[Darshan-commits] [Git][darshan/darshan][mmap-dev] 2 commits: allow common counters to be updated on the go
Shane Snyder
xgitlab at cels.anl.gov
Fri Feb 5 17:32:06 CST 2016
Shane Snyder pushed to branch mmap-dev at darshan / darshan
Commits:
bb625cbd by Shane Snyder at 2016-02-05T13:53:21-06:00
37b1bb02 by Shane Snyder at 2016-02-05T17:27:54-06:00
add common counter aggregation to logutils
6 changed files:
- darshan-runtime/darshan-common.h
- darshan-runtime/lib/darshan-common.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/darshan-posix.c
- darshan-util/darshan-mpiio-logutils.c
- darshan-util/darshan-posix-logutils.c
Changes:
--- a/darshan-runtime/darshan-common.h
+++ b/darshan-runtime/darshan-common.h
@@ -73,18 +73,24 @@
* base of the value counters (i.e., the first of 4 contiguous common value
* counters) and __cnt_p is a pointer to the base of the count counters (i.e.
* the first of 4 contiguous common count counters). It is assumed your counters
- * are stored as int64_t types.
+ * are stored as int64_t types. __online_flag is set if the common val counters are
+ * updated during runtime (as opposed to being updated once at darshan shutdown time).
-#define DARSHAN_COMMON_VAL_COUNTER_INC(__val_p, __cnt_p, __value, __count) do {\
+#define DARSHAN_COMMON_VAL_COUNTER_INC(__val_p, __cnt_p, __value, __count, __online_flag) do {\
int i; \
int set = 0; \
int64_t min = *(__cnt_p); \
int min_index = 0; \
+ int inc_count; \
if(__value == 0) break; \
+ if(__online_flag) \
+ inc_count = 1; \
+ else \
+ inc_count = __count; \
for(i=0; i<4; i++) { \
/* increment bucket if already exists */ \
if(*(__val_p + i) == __value) { \
- *(__cnt_p + i) += __count; \
+ *(__cnt_p + i) += inc_count; \
set = 1; \
break; \
@@ -138,7 +144,7 @@ struct darshan_variance_dt
* path string.
char* darshan_clean_file_path(
- const char* path);
+ const char *path);
/* darshan_common_val_counter()
@@ -148,13 +154,19 @@ char* darshan_clean_file_path(
* used by a specific module, for instance. 'common_val_root' is the
* root pointer for the tree which stores common value info,
* 'common_val_count' is a pointer to the number of nodes in the
- * tree (i.e., the number of allocated common value counters), and
- * 'val' is the new value to attempt to add.
+ * tree (i.e., the number of allocated common value counters), 'val'
+ * is the new value to attempt to add, 'val_p' is a pointer to the
+ * base counter (i.e., the first) of the common values (which are
+ * assumed to be 4 total and contiguous in memory), and 'cnt_p' is
+ * a pointer to the base counter of the common counts (which are
+ * again expected to be contiguous in memory).
void darshan_common_val_counter(
- void** common_val_root,
- int* common_val_count,
- int64_t val);
+ void **common_val_root,
+ int *common_val_count,
+ int64_t val,
+ int64_t *val_p,
+ int64_t *cnt_p);
/* darshan_walk_common_vals()
@@ -168,9 +180,9 @@ void darshan_common_val_counter(
* (which are again expected to be contiguous in memory).
