[Darshan-commits] [Git][darshan/darshan][master] 83 commits: first cut at mmap logic -- posix mod only for now
Shane Snyder
xgitlab at cels.anl.gov
Mon Jun 20 21:25:49 CDT 2016
Shane Snyder pushed to branch master at darshan / darshan
Commits:
0d84b5e5 by Shane Snyder at 2015-10-12T14:42:13-05:00
c3c5e597 by Shane Snyder at 2015-10-13T16:44:32-05:00
more mmap logic and instrumentation for testing
e810279e by Shane Snyder at 2015-11-11T15:43:27-06:00
Merge branch 'dev-modular' into mmap-dev
Conflicts:
darshan-runtime/darshan-core.h
darshan-runtime/lib/darshan-core.c
799d9890 by Shane Snyder at 2015-11-24T14:45:31-06:00
update logutils to allow logs with only job info
bdb2a5f0 by Shane Snyder at 2015-12-01T12:40:28-06:00
runtime now mmaps header and job data to tmp log
3b0c668b by Shane Snyder at 2015-12-02T14:36:19-06:00
update logutils to read uncompressed log files
4f1b27ad by Shane Snyder at 2015-12-02T15:18:33-06:00
bug fix in mmap region pointer assignment
b1791172 by Shane Snyder at 2015-12-03T16:20:34-06:00
updated logutils hash read deserialization method
523b19e4 by Shane Snyder at 2015-12-03T16:22:25-06:00
update core runtime record hash implementation
Now, as the app executes, darshan-core persists the id->name
mapping data to the tmp log file. This is done by serializing the
id->name mapping to the mmap log file region when new records are
registered.
376eefa8 by Shane Snyder at 2015-12-04T10:20:47-06:00
modify register_record routine used by modules
Now, register_record() accepts an argument for the size of
the record being registered, and this is used to track how much
data each module has stored in their allocated memory region.
9193b34a by Shane Snyder at 2015-12-04T11:10:14-06:00
add new utility to stitch together darshan logs
c9618c8a by Shane Snyder at 2015-12-04T13:52:19-06:00
runtime now stores mnt & exe data at all ranks
4ac75905 by Shane Snyder at 2015-12-04T15:18:06-06:00
modify hash write routine to use new serialization
66a83b03 by Shane Snyder at 2015-12-07T13:25:52-06:00
first cut at the stitch logs utility
Currently, this tool can take a set of temporary, uncompressed log
files on a given node, and combine into a single darshan log.
Next step would be to modify this code to perform shared file
reduction logic to combine per-node log files into per-job log
files.
cb1c7ace by Shane Snyder at 2015-12-08T15:04:41-06:00
change runtime darshan record_ref struct
9d7f638b by Shane Snyder at 2015-12-08T15:16:19-06:00
change util record ref structure def
05acb6d4 by Shane Snyder at 2015-12-08T16:07:43-06:00
introduce base record concept in posix mod
ed103a2a by Shane Snyder at 2015-12-08T16:22:23-06:00
add base record concept to utilities
be3912a8 by Shane Snyder at 2015-12-09T10:28:40-06:00
update utilities and log format to use base rec
fe340438 by Shane Snyder at 2015-12-14T12:48:15-06:00
add an aggregation routine to module logutils
a84e8657 by Shane Snyder at 2015-12-17T16:54:46-06:00
integrate normal darshan shutdown back into code
80c07c27 by Shane Snyder at 2015-12-17T16:55:11-06:00
more darshan-util updates for handling tmp logs
cc498bfa by Shane Snyder at 2016-01-14T16:16:55-06:00
minor reorganization of some runtime code
b989ffe4 by Shane Snyder at 2016-01-14T16:20:15-06:00
integrate new darshan-diff util in mmap branch
c52fed2a by Shane Snyder at 2016-01-14T16:22:32-06:00
typos in darshan-diff
032f99b4 by Shane Snyder at 2016-01-14T16:42:37-06:00
forgot to install diff utility in makefile
d3fae782 by Shane Snyder at 2016-01-18T21:42:11-06:00
update how module & record registration
- modules now receive a memory buffer after successfully
registering with darshan-core. modules can request a specific
memory amount, but may not be honored depending on the configured
darshan memory limit
- split the previous register_record function into 2 parts:
* lookup() -> lookup darshan_record_id corresp. to path name
* register() -> register record_id & name with darshan-core
- register_record now returns true if the record added; false
otherwise (if module was out of memory or darshan is out of memory
for storing id->name mappings)
f78c456f by Shane Snyder at 2016-01-19T12:57:25-06:00
apply mmap code changes to other i/o modules
265bdaba by Shane Snyder at 2016-01-19T16:18:22-06:00
Conflicts:
darshan-runtime/Makefile.in
darshan-util/Makefile.in
darshan-util/darshan-bgq-logutils.c
darshan-util/darshan-diff.c
darshan-util/darshan-hdf5-logutils.c
darshan-util/darshan-logutils.c
darshan-util/darshan-mpiio-logutils.c
