[Darshan-commits] [Git][darshan/darshan][dev-stdio-utils] update rest of darshan-job-summary for STDIO mod
Philip Carns
xgitlab at cels.anl.gov
Thu Sep 15 11:32:20 CDT 2016
Philip Carns pushed to branch dev-stdio-utils at darshan / darshan
Commits:
e7f180dc by Phil Carns at 2016-09-15T12:31:50-04:00
3 changed files:
- darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
- darshan-util/darshan-job-summary/share/file-access-eps.gplt
- darshan-util/darshan-job-summary/share/file-access-table.tex
Changes:
--- a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
+++ b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
@@ -211,7 +211,7 @@ while($line = <PARSE_OUT>)
$summary{$fields[3]} += $fields[4];
# accumulate independent and shared data as well as fs data
- if ($fields[3] eq "POSIX_F_READ_TIME")
+ if ($fields[3] eq "POSIX_F_READ_TIME" || $fields[3] eq "STDIO_F_READ_TIME")
if ($fields[1] == -1)
@@ -222,7 +222,7 @@ while($line = <PARSE_OUT>)
$cumul_read_indep += $fields[4];
- elsif ($fields[3] eq "POSIX_F_WRITE_TIME")
+ elsif ($fields[3] eq "POSIX_F_WRITE_TIME" || $fields[3] eq "STDIO_F_WRITE_TIME")
@@ -233,7 +233,7 @@ while($line = <PARSE_OUT>)
$cumul_write_indep += $fields[4];
- elsif ($fields[3] eq "POSIX_F_META_TIME")
+ elsif ($fields[3] eq "POSIX_F_META_TIME" || $fields[3] eq "STDIO_F_META_TIME")
@@ -244,7 +244,7 @@ while($line = <PARSE_OUT>)
$cumul_meta_indep += $fields[4];
- elsif ($fields[3] eq "POSIX_BYTES_READ")
+ elsif ($fields[3] eq "POSIX_BYTES_READ" || $fields[3] eq "STDIO_BYTES_READ")
@@ -260,7 +260,7 @@ while($line = <PARSE_OUT>)
$fs_data{$fields[6]}->[0] += $fields[4];
- elsif ($fields[3] eq "POSIX_BYTES_WRITTEN")
+ elsif ($fields[3] eq "POSIX_BYTES_WRITTEN" || $fields[3] eq "STDIO_BYTES_WRITTEN")
@@ -278,12 +278,13 @@ while($line = <PARSE_OUT>)
# record start and end of reads and writes
- elsif ($fields[3] eq "POSIX_F_READ_START_TIMESTAMP")
+ elsif ($fields[3] eq "POSIX_F_READ_START_TIMESTAMP" ||
+ $fields[3] eq "STDIO_F_READ_START_TIMESTAMP")
# store until we find the end
$last_read_start = $fields[4];
- elsif ($fields[3] eq "POSIX_F_READ_END_TIMESTAMP" && $fields[4] != 0)
+ elsif (($fields[3] eq "POSIX_F_READ_END_TIMESTAMP" || $fields[3] eq "STDIO_F_READ_END_TIMESTAMP") && $fields[4] != 0)
# assume we got the read start already
my $xdelta = $fields[4] - $last_read_start;
@@ -296,12 +297,13 @@ while($line = <PARSE_OUT>)
print FA_READ "$last_read_start\t$fields[1]\t$xdelta\t0\n";
- elsif ($fields[3] eq "POSIX_F_WRITE_START_TIMESTAMP")
+ elsif ($fields[3] eq "POSIX_F_WRITE_START_TIMESTAMP" ||
+ $fields[3] eq "STDIO_F_WRITE_START_TIMESTAMP")
$last_write_start = $fields[4];
- elsif ($fields[3] eq "POSIX_F_WRITE_END_TIMESTAMP" && $fields[4] != 0)
+ elsif (($fields[3] eq "POSIX_F_WRITE_END_TIMESTAMP" || $fields[3] eq "STDIO_F_WRITE_END_TIMESTAMP") && $fields[4] != 0)
# assume we got the write start already
my $xdelta = $fields[4] - $last_write_start;