void darshan_walk_common_vals(
- void* common_val_root,
- int64_t* val_p,
- int64_t* cnt_p);
+ void *common_val_root,
+ int64_t *val_p,
+ int64_t *cnt_p);
/* darshan_variance_reduce()
--- a/darshan-runtime/lib/darshan-common.c
+++ b/darshan-runtime/lib/darshan-common.c
@@ -83,7 +83,7 @@ static int64_t* walker_val_p = NULL;
static int64_t* walker_cnt_p = NULL;
void darshan_common_val_counter(void **common_val_root, int *common_val_count,
- int64_t val)
+ int64_t val, int64_t *common_val_p, int64_t *common_cnt_p)
struct darshan_common_val_counter* counter;
struct darshan_common_val_counter* found;
@@ -102,12 +102,10 @@ void darshan_common_val_counter(void **common_val_root, int *common_val_count,
found = *(struct darshan_common_val_counter**)tmp;
found->freq++;
- return;
- /* we can add a new one as long as we haven't hit the limit */
- if(*common_val_count < DARSHAN_COMMON_VAL_MAX_RUNTIME_COUNT)
+ else if(*common_val_count < DARSHAN_COMMON_VAL_MAX_RUNTIME_COUNT)
+ /* we can add a new one as long as we haven't hit the limit */
counter = malloc(sizeof(*counter));
if(!counter)
@@ -127,22 +125,28 @@ void darshan_common_val_counter(void **common_val_root, int *common_val_count,
(*common_val_count)++;
+#ifdef __DARSHAN_ENABLE_MMAP_LOGS
+ /* if we are using darshan's mmap feature, update common access
+ * counters as we go
+ DARSHAN_COMMON_VAL_COUNTER_INC(common_val_p, common_cnt_p,
+ found->val, found->freq, 1);
+#endif
return;
-void darshan_walk_common_vals(void *common_val_root, int64_t* val_p,
- int64_t* cnt_p)
+void darshan_walk_common_vals(void *common_val_root, int64_t *val_p,
+ int64_t *cnt_p)
walker_val_p = val_p;
walker_cnt_p = cnt_p;
twalk(common_val_root, darshan_common_val_walker);
- tdestroy(common_val_root, free);
return;
-static void darshan_common_val_walker(const void* nodep, const VISIT which,
+static void darshan_common_val_walker(const void *nodep, const VISIT which,
const int depth)
@@ -153,7 +157,7 @@ static void darshan_common_val_walker(const void* nodep, const VISIT which,
case leaf:
counter = *(struct darshan_common_val_counter**)nodep;
DARSHAN_COMMON_VAL_COUNTER_INC(walker_val_p, walker_cnt_p,
- counter->val, counter->freq);
+ counter->val, counter->freq, 0);
default:
break;
@@ -161,7 +165,7 @@ static void darshan_common_val_walker(const void* nodep, const VISIT which,
return;
-static int darshan_common_val_compare(const void* a_p, const void* b_p)
+static int darshan_common_val_compare(const void *a_p, const void *b_p)
const struct darshan_common_val_counter* a = a_p;
const struct darshan_common_val_counter* b = b_p;
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -4,6 +4,9 @@
+#define _XOPEN_SOURCE 500
+#define _GNU_SOURCE
#include "darshan-runtime-config.h"
#include <stdio.h>
#include <unistd.h>
@@ -17,7 +20,6 @@
#include <errno.h>
#include <search.h>
#include <assert.h>
-#define __USE_GNU
#include <pthread.h>
#include "uthash.h"
@@ -138,7 +140,9 @@ static void mpiio_shutdown(void);
DARSHAN_MPI_CALL(PMPI_Type_size)(__datatype, &size); \
size = size * __count; \
DARSHAN_BUCKET_INC(&(file->file_record->counters[MPIIO_SIZE_READ_AGG_0_100]), size); \
- darshan_common_val_counter(&file->access_root, &file->access_count, size); \
+ darshan_common_val_counter(&file->access_root, &file->access_count, size, \
+ &(file->file_record->counters[MPIIO_ACCESS1_ACCESS]), \
+ &(file->file_record->counters[MPIIO_ACCESS1_COUNT])); \
file->file_record->counters[MPIIO_BYTES_READ] += size; \
file->file_record->counters[__counter] += 1; \
if(file->last_io_type == DARSHAN_IO_WRITE) \