darshan-util/darshan-null-logutils.c
darshan-util/darshan-parser.c
darshan-util/darshan-pnetcdf-logutils.c
darshan-util/darshan-posix-logutils.c
96801d4a by Shane Snyder at 2016-01-19T17:44:11-06:00
fix post-merge build errors
dev-modular should be completely merged into mmap-dev branch
f57f753c by Shane Snyder at 2016-01-20T16:03:28-06:00
bug fixes from merge of mmap-dev to dev-modular
10c3b107 by Shane Snyder at 2016-01-20T22:21:28-06:00
bug fix in log aggregation tool
d3ebeb50 by Shane Snyder at 2016-01-20T22:21:43-06:00
add aggregation capability to i/o modules
ac6c6442 by Shane Snyder at 2016-01-22T10:08:27-06:00
bug fix in darshan put_header routine
d5abad0f by Shane Snyder at 2016-01-22T10:53:52-06:00
remove profiling macros from posix module
bb25083b by Shane Snyder at 2016-01-25T13:19:59-06:00
rename merge log utility
e81a9cae by Shane Snyder at 2016-01-25T15:56:06-06:00
autconf/runtime changes for configuring mmap code
8070c831 by Shane Snyder at 2016-01-26T12:59:32-06:00
update command line args for log merging utility
b4be0abd by Shane Snyder at 2016-01-26T13:00:11-06:00
allreduce job start time in darshan-core init.
5f4e06f6 by Shane Snyder at 2016-01-26T13:02:54-06:00
autogenerate an example epilog script
c276e4c2 by Shane Snyder at 2016-01-29T13:00:26-06:00
first cut at unifying mmap feature with darshan
a22233d7 by Shane Snyder at 2016-01-29T15:40:17-06:00
improve slurm epilog script
epilog will now skip on-node compression if only a single compute
node is used and will generate the final log file instead
bb625cbd by Shane Snyder at 2016-02-05T13:53:21-06:00
allow common counters to be updated on the go
37b1bb02 by Shane Snyder at 2016-02-05T17:27:54-06:00
add common counter aggregation to logutils
f26baefc by Shane Snyder at 2016-02-26T12:34:02-06:00
allow job end time to be set by darshan-merge
d4a3d112 by Shane Snyder at 2016-02-29T17:22:57-06:00
add variance counter reduction logic to logutils
04063da7 by Shane Snyder at 2016-03-01T17:43:38-06:00
common access counters are now sorted in logs
common value counters are sorted first by decreasing counts,
and then by decreasing size.
94430f41 by Shane Snyder at 2016-03-01T18:30:08-06:00
bug fix in aggregating common accesses
d6dad7f3 by Shane Snyder at 2016-05-26T12:29:34-05:00
add variable-length definition of name records
also some code clean up to change references of record hash
to name hash to be more clear about what it is actually storing.
999ee9c8 by Shane Snyder at 2016-05-26T12:53:05-05:00
darshan-util edits for var. length name records
8f463e51 by Shane Snyder at 2016-05-27T15:10:12-05:00
remove shared name records on nonzero ranks
7d35c45a by Shane Snyder at 2016-05-27T16:36:32-05:00
register/lookup_record now use strings explicitly
bfde9eb7 by Shane Snyder at 2016-05-31T15:47:51-05:00
numerous darshan-core api changes
- memory management is now entirely handled by darshan-core for
module records
* when registering new records, darshan-core returns the
corresponding buffer to write it to, rather than allowing
module to determine this
- modules now decide whether darshan-core should track record
names by passing either a valid name or NULL to the register
function
* this allows modules to register records that aren't really
tracked by darshan-core
- only the POSIX module has been ported to new changes for this
commit
9bfc7b65 by Shane Snyder at 2016-06-06T17:16:31-05:00
add record_ref interface to darshan-common
This interface provides some convenience functions for mapping
opaque record identifiers (could be a filename, file descriptor,
or any other type of file handle) to a corresponding runtime
structure referencing the actual file record. This runtime
structure should at least contain a pointer to the actual file
record, and can also persist arbitrary state for this record.
d8f3575a by Shane Snyder at 2016-06-08T16:58:23-05:00
darshan-core code and documentation cleanup
Cleanup the structure and documenation of the code to be in sync
with the new mmap version of Darshan. In particular, I made sure
all extra mmap logic was properly ifdef wrapped so it's more clear
which portions of the code are responsible for implementing that
feature.
54baa7dd by Shane Snyder at 2016-06-08T17:34:05-05:00
fix comment and shuffle some more code
fed37946 by Shane Snyder at 2016-06-09T12:06:25-05:00
convert to a single module shutdown function
rather than using 'begin_shutdown', 'get_output_data', and
'shutdown', we combine all three into one shutdown routine.
