[Darshan-commits] [Git][darshan/darshan][master] 42 commits: bug fix in reduction of min nonzero counters
Shane Snyder xgitlab at cels.anl.gov
Tue Jun 28 15:33:34 CDT 2016
Shane Snyder pushed to branch master at darshan / darshan
Commits:
4d50fd77 by Shane Snyder at 2016-02-19T15:19:22-06:00
92003506 by Shane Snyder at 2016-02-19T15:19:22-06:00
update release checklist to refer to gitlab
30d6bffe by Shane Snyder at 2016-02-19T15:19:22-06:00
updated configure to reference 3.0.0 version
d14cd758 by Shane Snyder at 2016-02-19T15:19:22-06:00
updated ChangeLog for 3.0.0 release
62ed332a by Shane Snyder at 2016-02-23T16:55:27-06:00
add stubbed out lustre source and header files
1eecb3b1 by Shane Snyder at 2016-02-23T16:55:27-06:00
clean up headers for some modules
ffeeed89 by Shane Snyder at 2016-02-23T16:56:24-06:00
some initial luste mod logic and makefile changes
21c1b5d0 by Shane Snyder at 2016-02-24T22:27:10-06:00
cleanup bgq module to use fs_info struct
657c5b56 by Shane Snyder at 2016-02-24T22:28:58-06:00
initial runtime lustre module implementation
the POSIX module will call into the Lustre module for each file
record created that corresponds to a file from a Lustre FS. No
counters are currently stored but most of the module strucutre
has been stubbed.
b920e005 by Shane Snyder at 2016-02-25T08:28:23-08:00
makefile bug fix
7ba0dfe3 by Shane Snyder at 2016-02-25T08:53:36-08:00
add dummy counter to test lustre module
fdf5af2d by Shane Snyder at 2016-02-25T10:16:37-08:00
integrate lustre module into logutils library
c3a85a3e by Shane Snyder at 2016-02-25T11:10:13-08:00
switch lustre to use array instead of hash table
1c2df3e1 by Shane Snyder at 2016-05-17T09:56:52-05:00
remove object file from tracked files
3266825f by Shane Snyder at 2016-05-17T13:25:55-05:00
Merge branch 'master' into lustre-mod
Conflicts:
	ChangeLog
08956bd2 by Glenn K. Lockwood at 2016-05-18T21:38:05-07:00
new fs-specific counters for storage server and metadata server counts
19147a7b by Glenn K. Lockwood at 2016-05-18T21:39:00-07:00
checkpoint of code that populates OST and MDT counts per file system--doesn't seem to work though...
01bc23aa by Glenn K. Lockwood at 2016-05-18T21:39:48-07:00
moved the call to the lustre module up into the file open macro
b547fbfe by Glenn K. Lockwood at 2016-05-18T21:40:18-07:00
replaced the dummy counter with some real counters to describe file geometry on Lustre
64a4a226 by Glenn K. Lockwood at 2016-05-18T21:40:53-07:00
work in progress on enabling new lustre counters for files
4b63144a by Glenn K. Lockwood at 2016-05-19T19:38:33-07:00
fixed bug that was preventing OST/MDT counts from being populated correctly
08d83a03 by Glenn K. Lockwood at 2016-05-19T19:41:24-07:00
added filename hashing so multiple opens/closes don't create multiple lustre-mod records; added proper reducer so that shared files are flattened into a single set of counters whose values are dictated by rank 0
0934519c by Glenn K. Lockwood at 2016-05-20T07:10:58-07:00
tool to test ioctl/llapi calls, based on stat-perf.c
3e5753e4 by Glenn K. Lockwood at 2016-05-20T09:12:00-07:00
updated text descriptions of the Lustre counters
a2a9e135 by Glenn K. Lockwood at 2016-05-25T13:02:53-07:00
don't pull in the full Lustre API just for a few consts
a61ebca2 by Glenn K. Lockwood at 2016-06-02T16:54:11-07:00
added some infrastructure to facilitate unit testing of the darshan lustre module
6c828abb by Glenn K. Lockwood at 2016-06-03T10:24:19-07:00
forgot to add darshan-lustre.h, which is needed to hook together the module and darshan-core-stub.c
3193b2e9 by Glenn K. Lockwood at 2016-06-03T10:34:48-07:00
make ioctl return the full ost map in test app
8aa23fa3 by Glenn K. Lockwood at 2016-06-03T10:37:00-07:00
partly working lustre module supporting ost mapping; shared file agg still doesn't work, and log parsing doesn't either
dc1a9eb9 by Glenn K. Lockwood at 2016-06-03T10:39:14-07:00
add rank shuffling to non-MPI tester
6538893d by Glenn K. Lockwood at 2016-06-03T11:02:16-07:00
made print_lustre_runtime
15d6b046 by Glenn K. Lockwood at 2016-06-03T11:03:15-07:00
fixed problem where make was breaking if only some dependencies had been updated
ab49f325 by Glenn K. Lockwood at 2016-06-03T11:03:43-07:00
first record was being rejected because the core stub was handing out rec_id==0
f5f23bc1 by Glenn K. Lockwood at 2016-06-07T09:42:47-07:00
implemented a simple get_output_data that doesn't use MPI; all ranks except rank0 just drop their shared records
fad7e816 by Glenn K. Lockwood at 2016-06-07T11:53:20-07:00
added more stubs to enable testing of lustre-mod's shared-file reduction
4264247f by Glenn K. Lockwood at 2016-06-15T13:42:28-07:00
fixed a bug preventing shared file reduction from working correctly
735fc530 by Glenn K. Lockwood at 2016-06-15T14:18:37-07:00
moved the temporary record buffer used in darshan-{convert,parser} into the heap; darshan_diff remains on the stack
b51c463b by Glenn K. Lockwood at 2016-06-15T14:19:47-07:00
working set of tools to parse darshan lustre-mod logfiles
085aaaa7 by Glenn K. Lockwood at 2016-06-21T12:45:45-07:00
fixed bug that prevented parser from reading in record with striping > 1 but < 8
7d9b5b37 by Glenn K. Lockwood at 2016-06-21T13:35:33-07:00
fixed bugs that prevented record names from mapping to file systems in darshan-util; also fixed thread safety and deadlock issues
6eae98bd by Shane Snyder at 2016-06-28T15:07:05-05:00
Merge branch 'lustre-mod'
Conflicts:
	darshan-bgq-log-format.h
	darshan-runtime/darshan.h
	darshan-runtime/lib/darshan-bgq.c
	darshan-runtime/lib/darshan-core.c
	darshan-runtime/lib/darshan-posix.c
	darshan-util/darshan-convert.c
	darshan-util/darshan-diff.c
2a22e1ff by Shane Snyder at 2016-06-28T15:07:17-05:00
add autoconf checking for lustre module
26 changed files:
- darshan-log-format.h
- + darshan-lustre-log-format.h
- darshan-runtime/Makefile.in
- darshan-runtime/configure
- darshan-runtime/configure.in
- + darshan-runtime/darshan-lustre.h
- darshan-runtime/darshan.h
- darshan-runtime/lib/darshan-core-init-finalize.c
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-hdf5.c
- + darshan-runtime/lib/darshan-lustre.c
- + darshan-runtime/lib/darshan-lustre_old.c
- darshan-runtime/lib/darshan-pnetcdf.c
- darshan-runtime/lib/darshan-posix.c
- + darshan-test/2.x/llapi-perf.c
- + darshan-test/lustre/.gitignore
- + darshan-test/lustre/Makefile
- + darshan-test/lustre/darshan-core-stub.c
- + darshan-test/lustre/mpi.h
- + darshan-test/lustre/test-darshan.sh
- darshan-util/Makefile.in
- darshan-util/darshan-convert.c
- darshan-util/darshan-logutils.h
- + darshan-util/darshan-lustre-logutils.c
- + darshan-util/darshan-lustre-logutils.h
- darshan-util/darshan-parser.c
Changes:
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -111,6 +111,7 @@ struct darshan_base_record
 #include "darshan-hdf5-log-format.h"
 #include "darshan-pnetcdf-log-format.h"
 #include "darshan-bgq-log-format.h"
+#include "darshan-lustre-log-format.h"
 /* X-macro for keeping module ordering consistent */
 /* NOTE: first val used to define module enum values,
@@ -128,7 +129,8 @@ struct darshan_base_record
     X(DARSHAN_MPIIO_MOD,    "MPI-IO",   DARSHAN_MPIIO_VER,      &mpiio_logutils) \
     X(DARSHAN_HDF5_MOD,     "HDF5",     DARSHAN_HDF5_VER,       &hdf5_logutils) \
     X(DARSHAN_PNETCDF_MOD,  "PNETCDF",  DARSHAN_PNETCDF_VER,    &pnetcdf_logutils) \
-    X(DARSHAN_BGQ_MOD,      "BG/Q",     DARSHAN_BGQ_VER,        &bgq_logutils)
+    X(DARSHAN_BGQ_MOD,      "BG/Q",     DARSHAN_BGQ_VER,        &bgq_logutils) \
+    X(DARSHAN_LUSTRE_MOD,   "LUSTRE",   DARSHAN_LUSTRE_VER,     &lustre_logutils)
 /* unique identifiers to distinguish between available darshan modules */
 /* NOTES: - valid ids range from [0...DARSHAN_MAX_MODS-1]
--- /dev/null
+++ b/darshan-lustre-log-format.h
@@ -0,0 +1,59 @@
+ * Copyright (C) 2015 University of Chicago.
+ * See COPYRIGHT notice in top-level directory.