@@ -150,7 +154,8 @@ static void mpiio_shutdown(void);
if(file->file_record->fcounters[MPIIO_F_MAX_READ_TIME] < __elapsed) { \
file->file_record->fcounters[MPIIO_F_MAX_READ_TIME] = __elapsed; \
file->file_record->counters[MPIIO_MAX_READ_TIME_SIZE] = size; } \
- DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[MPIIO_F_READ_TIME], __tm1, __tm2, file->last_read_end); \
+ DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[MPIIO_F_READ_TIME], \
+ __tm1, __tm2, file->last_read_end); \
} while(0)
#define MPIIO_RECORD_WRITE(__ret, __fh, __count, __datatype, __counter, __tm1, __tm2) do { \
@@ -163,7 +168,9 @@ static void mpiio_shutdown(void);
DARSHAN_BUCKET_INC(&(file->file_record->counters[MPIIO_SIZE_WRITE_AGG_0_100]), size); \
file->file_record->counters[MPIIO_BYTES_WRITTEN] += size; \
if(file->last_io_type == DARSHAN_IO_READ) \
@@ -175,7 +182,8 @@ static void mpiio_shutdown(void);
if(file->file_record->fcounters[MPIIO_F_MAX_WRITE_TIME] < __elapsed) { \
file->file_record->fcounters[MPIIO_F_MAX_WRITE_TIME] = __elapsed; \
file->file_record->counters[MPIIO_MAX_WRITE_TIME_SIZE] = size; } \
- DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[MPIIO_F_WRITE_TIME], __tm1, __tm2, file->last_write_end); \
+ DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[MPIIO_F_WRITE_TIME], \
+ __tm1, __tm2, file->last_write_end); \
} while(0)
@@ -1088,7 +1096,7 @@ static void mpiio_record_reduction_op(
DARSHAN_COMMON_VAL_COUNTER_INC(&(tmp_file.counters[MPIIO_ACCESS1_ACCESS]),
&(tmp_file.counters[MPIIO_ACCESS1_COUNT]), infile->counters[j],
- infile->counters[j+4]);
+ infile->counters[j+4], 0);
/* second set */
@@ -1096,7 +1104,7 @@ static void mpiio_record_reduction_op(
&(tmp_file.counters[MPIIO_ACCESS1_COUNT]), inoutfile->counters[j],
- inoutfile->counters[j+4]);
+ inoutfile->counters[j+4], 0);
/* min non-zero (if available) value */
@@ -1328,10 +1336,18 @@ static void mpiio_get_output_data(
tmp = &(mpiio_runtime->file_runtime_array[i]);
+#ifndef __DARSHAN_ENABLE_MMAP_LOGS
+ /* walk common counters to get 4 most common -- only if mmap
+ * feature is disabled (mmap updates counters on the go)
/* common access sizes */
darshan_walk_common_vals(tmp->access_root,
&(tmp->file_record->counters[MPIIO_ACCESS1_ACCESS]),
&(tmp->file_record->counters[MPIIO_ACCESS1_COUNT]));
+#endif
+ tdestroy(tmp->access_root, free);
/* if there are globally shared files, do a shared file reduction */
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -220,7 +220,8 @@ static void posix_shutdown(void);
file->file_record->counters[POSIX_OPENS] += 1; \
if(file->file_record->fcounters[POSIX_F_OPEN_TIMESTAMP] == 0) \
file->file_record->fcounters[POSIX_F_OPEN_TIMESTAMP] = __tm1; \
- DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[POSIX_F_META_TIME], __tm1, __tm2, file->last_meta_end); \
+ DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[POSIX_F_META_TIME], \
+ __tm1, __tm2, file->last_meta_end); \
} while(0)
#define POSIX_RECORD_READ(__ret, __fd, __pread_flag, __pread_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
@@ -255,8 +256,12 @@ static void posix_shutdown(void);
else \
file->file_record->counters[POSIX_READS] += 1; \
DARSHAN_BUCKET_INC(&(file->file_record->counters[POSIX_SIZE_READ_0_100]), __ret); \
- darshan_common_val_counter(&file->access_root, &file->access_count, __ret); \
- darshan_common_val_counter(&file->stride_root, &file->stride_count, stride); \
+ darshan_common_val_counter(&file->access_root, &file->access_count, __ret, \
+ &(file->file_record->counters[POSIX_ACCESS1_ACCESS]), \