660130d9 by Shane Snyder at 2016-06-09T12:07:28-05:00
posix mod cleanup + shutdown func update
abf1d5ea by Shane Snyder at 2016-06-10T09:57:50-05:00
some more POSIX and common code cleanup
31e76e2c by Shane Snyder at 2016-06-10T09:58:06-05:00
update MPI-IO module to reflect recent changes
533d7fb2 by Shane Snyder at 2016-06-10T12:30:42-05:00
port hdf5 and pnetcdf modules to new API changes
a974efee by Shane Snyder at 2016-06-10T16:05:28-05:00
Merge branch 'master' into mmap-dev
Conflicts:
darshan-runtime/configure
darshan-runtime/configure.in
darshan-runtime/darshan.h
darshan-runtime/lib/darshan-hdf5.c
darshan-runtime/lib/darshan-mpiio.c
darshan-runtime/lib/darshan-pnetcdf.c
darshan-runtime/lib/darshan-posix.c
darshan-util/darshan-convert.c
darshan-util/darshan-logutils.h
69c954df by Shane Snyder at 2016-06-10T16:15:49-05:00
fix out-of-tree makefile bug in darshan-util
d599c583 by Shane Snyder at 2016-06-13T12:39:49-05:00
modifications for sorting module records
A common record comparision/sort routine is now defined in
darshan-common which can be used by any modules with fixed-length
records and whose records first field is the darshan_base_record.
The comparison was also updated to sort secondarily by darshan
record identifier to resolve a potential bug in the way we have
traditionally sorted the records.
30c06099 by Shane Snyder at 2016-06-13T21:44:26+00:00
fix compile error when mmap is disabled
c407379a by Shane Snyder at 2016-06-14T16:08:02+00:00
bug fix in initializing static modules
fba89f42 by Shane Snyder at 2016-06-14T16:08:36+00:00
port bgq module over to new interface changes
246c491e by Shane Snyder at 2016-06-14T16:56:34+00:00
parser shouldn't abort with no-name records
f5ff61de by Shane Snyder at 2016-06-14T14:46:15-05:00
simplify common counter logic
f6769e56 by Shane Snyder at 2016-06-16T19:21:22-05:00
logutil backwards compatibility for name records
936d1e10 by Shane Snyder at 2016-06-17T13:27:31-05:00
cleanup comments in darshan-common
538812e4 by Shane Snyder at 2016-06-17T14:29:13-05:00
cleanup makefile & autoconf mmap detection
080c680d by Shane Snyder at 2016-06-17T14:32:07-05:00
fix comment in darshan-config
927b8773 by Shane Snyder at 2016-06-17T16:39:58-05:00
ifdef wrap mmap #define
bb9d68c0 by Shane Snyder at 2016-06-17T16:40:27-05:00
honor DARSHAN_MODMEM env variable
ba0f880b by Shane Snyder at 2016-06-17T16:51:11-05:00
fix comments in module log format headers
b70be200 by Shane Snyder at 2016-06-17T18:29:14-05:00
port NULL module over to new API changes
0d2cb76b by Shane Snyder at 2016-06-17T20:13:21-05:00
text edits in darshan-runtime docs
ddd83318 by Shane Snyder at 2016-06-20T15:47:44-05:00
bug fix to byte swap module version array
f3afdb75 by Shane Snyder at 2016-06-20T16:03:11-05:00
move back-compat code out of dedicated directory
6ccaea46 by Shane Snyder at 2016-06-20T20:50:29-05:00
bgq backwards compatibility code
bb75028f by Shane Snyder at 2016-06-20T20:50:29-05:00
remove old modularization design docs
099470b3 by Shane Snyder at 2016-06-20T21:02:22-05:00
Merge remote-tracking branch 'origin/mmap-dev'
Merging mmap feature development branch back into master. Darshan
can now mmap its data structures to temporary log files at runtime to
protect against applications that do not call MPI_Finalize. Feature
can be enabled at configure time using '--enable-mmap-logs'.
20 changed files:
- darshan-bgq-log-format.h
- darshan-hdf5-log-format.h
- darshan-log-format.h
- darshan-mpiio-log-format.h
- darshan-null-log-format.h
- darshan-pnetcdf-log-format.h
- darshan-posix-log-format.h
- darshan-runtime/Makefile.in
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/darshan-common.h
- darshan-runtime/darshan-config.in
- darshan-runtime/darshan-core.h
- darshan-runtime/darshan-runtime-config.h.in
- darshan-runtime/darshan.h
- darshan-runtime/doc/darshan-runtime.txt
- darshan-runtime/lib/darshan-bgq.c
- darshan-runtime/lib/darshan-common.c
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-hdf5.c
The diff was not included because it is too large.
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/a6e8682980f49039d4f15194840139857291f216...099470b3c45fcc3790b03f7992bb953a838239c2
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160620/a50ed965/attachment-0001.html>
More information about the Darshan-commits
