ static void mpiio_shared_record_variance(MPI_Comm mod_comm,
     struct darshan_variance_dt *var_send_buf = NULL;
     struct darshan_variance_dt *var_recv_buf = NULL;
-    DARSHAN_MPI_CALL(PMPI_Type_contiguous)(sizeof(struct darshan_variance_dt),
+    PMPI_Type_contiguous(sizeof(struct darshan_variance_dt),
         MPI_BYTE, &var_dt);
-    DARSHAN_MPI_CALL(PMPI_Type_commit)(&var_dt);
+    PMPI_Type_commit(&var_dt);
-    DARSHAN_MPI_CALL(PMPI_Op_create)(darshan_variance_reduce, 1, &var_op);
+    PMPI_Op_create(darshan_variance_reduce, 1, &var_op);
     var_send_buf = malloc(shared_rec_count * sizeof(struct darshan_variance_dt));
     if(!var_send_buf)
@@ -1141,7 +1420,7 @@ static void mpiio_shared_record_variance(MPI_Comm mod_comm,
                             inrec_array[i].fcounters[MPIIO_F_META_TIME];
-    DARSHAN_MPI_CALL(PMPI_Reduce)(var_send_buf, var_recv_buf, shared_rec_count,
+    PMPI_Reduce(var_send_buf, var_recv_buf, shared_rec_count,
         var_dt, var_op, 0, mod_comm);
     if(my_rank == 0)
@@ -1164,7 +1443,7 @@ static void mpiio_shared_record_variance(MPI_Comm mod_comm,
                             inrec_array[i].counters[MPIIO_BYTES_WRITTEN];
     if(my_rank == 0)
@@ -1176,8 +1455,8 @@ static void mpiio_shared_record_variance(MPI_Comm mod_comm,
-    DARSHAN_MPI_CALL(PMPI_Type_free)(&var_dt);
-    DARSHAN_MPI_CALL(PMPI_Op_free)(&var_op);
+    PMPI_Type_free(&var_dt);
+    PMPI_Op_free(&var_op);
     free(var_send_buf);
     free(var_recv_buf);
@@ -1370,15 +1649,15 @@ static void mpiio_shutdown(
         /* construct a datatype for a MPIIO file record.  This is serving no purpose
-        DARSHAN_MPI_CALL(PMPI_Type_contiguous)(sizeof(struct darshan_mpiio_file),
+        PMPI_Type_contiguous(sizeof(struct darshan_mpiio_file),
         /* register a MPIIO file record reduction operator */
-        DARSHAN_MPI_CALL(PMPI_Op_create)(mpiio_record_reduction_op, 1, &red_op);
+        PMPI_Op_create(mpiio_record_reduction_op, 1, &red_op);
         /* reduce shared MPIIO file records */
         /* get the time and byte variances for shared files */
@@ -1398,8 +1677,8 @@ static void mpiio_shutdown(
             mpiio_rec_count -= shared_rec_count;
     *mpiio_buf_sz = mpiio_rec_count * sizeof(struct darshan_mpiio_file);
darshan-runtime/lib/darshan-pnetcdf.c
--- a/darshan-runtime/lib/darshan-pnetcdf.c
+++ b/darshan-runtime/lib/darshan-pnetcdf.c
@@ -94,7 +94,7 @@ static int my_rank = -1;
         if(newpath != __path) free(newpath); \
         break; \
     if(rec_ref->file_rec->fcounters[PNETCDF_F_OPEN_TIMESTAMP] == 0) \
         rec_ref->file_rec->fcounters[PNETCDF_F_OPEN_TIMESTAMP] = __tm1; \
     if(comm_size == 1) rec_ref->file_rec->counters[PNETCDF_INDEP_OPENS] += 1; \
@@ -406,15 +406,15 @@ static void pnetcdf_shutdown(
         /* construct a datatype for a PNETCDF file record.  This is serving no purpose
-        DARSHAN_MPI_CALL(PMPI_Type_contiguous)(sizeof(struct darshan_pnetcdf_file),
+        PMPI_Type_contiguous(sizeof(struct darshan_pnetcdf_file),
         /* register a PNETCDF file record reduction operator */
-        DARSHAN_MPI_CALL(PMPI_Op_create)(pnetcdf_record_reduction_op, 1, &red_op);
+        PMPI_Op_create(pnetcdf_record_reduction_op, 1, &red_op);
         /* reduce shared PNETCDF file records */
@@ -430,8 +430,8 @@ static void pnetcdf_shutdown(
             pnetcdf_rec_count -= shared_rec_count;
darshan-runtime/lib/darshan-posix.c
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -1656,11 +1656,11 @@ static void posix_shared_record_variance(MPI_Comm mod_comm,
         MPI_BYTE, &var_dt);
     if(!var_send_buf)
@@ -1685,7 +1685,7 @@ static void posix_shared_record_variance(MPI_Comm mod_comm,
                             inrec_array[i].fcounters[POSIX_F_META_TIME];
     if(my_rank == 0)
@@ -1708,7 +1708,7 @@ static void posix_shared_record_variance(MPI_Comm mod_comm,
                             inrec_array[i].counters[POSIX_BYTES_WRITTEN];
     if(my_rank == 0)
@@ -1720,8 +1720,8 @@ static void posix_shared_record_variance(MPI_Comm mod_comm,
     free(var_send_buf);
     free(var_recv_buf);