+#ifndef __DARSHAN_LUSTRE_LOG_FORMAT_H
+#define __DARSHAN_LUSTRE_LOG_FORMAT_H
+/* NOTE -- redefining the size of OST_ID will require changing the DARSHAN_BSWAP
+ * macro used in darshan-util/darshan-lustre-logutils.c as well
+typedef int64_t OST_ID;
+/* current Lustre log format version */
+#define DARSHAN_LUSTRE_VER 1
+#define LUSTRE_COUNTERS \
+    /* number of OSTs for file system */\
+    X(LUSTRE_OSTS) \
+    /* number of MDTs for file system */\
+    X(LUSTRE_MDTS) \
+    /* index of first OST for file */\
+    X(LUSTRE_STRIPE_OFFSET) \
+    /* bytes per stripe for file */\
+    X(LUSTRE_STRIPE_SIZE) \
+    /* number of stripes (OSTs) for file */\
+    X(LUSTRE_STRIPE_WIDTH) \
+    /* end of counters */\
+    X(LUSTRE_NUM_INDICES)
+#define X(a) a,
+/* integer statistics for Lustre file records */
+enum darshan_lustre_indices
+    LUSTRE_COUNTERS
+#undef X
+/* record structure for the Lustre module. a record is created and stored for
+ * every file opened that belongs to a Lustre file system. This record includes:
+ *      - a corresponding record identifier (created by hashing the file path)
+ *      - the rank of the process which opened the file (-1 for shared files)
+ *      - integer file I/O statistics (stripe size, width, # of OSTs, etc.)
+struct darshan_lustre_record
+    darshan_record_id rec_id;
+    int64_t rank;
+    int64_t counters[LUSTRE_NUM_INDICES];
+    OST_ID ost_ids[1];
+ *  helper function to calculate the size of a record
+#define LUSTRE_RECORD_SIZE( osts ) ( sizeof(struct darshan_lustre_record) + sizeof(OST_ID) * (osts - 1) )
+#endif /* __DARSHAN_LUSTRE_LOG_FORMAT_H */
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -19,6 +19,7 @@ LD = @LD@
 DISABLE_LDPRELOAD = @DISABLE_LDPRELOAD@
 ENABLE_MMAP_LOGS = @ENABLE_MMAP_LOGS@
 DARSHAN_USE_BGQ = @DARSHAN_USE_BGQ@
+DARSHAN_USE_LUSTRE = @DARSHAN_USE_LUSTRE@
 DARSHAN_LOG_FORMAT = $(srcdir)/../darshan-log-format.h
 DARSHAN_VERSION = @DARSHAN_VERSION@
@@ -44,69 +45,82 @@ CFLAGS += -DDARSHAN_BGQ
 CFLAGS_SHARED += -DDARSHAN_BGQ
 endif
+ifdef DARSHAN_USE_LUSTRE
+DARSHAN_STATIC_MOD_OBJS += lib/darshan-lustre.o
+DARSHAN_DYNAMIC_MOD_OBJS += lib/darshan-lustre.po
+CFLAGS += -DDARSHAN_LUSTRE
+CFLAGS_SHARED += -DDARSHAN_LUSTRE
+endif
 lib::
 	@mkdir -p $@
 lib/darshan-core-init-finalize.o: lib/darshan-core-init-finalize.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
 	$(CC) $(CFLAGS) -c $< -o $@
-lib/darshan-core-init-finalize.po: lib/darshan-core-init-finalize.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-core-init-finalize.po: lib/darshan-core-init-finalize.c darshan.h darshan-dynamic.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
 	$(CC) $(CFLAGS_SHARED) -c $< -o $@
 lib/darshan-core.o: lib/darshan-core.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
-lib/darshan-core.po: lib/darshan-core.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-core.po: lib/darshan-core.c darshan.h darshan-dynamic.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
-lib/darshan-common.o: lib/darshan-common.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-common.o: lib/darshan-common.c darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) | lib
-lib/darshan-common.po: lib/darshan-common.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-common.po: lib/darshan-common.c darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) | lib
-lib/darshan-null.o: lib/darshan-null.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-null-log-format.h | lib
+lib/darshan-null.o: lib/darshan-null.c darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-null-log-format.h | lib
-lib/darshan-null.po: lib/darshan-null.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-null-log-format.h | lib
+lib/darshan-null.po: lib/darshan-null.c darshan.h darshan-dynamic.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-null-log-format.h | lib
-lib/darshan-posix.o: lib/darshan-posix.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-posix-log-format.h | lib
+lib/darshan-posix.o: lib/darshan-posix.c darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-posix-log-format.h | lib
-lib/darshan-posix.po: lib/darshan-posix.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-posix-log-format.h | lib
+lib/darshan-posix.po: lib/darshan-posix.c darshan.h darshan-dynamic.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-posix-log-format.h | lib
-lib/darshan-mpiio.o: lib/darshan-mpiio.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
+lib/darshan-mpiio.o: lib/darshan-mpiio.c darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
-lib/darshan-mpiio.po: lib/darshan-mpiio.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
+lib/darshan-mpiio.po: lib/darshan-mpiio.c darshan.h darshan-dynamic.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
-lib/darshan-bgq.o: lib/darshan-bgq.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
+lib/darshan-bgq.o: lib/darshan-bgq.c darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
-lib/darshan-bgq.po: lib/darshan-bgq.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
+lib/darshan-bgq.po: lib/darshan-bgq.c darshan.h darshan-dynamic.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
-lib/darshan-hdf5.o: lib/darshan-hdf5.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-hdf5-log-format.h | lib
+lib/darshan-hdf5.o: lib/darshan-hdf5.c darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-hdf5-log-format.h | lib
-lib/darshan-hdf5.po: lib/darshan-hdf5.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-hdf5-log-format.h | lib
+lib/darshan-hdf5.po: lib/darshan-hdf5.c darshan.h darshan-dynamic.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-hdf5-log-format.h | lib
 lib/darshan-hdf5-stubs.o: lib/darshan-hdf5-stubs.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
-lib/darshan-pnetcdf.o: lib/darshan-pnetcdf.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-pnetcdf-log-format.h | lib
+lib/darshan-pnetcdf.o: lib/darshan-pnetcdf.c darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-pnetcdf-log-format.h | lib
-lib/darshan-pnetcdf.po: lib/darshan-pnetcdf.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-pnetcdf-log-format.h | lib
+lib/darshan-pnetcdf.po: lib/darshan-pnetcdf.c darshan.h darshan-dynamic.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-pnetcdf-log-format.h | lib
 lib/darshan-pnetcdf-stubs.o: lib/darshan-pnetcdf-stubs.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-lustre.o: lib/darshan-lustre.c darshan-lustre.h darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-lustre-log-format.h | lib
+	$(CC) $(CFLAGS) -c $< -o $@
+lib/darshan-lustre.po: lib/darshan-lustre.c darshan-lustre.h darshan.h darshan-dynamic.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-lustre-log-format.h | lib
+	$(CC) $(CFLAGS_SHARED) -c $< -o $@
 lib/lookup3.o: lib/lookup3.c
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -621,6 +621,7 @@ ac_includes_default="\
 ac_subst_vars='LTLIBOBJS
 LIBOBJS
+DARSHAN_USE_LUSTRE
 DARSHAN_USE_BGQ
 MPICH_LIB_OLD
 DARSHAN_VERSION
@@ -689,6 +690,7 @@ enable_ld_preload
 enable_cuserid
 enable_group_readable_logs
 enable_bgq_mod
+enable_lustre_mod
 enable_mmap_logs
 with_mem_align
 with_log_path_by_env
@@ -1320,6 +1322,7 @@ Optional Features:
   --enable-group-readable-logs
                           Set log files to be group readable
   --disable-bgq-mod       Disables compilation and use of BG/Q module (for BG/Q systems)
+  --disable-lustre-mod    Disables compilation and use of the Lustre module
   --enable-mmmap-logs     Enables ability to mmap I/O data to log file
 Optional Packages:
@@ -3566,7 +3569,7 @@ fi
 fi
-# Check whether --enable-bgq_mod was given.
+# Check whether --enable-bgq-mod was given.
 if test "${enable_bgq_mod+set}" = set; then :
   enableval=$enable_bgq_mod;
 else
@@ -3575,6 +3578,15 @@ else
 fi
+# Check whether --enable-lustre-mod was given.
+if test "${enable_lustre_mod+set}" = set; then :
+  enableval=$enable_lustre_mod;
+else
+  enable_lustre_mod=check
+fi
 # Check whether --enable-mmap-logs was given.
 if test "${enable_mmap_logs+set}" = set; then :
   enableval=$enable_mmap_logs; if test "x$enableval" = "xyes" ; then
@@ -3694,6 +3706,7 @@ _ACEOF
 fi
+# if bgq module not disabled, check to make sure BG/Q environment available
 if test x$enable_bgq_mod != xno; then
     { $as_echo "$as_me:${as_lineno-$LINENO}: checking for BG/Q environment" >&5
 $as_echo_n "checking for BG/Q environment... " >&6; }
@@ -3726,6 +3739,20 @@ fi
 rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
 fi
+# if lustre module not disabled, check for needed Lustre module header
+if test x$enable_lustre_mod != xno; then
+    ac_fn_c_check_header_mongrel "$LINENO" "lustre/lustre_user.h" "ac_cv_header_lustre_lustre_user_h" "$ac_includes_default"
+if test "x$ac_cv_header_lustre_lustre_user_h" = xyes; then :
+  DARSHAN_USE_LUSTRE=1
+else
+  if test "x$enable_lustre_mod" = xyes; then :
+  as_fn_error $? "Cannot find required headers for the Lustre module" "$LINENO" 5
+fi
+fi
+fi
 if test x$GOT_ALIGNMENT != x1; then
     as_fn_error $? "must provide --with-mem-align=<num> argument to configure." "$LINENO" 5
 fi
@@ -4331,6 +4358,7 @@ DARSHAN_VERSION="3.0.1"
 ac_config_files="$ac_config_files Makefile darshan-mk-log-dirs.pl darshan-gen-cc.pl darshan-gen-cxx.pl darshan-gen-fortran.pl darshan-config share/craype-1.x/darshan-module share/craype-2.x/darshan-module lib/pkgconfig/darshan-runtime.pc share/mpi-profile/darshan-cc.conf share/mpi-profile/darshan-cxx.conf share/mpi-profile/darshan-f.conf share/mpi-profile/darshan-bg-cc.conf share/mpi-profile/darshan-bg-cxx.conf share/mpi-profile/darshan-bg-f.conf share/ld-opts/darshan-base-ld-opts"
 cat >confcache <<\_ACEOF
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -47,12 +47,19 @@ fi]
 AC_ARG_ENABLE(
-    [bgq_mod],
+    [bgq-mod],
     [  --disable-bgq-mod       Disables compilation and use of BG/Q module (for BG/Q systems)],
     [enable_bgq_mod=check]
+AC_ARG_ENABLE(
+    [lustre-mod],
+    [  --disable-lustre-mod    Disables compilation and use of the Lustre module],
+    [enable_lustre_mod=check]
 AC_ARG_ENABLE(mmap-logs,
 [  --enable-mmmap-logs     Enables ability to mmap I/O data to log file],
 [if test "x$enableval" = "xyes" ; then
@@ -130,6 +137,7 @@ AC_ARG_WITH(mod-mem,
     fi
     AC_MSG_CHECKING(for BG/Q environment)
     AC_TRY_COMPILE([
@@ -145,6 +153,15 @@ if test x$enable_bgq_mod != xno; then
 fi
+    AC_CHECK_HEADER([lustre/lustre_user.h],
+        DARSHAN_USE_LUSTRE=1,
+        AS_IF([test "x$enable_lustre_mod" = xyes],
+            AC_MSG_ERROR(Cannot find required headers for the Lustre module),
+fi
     AC_MSG_ERROR(must provide --with-mem-align=<num> argument to configure.)
