[Darshan-commits] [Git][darshan/darshan][master] 3 commits: fix typos in fortran env vars in runtime docs
Shane Snyder xgitlab at cels.anl.gov
Fri May 13 10:45:12 CDT 2016
Shane Snyder pushed to branch master at darshan / darshan
Commits:
4f1dbfc7 by Shane Snyder at 2016-05-12T09:49:38-05:00
f75b4349 by Shane Snyder at 2016-05-12T17:13:29-05:00
fortran compiler generator autodetects mpich libs
this functionality is helpful especially on mira/cetus where
the mpich libraries are named depending on the fortran version
and the type of compiler being used (gcc, xl, etc.).
b41c9d63 by Shane Snyder at 2016-05-13T10:38:56-05:00
cxx compiler generators autodetect mpich lib name
3 changed files:
- darshan-runtime/darshan-gen-cxx.pl.in
- darshan-runtime/darshan-gen-fortran.pl.in
- darshan-runtime/doc/darshan-runtime.txt
Changes:
--- a/darshan-runtime/darshan-gen-cxx.pl.in
+++ b/darshan-runtime/darshan-gen-cxx.pl.in
@@ -282,6 +282,10 @@ print OUTPUT<<"EOF";
     if [ \$? -eq 0 ] ; then
         CXXMPICH=-lmpicxx
     fi
+    bgqlib_out=`grep -m 1 -Po "libmpichcxx-\\S+" \$tmpfile`
+    if [ \$? -eq 0 ] ; then
+        CXXMPICH=`echo \$bgqlib_out | sed 's/libmpichcxx-\\(.*\\)\\.a.*/-lmpichcxx-\\1/'`
+    fi
     rm \$tmpfile >& /dev/null
--- a/darshan-runtime/darshan-gen-fortran.pl.in
+++ b/darshan-runtime/darshan-gen-fortran.pl.in
@@ -287,7 +287,13 @@ print OUTPUT<<"EOF";
         if [ \$rc_cnk_check -eq 0 ] ; then
             FMPICH=-lfmpich.cnk
         else
-            FMPICH=-lfmpich
+            bgqlib_out=`grep -Po "libmpichf\\S\+\-\\S\+" \$tmpfile 2>/dev/null`
+            rc_bgqlib_check=\$?
+            if [ \$rc_bgqlib_check -eq 0 ] ; then
+                FMPICH=`echo \$bgqlib_out | sed 's/libmpich\\(.*\\)-\\(.*\\).a/-lmpich\\1-\\2/'`
+            else
+                FMPICH=-lfmpich
+            fi
         fi
     fi
--- a/darshan-runtime/doc/darshan-runtime.txt
+++ b/darshan-runtime/doc/darshan-runtime.txt
@@ -169,8 +169,8 @@ Example for MPICH 3.1 or earlier:
 export MPICC_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-cc
 export MPICXX_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-cxx
-export MPICF77_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-f
-export MPICF90_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-f
+export MPIF77_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-f
+export MPIF90_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-f
 Examples for command line use:
@@ -313,8 +313,8 @@ Blue Gene profiling configuration example:
 export MPICC_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-bg-cc
 export MPICXX_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-bg-cxx
-export MPICF77_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-bg-f
-export MPICF90_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-bg-f
+export MPIF77_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-bg-f
+export MPIF90_PROFILE=$DARSHAN_PREFIX/share/mpi-profile/darshan-bg-f
 === Cray platforms (XE, XC, or similar)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/a3b2cfb9aaa057df2487149025b2a0fd0b67d9a1...b41c9d63248117c83c5c6165b39e77403d3277dc
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160513/4a3945d1/attachment.html>
More information about the Darshan-commits mailing list