@@ -1906,15 +1906,15 @@ static void posix_shutdown(
         /* construct a datatype for a POSIX file record.  This is serving no purpose
-        DARSHAN_MPI_CALL(PMPI_Type_contiguous)(sizeof(struct darshan_posix_file),
+        PMPI_Type_contiguous(sizeof(struct darshan_posix_file),
         /* register a POSIX file record reduction operator */
-        DARSHAN_MPI_CALL(PMPI_Op_create)(posix_record_reduction_op, 1, &red_op);
+        PMPI_Op_create(posix_record_reduction_op, 1, &red_op);
         /* reduce shared POSIX file records */
@@ -1934,8 +1934,8 @@ static void posix_shutdown(
             posix_rec_count -= shared_rec_count;
darshan-runtime/lib/darshan-stdio.c
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -1184,15 +1184,15 @@ static void stdio_shutdown(
         /* construct a datatype for a STDIO file record.  This is serving no purpose
-        DARSHAN_MPI_CALL(PMPI_Type_contiguous)(sizeof(struct darshan_stdio_file),
+        PMPI_Type_contiguous(sizeof(struct darshan_stdio_file),
         /* register a STDIO file record reduction operator */
-        DARSHAN_MPI_CALL(PMPI_Op_create)(stdio_record_reduction_op, 1, &red_op);
+        PMPI_Op_create(stdio_record_reduction_op, 1, &red_op);
         /* reduce shared STDIO file records */
@@ -1212,8 +1212,8 @@ static void stdio_shutdown(
             stdio_rec_count -= shared_rec_count;
     /* filter out any records that have no activity on them; this is
@@ -1323,11 +1323,11 @@ static void stdio_shared_record_variance(MPI_Comm mod_comm,
         MPI_BYTE, &var_dt);
     if(!var_send_buf)
@@ -1352,7 +1352,7 @@ static void stdio_shared_record_variance(MPI_Comm mod_comm,
                             inrec_array[i].fcounters[STDIO_F_META_TIME];
     if(my_rank == 0)
@@ -1375,7 +1375,7 @@ static void stdio_shared_record_variance(MPI_Comm mod_comm,
                             inrec_array[i].counters[STDIO_BYTES_WRITTEN];
     if(my_rank == 0)
@@ -1387,8 +1387,8 @@ static void stdio_shared_record_variance(MPI_Comm mod_comm,
     free(var_send_buf);
     free(var_recv_buf);
darshan-runtime/share/ld-opts/darshan-base-ld-opts.in
--- a/darshan-runtime/share/ld-opts/darshan-base-ld-opts.in
+++ b/darshan-runtime/share/ld-opts/darshan-base-ld-opts.in
@@ -1,6 +1,13 @@
 --undefined=MPI_Init
 --undefined=MPI_Wtime
+--wrap=MPI_Init
+--wrap=MPI_Init_thread
+--wrap=MPI_Finalize
+--wrap=PMPI_Init
+--wrap=PMPI_Init_thread
+--wrap=PMPI_Finalize
 @@darshan_share_path@/ld-opts/darshan-posix-ld-opts
 @@darshan_share_path@/ld-opts/darshan-pnetcdf-ld-opts
 @@darshan_share_path@/ld-opts/darshan-stdio-ld-opts
+@@darshan_share_path@/ld-opts/darshan-mpiio-ld-opts
 @DARSHAN_HDF5_LD_OPTS@
darshan-runtime/share/ld-opts/darshan-mpiio-ld-opts
--- /dev/null
+++ b/darshan-runtime/share/ld-opts/darshan-mpiio-ld-opts
@@ -0,0 +1,84 @@
+--wrap=MPI_File_close
+--wrap=MPI_File_iread_at
+--wrap=MPI_File_iread_shared
+--wrap=MPI_File_iwrite_at
+--wrap=MPI_File_iwrite_shared
+--wrap=MPI_File_open
+--wrap=MPI_File_read_all_begin
+--wrap=MPI_File_read_at_all
+--wrap=MPI_File_read_at_all_begin
+--wrap=MPI_File_read_ordered_begin
+--wrap=MPI_File_read_shared
+--wrap=MPI_File_set_view
+--wrap=MPI_File_sync
+--wrap=MPI_File_write_all_begin
+--wrap=MPI_File_write_at_all_begin
+--wrap=MPI_File_write_ordered_begin
+--wrap=MPI_File_write_shared
+--wrap=PMPI_File_close
+--wrap=PMPI_File_iread_at
+--wrap=PMPI_File_iread_shared
+--wrap=PMPI_File_iwrite_at
+--wrap=PMPI_File_iwrite_shared
+--wrap=PMPI_File_open
+--wrap=PMPI_File_read_all_begin
+--wrap=PMPI_File_read_at_all
+--wrap=PMPI_File_read_at_all_begin
+--wrap=PMPI_File_read_ordered_begin
+--wrap=PMPI_File_read_shared
+--wrap=PMPI_File_set_view
+--wrap=PMPI_File_sync
+--wrap=PMPI_File_write_all_begin
+--wrap=PMPI_File_write_at_all_begin
+--wrap=PMPI_File_write_ordered_begin
+--wrap=PMPI_File_write_shared
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/c7b5ac907c2cc0bb038b304e85541bc84ad523fd...48dbd2e8f97e54f3d48870b55440dc64e0c7ec64
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20171013/ca3c4465/attachment-0001.html>
More information about the Darshan-commits