 fi
@@ -334,6 +351,7 @@ AC_SUBST(ENABLE_MMAP_LOGS)
 AC_SUBST(DARSHAN_VERSION)
 AC_SUBST(MPICH_LIB_OLD)
 AC_SUBST(DARSHAN_USE_BGQ)
+AC_SUBST(DARSHAN_USE_LUSTRE)
 AC_OUTPUT(Makefile
 darshan-gen-cc.pl
--- /dev/null
+++ b/darshan-runtime/darshan-lustre.h
@@ -0,0 +1,19 @@
+struct lustre_record_runtime
+    struct darshan_lustre_record *record;
+    size_t record_size;
+    UT_hash_handle hlink;
+struct lustre_runtime
+    int    record_count;       /* number of records defined */
+    size_t record_buffer_max;  /* size of the allocated buffer pointed to by record_buffer */
+    size_t record_buffer_used; /* size of the allocated buffer actually used */
+    void   *next_free_record;  /* pointer to end of record_buffer */
+    void   *record_buffer;     /* buffer in which records are created */
+    struct lustre_record_runtime *record_runtime_array;
+    struct lustre_record_runtime *record_runtime_hash;
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -73,6 +73,15 @@ typedef void (*darshan_module_shutdown)(
     int *mod_buf_sz /* output parameter to save module buffer size */
+/* stores FS info from statfs calls for a given mount point */
+struct darshan_fs_info
+    int fs_type;
+    int block_size;
+    int ost_count;
+    int mdt_count;
 * darshan-core functions exported to darshan modules *
@@ -122,17 +131,18 @@ darshan_record_id darshan_core_gen_record_id(
  * Darshan record (e.g., the full file path), which for now is just a
  * string. 'mod_id' is the identifier of the calling module. 'rec_len'
  * is the size of the record being registered with Darshan. If given,
- * 'file_alignment' is a pointer to an integer which on return will
- * contain the corresponding file system alignment of the file system
- * path 'name' resides on. Returns a pointer to the address the record
- * should be written to on success, NULL on failure.
+ * 'fs_info' is a pointer to a structure containing information on
+ * the underlying FS this record is associated with (determined by
+ * matching the file name prefix with Darshan's list of tracked mount
+ * points). Returns a pointer to the address the record should be
+ * written to on success, NULL on failure.
 void *darshan_core_register_record(
     darshan_record_id rec_id,
     const char *name,
     darshan_module_id mod_id,
     int rec_len,
-    int *file_alignment);
+    struct darshan_fs_info *fs_info);
 /* darshan_core_wtime()
--- a/darshan-runtime/lib/darshan-core-init-finalize.c
+++ b/darshan-runtime/lib/darshan-core-init-finalize.c
@@ -15,6 +15,7 @@
 #include "darshan.h"
 #include "darshan-core.h"
+#include "darshan-dynamic.h"
 #ifdef DARSHAN_PRELOAD
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -19,6 +19,8 @@
 #include <limits.h>
 #include <pthread.h>
 #include <fcntl.h>
+#include <dirent.h>
+#include <sys/ioctl.h>
 #include <sys/types.h>
 #include <sys/stat.h>
 #include <sys/mman.h>
@@ -32,6 +34,10 @@
+#ifdef DARSHAN_LUSTRE
+#include <lustre/lustre_user.h>
+#endif
 extern char* __progname;
 extern char* __progname_full;
@@ -83,9 +89,9 @@ void (*mod_static_init_fns[])(void) =
 #define DARSHAN_MAX_MNT_TYPE 32
 struct mnt_data
-    int block_size;
     char path[DARSHAN_MAX_MNT_PATH];
     char type[DARSHAN_MAX_MNT_TYPE];
+    struct darshan_fs_info fs_info;
 static struct mnt_data mnt_data_array[DARSHAN_MAX_MNTS];
 static int mnt_data_count = 0;
@@ -99,11 +105,11 @@ static void darshan_log_record_hints_and_ver(
     struct darshan_core_runtime* core);
 static void darshan_get_exe_and_mounts(
     struct darshan_core_runtime *core, int argc, char **argv);
+static void darshan_fs_info_from_path(
+    const char *path, struct darshan_fs_info *fs_info);
 static int darshan_add_name_record_ref(
     struct darshan_core_runtime *core, darshan_record_id rec_id,
     const char *name, darshan_module_id mod_id);
-static int darshan_block_size_from_path(
-    const char *path);
 static void darshan_get_user_name(
     char *user);
 static void darshan_get_logfile_name(
@@ -919,12 +925,43 @@ static void add_entry(char* buf, int* space_left, struct mntent* entry)
 #define LL_SUPER_MAGIC 0x0BD00BD0
 #endif
     ret = statfs(entry->mnt_dir, &statfsbuf);
+    mnt_data_array[mnt_data_count].fs_info.fs_type = statfsbuf.f_type;
     if(ret == 0 && statfsbuf.f_type != LL_SUPER_MAGIC)
-        mnt_data_array[mnt_data_count].block_size = statfsbuf.f_bsize;
+        mnt_data_array[mnt_data_count].fs_info.block_size = statfsbuf.f_bsize;
     else if(ret == 0 && statfsbuf.f_type == LL_SUPER_MAGIC)
-        mnt_data_array[mnt_data_count].block_size = 1024*1024;
+        mnt_data_array[mnt_data_count].fs_info.block_size = 1024*1024;
     else
-        mnt_data_array[mnt_data_count].block_size = 4096;
+        mnt_data_array[mnt_data_count].fs_info.block_size = 4096;
+    /* attempt to retrieve OST and MDS counts from Lustre */
+    mnt_data_array[mnt_data_count].fs_info.ost_count = -1;
+    mnt_data_array[mnt_data_count].fs_info.mdt_count = -1;
+    if ( statfsbuf.f_type == LL_SUPER_MAGIC )
+        int n_ost, n_mdt;
+        int ret_ost, ret_mdt;
+        DIR *mount_dir;
+        mount_dir = opendir( entry->mnt_dir );
+        if ( mount_dir  )
+            /* n_ost and n_mdt are used for both input and output to ioctl */
+            n_ost = 0;
+            n_mdt = 1;
+            ret_ost = ioctl( dirfd(mount_dir), LL_IOC_GETOBDCOUNT, &n_ost );
+            ret_mdt = ioctl( dirfd(mount_dir), LL_IOC_GETOBDCOUNT, &n_mdt );
+            if ( !(ret_ost < 0 || ret_mdt < 0) )
+                mnt_data_array[mnt_data_count].fs_info.ost_count = n_ost;
+                mnt_data_array[mnt_data_count].fs_info.mdt_count = n_mdt;
+            closedir( mount_dir );
+#endif
     /* store mount information with the job-level metadata in darshan log */
     ret = snprintf(tmp_mnt, 256, "\n%s\t%s",
@@ -1059,21 +1096,55 @@ static void darshan_get_exe_and_mounts(struct darshan_core_runtime *core,
     return;
-static int darshan_block_size_from_path(const char *path)
+static void darshan_fs_info_from_path(const char *path, struct darshan_fs_info *fs_info)
     int i;
-    int block_size = -1;
+    fs_info->fs_type = -1;
+    fs_info->block_size = -1;
     for(i=0; i<mnt_data_count; i++)
         if(!(strncmp(mnt_data_array[i].path, path, strlen(mnt_data_array[i].path))))
-            block_size = mnt_data_array[i].block_size;
-            break;;
+            *fs_info = mnt_data_array[i].fs_info;
+            return;
-    return block_size;
+    return;
+static int darshan_add_name_record_ref(struct darshan_core_runtime *core,
+    darshan_record_id rec_id, const char *name, darshan_module_id mod_id)
+    struct darshan_core_name_record_ref *ref;
+    int record_size = sizeof(darshan_record_id) + strlen(name) + 1;
+    if((record_size + core->name_mem_used) > DARSHAN_NAME_RECORD_BUF_SIZE)
+        return(0);
+    ref = malloc(sizeof(*ref));
+    if(!ref)
+        return(0);
+    memset(ref, 0, sizeof(*ref));
+    /* initialize the name record */
+    ref->name_record = (struct darshan_name_record *)
+        ((char *)core->log_name_p + core->name_mem_used);
+    memset(ref->name_record, 0, record_size);
+    ref->name_record->id = rec_id;
+    strcpy(ref->name_record->name, name);
+    DARSHAN_MOD_FLAG_SET(ref->mod_flags, mod_id);
+    /* add the record to the hash table */
+    HASH_ADD(hlink, core->name_hash, name_record->id,
+        sizeof(darshan_record_id), ref);
+    core->name_mem_used += record_size;
+#ifdef __DARSHAN_ENABLE_MMAP_LOGS
+    core->log_hdr_p->name_map.len += record_size;
+#endif
+    return(1);
 static void darshan_get_user_name(char *cuser)
@@ -1239,39 +1310,6 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
     return;
-static int darshan_add_name_record_ref(struct darshan_core_runtime *core,
-    darshan_record_id rec_id, const char *name, darshan_module_id mod_id)
-    struct darshan_core_name_record_ref *ref;
-    int record_size = sizeof(darshan_record_id) + strlen(name) + 1;
-    if((record_size + core->name_mem_used) > DARSHAN_NAME_RECORD_BUF_SIZE)
-        return(0);
-    ref = malloc(sizeof(*ref));
-    if(!ref)
-        return(0);
-    memset(ref, 0, sizeof(*ref));
-    /* initialize the name record */
-    ref->name_record = (struct darshan_name_record *)
-        ((char *)core->log_name_p + core->name_mem_used);
-    memset(ref->name_record, 0, record_size);
-    ref->name_record->id = rec_id;
-    strcpy(ref->name_record->name, name);
-    DARSHAN_MOD_FLAG_SET(ref->mod_flags, mod_id);
-    /* add the record to the hash table */
-    HASH_ADD(hlink, core->name_hash, name_record->id,
-        sizeof(darshan_record_id), ref);