@@ -877,7 +879,7 @@ open(FS_TABLE, ">$tmp_dir/fs-data-table.tex") || die("error opening output files
print FS_TABLE "
\\begin{tabular}{c|r|r|r|r}
\\multicolumn{5}{c}{ } \\\\
-\\multicolumn{5}{c}{Data Transfer Per Filesystem (POSIX)} \\\\
+\\multicolumn{5}{c}{Data Transfer Per Filesystem (POSIX and STDIO)} \\\\
\\hline
\\multirow{2}{*}{File System} \& \\multicolumn{2}{c}{Write} \\vline \& \\multicolumn{2}{c}{Read} \\\\
\\cline{2-5}
@@ -926,7 +928,7 @@ open(VAR_TABLE, ">$tmp_dir/variance-table.tex") || die("error opening output fil
print VAR_TABLE "
\\begin{tabular}{c|r|r|r|r|r|r|r|r|r}
\\multicolumn{10}{c}{} \\\\
-\\multicolumn{10}{c}{Variance in Shared Files (POSIX)} \\\\
+\\multicolumn{10}{c}{Variance in Shared Files (POSIX and STDIO)} \\\\
\\hline
File \& Processes \& \\multicolumn{3}{c}{Fastest} \\vline \&
\\multicolumn{3}{c}{Slowest} \\vline \& \\multicolumn{2}{c}{\$\\sigma\$} \\\\
--- a/darshan-util/darshan-job-summary/share/file-access-eps.gplt
+++ b/darshan-util/darshan-job-summary/share/file-access-eps.gplt
@@ -8,7 +8,7 @@ set xdata time
set timefmt "%s"
set format x "%H:%M:%S"
set yrange [-1:ymax]
-set title "Timespan from first to last read access on independent files (POSIX)"
+set title "Timespan from first to last read access on independent files (POSIX and STDIO)"
set xrange ["0":runtime]
set ytics 0,yinc,ymaxtic
set lmargin 6
@@ -25,7 +25,7 @@ set style increment user
plot "file-access-read.dat" using 1:2:3:4 with vectors nohead filled notitle
set output "file-access-write.eps"
-set title "Timespan from first to last write access on independent files (POSIX)"
+set title "Timespan from first to last write access on independent files (POSIX and STDIO)"
# lw 3 to make lines thicker...
plot "file-access-write.dat" using 1:2:3:4 with vectors nohead filled lt 2 notitle
@@ -34,7 +34,7 @@ set output "file-access-shared.eps"
unset ytics
set ylabel "All processes"
set yrange [-1:1]
-set title "Timespan from first to last access on files shared by all processes (POSIX)"
+set title "Timespan from first to last access on files shared by all processes (POSIX and STDIO)"
plot "file-access-read-sh.dat" using 1:2:3:4 with vectors nohead filled lw 10 title "read", \
"file-access-write-sh.dat" using 1:(($2)-.2):3:4 with vectors nohead filled lw 10 title "write"
--- a/darshan-util/darshan-job-summary/share/file-access-table.tex
+++ b/darshan-util/darshan-job-summary/share/file-access-table.tex
@@ -1,5 +1,5 @@
\begin{tabular}{l|p{1.7in}r}
-\multicolumn{3}{c}{Average I/O per process (POSIX)} \\
+\multicolumn{3}{c}{Average I/O per process (POSIX and STDIO)} \\
\hline
& Cumulative time spent in I/O functions (seconds) & Amount of I/O (MB) \\
\hline
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/e7f180dc028cb1ea34cf01d2225feeac99467912
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160915/b1659b31/attachment-0001.html>
More information about the Darshan-commits
