[Darshan-commits] [Git][darshan/darshan][master] cleanup compiler warnings from edison
Shane Snyder
xgitlab at cels.anl.gov
Tue Jun 28 15:51:55 CDT 2016
Shane Snyder pushed to branch master at darshan / darshan
Commits:
7d8ebfa0 by Shane Snyder at 2016-06-28T13:49:49-07:00
4 changed files:
- darshan-runtime/configure
- darshan-runtime/darshan-runtime-config.h.in
- darshan-runtime/lib/darshan-common.c
- darshan-runtime/lib/darshan-core.c
Changes:
The diff for this file was not included because it is too large.
--- a/darshan-runtime/darshan-runtime-config.h.in
+++ b/darshan-runtime/darshan-runtime-config.h.in
@@ -60,9 +60,6 @@
/* Define to the one symbol short name of this package. */
#undef PACKAGE_TARNAME
-/* Define to the home page for this package. */
-#undef PACKAGE_URL
/* Define to the version of this package. */
#undef PACKAGE_VERSION
--- a/darshan-runtime/lib/darshan-common.c
+++ b/darshan-runtime/lib/darshan-common.c
@@ -224,7 +224,7 @@ void darshan_common_val_counter(void **common_val_root, int *common_val_count,
int64_t val, int64_t *common_val_p, int64_t *common_cnt_p)
struct darshan_common_val_counter* counter;
- struct darshan_common_val_counter* found;
+ struct darshan_common_val_counter* found = NULL;
struct darshan_common_val_counter tmp_counter;
void* tmp;
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -330,12 +330,12 @@ void darshan_core_shutdown()
int64_t last_end_time;
double start_log_time;
double tm_end;
- double open1, open2;
- double job1, job2;
- double rec1, rec2;
+ double open1 = 0, open2 = 0;
+ double job1 = 0, job2 = 0;
+ double rec1 = 0, rec2 = 0;
double mod1[DARSHAN_MAX_MODS] = {0};
double mod2[DARSHAN_MAX_MODS] = {0};
- double header1, header2;
+ double header1 = 0, header2 = 0;
char *logfile_name;
int local_mod_use[DARSHAN_MAX_MODS] = {0};
int global_mod_use_count[DARSHAN_MAX_MODS] = {0};
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/7d8ebfa060aaa1518fe675681ecb68a4720ab648
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160628/d5f6c699/attachment-0001.html>
More information about the Darshan-commits
