[Darshan-commits] [Git][darshan/darshan][dev-stdio] move fseek wrapper to stdio module
Philip Carns
xgitlab at cels.anl.gov
Sun May 1 09:32:31 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
91092ee1 by Phil Carns at 2016-05-01T10:32:14-04:00
7 changed files:
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-posix-ld-opts
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
- darshan-stdio-log-format.h
- darshan-test/regression/test-cases/stdio-test.sh
- darshan-util/darshan-stdio-logutils.c
Changes:
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -57,7 +57,6 @@ DARSHAN_FORWARD_DECL(readv, ssize_t, (int fd, const struct iovec *iov, int iovcn
DARSHAN_FORWARD_DECL(writev, ssize_t, (int fd, const struct iovec *iov, int iovcnt));
DARSHAN_FORWARD_DECL(lseek, off_t, (int fd, off_t offset, int whence));
DARSHAN_FORWARD_DECL(lseek64, off64_t, (int fd, off64_t offset, int whence));
-DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
DARSHAN_FORWARD_DECL(__xstat, int, (int vers, const char* path, struct stat *buf));
DARSHAN_FORWARD_DECL(__xstat64, int, (int vers, const char* path, struct stat64 *buf));
DARSHAN_FORWARD_DECL(__lxstat, int, (int vers, const char* path, struct stat *buf));
@@ -787,37 +786,6 @@ off_t DARSHAN_DECL(lseek64)(int fd, off_t offset, int whence)
return(ret);
-int DARSHAN_DECL(fseek)(FILE *stream, long offset, int whence)
- int ret;
- struct posix_file_runtime* file;
- double tm1, tm2;
- MAP_OR_FAIL(fseek);
- tm1 = darshan_core_wtime();
- ret = __real_fseek(stream, offset, whence);
- tm2 = darshan_core_wtime();
- if(ret >= 0)
- POSIX_LOCK();
- posix_runtime_initialize();
- file = posix_file_by_fd(fileno(stream));
- if(file)
- file->offset = ftell(stream);
- DARSHAN_TIMER_INC_NO_OVERLAP(
- file->file_record->fcounters[POSIX_F_META_TIME],
- tm1, tm2, file->last_meta_end);
- file->file_record->counters[POSIX_FSEEKS] += 1;
- POSIX_UNLOCK();
- return(ret);
int DARSHAN_DECL(__xstat)(int vers, const char *path, struct stat *buf)
int ret;
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -36,6 +36,7 @@ DARSHAN_FORWARD_DECL(fopen64, FILE*, (const char *path, const char *mode));
DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
+DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
/* The stdio_file_runtime structure maintains necessary runtime metadata
* for the STDIO file record (darshan_stdio_record structure, defined in
@@ -306,6 +307,37 @@ size_t DARSHAN_DECL(fread)(void *ptr, size_t size, size_t nmemb, FILE *stream)
return(ret);
+int DARSHAN_DECL(fseek)(FILE *stream, long offset, int whence)
+ int ret;
+ struct stdio_file_runtime* file;
+ double tm1, tm2;
+ MAP_OR_FAIL(fseek);
+ tm1 = darshan_core_wtime();
+ ret = __real_fseek(stream, offset, whence);
+ tm2 = darshan_core_wtime();
+ if(ret >= 0)
+ STDIO_LOCK();
+ stdio_runtime_initialize();
+ file = stdio_file_by_stream(stream);
+ if(file)
+ file->offset = ftell(stream);
+ DARSHAN_TIMER_INC_NO_OVERLAP(
+ file->file_record->fcounters[STDIO_F_META_TIME],
+ tm1, tm2, file->last_meta_end);
+ file->file_record->counters[STDIO_SEEKS] += 1;
+ STDIO_UNLOCK();
+ return(ret);
* Internal functions for manipulating STDIO module state *
--- a/darshan-runtime/share/ld-opts/darshan-posix-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-posix-ld-opts
@@ -16,7 +16,6 @@
--wrap=writev
--wrap=lseek
--wrap=lseek64
---wrap=fseek
--wrap=__xstat
--wrap=__xstat64
--wrap=__lxstat
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -4,3 +4,4 @@
--wrap=fclose
--wrap=fwrite
--wrap=fread
+--wrap=fseek
--- a/darshan-stdio-log-format.h
+++ b/darshan-stdio-log-format.h
@@ -48,7 +48,7 @@
* functions for changing file position
- * int fseek(FILE *, long int, int);
+ * int fseek(FILE *, long int, int); DONE
* int fseeko(FILE *, off_t, int);
* int fsetpos(FILE *, const fpos_t *);
* void rewind(FILE *);
@@ -64,12 +64,14 @@
X(STDIO_BYTES_WRITTEN) \
/* number of writes */ \
X(STDIO_WRITES) \
- /* maximum byte (offset) written */\
+ /* maximum byte (offset) read */\
X(STDIO_MAX_BYTE_READ) \
- /* total bytes written */ \
+ /* total bytes read */ \
X(STDIO_BYTES_READ) \
- /* number of writes */ \
+ /* number of reads */ \
X(STDIO_READS) \
+ /* count of seeks */\
+ X(STDIO_SEEKS) \
/* end of counters */\
X(STDIO_NUM_INDICES)
--- a/darshan-test/regression/test-cases/stdio-test.sh
+++ b/darshan-test/regression/test-cases/stdio-test.sh
@@ -33,12 +33,18 @@ fi
# check results
-# in this case we want to confirm that the STDIO counters were triggered
+# check at least one counter from each general open/read/write/seek category
STDIO_OPENS=`grep STDIO_OPENS $DARSHAN_TMP/${PROG}.darshan.txt |head -n 1 |cut -f 5`
if [ ! "$STDIO_OPENS" -gt 0 ]; then
echo "Error: STDIO open count of $STDIO_OPENS is incorrect" 1>&2
exit 1
fi
+STDIO_SEEKS=`grep STDIO_SEEKS $DARSHAN_TMP/${PROG}.darshan.txt |head -n 1 |cut -f 5`
+if [ ! "$STDIO_SEEKS" -gt 0 ]; then
+ echo "Error: STDIO open count of $STDIO_SEEKS is incorrect" 1>&2
+ exit 1
+fi
STDIO_BYTES_WRITTEN=`grep STDIO_BYTES_WRITTEN $DARSHAN_TMP/${PROG}.darshan.txt |head -n 1 |cut -f 5`
if [ ! "$STDIO_BYTES_WRITTEN" -eq 6 ]; then
echo "Error: STDIO open count of $STDIO_BYTES_WRITTEN is incorrect" 1>&2
--- a/darshan-util/darshan-stdio-logutils.c
+++ b/darshan-util/darshan-stdio-logutils.c
@@ -143,7 +143,7 @@ static void darshan_log_print_stdio_record(void *file_rec, char *file_name,
static void darshan_log_print_stdio_description()
printf("\n# description of STDIO counters:\n");
- printf("# STDIO_{OPENS|WRITES|READS} are types of operations.\n");
+ printf("# STDIO_{OPENS|WRITES|READS|SEEKS} are types of operations.\n");
printf("# STDIO_BYTES_*: total bytes read and written.\n");
printf("# STDIO_MAX_BYTE_*: highest offset byte read and written.\n");
printf("# STDIO_F_*_START_TIMESTAMP: timestamp of the first call to that type of function.\n");
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/91092ee14a7a54a97b6622602893ea05170a58c3
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160501/7596dd90/attachment.html>
More information about the Darshan-commits
