[Darshan-commits] [Git][darshan/darshan][dev-stdio] move fread wrapper to stdio module
Philip Carns xgitlab at cels.anl.gov
Sun May 1 09:21:33 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
da685755 by Phil Carns at 2016-05-01T10:21:19-04:00
8 changed files:
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-posix-ld-opts
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
- darshan-stdio-log-format.h
- darshan-test/regression/test-cases/src/stdio-test.c
- darshan-test/regression/test-cases/stdio-test.sh
- darshan-util/darshan-stdio-logutils.c
Changes:
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -55,7 +55,6 @@ DARSHAN_FORWARD_DECL(pread64, ssize_t, (int fd, void *buf, size_t count, off64_t
 DARSHAN_FORWARD_DECL(pwrite64, ssize_t, (int fd, const void *buf, size_t count, off64_t offset));
 DARSHAN_FORWARD_DECL(readv, ssize_t, (int fd, const struct iovec *iov, int iovcnt));
 DARSHAN_FORWARD_DECL(writev, ssize_t, (int fd, const struct iovec *iov, int iovcnt));
-DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
 DARSHAN_FORWARD_DECL(lseek, off_t, (int fd, off_t offset, int whence));
 DARSHAN_FORWARD_DECL(lseek64, off64_t, (int fd, off64_t offset, int whence));
 DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
@@ -726,37 +725,6 @@ ssize_t DARSHAN_DECL(writev)(int fd, const struct iovec *iov, int iovcnt)
     return(ret);
-size_t DARSHAN_DECL(fread)(void *ptr, size_t size, size_t nmemb, FILE *stream)
-    size_t ret;
-    int aligned_flag = 0;
-    double tm1, tm2;
-    MAP_OR_FAIL(fread);
-    if((unsigned long)ptr % darshan_mem_alignment == 0) aligned_flag = 1;
-    tm1 = darshan_core_wtime();
-    ret = __real_fread(ptr, size, nmemb, stream);
-    tm2 = darshan_core_wtime();
-    POSIX_LOCK();
-    posix_runtime_initialize();
-    if(ret > 0)
-        POSIX_RECORD_READ(size*ret, fileno(stream), 0, 0,
-            aligned_flag, 1, tm1, tm2);
-    else
-        POSIX_RECORD_READ(ret, fileno(stream), 0, 0,
-    POSIX_UNLOCK();
-    return(ret);
 off_t DARSHAN_DECL(lseek)(int fd, off_t offset, int whence)
     off_t ret;
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -35,6 +35,7 @@ DARSHAN_FORWARD_DECL(fopen, FILE*, (const char *path, const char *mode));
 DARSHAN_FORWARD_DECL(fopen64, FILE*, (const char *path, const char *mode));
 DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
 DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
+DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
 /* The stdio_file_runtime structure maintains necessary runtime metadata
  * for the STDIO file record (darshan_stdio_record structure, defined in
@@ -64,8 +65,6 @@ struct stdio_file_runtime
     /* TODO: make sure we need/want all of these fields */
     struct darshan_stdio_record* file_record;
     int64_t offset;
-    int64_t last_byte_read;
-    int64_t last_byte_written;
     enum darshan_io_type last_io_type;
     double last_meta_end;
     double last_read_end;
@@ -153,8 +152,6 @@ static void stdio_shutdown(void);
     file = stdio_file_by_name_setstream(__path, __ret); \
     if(!file) break; \
     file->offset = 0; \
-    file->last_byte_written = 0; \
-    file->last_byte_read = 0; \
     file->file_record->counters[STDIO_OPENS] += 1; \
     if(file->file_record->fcounters[STDIO_F_OPEN_START_TIMESTAMP] == 0 || \
      file->file_record->fcounters[STDIO_F_OPEN_START_TIMESTAMP] > __tm1) \