-    core->name_mem_used += record_size;
-#ifdef __DARSHAN_ENABLE_MMAP_LOGS
-    core->log_hdr_p->name_map.len += record_size;
-#endif
-    return(1);
 static void darshan_get_shared_records(struct darshan_core_runtime *core,
     darshan_record_id **shared_recs, int *shared_rec_cnt)
@@ -1889,7 +1927,7 @@ void *darshan_core_register_record(
     const char *name,
     int rec_len,
     void *rec_buf;
@@ -1942,8 +1980,8 @@ void *darshan_core_register_record(
 #endif
     DARSHAN_CORE_UNLOCK();
-    if(file_alignment)
-        *file_alignment = darshan_block_size_from_path(name);
+    if(fs_info)
+        darshan_fs_info_from_path(name, fs_info);
     return(rec_buf);;
--- a/darshan-runtime/lib/darshan-hdf5.c
+++ b/darshan-runtime/lib/darshan-hdf5.c
@@ -4,6 +4,9 @@
+#define _XOPEN_SOURCE 500
+#define _GNU_SOURCE
 #include "darshan-runtime-config.h"
 #include <stdio.h>
 #include <unistd.h>
@@ -16,7 +19,6 @@
 #include <errno.h>
 #include <search.h>
 #include <assert.h>
-#define __USE_GNU
--- /dev/null
+++ b/darshan-runtime/lib/darshan-lustre.c
@@ -0,0 +1,515 @@
+#include "darshan-runtime-config.h"
+#include <stdio.h>
+#include <unistd.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <time.h>
+#include <stdlib.h>
+#include <assert.h>
+#include <pthread.h>
+/* XXX stick this into autoconf .h */
+#include "uthash.h"
+#include "darshan.h"
+#include "darshan-lustre.h"
+struct lustre_runtime *lustre_runtime = NULL;
+static pthread_mutex_t lustre_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
+static int instrumentation_disabled = 0;
+static int my_rank = -1;
+static void lustre_runtime_initialize(void);
+static void lustre_begin_shutdown(void);
+static void lustre_get_output_data(MPI_Comm mod_comm, darshan_record_id *shared_recs,
+    int shared_rec_count, void **lustre_buf, int *lustre_buf_sz);
+static void lustre_shutdown(void);
+static int lustre_record_compare(const void* a_p, const void* b_p);
+static void lustre_record_reduction_op(void* infile_v, void* inoutfile_v,
+    int *len, MPI_Datatype *datatype);
+#define LUSTRE_LOCK() pthread_mutex_lock(&lustre_runtime_mutex)
+#define LUSTRE_UNLOCK() pthread_mutex_unlock(&lustre_runtime_mutex)
+void darshan_instrument_lustre_file(const char* filepath, int fd)
+    struct lustre_record_runtime *rec_rt;
+    struct darshan_lustre_record *rec;
+    int limit_flag;
+    int i;
+    struct lov_user_md *lum;
+    size_t lumsize = sizeof(struct lov_user_md) +
+        LOV_MAX_STRIPE_COUNT * sizeof(struct lov_user_ost_data);
+    size_t rec_size;
+    char *newname = NULL;
+    LUSTRE_LOCK();
+    if(instrumentation_disabled)
+        LUSTRE_UNLOCK();
+        return;
+    /* make sure the lustre module is already initialized */
+    lustre_runtime_initialize();
+    if(!lustre_runtime)
+        LUSTRE_UNLOCK();
+        return;
+    /* if we can't issue ioctl, we have no counter data at all */
+    if ( (lum = calloc(1, lumsize)) == NULL )
+        LUSTRE_UNLOCK();
+        return;
+    /* find out the OST count of this file so we can allocate memory */
+    lum->lmm_magic = LOV_USER_MAGIC;
+    lum->lmm_stripe_count = LOV_MAX_STRIPE_COUNT;
+    /* -1 means ioctl failed, likely because file isn't on Lustre */
+    if ( ioctl( fd, LL_IOC_LOV_GETSTRIPE, (void *)lum ) == -1 )
+        free(lum);
+        LUSTRE_UNLOCK();
+        return;
+    rec_size = LUSTRE_RECORD_SIZE( lum->lmm_stripe_count );
+    /* get fully qualified name for record */
+    newname = darshan_clean_file_path(filepath);
+    if(!newname)
+        newname = (char*)filepath;
+        /* broken out for clarity */
+        void *end_of_new_record = (char*)lustre_runtime->next_free_record + rec_size;
+        void *end_of_rec_buffer = (char*)lustre_runtime->record_buffer + lustre_runtime->record_buffer_max;
+        limit_flag = ( end_of_new_record > end_of_rec_buffer );
+    /* register a Lustre file record with Darshan */
+    fs_info.fs_type = -1;
+    darshan_core_register_record(
+        (void *)newname,
+        strlen(newname),
+        DARSHAN_LUSTRE_MOD,
+        1,
+        limit_flag,
+        &rec_id,
+        &fs_info);
+    /* if record id is 0, darshan has no more memory for instrumenting */
+    if(rec_id == 0)
+        free(lum);
+        LUSTRE_UNLOCK();
+        return;
+    /* search the hash table for this file record, and initialize if not found */
+    HASH_FIND(hlink, lustre_runtime->record_runtime_hash, &rec_id, sizeof(darshan_record_id), rec_rt );
+    if ( !rec_rt ) {
+        /* allocate a new lustre record and append it to the array */
+        rec_rt = &(lustre_runtime->record_runtime_array[lustre_runtime->record_count]);
+        rec_rt->record = lustre_runtime->next_free_record;
+        rec_rt->record_size = rec_size;
+        lustre_runtime->next_free_record = (char*)(lustre_runtime->next_free_record) + rec_size;
+        lustre_runtime->record_buffer_used += rec_size;
+        rec = rec_rt->record;
+        rec->rec_id = rec_id;
+        rec->rank = my_rank;
+        /* implicit assumption here that none of these counters will change
+         * after the first time a file is opened.  This may not always be
+         * true in the future */
+        if ( fs_info.fs_type != -1 )
+            rec->counters[LUSTRE_OSTS] = fs_info.ost_count;
+            rec->counters[LUSTRE_MDTS] = fs_info.mdt_count;
+        else
+            rec->counters[LUSTRE_OSTS] = -1;
+            rec->counters[LUSTRE_MDTS] = -1;
+        rec->counters[LUSTRE_STRIPE_SIZE] = lum->lmm_stripe_size;
+        rec->counters[LUSTRE_STRIPE_WIDTH] = lum->lmm_stripe_count;
+        rec->counters[LUSTRE_STRIPE_OFFSET] = lum->lmm_stripe_offset;
+        for ( i = 0; i < lum->lmm_stripe_count; i++ )
+            rec->ost_ids[i] = lum->lmm_objects[i].l_ost_idx;
+        free(lum);
+        HASH_ADD(hlink, lustre_runtime->record_runtime_hash, record->rec_id, sizeof(darshan_record_id), rec_rt);
+        lustre_runtime->record_count++;
+    LUSTRE_UNLOCK();
+    return;
+static void lustre_runtime_initialize()
+    int mem_limit;
+    int max_records;
+    struct darshan_module_funcs lustre_mod_fns =
+        .begin_shutdown = &lustre_begin_shutdown,
+        .get_output_data = &lustre_get_output_data,
+        .shutdown = &lustre_shutdown
+    /* don't do anything if already initialized or instrumenation is disabled */
+    if(lustre_runtime || instrumentation_disabled)
+        return;
+    /* register the lustre module with darshan-core */
+    darshan_core_register_module(
+        &lustre_mod_fns,
+        &my_rank,
+        &mem_limit,
+        NULL);
+    /* return if no memory assigned by darshan core */
+    if(mem_limit == 0)
+        return;
+    lustre_runtime = malloc(sizeof(*lustre_runtime));
+        return;
+    memset(lustre_runtime, 0, sizeof(*lustre_runtime));
+    /* allocate the full size of the memory limit we are given */
+    lustre_runtime->record_buffer= malloc(mem_limit);
+    if(!lustre_runtime->record_buffer)
+        lustre_runtime->record_buffer_max = 0;
+        return;
+    lustre_runtime->record_buffer_max = mem_limit;
+    lustre_runtime->next_free_record = lustre_runtime->record_buffer;
+    memset(lustre_runtime->record_buffer, 0, lustre_runtime->record_buffer_max);
+    /* Allocate array of Lustre runtime data.  We calculate the maximum possible
+     * number of records that will fit into mem_limit by assuming that each
+     * record has the minimum possible OST count, then allocate that many
+     * runtime records.  record_buffer will always run out of memory before
+     * we overflow record_runtime_array.
+    max_records = mem_limit / sizeof(struct darshan_lustre_record);
+    lustre_runtime->record_runtime_array =
+        malloc( max_records * sizeof(struct lustre_record_runtime));
+    if(!lustre_runtime->record_runtime_array)
+        free( lustre_runtime->record_buffer );
+        return;
+    memset(lustre_runtime->record_runtime_array, 0,
+        max_records * sizeof(struct lustre_record_runtime));
+    return;
+ * Functions exported by Lustre module for coordinating with darshan-core *
+    assert(lustre_runtime);
+    LUSTRE_LOCK();
+    /* disable further instrumentation while Darshan shuts down */
+    instrumentation_disabled = 1;
+    LUSTRE_UNLOCK();
+    return;
+    MPI_Comm mod_comm,
+    darshan_record_id *shared_recs,
+    void **lustre_buf,
+    int *lustre_buf_sz)
+    struct lustre_record_runtime *file;
+    int i;
+    /* if there are globally shared files, do a shared file reduction */
+    /* NOTE: the shared file reduction is also skipped if the
+     * DARSHAN_DISABLE_SHARED_REDUCTION environment variable is set.
