[Darshan-commits] [Git][darshan/darshan][master] filter stderr/stdin/stdout for regression tests
Shane Snyder
xgitlab at cels.anl.gov
Wed Aug 24 21:30:42 CDT 2016
Shane Snyder pushed to branch master at darshan / darshan
Commits:
0ed720e8 by Shane Snyder at 2016-08-24T21:30:03-05:00
2 changed files:
- darshan-test/regression/test-cases/fprintf-fscanf-test.sh
- darshan-test/regression/test-cases/stdio-test.sh
Changes:
--- a/darshan-test/regression/test-cases/fprintf-fscanf-test.sh
+++ b/darshan-test/regression/test-cases/fprintf-fscanf-test.sh
@@ -29,21 +29,21 @@ fi
# check results
-STDIO_OPENS=`grep STDIO_OPENS $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_OPENS=`grep STDIO_OPENS $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! "$STDIO_OPENS" -eq 4 ]; then
echo "Error: STDIO open count of $STDIO_OPENS is incorrect" 1>&2
exit 1
fi
# this will check fprintf counting
-STDIO_BYTES_WRITTEN=`grep STDIO_BYTES_WRITTEN $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_BYTES_WRITTEN=`grep STDIO_BYTES_WRITTEN $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! "$STDIO_BYTES_WRITTEN" -eq 15 ]; then
echo "Error: STDIO bytes written count of $STDIO_BYTES_WRITTEN is incorrect" 1>&2
exit 1
fi
# this will check fscanf counting
-STDIO_BYTES_READ=`grep STDIO_BYTES_READ $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_BYTES_READ=`grep STDIO_BYTES_READ $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! "$STDIO_BYTES_READ" -eq 15 ]; then
echo "Error: STDIO bytes read count of $STDIO_BYTES_READ is incorrect" 1>&2
exit 1
--- a/darshan-test/regression/test-cases/stdio-test.sh
+++ b/darshan-test/regression/test-cases/stdio-test.sh
@@ -31,22 +31,22 @@ fi
# check at least one counter from each general open/read/write/seek category
if [ ! "$STDIO_OPENS" -gt 0 ]; then
exit 1
fi
-STDIO_SEEKS=`grep STDIO_SEEKS $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_SEEKS=`grep STDIO_SEEKS $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! "$STDIO_SEEKS" -gt 0 ]; then
echo "Error: STDIO open count of $STDIO_SEEKS is incorrect" 1>&2
exit 1
fi
if [ ! "$STDIO_BYTES_WRITTEN" -eq 6 ]; then
echo "Error: STDIO open count of $STDIO_BYTES_WRITTEN is incorrect" 1>&2
exit 1
fi
if [ ! "$STDIO_BYTES_READ" -eq 6 ]; then
echo "Error: STDIO open count of $STDIO_BYTES_READ is incorrect" 1>&2
exit 1
@@ -55,32 +55,32 @@ fi
# make sure that some of the floating point counters are valid
# use bc for floating point comparison
-STDIO_F_OPEN_START_TIMESTAMP=`grep STDIO_F_OPEN_START_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_OPEN_START_TIMESTAMP=`grep STDIO_F_OPEN_START_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_OPEN_START_TIMESTAMP > 0" | bc -l) ]; then
echo "Error: counter is incorrect" 1>&2
exit 1
fi
-STDIO_F_OPEN_END_TIMESTAMP=`grep STDIO_F_OPEN_END_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_OPEN_END_TIMESTAMP=`grep STDIO_F_OPEN_END_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_OPEN_END_TIMESTAMP > 0" | bc -l) ]; then
exit 1
fi
-STDIO_F_META_TIME=`grep STDIO_F_META_TIME $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_META_TIME=`grep STDIO_F_META_TIME $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_META_TIME > 0" | bc -l) ]; then
exit 1
fi
-STDIO_F_WRITE_TIME=`grep STDIO_F_WRITE_TIME $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_WRITE_TIME=`grep STDIO_F_WRITE_TIME $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_WRITE_TIME > 0" | bc -l) ]; then
exit 1
fi
-STDIO_F_CLOSE_START_TIMESTAMP=`grep STDIO_F_CLOSE_START_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_CLOSE_START_TIMESTAMP=`grep STDIO_F_CLOSE_START_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_CLOSE_START_TIMESTAMP > 0" | bc -l) ]; then
exit 1
fi
-STDIO_F_CLOSE_END_TIMESTAMP=`grep STDIO_F_CLOSE_END_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_CLOSE_END_TIMESTAMP=`grep STDIO_F_CLOSE_END_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_CLOSE_END_TIMESTAMP > 0" | bc -l) ]; then
exit 1
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/0ed720e8472f836423958ac95c256ac2317036ac
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160824/b1aed9f4/attachment-0001.html>
More information about the Darshan-commits