@@ -164,13 +161,30 @@ static void stdio_shutdown(void);
 } while(0)
+#define STDIO_RECORD_READ(__fp, __bytes,  __tm1, __tm2) do{ \
+    int64_t this_offset; \
+    struct stdio_file_runtime* file; \
+    file = stdio_file_by_stream(__fp); \
+    if(!file) break; \
+    this_offset = file->offset; \
+    file->offset = this_offset + __bytes; \
+    if(file->file_record->counters[STDIO_MAX_BYTE_READ] < (this_offset + __bytes - 1)) \
+        file->file_record->counters[STDIO_MAX_BYTE_READ] = (this_offset + __bytes - 1); \
+    file->file_record->counters[STDIO_BYTES_READ] += __bytes; \
+    file->file_record->counters[STDIO_READS] += 1; \
+    if(file->file_record->fcounters[STDIO_F_READ_START_TIMESTAMP] == 0 || \
+     file->file_record->fcounters[STDIO_F_READ_START_TIMESTAMP] > __tm1) \
+        file->file_record->fcounters[STDIO_F_READ_START_TIMESTAMP] = __tm1; \
+    file->file_record->fcounters[STDIO_F_READ_END_TIMESTAMP] = __tm2; \
+    DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[STDIO_F_READ_TIME], __tm1, __tm2, file->last_write_end); \
+} while(0)
 #define STDIO_RECORD_WRITE(__fp, __bytes,  __tm1, __tm2) do{ \
     if(!file) break; \
-    file->last_byte_written = this_offset + __bytes - 1; \
     if(file->file_record->counters[STDIO_MAX_BYTE_WRITTEN] < (this_offset + __bytes - 1)) \
         file->file_record->counters[STDIO_MAX_BYTE_WRITTEN] = (this_offset + __bytes - 1); \
@@ -238,8 +252,6 @@ int DARSHAN_DECL(fclose)(FILE *fp)
     file = stdio_file_by_stream(fp);
     if(file)
         if(file->file_record->fcounters[STDIO_F_CLOSE_START_TIMESTAMP] == 0 ||
          file->file_record->fcounters[STDIO_F_CLOSE_START_TIMESTAMP] > tm1)
            file->file_record->fcounters[STDIO_F_CLOSE_START_TIMESTAMP] = tm1;
@@ -274,6 +286,26 @@ size_t DARSHAN_DECL(fwrite)(const void *ptr, size_t size, size_t nmemb, FILE *st
     return(ret);
+size_t DARSHAN_DECL(fread)(void *ptr, size_t size, size_t nmemb, FILE *stream)
+    size_t ret;
+    double tm1, tm2;
+    MAP_OR_FAIL(fread);
+    tm1 = darshan_core_wtime();
+    ret = __real_fread(ptr, size, nmemb, stream);
+    tm2 = darshan_core_wtime();
+    STDIO_LOCK();
+    stdio_runtime_initialize();
+    if(ret > 0)
+        STDIO_RECORD_READ(stream, size*ret, tm1, tm2);
+    STDIO_UNLOCK();
+    return(ret);
  * Internal functions for manipulating STDIO module state *
--- a/darshan-runtime/share/ld-opts/darshan-posix-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-posix-ld-opts
@@ -14,7 +14,6 @@
 --wrap=pwrite64
 --wrap=readv
 --wrap=writev
---wrap=fread
 --wrap=lseek
 --wrap=lseek64
 --wrap=fseek
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -3,3 +3,4 @@
 --wrap=fopen64
 --wrap=fclose
 --wrap=fwrite
+--wrap=fread
--- a/darshan-stdio-log-format.h
+++ b/darshan-stdio-log-format.h
@@ -13,13 +13,13 @@
  * functions for opening streams
- * FILE    *fdopen(int, const char *);                     DONE
+ * FILE    *fdopen(int, const char *);                      DONE
  * FILE    *fopen(const char *, const char *);
  * FILE    *freopen(const char *, const char *, FILE *);
  * functions for closing streams
- * int      fclose(FILE *);                                DONE
+ * int      fclose(FILE *);                                 DONE
  * functions for flushing streams
@@ -29,7 +29,7 @@
  * int      fgetc(FILE *);