+    if (shared_rec_count && !getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
+        /* necessary initialization of shared records */
+        for(i = 0; i < shared_rec_count; i++)
+            HASH_FIND(hlink, lustre_runtime->record_runtime_hash, &shared_recs[i],
+                sizeof(darshan_record_id), file);
+            assert(file);
+            file->record->rank = -1;
+        /* sort the array of files descending by rank so that we get all of the
+         * shared files (marked by rank -1) in a contiguous portion at end
+         * of the array
+        sort_lustre_records();
+        /* simply drop all shared records from non-root ranks by truncating
+         * the record array and recalculating the size of the used buffer
+        if (my_rank != 0)
+            lustre_runtime->record_count -= shared_rec_count;
+            lustre_runtime->record_buffer_used = 0;
+            for ( i = 0; i < lustre_runtime->record_count; i++ )
+                    LUSTRE_RECORD_SIZE( (lustre_runtime->record_runtime_array[i]).record->counters[LUSTRE_STRIPE_WIDTH] );
+    *lustre_buf = (void *)(lustre_runtime->record_buffer);
+    *lustre_buf_sz = lustre_runtime->record_buffer_used;
+    return;
+    HASH_CLEAR(hlink, lustre_runtime->record_runtime_hash);
+    free(lustre_runtime->record_runtime_array);
+    free(lustre_runtime->record_buffer);
+    free(lustre_runtime);
+    lustre_runtime = NULL;
+    return;
+/* compare function for sorting file records by descending rank */
+    const struct lustre_record_runtime* a = a_p;
+    const struct lustre_record_runtime* b = b_p;
+    if (a->record->rank < b->record->rank)
+        return 1;
+    if (a->record->rank > b->record->rank)
+        return -1;
+    /* if ( a->record->rank == b->record->rank ) we MUST do a secondary
+     * sort so that the order of qsort is fully deterministic and consistent
+     * across all MPI ranks.  Without a secondary sort, the sort order can
+     * be affected by rank-specific variations (e.g., the order in which
+     * files are first opened).
+    return 0;
+ * Sort the record_runtimes and records by MPI rank to facilitate shared redux.
+ * This requires craftiness and additional heap utilization because the records
+ * (but not record_runtimes) have variable size.  Currently has to temporarily
+ * duplicate the entire record_buffer; there is room for more memory-efficient
+ * optimization if this becomes a scalability issue.
+int sort_lustre_records()
+    int i;
+    struct lustre_record_runtime *rec_rt, *tmp_rec_rt;
+    char  *new_buf, *p;
+    /* Create a new buffer to store an entire replica of record_buffer.  Since
+     * we know the exact size of record_buffer's useful data at this point, we
+     * can allocate the exact amount we need instead of record_buffer_max */
+    new_buf = malloc(lustre_runtime->record_buffer_used);
+    p = new_buf;
+    if ( !new_buf )
+        return 1;
+    /* qsort breaks the hash table, so delete it now to free its memory buffers
+     * and prevent later confusion */
+    HASH_ITER( hlink, lustre_runtime->record_runtime_hash, rec_rt, tmp_rec_rt )
+        HASH_DELETE( hlink, lustre_runtime->record_runtime_hash, rec_rt );
+    /* sort the runtime records, which is has fixed-length elements */
+    qsort(
+        lustre_runtime->record_runtime_array,
+        lustre_runtime->record_count,
+        sizeof(struct lustre_record_runtime),
+        lustre_record_compare
+    /* rebuild the hash and array with the qsorted runtime records */
+        rec_rt = &(lustre_runtime->record_runtime_array[i]);
+        HASH_ADD(hlink, lustre_runtime->record_runtime_hash, record->rec_id, sizeof(darshan_record_id), rec_rt );
+    /* create reordered record buffer, then copy it back in place */
+        memcpy( p, rec_rt->record, rec_rt->record_size );
+        /* fix record pointers within each runtime record too - pre-emptively
+         * point them at where they will live in record_buffer after we memcpy
+         * below */
+        rec_rt->record = (struct darshan_lustre_record *)((char*)(lustre_runtime->record_buffer) + (p - new_buf));
+        p += rec_rt->record_size;
+    memcpy(
+        lustre_runtime->record_buffer,
+        new_buf,
+        lustre_runtime->record_buffer_used );
+    free(new_buf);
+    return 0;
+/* this is just boilerplate reduction code that isn't currently used */
+    struct darshan_lustre_record tmp_record;
+    struct darshan_lustre_record *infile = infile_v;
+    struct darshan_lustre_record *inoutfile = inoutfile_v;
+    int i, j;
+    for( i=0; i<*len; i++ )
+        memset(&tmp_record, 0, sizeof(struct darshan_lustre_record));
+        tmp_record.rec_id = infile->rec_id;
+        tmp_record.rank = -1;
+        /* preserve only rank 0's value */
+        for( j = LUSTRE_OSTS; j < LUSTRE_NUM_INDICES; j++)
+            if ( my_rank == 0 )
+                tmp_record.counters[j] = infile->counters[j];
+            else
+                tmp_record.counters[j] = inoutfile->counters[j];
+        /* update pointers */
+        *inoutfile = tmp_record;
+        inoutfile++;
+        infile++;
+    return;
+ *  Dump the memory structure of our records and runtime records
+void print_lustre_runtime( void )
+    int i, j;
+    /* print what we just loaded */
+        rec = (lustre_runtime->record_runtime_array[i]).record;
+        printf( "File %2d\n", i );
+        for ( j = 0; j < LUSTRE_NUM_INDICES; j++ )
+            printf( "  Counter %-2d: %10ld, addr %ld\n",
+                j,
+                rec->counters[j],
+                (char*)(&(rec->counters[j])) - (char*)(lustre_runtime->record_buffer) );
+        for ( j = 0; j < rec->counters[LUSTRE_STRIPE_WIDTH]; j++ )
+            if ( j > 0 && j % 2 == 0 ) printf("\n");
+            printf( "  Stripe  %-2d: %10ld, addr %-9d",
+                j,
+                rec->ost_ids[j],
+                (char*)(&(rec->ost_ids[j])) - (char*)(lustre_runtime->record_buffer) );
+        printf( "\n" );
+    return;
+ *  Dump the order in which records appear in memory
+void print_array( void )
+    int i;
+    printf("*** DUMPING RECORD LIST BY ARRAY SEQUENCE\n");
+        printf( "*** record %d rank %d osts %d\n",
+            rec_rt->record->rec_id,
+            rec_rt->record->rank,
+            rec_rt->record->counters[LUSTRE_STRIPE_WIDTH]);
+void print_hash( void )
+    printf("*** DUMPING RECORD LIST BY HASH SEQUENCE\n");
+    return;
+ * Local variables:
+ *  c-indent-level: 4
+ *  c-basic-offset: 4
+ * End:
+ * vim: ts=8 sts=4 sw=4 expandtab
--- /dev/null
+++ b/darshan-runtime/lib/darshan-lustre_old.c
@@ -0,0 +1,543 @@
+#include <stdio.h>
+#include <time.h>
+#define LUSTRE_RECORD_SIZE( osts ) ( sizeof(struct darshan_lustre_record) + sizeof(int64_t) * (osts - 1) )
+    int limit_flag;
+    int i;
+    size_t rec_size;
+    LUSTRE_LOCK();
+        return;
+        free(lum);
+        return;
+        (void *)filepath,
+        strlen(filepath),
+        1,
+        limit_flag,
+        &rec_id,
+        &fs_info);
+    if(rec_id == 0)
+        free(lum);
+        LUSTRE_UNLOCK();
+        return;
+    if ( !rec_rt ) {
+        else
+        free(lum);
+    LUSTRE_UNLOCK();
+    return;
+    int mem_limit;
+    int max_records;
+        return;
+        &lustre_mod_fns,
+        &my_rank,
+        &mem_limit,
+        NULL);
+        return;
+        return;
+        return;
+        return;
+    return;
+    LUSTRE_LOCK();
+    LUSTRE_UNLOCK();
+    return;
+    int i, ishared;
+    int *rec_lengths;
+    size_t shared_rec_size;
+    struct darshan_lustre_record *red_send_buf = NULL;
+    struct darshan_lustre_record *red_recv_buf = NULL;
+    MPI_Datatype red_type;
+    MPI_Aint *rec_offsets;
+    MPI_Op red_op;
+            assert(file);
+         * of the array
+        /* make red_send_buf point to the first shared-file record */
+        ishared = lustre_runtime->record_count - shared_rec_count;
+        red_send_buf =
+            (lustre_runtime->record_runtime_array[ishared]).record;
+        /* allocate memory for the reduction output on rank 0 */
+        if (my_rank == 0)
+            shared_rec_size = lustre_runtime->record_buffer_used - ((char*)red_send_buf - (char*)lustre_runtime->record_buffer);
+            red_recv_buf = malloc(shared_rec_size);
+            if (!red_recv_buf)
+                return;
+        /* need to build rec_lengths (array of ints) and rec_offsets (array of ints) */
+        rec_lengths = malloc(sizeof(*rec_lengths) * shared_rec_count);
+        rec_offsets = malloc(sizeof(*rec_offsets) * shared_rec_count);
+        for ( i = ishared; i < shared_rec_count; i ++ )
+            rec_lengths[i] = (lustre_runtime->record_runtime_array[i]).record_size;
+            rec_offsets[i] = (char*)((lustre_runtime->record_runtime_array[i]).record) -
+                (char*)((lustre_runtime->record_runtime_array[ishared]).record);
+        DARSHAN_MPI_CALL(PMPI_Type_hindexed)(
+            shared_rec_count,
+            rec_lengths,
+            rec_offsets,
+            MPI_BYTE,
+            &red_type
+        DARSHAN_MPI_CALL(PMPI_Type_commit)(&red_type);
+        DARSHAN_MPI_CALL(PMPI_Op_create)(lustre_record_reduction_op, 1, &red_op);
+        DARSHAN_MPI_CALL(PMPI_Reduce)(red_send_buf, red_recv_buf,
+            shared_rec_count, red_type, red_op, 0, mod_comm);
+        /* clean up reduction state */
+        if (my_rank == 0)
+            memcpy(&(lustre_runtime->record_buffer[ishared]), red_recv_buf,
+                shared_rec_size);
+            free(red_recv_buf);
+        else
+        free(rec_lengths);
+        free(rec_offsets);
+        DARSHAN_MPI_CALL(PMPI_Type_free)(&red_type);
+        DARSHAN_MPI_CALL(PMPI_Op_free)(&red_op);
+    return;
+    return;
+        return 1;
+        return -1;
+    return 0;
+    int i;
+    p = new_buf;
+    if ( !new_buf )
+        return 1;
+    qsort(
+         * below */
+    memcpy(
+        new_buf,
+    free(new_buf);
+    return 0;
+    int i, j;
+            else
+        inoutfile++;
+        infile++;