+ &(file->file_record->counters[POSIX_ACCESS1_COUNT])); \
+ darshan_common_val_counter(&file->stride_root, &file->stride_count, stride, \
+ &(file->file_record->counters[POSIX_STRIDE1_STRIDE]), \
+ &(file->file_record->counters[POSIX_STRIDE1_COUNT])); \
if(!__aligned) \
file->file_record->counters[POSIX_MEM_NOT_ALIGNED] += 1; \
file_alignment = file->file_record->counters[POSIX_FILE_ALIGNMENT]; \
@@ -271,7 +276,8 @@ static void posix_shutdown(void);
if(file->file_record->fcounters[POSIX_F_MAX_READ_TIME] < __elapsed) { \
file->file_record->fcounters[POSIX_F_MAX_READ_TIME] = __elapsed; \
file->file_record->counters[POSIX_MAX_READ_TIME_SIZE] = __ret; } \
- DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[POSIX_F_READ_TIME], __tm1, __tm2, file->last_read_end); \
+ DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[POSIX_F_READ_TIME], \
} while(0)
#define POSIX_RECORD_WRITE(__ret, __fd, __pwrite_flag, __pwrite_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
@@ -306,8 +312,12 @@ static void posix_shutdown(void);
else \
file->file_record->counters[POSIX_WRITES] += 1; \
DARSHAN_BUCKET_INC(&(file->file_record->counters[POSIX_SIZE_WRITE_0_100]), __ret); \
if(!__aligned) \
@@ -322,7 +332,8 @@ static void posix_shutdown(void);
if(file->file_record->fcounters[POSIX_F_MAX_WRITE_TIME] < __elapsed) { \
file->file_record->fcounters[POSIX_F_MAX_WRITE_TIME] = __elapsed; \
file->file_record->counters[POSIX_MAX_WRITE_TIME_SIZE] = __ret; } \
- DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[POSIX_F_WRITE_TIME], __tm1, __tm2, file->last_write_end); \
+ DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[POSIX_F_WRITE_TIME], \
} while(0)
#define POSIX_LOOKUP_RECORD_STAT(__path, __statbuf, __tm1, __tm2) do { \
@@ -336,8 +347,9 @@ static void posix_shutdown(void);
} while(0)
#define POSIX_RECORD_STAT(__file, __statbuf, __tm1, __tm2) do { \
- DARSHAN_TIMER_INC_NO_OVERLAP((__file)->file_record->fcounters[POSIX_F_META_TIME], __tm1, __tm2, (__file)->last_meta_end); \
(__file)->file_record->counters[POSIX_STATS] += 1; \
+ DARSHAN_TIMER_INC_NO_OVERLAP((__file)->file_record->fcounters[POSIX_F_META_TIME], \
+ __tm1, __tm2, (__file)->last_meta_end); \
} while(0)
@@ -1773,14 +1785,14 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
DARSHAN_COMMON_VAL_COUNTER_INC(&(tmp_file.counters[POSIX_STRIDE1_STRIDE]),
&(tmp_file.counters[POSIX_STRIDE1_COUNT]), infile->counters[j],
/* second set */
for(j=POSIX_STRIDE1_STRIDE; j<=POSIX_STRIDE4_STRIDE; j++)
&(tmp_file.counters[POSIX_STRIDE1_COUNT]), inoutfile->counters[j],
/* same for access counts */
@@ -1804,14 +1816,14 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
DARSHAN_COMMON_VAL_COUNTER_INC(&(tmp_file.counters[POSIX_ACCESS1_ACCESS]),
&(tmp_file.counters[POSIX_ACCESS1_COUNT]), infile->counters[j],
/* second set */
for(j=POSIX_ACCESS1_ACCESS; j<=POSIX_ACCESS4_ACCESS; j++)
&(tmp_file.counters[POSIX_ACCESS1_COUNT]), inoutfile->counters[j],
@@ -2046,6 +2058,11 @@ static void posix_get_output_data(
tmp = &(posix_runtime->file_runtime_array[i]);
/* common accesses */
&(tmp->file_record->counters[POSIX_ACCESS1_ACCESS]),
@@ -2054,6 +2071,10 @@ static void posix_get_output_data(
darshan_walk_common_vals(tmp->stride_root,
&(tmp->file_record->counters[POSIX_STRIDE1_STRIDE]),
&(tmp->file_record->counters[POSIX_STRIDE1_COUNT]));
+#endif
+ tdestroy(tmp->stride_root, free);
--- a/darshan-util/darshan-mpiio-logutils.c
+++ b/darshan-util/darshan-mpiio-logutils.c
@@ -228,7 +228,10 @@ static void darshan_log_agg_mpiio_files(void *rec, void *agg_rec, int init_flag)