  * char    *fgets(char *, int, FILE *);
- * size_t   fread(void *, size_t, size_t, FILE *);
+ * size_t   fread(void *, size_t, size_t, FILE *);          DONE
  * int      fscanf(FILE *, const char *, ...);
  * int      getc(FILE *);
  * int      getc_unlocked(FILE *);
@@ -64,6 +64,12 @@
     X(STDIO_BYTES_WRITTEN) \
     /* number of writes */ \
     X(STDIO_WRITES) \
+    /* maximum byte (offset) written */\
+    X(STDIO_MAX_BYTE_READ) \
+    /* total bytes written */ \
+    X(STDIO_BYTES_READ) \
+    /* number of writes */ \
+    X(STDIO_READS) \
     /* end of counters */\
     X(STDIO_NUM_INDICES)
@@ -80,10 +86,16 @@
     X(STDIO_F_WRITE_START_TIMESTAMP) \
     /* timestamp of last write completion */\
     X(STDIO_F_WRITE_END_TIMESTAMP) \
+    /* timestamp of first read */\
+    X(STDIO_F_READ_START_TIMESTAMP) \
+    /* timestamp of last read completion */\
+    X(STDIO_F_READ_END_TIMESTAMP) \
     /* cumulative meta time */\
     X(STDIO_F_META_TIME) \
     /* cumulative write time */\
     X(STDIO_F_WRITE_TIME) \
+    /* cumulative read time */\
+    X(STDIO_F_READ_TIME) \
     X(STDIO_F_NUM_INDICES)
--- a/darshan-test/regression/test-cases/src/stdio-test.c
+++ b/darshan-test/regression/test-cases/src/stdio-test.c
@@ -31,6 +31,7 @@ int main(int argc, char **argv)
    int namelen;
    char processor_name[MPI_MAX_PROCESSOR_NAME];
    FILE *file;
+   char buffer[128] = {0};
    /* startup MPI and determine the rank of this process */
    MPI_Init(&argc,&argv);
@@ -43,7 +44,7 @@ int main(int argc, char **argv)
    if (mynod == 0) printf("# Using stdio calls.\n");
-   file = fopen(opt_file, "w");
+   file = fopen(opt_file, "w+");
    if(!file)
       perror("fopen");
@@ -51,7 +52,11 @@ int main(int argc, char **argv)
    if(mynod == 0)
       fwrite("hello", 1, 6, file);
+      fseek(file, 0, SEEK_SET);
+      fread(buffer, 1, 1024, file);
    fclose(file);
--- a/darshan-test/regression/test-cases/stdio-test.sh
+++ b/darshan-test/regression/test-cases/stdio-test.sh
@@ -44,6 +44,11 @@ if [ ! "$STDIO_BYTES_WRITTEN" -eq 6 ]; then
     echo "Error: STDIO open count of $STDIO_BYTES_WRITTEN is incorrect" 1>&2
     exit 1
 fi
+STDIO_BYTES_READ=`grep STDIO_BYTES_READ $DARSHAN_TMP/${PROG}.darshan.txt |head -n 1 |cut -f 5`
+if [ ! "$STDIO_BYTES_READ" -eq 6 ]; then
+    echo "Error: STDIO open count of $STDIO_BYTES_READ is incorrect" 1>&2
+    exit 1
+fi
 # make sure that some of the floating point counters are valid
--- a/darshan-util/darshan-stdio-logutils.c
+++ b/darshan-util/darshan-stdio-logutils.c
@@ -143,7 +143,7 @@ static void darshan_log_print_stdio_record(void *file_rec, char *file_name,
 static void darshan_log_print_stdio_description()
     printf("\n# description of STDIO counters:\n");
-    printf("#   STDIO_{OPENS|WRITES} are types of operations.\n");
+    printf("#   STDIO_{OPENS|WRITES|READS} are types of operations.\n");
     printf("#   STDIO_BYTES_*: total bytes read and written.\n");
     printf("#   STDIO_MAX_BYTE_*: highest offset byte read and written.\n");
     printf("#   STDIO_F_*_START_TIMESTAMP: timestamp of the first call to that type of function.\n");
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/da6857556a3047178d7cf964f34a088bb0d7e67c
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160501/b06f4f09/attachment-0001.html>
More information about the Darshan-commits mailing list
