[Darshan-commits] [Git][darshan/darshan][dev-stdio-utils] get file count summary working with stdio
Philip Carns xgitlab at cels.anl.gov
Thu Sep 15 11:16:27 CDT 2016
Philip Carns pushed to branch dev-stdio-utils at darshan / darshan
Commits:
715368e5 by Phil Carns at 2016-09-15T12:16:03-04:00
1 changed file:
- darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
Changes:
--- a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
+++ b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
@@ -1151,14 +1151,14 @@ sub process_file_record
     my(%file_record) = %{$_[1]};
     my $rank = $file_record{'RANK'};
-    if(!defined $file_record{'POSIX_OPENS'})
+    if(!defined $file_record{'POSIX_OPENS'} && !defined $file_record{'STDIO_OPENS'})
         # ignore data records that don't have POSIX & MPI data
         return;
-    if($file_record{'POSIX_OPENS'} == 0 &&
-        (!defined $file_record{'STDIO_OPENS'}) &&
+    if((!defined $file_record{'POSIX_OPENS'} || $file_record{'POSIX_OPENS'} == 0) &&
+        (!defined $file_record{'STDIO_OPENS'} || $file_record{'STDIO_OPENS'} == 0) &&
         (!defined $file_record{'MPIIO_INDEP_OPENS'} ||
         ($file_record{'MPIIO_INDEP_OPENS'} == 0 && $file_record{'MPIIO_COLL_OPENS'} == 0)))
@@ -1171,19 +1171,41 @@ sub process_file_record
     $hash_files{$hash}{'min_open_size'} = 0;
     # record largest size that the file reached at any rank
-    if(!defined($hash_files{$hash}{'max_size'}) ||
-        $hash_files{$hash}{'max_size'} <
-        ($file_record{'POSIX_MAX_BYTE_READ'} + 1))
+    if(defined $file_record{'POSIX_OPENS'})
-        $hash_files{$hash}{'max_size'} =
-            $file_record{'POSIX_MAX_BYTE_READ'} + 1;
+        if(!defined($hash_files{$hash}{'max_size'}) ||
+            $hash_files{$hash}{'max_size'} <
+            ($file_record{'POSIX_MAX_BYTE_READ'} + 1))
+            $hash_files{$hash}{'max_size'} =
+                $file_record{'POSIX_MAX_BYTE_READ'} + 1;
+            ($file_record{'POSIX_MAX_BYTE_WRITTEN'} + 1))
+                $file_record{'POSIX_MAX_BYTE_WRITTEN'} + 1;
-        ($file_record{'POSIX_MAX_BYTE_WRITTEN'} + 1))
+    # for stdio as well
+    if(defined $file_record{'STDIO_OPENS'})
-            $file_record{'POSIX_MAX_BYTE_WRITTEN'} + 1;
+            ($file_record{'STDIO_MAX_BYTE_READ'} + 1))
+                $file_record{'STDIO_MAX_BYTE_READ'} + 1;
+            ($file_record{'STDIO_MAX_BYTE_WRITTEN'} + 1))
+                $file_record{'STDIO_MAX_BYTE_WRITTEN'} + 1;
     # make sure there is an initial value for read and write flags
@@ -1221,12 +1243,12 @@ sub process_file_record
     else
         # posix file
-        if($file_record{'POSIX_READS'} > 0)
+        if((defined $file_record{'POSIX_READS'} && $file_record{'POSIX_READS'} > 0) || (defined $file_record{'STDIO_READS'} && $file_record{'STDIO_READS'} > 0))
             # data was read from the file
             $hash_files{$hash}{'was_read'} = 1;
-        if($file_record{'POSIX_WRITES'} > 0)
+        if((defined $file_record{'POSIX_WRITES'} && $file_record{'POSIX_WRITES'} > 0) || (defined $file_record{'STDIO_WRITES'} && $file_record{'STDIO_WRITES'} > 0))
             # data was written to the file
             $hash_files{$hash}{'was_written'} = 1;
@@ -1237,24 +1259,52 @@ sub process_file_record
     if ($rank == -1)
-        $hash_files{$hash}{'procs'}          = $nprocs;
-        $hash_files{$hash}{'slowest_rank'}   = $file_record{'POSIX_SLOWEST_RANK'};
-        $hash_files{$hash}{'slowest_time'}   = $file_record{'POSIX_F_SLOWEST_RANK_TIME'};
-        $hash_files{$hash}{'slowest_bytes'}  = $file_record{'POSIX_SLOWEST_RANK_BYTES'};
-        $hash_files{$hash}{'fastest_rank'}   = $file_record{'POSIX_FASTEST_RANK'};
-        $hash_files{$hash}{'fastest_time'}   = $file_record{'POSIX_F_FASTEST_RANK_TIME'};
-        $hash_files{$hash}{'fastest_bytes'}  = $file_record{'POSIX_FASTEST_RANK_BYTES'};
-        $hash_files{$hash}{'variance_time'}  = $file_record{'POSIX_F_VARIANCE_RANK_TIME'};
-        $hash_files{$hash}{'variance_bytes'} = $file_record{'POSIX_F_VARIANCE_RANK_BYTES'};
+        if(defined $file_record{'POSIX_OPENS'} && $file_record{'POSIX_OPENS'} > 0)
+            $hash_files{$hash}{'procs'}          = $nprocs;
+            $hash_files{$hash}{'slowest_rank'}   = $file_record{'POSIX_SLOWEST_RANK'};
+            $hash_files{$hash}{'slowest_time'}   = $file_record{'POSIX_F_SLOWEST_RANK_TIME'};
