[Darshan-commits] [Git][darshan/darshan][dev-modular] small reorg of darshan init code
Shane Snyder
xgitlab at cels.anl.gov
Thu Feb 4 17:59:20 CST 2016
Shane Snyder pushed to branch dev-modular at darshan / darshan
Commits:
75bd3020 by Shane Snyder at 2016-02-04T17:57:12-06:00
this reorganization prevents darshan from being "enabled"
(i.e., accessible to modules) until the initialization
has completely finished.
1 changed file:
- darshan-runtime/lib/darshan-core.c
Changes:
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -119,6 +119,7 @@ static void darshan_core_cleanup(
void darshan_core_initialize(int argc, char **argv)
+ struct darshan_core_runtime *init_core = NULL;
int i;
int internal_timing_flag = 0;
double init_start, init_time, init_max;
@@ -166,25 +167,25 @@ void darshan_core_initialize(int argc, char **argv)
/* allocate structure to track darshan_core_runtime information */
- darshan_core = malloc(sizeof(*darshan_core));
- if(darshan_core)
+ init_core = malloc(sizeof(*init_core));
+ if(init_core)
- memset(darshan_core, 0, sizeof(*darshan_core));
+ memset(init_core, 0, sizeof(*init_core));
- darshan_core->log_job.uid = getuid();
- darshan_core->log_job.start_time = time(NULL);
- darshan_core->log_job.nprocs = nprocs;
- darshan_core->wtime_offset = DARSHAN_MPI_CALL(PMPI_Wtime)();
+ init_core->log_job.uid = getuid();
+ init_core->log_job.start_time = time(NULL);
+ init_core->log_job.nprocs = nprocs;
+ init_core->wtime_offset = DARSHAN_MPI_CALL(PMPI_Wtime)();
/* record exe and arguments */
for(i=0; i<argc; i++)
- chars_left = DARSHAN_EXE_LEN-strlen(darshan_core->exe);
- strncat(darshan_core->exe, argv[i], chars_left);
+ chars_left = DARSHAN_EXE_LEN-strlen(init_core->exe);
+ strncat(init_core->exe, argv[i], chars_left);
if(i < (argc-1))
- strncat(darshan_core->exe, " ", chars_left);
+ strncat(init_core->exe, " ", chars_left);
@@ -193,22 +194,22 @@ void darshan_core_initialize(int argc, char **argv)
if(argc == 0)
- strncat(darshan_core->exe, __progname_full, chars_left);
- strncat(darshan_core->exe, " <unknown args>", chars_left);
+ strncat(init_core->exe, __progname_full, chars_left);
+ strncat(init_core->exe, " <unknown args>", chars_left);
if(chars_left == 0)
/* we ran out of room; mark that string was truncated */
truncate_offset = DARSHAN_EXE_LEN - strlen(truncate_string);
- sprintf(&darshan_core->exe[truncate_offset], "%s",
+ sprintf(&init_core->exe[truncate_offset], "%s",
truncate_string);
/* collect information about command line and mounted file systems */
- darshan_core->trailing_data = darshan_get_exe_and_mounts(darshan_core);
+ init_core->trailing_data = darshan_get_exe_and_mounts(init_core);
/* bootstrap any modules with static initialization routines */
i = 0;
@@ -232,6 +233,10 @@ void darshan_core_initialize(int argc, char **argv)
+ /* if darshan was successfully initialized, set the global pointer */
+ if(init_core)
+ darshan_core = init_core;
return;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/75bd30201d6b1cb374508fc4ccd7c87ce1a757e5
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160204/267f6850/attachment.html>
More information about the Darshan-commits