+    return;
+    int i, j;
+                j,
+                rec->counters[j],
+                j,
+                rec->ost_ids[j],
+        printf( "\n" );
+    return;
+    int i;
+    return;
+ * End:
--- a/darshan-runtime/lib/darshan-pnetcdf.c
+++ b/darshan-runtime/lib/darshan-pnetcdf.c
@@ -4,6 +4,9 @@
 #include <stdio.h>
 #include <unistd.h>
@@ -16,7 +19,6 @@
 #include <errno.h>
 #include <search.h>
 #include <assert.h>
-#define __USE_GNU
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -37,6 +37,10 @@ typedef int64_t off64_t;
 #define aiocb64 aiocb
 #endif
+#ifndef LL_SUPER_MAGIC
+#define LL_SUPER_MAGIC 0x0BD00BD0
+#endif
 DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...));
 DARSHAN_FORWARD_DECL(open64, int, (const char *path, int flags, ...));
 DARSHAN_FORWARD_DECL(creat, int, (const char* path, mode_t mode));
@@ -117,6 +121,7 @@ struct posix_file_record_ref
     int access_count;
     void *stride_root;
     int stride_count;
+    int fs_type; /* same as darshan_fs_info->fs_type */
     struct posix_aio_tracker* aio_list;
@@ -161,6 +166,11 @@ static void posix_shutdown(
     int shared_rec_count, void **posix_buf, int *posix_buf_sz);
+/* XXX modules don't expose an API for other modules, so use extern to get
+ * Lustre instrumentation function
+extern void darshan_instrument_lustre_file(const char *filepath, int fd);
 static struct posix_runtime *posix_runtime = NULL;
 static pthread_mutex_t posix_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
@@ -216,6 +226,8 @@ static int darshan_mem_alignment = 1;
     DARSHAN_TIMER_INC_NO_OVERLAP(rec_ref->file_rec->fcounters[POSIX_F_META_TIME], \
         __tm1, __tm2, rec_ref->last_meta_end); \
     darshan_add_record_ref(&(posix_runtime->fd_hash), &__ret, sizeof(int), rec_ref); \
+    if(rec_ref->fs_type == LL_SUPER_MAGIC) \
+        darshan_instrument_lustre_file(__path, __ret); \
     if(newpath != __path) free(newpath); \
 } while(0)
@@ -1444,7 +1456,7 @@ static struct posix_file_record_ref *posix_track_new_file_record(
     struct darshan_posix_file *file_rec = NULL;
     struct posix_file_record_ref *rec_ref = NULL;
-    int file_alignment;
     int ret;
     rec_ref = malloc(sizeof(*rec_ref));
@@ -1469,7 +1481,7 @@ static struct posix_file_record_ref *posix_track_new_file_record(
         path,
         DARSHAN_POSIX_MOD,
         sizeof(struct darshan_posix_file),
-        &file_alignment);
+        &fs_info);
     if(!file_rec)
@@ -1483,8 +1495,9 @@ static struct posix_file_record_ref *posix_track_new_file_record(
     file_rec->base_rec.id = rec_id;
     file_rec->base_rec.rank = my_rank;
     file_rec->counters[POSIX_MEM_ALIGNMENT] = darshan_mem_alignment;
-    file_rec->counters[POSIX_FILE_ALIGNMENT] = file_alignment;
+    file_rec->counters[POSIX_FILE_ALIGNMENT] = fs_info.block_size;
     rec_ref->file_rec = file_rec;
+    rec_ref->fs_type = fs_info.fs_type;
     posix_runtime->file_rec_count++;
     return(rec_ref);
--- /dev/null
+++ b/darshan-test/2.x/llapi-perf.c
@@ -0,0 +1,314 @@
+ *  (C) 2012 by Argonne National Laboratory.
+ *      See COPYRIGHT in top-level directory.
+/* llapi-perf.c
+ * Time how long it takes to extract various file data from Lustre via
+ * ioctl and llapi calls from every process.  -i uses ioctl, -a uses the
+ * Lustre API.  This also retains the features of stat-perf.c, which
+ * times how long it takes to issue a stat64() call to the designated file
+ * from every process.  -f causes it to use fstat64() rather than stat64().
+ * -l causes it to use lseek(SEEK_END) instead of stat64().
+ * -c causes it to create the file from scratch rather than operating on an
+ *  existing file.  -r issues a realpath() call on the file.
+#define _LARGEFILE64_SOURCE
+#include <stdio.h>
+#include <fcntl.h>
+#include <string.h>
+#include <sys/time.h>
+#include <mpi.h>
+#include <errno.h>
+#include <getopt.h>
+#ifndef NO_LUSTRE
+#include <lustre/lustreapi.h>
+#endif
+static char* opt_file = NULL;
+static int opt_create = 0;
+static int opt_fstat = 0;
+static int opt_lseek = 0;
+static int opt_realpath = 0;
+static int opt_ioctl = 0;
+static int opt_llapi = 0;
+static int opt_fpp = 0;
+static int rank = -1;
+static int parse_args(int argc, char **argv);
+static void usage(void);
+int main(int argc, char **argv)
+   int fd;
+   int ret;
+   double stime, etime, elapsed, slowest;
+   struct stat64 statbuf;
+   int nprocs;
+   off64_t offset, orig_offset;
+   char* new_path;
+   MPI_Init(&argc,&argv);
+   MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+   MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+   /* parse the command line arguments */
+   parse_args(argc, argv);
+   MPI_Barrier(MPI_COMM_WORLD);
+   /* open specified file */
+   if(!opt_create)
+      fd = open(opt_file, O_RDWR);
+      if(fd < 0)
+         perror("open");
+         exit(1);
+   else
+      /* rank 0 create, everyone else open */
+      if(rank == 0 || opt_fpp)
+         fd = open(opt_file, O_RDWR|O_CREAT|O_EXCL, S_IRUSR|S_IWUSR);
+         if(fd < 0)
+            perror("open");
+            exit(1);
+      else
+         if(fd < 0)
+            perror("open");
+            exit(1);
+   stime = MPI_Wtime();
+   ret = 0;
+   if(opt_fstat)
+      ret = fstat64(fd, &statbuf);
+   else if(opt_lseek)
+      /* find current position */
+      orig_offset = lseek64(fd, 0, SEEK_CUR);
+      if(orig_offset < 0)
+         ret = -1;
+      else
+         /* find end of file; this is the size */
+         offset = lseek64(fd, 0, SEEK_END);
+         if(offset < 0)
+            ret = -1;
+         else
+            /* go back to original position */
+            offset = lseek64(fd, orig_offset, SEEK_SET);
+            if(offset < 0)
+                ret = -1;
+   else if(opt_realpath)
+      new_path = realpath(opt_file, NULL);
+      if(!new_path)
+        ret = -1;
+      else
+        free(new_path);
+   else if ( opt_llapi || opt_ioctl )
+#ifdef NO_LUSTRE
+      fprintf(stderr, "Not compiled with Lustre support\n");
+      ret = -1;
+#else
+      lum = calloc(1, lumsize);
+      if (lum == NULL) {
+         ret = ENOMEM;
+         fprintf(stderr, "No memory\n");
+      else {
+        if ( opt_llapi )
+         ret = llapi_file_get_stripe(opt_file, lum);
+        else if ( opt_ioctl )
+            ret = ioctl( fd, LL_IOC_LOV_GETSTRIPE, (void *)lum );
+#ifdef DEBUG
+        /* different API/ioctl calls populate only parts of lum */
+        printf( "stripe_width=%d stripe_size=%d starting_ost=%d\n",
+             lum->lmm_stripe_count,
+             lum->lmm_stripe_size,
+             lum->lmm_stripe_count );
+#endif
+#endif
+   else
+      ret = stat64(opt_file, &statbuf);
+   if(ret != 0 && !opt_ioctl && !opt_llapi)
+      perror("stat64 or fstat64");
+      exit(1);
+#ifndef NO_LUSTRE
+   else if ( ret < 0 && opt_ioctl )
+      perror("ioctl");
+      exit(1);
+#endif
+   etime = MPI_Wtime();
+   elapsed = etime-stime;
+   ret = MPI_Reduce(&elapsed, &slowest, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD);
+   if(ret != 0)
+      fprintf(stderr, "Error: MPI_Reduce() failure.\n");
+      exit(1);
+   slowest *= 1000.0;
+   if(rank == 0)
+      printf("opt_file: %s, opt_create: %d, opt_fstat: %d, opt_lseek: %d, opt_realpath: %d, opt_llapi: %d, opt_ioctl: %d, opt_fpp: %d, nprocs: %d, time: %f ms\n",
+        opt_file,
+        opt_create,
+        opt_fstat,
+        opt_lseek,
+        opt_realpath,
+        opt_llapi,
+        opt_ioctl,
+        opt_fpp,
+        nprocs,
+        slowest);
+   MPI_Finalize();
+   return(0);
+   int c;
+   while ((c = getopt(argc, argv, "fclripa")) != EOF) {
+      switch (c) {
+         case 'c': /* create file */
+            opt_create = 1;
+            break;
+         case 'f': /* fstat instead of stat */
+            opt_fstat = 1;
+            break;
+         case 'l': /* lseek instead of stat */
+            opt_lseek = 1;
+            break;
+         case 'r': /* realpath instead of stat */
+            opt_realpath = 1;
+            break;
+         case 'i': /* use ioctl test */
+            opt_ioctl = 1;
+            break;
+         case 'a': /* use llapi test*/
+            opt_llapi = 1;
+            break;
+         case 'p': /* file per process instead of shared file */
+            opt_fpp = 1;
+            break;
+         case 'h':
+            if (rank == 0)
+                usage();
+            exit(0);
+         case '?': /* unknown */
+            if (rank == 0)
+                usage();
+            exit(1);
+         default:
+            break;
+   if(opt_lseek + opt_fstat + opt_realpath + opt_ioctl + opt_llapi > 1)
+      fprintf(stderr, "Error: Only specify one of -l, -f, -i, -a, or -r.\n");
+      usage();
+      exit(1);
+   if(argc-optind != 1)
+      if(rank == 0)
+          usage();
+      exit(1);
+   if ( opt_fpp )
+      opt_file = malloc( sizeof(char) * (strlen( argv[optind] ) + 10) );
+      sprintf( opt_file, "%s.%d", argv[optind], rank );
+   else
+      opt_file = strdup(argv[optind]);
+   assert(opt_file);
+   return(0);
+    printf("Usage: stat-perf [<OPTIONS>...] <FILE NAME>\n");
+    printf("\n<OPTIONS> is one or more of\n");
+    printf(" -c       create new file to stat\n");
+    printf(" -p       do file-per-process instead of shared file\n");
+    printf(" -f       use fstat instead of stat\n");
+    printf(" -l       use lseek instead of stat\n");
+    printf(" -r       use realpath instead of stat\n");
+    printf(" -a       use Lustre API test\n");
+    printf(" -i       use ioctl Lustre test\n");
+    printf(" -h       print this help\n");
+ *  c-indent-level: 3
+ *  c-basic-offset: 3
+ *  tab-width: 3
+ * vim: ts=3
+ * End:
--- /dev/null
+++ b/darshan-test/lustre/.gitignore
@@ -0,0 +1,2 @@
+*.o
+darshan-tester
--- /dev/null
+++ b/darshan-test/lustre/Makefile
@@ -0,0 +1,19 @@
+.PHONY: clean
+BINS = darshan-tester darshan-tester-mpi
+OBJS = darshan-lustre.o darshan-core-stub.o
+CFLAGS = -O0 -g -I../.. -I../../darshan-runtime
+### Include -I. when building non-MPI tests to include the mpi.h stub header
+CFLAGS += -I.