+            $hash_files{$hash}{'slowest_bytes'}  = $file_record{'POSIX_SLOWEST_RANK_BYTES'};
+            $hash_files{$hash}{'fastest_rank'}   = $file_record{'POSIX_FASTEST_RANK'};
+            $hash_files{$hash}{'fastest_time'}   = $file_record{'POSIX_F_FASTEST_RANK_TIME'};
+            $hash_files{$hash}{'fastest_bytes'}  = $file_record{'POSIX_FASTEST_RANK_BYTES'};
+            $hash_files{$hash}{'variance_time'}  = $file_record{'POSIX_F_VARIANCE_RANK_TIME'};
+            $hash_files{$hash}{'variance_bytes'} = $file_record{'POSIX_F_VARIANCE_RANK_BYTES'};
+        elsif(defined $file_record{'STDIO_OPENS'} && $file_record{'STDIO_OPENS'} > 0)
+            $hash_files{$hash}{'slowest_rank'}   = $file_record{'STDIO_SLOWEST_RANK'};
+            $hash_files{$hash}{'slowest_time'}   = $file_record{'STDIO_F_SLOWEST_RANK_TIME'};
+            $hash_files{$hash}{'slowest_bytes'}  = $file_record{'STDIO_SLOWEST_RANK_BYTES'};
+            $hash_files{$hash}{'fastest_rank'}   = $file_record{'STDIO_FASTEST_RANK'};
+            $hash_files{$hash}{'fastest_time'}   = $file_record{'STDIO_F_FASTEST_RANK_TIME'};
+            $hash_files{$hash}{'fastest_bytes'}  = $file_record{'STDIO_FASTEST_RANK_BYTES'};
+            $hash_files{$hash}{'variance_time'}  = $file_record{'STDIO_F_VARIANCE_RANK_TIME'};
+            $hash_files{$hash}{'variance_bytes'} = $file_record{'STDIO_F_VARIANCE_RANK_BYTES'};
     else
-        my $total_time = $file_record{'POSIX_F_META_TIME'} +
+        my $total_time = 0;
+        my $total_bytes = 0;
+            $total_time += $file_record{'POSIX_F_META_TIME'} +
                          $file_record{'POSIX_F_READ_TIME'} +
                          $file_record{'POSIX_F_WRITE_TIME'};
-        my $total_bytes = $file_record{'POSIX_BYTES_READ'} +
+            $total_bytes += $file_record{'POSIX_BYTES_READ'} +
                           $file_record{'POSIX_BYTES_WRITTEN'};
+            $total_time += $file_record{'STDIO_F_META_TIME'} +
+                         $file_record{'STDIO_F_READ_TIME'} +
+                         $file_record{'STDIO_F_WRITE_TIME'};
+            $total_bytes += $file_record{'STDIO_BYTES_READ'} +
+                          $file_record{'STDIO_BYTES_WRITTEN'};
         if(!defined($hash_files{$hash}{'slowest_time'}) ||
            $hash_files{$hash}{'slowest_time'} < $total_time)
@@ -1336,20 +1386,41 @@ sub process_file_record
         else
-            # add up posix times
-            if(defined($hash_unique_file_time{$rank}))
+            if(defined($file_record{POSIX_OPENS}))
-                $hash_unique_file_time{$rank} +=
-                    $file_record{POSIX_F_META_TIME} +
-                    $file_record{POSIX_F_READ_TIME} +
-                    $file_record{POSIX_F_WRITE_TIME};
+                # add up posix times
+                if(defined($hash_unique_file_time{$rank}))
+                    $hash_unique_file_time{$rank} +=
+                        $file_record{POSIX_F_META_TIME} +
+                        $file_record{POSIX_F_READ_TIME} +
+                        $file_record{POSIX_F_WRITE_TIME};
+                else
+                    $hash_unique_file_time{$rank} =
-            else
+            if(defined($file_record{STDIO_OPENS}))
-                $hash_unique_file_time{$rank} =
+                        $file_record{STDIO_F_META_TIME} +
+                        $file_record{STDIO_F_READ_TIME} +
+                        $file_record{STDIO_F_WRITE_TIME};
+                else
@@ -1365,7 +1436,14 @@ sub process_file_record
         else
-            $shared_file_time += $file_record{'POSIX_F_SLOWEST_RANK_TIME'};
+                $shared_file_time += $file_record{'POSIX_F_SLOWEST_RANK_TIME'};
+                $shared_file_time += $file_record{'STDIO_F_SLOWEST_RANK_TIME'};
@@ -1391,8 +1469,16 @@ sub process_file_record
     else
         # normal case
-        $total_job_bytes += $file_record{'POSIX_BYTES_WRITTEN'} +
-            $file_record{'POSIX_BYTES_READ'};
+            $total_job_bytes += $file_record{'POSIX_BYTES_WRITTEN'} +
+                $file_record{'POSIX_BYTES_READ'};
+            $total_job_bytes += $file_record{'STDIO_BYTES_WRITTEN'} +
+            $file_record{'STDIO_BYTES_READ'};
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/715368e51a2b65143592710f3ee6403b59e45f9f
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160915/d4e5fab5/attachment-0001.html>
More information about the Darshan-commits mailing list