struct darshan_mpiio_file *mpi_rec = (struct darshan_mpiio_file *)rec;
struct darshan_mpiio_file *agg_mpi_rec = (struct darshan_mpiio_file *)agg_rec;
- int i;
+ int i, j, k;
+ int set;
+ int min_ndx;
+ int64_t min;
double mpi_time = mpi_rec->fcounters[MPIIO_F_READ_TIME] +
mpi_rec->fcounters[MPIIO_F_WRITE_TIME] +
mpi_rec->fcounters[MPIIO_F_META_TIME];
@@ -310,8 +313,44 @@ static void darshan_log_agg_mpiio_files(void *rec, void *agg_rec, int init_flag)
case MPIIO_SLOWEST_RANK_BYTES:
/* these are set with the FP counters */
break;
+ case MPIIO_ACCESS1_ACCESS:
+ /* increment common value counters */
+ for(j = i; j < i + 4; j++)
+ min = agg_mpi_rec->counters[i + 4];
+ min_ndx = 0;
+ set = 0;
+ for(k = 0; k < 4; k++)
+ if(agg_mpi_rec->counters[i + k] == mpi_rec->counters[j])
+ agg_mpi_rec->counters[i + k + 4] += mpi_rec->counters[j + 4];
+ set = 1;
+ break;
+ else if(agg_mpi_rec->counters[i + k + 4] < min)
+ min = agg_mpi_rec->counters[i + k + 4];
+ min_ndx = k;
+ if(!set && (mpi_rec->counters[j + 4] > min))
+ agg_mpi_rec->counters[i + min_ndx] = mpi_rec->counters[j];
+ agg_mpi_rec->counters[i + min_ndx + 4] = mpi_rec->counters[j + 4];
+ break;
+ case MPIIO_ACCESS2_ACCESS:
+ case MPIIO_ACCESS3_ACCESS:
+ case MPIIO_ACCESS4_ACCESS:
+ case MPIIO_ACCESS1_COUNT:
+ case MPIIO_ACCESS2_COUNT:
+ case MPIIO_ACCESS3_COUNT:
+ case MPIIO_ACCESS4_COUNT:
+ /* these are set all at once with common counters above */
+ break;
default:
- /* TODO: common access sizes */
agg_mpi_rec->counters[i] = -1;
break;
--- a/darshan-util/darshan-posix-logutils.c
+++ b/darshan-util/darshan-posix-logutils.c
@@ -229,7 +229,10 @@ static void darshan_log_agg_posix_files(void *rec, void *agg_rec, int init_flag)
struct darshan_posix_file *psx_rec = (struct darshan_posix_file *)rec;
struct darshan_posix_file *agg_psx_rec = (struct darshan_posix_file *)agg_rec;
- int i;
+ int i, j, k;
+ int set;
+ int min_ndx;
+ int64_t min;
double psx_time = psx_rec->fcounters[POSIX_F_READ_TIME] +
psx_rec->fcounters[POSIX_F_WRITE_TIME] +
psx_rec->fcounters[POSIX_F_META_TIME];
@@ -326,8 +329,52 @@ static void darshan_log_agg_posix_files(void *rec, void *agg_rec, int init_flag)
case POSIX_SLOWEST_RANK_BYTES:
break;
+ case POSIX_STRIDE1_STRIDE:
+ case POSIX_ACCESS1_ACCESS:
+ min = agg_psx_rec->counters[i + 4];
+ min_ndx = 0;
+ set = 0;
+ if(agg_psx_rec->counters[i + k] == psx_rec->counters[j])
+ agg_psx_rec->counters[i + k + 4] += psx_rec->counters[j + 4];
+ set = 1;
+ break;
+ else if(agg_psx_rec->counters[i + k + 4] < min)
+ min = agg_psx_rec->counters[i + k + 4];
+ min_ndx = k;
+ if(!set && (psx_rec->counters[j + 4] > min))
+ agg_psx_rec->counters[i + min_ndx] = psx_rec->counters[j];
+ agg_psx_rec->counters[i + min_ndx + 4] = psx_rec->counters[j + 4];
+ break;
+ case POSIX_STRIDE2_STRIDE:
+ case POSIX_STRIDE3_STRIDE:
+ case POSIX_STRIDE4_STRIDE:
+ case POSIX_STRIDE1_COUNT:
+ case POSIX_STRIDE2_COUNT:
+ case POSIX_STRIDE3_COUNT:
+ case POSIX_STRIDE4_COUNT:
+ case POSIX_ACCESS2_ACCESS:
+ case POSIX_ACCESS3_ACCESS:
+ case POSIX_ACCESS4_ACCESS:
+ case POSIX_ACCESS1_COUNT:
+ case POSIX_ACCESS2_COUNT:
+ case POSIX_ACCESS3_COUNT:
+ case POSIX_ACCESS4_COUNT:
+ break;
default:
- /* TODO: common access counters and strides */
agg_psx_rec->counters[i] = -1;
break;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/a22233d71f256a142c0ddc2729e8d5cc0d59de45...37b1bb02d5c0a9bb80b024890d8ebaf6a73d977b
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160205/634ee46d/attachment-0001.html>
More information about the Darshan-commits