+darshan-tester: $(OBJS)
+	$(CC) $(LDFLAGS) $^ $(LOADLIBES) $(LDLIBS) -o $@
+darshan-tester-mpi: $(OBJS)
+darshan-lustre.o: ../../darshan-runtime/lib/darshan-lustre.c
+	$(CC) $(CPPFLAGS) $(CFLAGS) -c $? -o $@
+clean:
+	- at rm -v $(OBJS) $(BINS)
--- /dev/null
+++ b/darshan-test/lustre/darshan-core-stub.c
@@ -0,0 +1,104 @@
+#include "darshan-core.h"
+#include <stdio.h>
+#include <fcntl.h>
+ *  Global variables
+static darshan_record_id next_rec_id = 1;
+static int my_rank = 0;
+static struct darshan_module_funcs mod_funcs;
+ *  Import routines from Lustre module
+extern struct lustre_runtime *lustre_runtime;
+void darshan_core_register_record(
+    void *name,
+    int len,
+    darshan_module_id mod_id,
+    int printable_flag,
+    int mod_limit_flag,
+    darshan_record_id *rec_id,
+    *rec_id = next_rec_id++;
+    if (fs_info)
+        memset( fs_info, 0, sizeof(struct darshan_fs_info) );
+    return;
+void darshan_core_register_module(
+    struct darshan_module_funcs *funcs,
+    int *rank,
+    int *mod_mem_limit,
+    int *sys_mem_alignment)
+/*  if (sys_mem_alignment) *sys_mem_alignment = darshan_mem_alignment; */
+    if (rank) *rank = my_rank;
+    *mod_mem_limit = DARSHAN_MOD_MEM_MAX;
+    mod_funcs = *funcs;
+    return;
+void darshan_core_shutdown()
+    darshan_record_id *mod_shared_recs = NULL;
+    int mod_shared_rec_cnt = 0;
+    void* mod_buf = NULL;
+    int mod_buf_sz = 0;
+    mod_funcs.begin_shutdown();
+    mod_funcs.get_output_data( MPI_COMM_WORLD, mod_shared_recs, mod_shared_rec_cnt, &mod_buf, &mod_buf_sz );
+    print_lustre_runtime();
+    mod_funcs.shutdown();
+    return;
+int main( int argc, char **argv )
+    int fd, i;
+    char *fname;
+    srand(234);
+    /* build Darshan records */
+    for ( i = 1; i < argc; i++ )
+        fname = argv[i];
+        printf( "File %3d - processing %s\n", i, fname );
+        fd = open( fname, O_RDONLY );
+        darshan_instrument_lustre_file( fname, fd );
+        close(fd);
+        (lustre_runtime->record_runtime_array[i]).record->rank = rand() % 10;
+    darshan_core_shutdown();
+    return 0;
--- /dev/null
+++ b/darshan-test/lustre/mpi.h
@@ -0,0 +1,10 @@
+ *  VERY primitive stubs that allow darshan.h to be included in non-MPI
+ *  applications like darshan-tester
+typedef int MPI_Comm;
+typedef int MPI_Datatype;
+typedef int MPI_Op;
+typedef long MPI_Aint;
+unsigned char MPI_BYTE;
+#define MPI_COMM_WORLD 0
--- /dev/null
+++ b/darshan-test/lustre/test-darshan.sh
@@ -0,0 +1,32 @@
+#!/bin/bash
+#  Run the test program through Valgrind to expose memory leaks and buffer
+#  overflows on a variety of different file locations and geometries
+### Make some files to test.  Assume $SCRATCH points at Lustre
+for stripe in 1 2 4 8 16 32
+do
+    if [ ! -f $SCRATCH/stripe${stripe} ]; then
+        lfs setstripe -c $stripe $SCRATCH/stripe${stripe}
+    fi
+done
+set -x
+valgrind --tool=memcheck \
+         --leak-check=yes \
+         --show-reachable=yes \
+         --num-callers=20 \
+         --track-fds=yes \
+         --read-var-info=yes \
+         ./darshan-tester \
+         $SCRATCH/stripe4 \
+         $SCRATCH/stripe32 \
+         $SCRATCH/stripe1 \
+         $SCRATCH/stripe16 \
+         $SCRATCH/stripe8 \
+         $HOME/.bashrc \
+         $SCRATCH/stripe2
+set +x
--- a/darshan-util/Makefile.in
+++ b/darshan-util/Makefile.in
@@ -13,10 +13,10 @@ libdir = $(DESTDIR)@libdir@
 pkgconfigdir = $(DESTDIR)$(libdir)/pkgconfig
-DARSHAN_MOD_LOG_FORMATS = $(srcdir)/../darshan-posix-log-format.h $(srcdir)/../darshan-mpiio-log-format.h $(srcdir)/../darshan-hdf5-log-format.h $(srcdir)/../darshan-pnetcdf-log-format.h
-DARSHAN_MOD_LOGUTIL_HEADERS = darshan-posix-logutils.h darshan-mpiio-logutils.h darshan-hdf5-logutils.h darshan-pnetcdf-logutils.h
-DARSHAN_STATIC_MOD_OBJS = darshan-posix-logutils.o darshan-mpiio-logutils.o darshan-hdf5-logutils.o darshan-pnetcdf-logutils.o darshan-bgq-logutils.o
-DARSHAN_DYNAMIC_MOD_OBJS = darshan-posix-logutils.po darshan-mpiio-logutils.po darshan-hdf5-logutils.po darshan-pnetcdf-logutils.po darshan-bgq-logutils.po
+DARSHAN_MOD_LOG_FORMATS = $(srcdir)/../darshan-posix-log-format.h $(srcdir)/../darshan-mpiio-log-format.h $(srcdir)/../darshan-hdf5-log-format.h $(srcdir)/../darshan-pnetcdf-log-format.h $(srcdir)/../darshan-lustre-log-format.h
+DARSHAN_MOD_LOGUTIL_HEADERS = darshan-posix-logutils.h darshan-mpiio-logutils.h darshan-hdf5-logutils.h darshan-pnetcdf-logutils.h darshan-lustre-logutils.h
+DARSHAN_STATIC_MOD_OBJS = darshan-posix-logutils.o darshan-mpiio-logutils.o darshan-hdf5-logutils.o darshan-pnetcdf-logutils.o darshan-bgq-logutils.o darshan-lustre-logutils.o
+DARSHAN_DYNAMIC_MOD_OBJS = darshan-posix-logutils.po darshan-mpiio-logutils.po darshan-hdf5-logutils.po darshan-pnetcdf-logutils.po darshan-bgq-logutils.po darshan-lustre-logutils.po
 DARSHAN_ENABLE_SHARED=@DARSHAN_ENABLE_SHARED@
@@ -81,6 +81,11 @@ darshan-bgq-logutils.o: darshan-bgq-logutils.c darshan-logutils.h darshan-bgq-lo
 darshan-bgq-logutils.po: darshan-bgq-logutils.c darshan-logutils.h darshan-bgq-logutils.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-bgq-log-format.h | uthash-1.9.2
+darshan-lustre-logutils.o: darshan-lustre-logutils.c darshan-logutils.h darshan-lustre-logutils.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-lustre-log-format.h | uthash-1.9.2
+darshan-lustre-logutils.po: darshan-lustre-logutils.c darshan-logutils.h darshan-lustre-logutils.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-lustre-log-format.h | uthash-1.9.2
 libdarshan-util.a: darshan-logutils.o $(DARSHAN_STATIC_MOD_OBJS)
 	ar rcs libdarshan-util.a $^
--- a/darshan-util/darshan-convert.c
+++ b/darshan-util/darshan-convert.c
@@ -19,8 +19,6 @@
 #include "darshan-logutils.h"
-#define DEF_MOD_BUF_SIZE 1024 /* 1 KiB is enough for all current mod records ... */
 extern uint32_t darshan_hashlittle(const void *key, size_t length, uint32_t initval);
 int usage (char *exename)
@@ -343,6 +341,14 @@ int main(int argc, char **argv)
         return(-1);
+    mod_buf = malloc(DEF_MOD_BUF_SIZE);
+    if (!mod_buf)
+        darshan_log_close(infile);
+        darshan_log_close(outfile);
+        return(-1);
     /* loop over each module and convert it's data to the new format */
     for(i=0; i<DARSHAN_MAX_MODS; i++)
@@ -369,6 +375,7 @@ int main(int argc, char **argv)
             unlink(outfile_name);
+            free(mod_buf);
             return(-1);
@@ -391,6 +398,7 @@ int main(int argc, char **argv)
         } while((ret = mod_logutils[i]->log_get_record(infile, mod_buf)) == 1);
+    free(mod_buf);
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -17,6 +17,11 @@
 #include "darshan-log-format.h"
+/* Maximum size of a record - Lustre OST lists can get huge, but 81920 is enough
+ * for 10K OSTs
+#define DEF_MOD_BUF_SIZE 81920 /* 640 KiB */
 struct darshan_fd_int_state;
 /* darshan file descriptor definition */
@@ -120,6 +125,7 @@ extern struct darshan_mod_logutil_funcs *mod_logutils[];
 #include "darshan-hdf5-logutils.h"
 #include "darshan-pnetcdf-logutils.h"
 #include "darshan-bgq-logutils.h"
+#include "darshan-lustre-logutils.h"
 darshan_fd darshan_log_open(const char *name);
 darshan_fd darshan_log_create(const char *name, enum darshan_comp_type comp_type,
--- /dev/null
+++ b/darshan-util/darshan-lustre-logutils.c
@@ -0,0 +1,232 @@
+#include "darshan-util-config.h"
+#include <stdio.h>
+#include <inttypes.h>
+#include "darshan-logutils.h"
+/* counter name strings for the LUSTRE module */
+#define X(a) #a,
+char *lustre_counter_names[] = {
+    LUSTRE_COUNTERS
+#undef X
+static int darshan_log_get_lustre_record(darshan_fd fd, void* lustre_buf,
+    darshan_record_id* rec_id);
+static int darshan_log_put_lustre_record(darshan_fd fd, void* lustre_buf, int ver);
+static void darshan_log_print_lustre_record(void *file_rec,
+    char *file_name, char *mnt_pt, char *fs_type, int ver);
+static void darshan_log_print_lustre_description(void);
+static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
+    void *rec2, char *file_name2);
+struct darshan_mod_logutil_funcs lustre_logutils =
+    .log_get_record = &darshan_log_get_lustre_record,
+    .log_put_record = &darshan_log_put_lustre_record,
+    .log_print_record = &darshan_log_print_lustre_record,
+    .log_print_description = &darshan_log_print_lustre_description,
+    .log_print_diff = &darshan_log_print_lustre_record_diff
+    int i;
+    int ret;
+    /* retrieve the fixed-size portion of the record */
+    ret = darshan_log_getmod(fd, DARSHAN_LUSTRE_MOD, lustre_buf,
+        sizeof(struct darshan_lustre_record));
+    if(ret < 0)
+        return(-1);
+    else if(ret < sizeof(struct darshan_lustre_record))
+        return(0);
+    rec = (struct darshan_lustre_record *)lustre_buf;
+    /* swap bytes if necessary */
+    if(fd->swap_flag)
+        DARSHAN_BSWAP64(&rec->rec_id);
+        DARSHAN_BSWAP64(&rec->rank);
+        for(i=0; i<LUSTRE_NUM_INDICES; i++)
+            DARSHAN_BSWAP64(&rec->counters[i]);
+    /* now read the rest of the record */
+    if ( rec->counters[LUSTRE_STRIPE_WIDTH] > 1 ) {
+            fd,
+            (void*)(&(rec->ost_ids[1])),
+            (rec->counters[LUSTRE_STRIPE_WIDTH] - 1)*sizeof(OST_ID)
+        if(ret < 0)
+            return(-1);
+        else if(ret < (rec->counters[LUSTRE_STRIPE_WIDTH] - 1)*sizeof(OST_ID))
+            return(0);
+        if ( fd->swap_flag )
+            for (i = 1; i < rec->counters[LUSTRE_STRIPE_WIDTH]; i++ )
+                DARSHAN_BSWAP64(&(rec->ost_ids[i]));
+    *rec_id = rec->rec_id;
+    return(1);
+    struct darshan_lustre_record *rec = (struct darshan_lustre_record *)lustre_buf;
+    int ret;
+    ret = darshan_log_putmod(fd, DARSHAN_LUSTRE_MOD, rec,
+        LUSTRE_RECORD_SIZE(rec->counters[LUSTRE_STRIPE_WIDTH]), ver);
+    if(ret < 0)
+        return(-1);
+    return(0);
+static void darshan_log_print_lustre_record(void *rec, char *file_name,
+    char *mnt_pt, char *fs_type, int ver)
+    int i;
+    struct darshan_lustre_record *lustre_rec =
+        (struct darshan_lustre_record *)rec;
+        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_LUSTRE_MOD],
+            lustre_rec->rank, lustre_rec->rec_id, lustre_counter_names[i],
+            lustre_rec->counters[i], file_name, mnt_pt, fs_type);
+    for (i = 0; i < lustre_rec->counters[LUSTRE_STRIPE_WIDTH]; i++ )
+        char strbuf[25];
+        snprintf( strbuf, 25, "LUSTRE_OST_ID_%d", i );
+            lustre_rec->rank,
+            lustre_rec->rec_id,
+            strbuf,
+            lustre_rec->ost_ids[i],
+            file_name,
+            mnt_pt,
+            fs_type);
+    return;
+static void darshan_log_print_lustre_description()
+    /* TODO: add actual counter descriptions here */
+    printf("\n# description of LUSTRE counters:\n");
+    printf("#   LUSTRE_OSTS: number of OSTs across the entire file system.\n");
+    printf("#   LUSTRE_MDTS: number of MDTs across the entire file system.\n");
+    printf("#   LUSTRE_STRIPE_SIZE: stripe size for file in bytes.\n");
+    printf("#   LUSTRE_STRIPE_WIDTH: number of OSTs over which file is striped.\n");
+    printf("#   LUSTRE_STRIPE_OFFSET: OST ID offset specified when the file was created.\n");
+    printf("#   LUSTRE_OST_ID_*: indices of OSTs over which the file is striped.\n");
+    DARSHAN_PRINT_HEADER();
+    return;
+    struct darshan_lustre_record *lustre_rec1 = (struct darshan_lustre_record *)rec1;
+    struct darshan_lustre_record *lustre_rec2 = (struct darshan_lustre_record *)rec2;
+    int i;
+    /* NOTE: we assume that both input records are the same module format version */
+        if(!lustre_rec2)
+            printf("- ");
+                lustre_rec1->rank, lustre_rec1->rec_id, lustre_counter_names[i],
+                lustre_rec1->counters[i], file_name1, "", "");
+        else if(!lustre_rec1)
+            printf("+ ");
+                lustre_rec2->rank, lustre_rec2->rec_id, lustre_counter_names[i],
+                lustre_rec2->counters[i], file_name2, "", "");
+        else if(lustre_rec1->counters[i] != lustre_rec2->counters[i])
+            printf("- ");
+            printf("+ ");
+    /* would it be more or less useful to sort the OST IDs before comparing? */
+    if ( lustre_rec1->counters[LUSTRE_STRIPE_WIDTH] == lustre_rec2->counters[LUSTRE_STRIPE_WIDTH] ) {
+        for (i = 0; i < lustre_rec1->counters[LUSTRE_STRIPE_WIDTH]; i++ )
+            if (lustre_rec1->ost_ids[i] != lustre_rec2->ost_ids[i])
+                char strbuf[25];
+                printf("- ");
+                    lustre_rec1->rec_id,
+                    strbuf,
+                    lustre_rec1->ost_ids[i],
+                    file_name1,
+                printf("+ ");
+                    lustre_rec2->rec_id,
+                    strbuf,
+                    lustre_rec2->ost_ids[i],
+                    file_name2,
+    return;
+ * End:
--- /dev/null
+++ b/darshan-util/darshan-lustre-logutils.h
@@ -0,0 +1,14 @@
+#ifndef __DARSHAN_LUSTRE_LOG_UTILS_H
+#define __DARSHAN_LUSTRE_LOG_UTILS_H
+extern char *lustre_counter_names[];
+extern struct darshan_mod_logutil_funcs lustre_logutils;
+#endif
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -20,8 +20,6 @@
  * Options
@@ -213,7 +211,7 @@ int main(int argc, char **argv)
     char *save;
     char buffer[DARSHAN_JOB_METADATA_LEN];
     int empty_mods = 0;
-    char mod_buf[DEF_MOD_BUF_SIZE];
+    char *mod_buf;
     hash_entry_t *file_hash = NULL;
     hash_entry_t *curr = NULL;
@@ -364,6 +362,12 @@ int main(int argc, char **argv)
         memset(pdata.rank_cumul_md_time, 0, sizeof(double)*job.nprocs);
+    if (!mod_buf) {
+        darshan_log_close(fd);
+        return(-1);
         struct darshan_base_record *base_rec;
@@ -650,6 +654,7 @@ cleanup:
     free(pdata.rank_cumul_io_time);
     free(pdata.rank_cumul_md_time);
+    free(mod_buf);
     /* free record hash data */
     HASH_ITER(hlink, name_hash, ref, tmp_ref)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/301fd4921716685494a7365adec22e3bf7a9b15d...2a22e1ffdbd81753756ba7c1595481d89e51f65e
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160628/f1bc3f17/attachment-0001.html>
More information about the Darshan-commits mailing list
