[Darshan-commits] [Git][darshan/darshan][gkl/obfuscate-fs-fix] 5 commits: bug fix in writing of name records
Glenn K. Lockwood
xgitlab at cels.anl.gov
Wed Aug 24 12:02:12 CDT 2016
Glenn K. Lockwood pushed to branch gkl/obfuscate-fs-fix at darshan / darshan
Commits:
d4dc84f4 by Shane Snyder at 2016-08-17T21:30:12-05:00
49ebb1b4 by Shane Snyder at 2016-08-17T21:30:47-05:00
make sure to write records in current version
173d3d49 by Phil Carns at 2016-08-20T09:11:40-04:00
tracking stdout stderr and stdin
6e75dade by Glenn K. Lockwood at 2016-08-24T09:57:37-07:00
Merge branch 'master' into gkl/obfuscate-fs-fix to pull in fix from d4dc84f
eadbecfd by Glenn K. Lockwood at 2016-08-24T10:00:07-07:00
fix wrong struct type (inconsequential as it may be in the given context)
12 changed files:
- darshan-runtime/lib/darshan-common.c
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
- darshan-util/darshan-bgq-logutils.c
- darshan-util/darshan-hdf5-logutils.c
- darshan-util/darshan-logutils.c
- darshan-util/darshan-lustre-logutils.c
- darshan-util/darshan-mpiio-logutils.c
- darshan-util/darshan-null-logutils.c
- darshan-util/darshan-pnetcdf-logutils.c
- darshan-util/darshan-posix-logutils.c
- darshan-util/darshan-stdio-logutils.c
Changes:
--- a/darshan-runtime/lib/darshan-common.c
+++ b/darshan-runtime/lib/darshan-common.c
@@ -126,7 +126,11 @@ char* darshan_clean_file_path(const char* path)
char* cwd = NULL;
char* filter = NULL;
- if(!path || strlen(path) < 1)
+ /* NOTE: the last check in this if statement is for path strings that
+ * begin with the '<' character. We assume that these are special
+ * reserved paths used by Darshan, like <STDIN>.
+ if(!path || strlen(path) < 1 || path[0] == '<')
return(NULL);
if(path[0] == '/')
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -94,7 +94,9 @@ DARSHAN_FORWARD_DECL(fputc, int, (int c, FILE *stream));
DARSHAN_FORWARD_DECL(putw, int, (int w, FILE *stream));
DARSHAN_FORWARD_DECL(fputs, int, (const char *s, FILE *stream));
DARSHAN_FORWARD_DECL(fprintf, int, (FILE *stream, const char *format, ...));
+DARSHAN_FORWARD_DECL(printf, int, (const char *format, ...));
DARSHAN_FORWARD_DECL(vfprintf, int, (FILE *stream, const char *format, va_list));
+DARSHAN_FORWARD_DECL(vprintf, int, (const char *format, va_list));
DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fgetc, int, (FILE *stream));
DARSHAN_FORWARD_DECL(getw, int, (FILE *stream));
@@ -463,6 +465,25 @@ int DARSHAN_DECL(fputs)(const char *s, FILE *stream)
return(ret);
+int DARSHAN_DECL(vprintf)(const char *format, va_list ap)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(vprintf);
+ tm1 = darshan_core_wtime();
+ ret = __real_vprintf(format, ap);
+ tm2 = darshan_core_wtime();
+ STDIO_PRE_RECORD();
+ if(ret > 0)
+ STDIO_RECORD_WRITE(stdout, ret, tm1, tm2, 0);
+ STDIO_POST_RECORD();
+ return(ret);
int DARSHAN_DECL(vfprintf)(FILE *stream, const char *format, va_list ap)
int ret;
@@ -472,14 +493,38 @@ int DARSHAN_DECL(vfprintf)(FILE *stream, const char *format, va_list ap)
MAP_OR_FAIL(vfprintf);
- start_off = ftell(stream);
ret = __real_vfprintf(stream, format, ap);
- end_off = ftell(stream);
STDIO_PRE_RECORD();
if(ret > 0)
- STDIO_RECORD_WRITE(stream, (end_off-start_off), tm1, tm2, 0);
+ STDIO_RECORD_WRITE(stream, ret, tm1, tm2, 0);
+ return(ret);
+int DARSHAN_DECL(printf)(const char *format, ...)
+ int ret;
+ double tm1, tm2;
+ va_list ap;
+ /* NOTE: we intentionally switch to vprintf here to handle the variable
+ * length arguments.
+ va_start(ap, format);
+ va_end(ap);
+ if(ret > 0)
return(ret);
@@ -491,7 +536,6 @@ int DARSHAN_DECL(fprintf)(FILE *stream, const char *format, ...)
int ret;
double tm1, tm2;
va_list ap;
- long start_off, end_off;
@@ -499,16 +543,14 @@ int DARSHAN_DECL(fprintf)(FILE *stream, const char *format, ...)
/* NOTE: we intentionally switch to vfprintf here to handle the variable
* length arguments.
va_end(ap);
STDIO_PRE_RECORD();
if(ret > 0)
return(ret);
@@ -939,6 +981,11 @@ static void stdio_runtime_initialize()
return;
memset(stdio_runtime, 0, sizeof(*stdio_runtime));
+ /* instantiate records for stdin, stdout, and stderr */
+ STDIO_RECORD_OPEN(stdin, "<STDIN>", 0, 0);
+ STDIO_RECORD_OPEN(stdout, "<STDOUT>", 0, 0);
+ STDIO_RECORD_OPEN(stderr, "<STDERR>", 0, 0);
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -20,6 +20,7 @@
--wrap=fseeko64
--wrap=fprintf
--wrap=vfprintf
+--wrap=vprintf
--wrap=fputc
--wrap=fputs
--wrap=putw
@@ -27,3 +28,4 @@
--wrap=fsetpos64
--wrap=rewind
--wrap=__isoc99_fscanf
+--wrap=printf
--- a/darshan-util/darshan-bgq-logutils.c
+++ b/darshan-util/darshan-bgq-logutils.c
@@ -120,7 +120,7 @@ static int darshan_log_put_bgq_rec(darshan_fd fd, void* bgq_buf, int ver)
int ret;
ret = darshan_log_put_mod(fd, DARSHAN_BGQ_MOD, rec,
- sizeof(struct darshan_bgq_record), ver);
+ sizeof(struct darshan_bgq_record), DARSHAN_BGQ_VER);
if(ret < 0)
return(-1);
--- a/darshan-util/darshan-hdf5-logutils.c
+++ b/darshan-util/darshan-hdf5-logutils.c
@@ -85,7 +85,7 @@ static int darshan_log_put_hdf5_file(darshan_fd fd, void* hdf5_buf, int ver)
int ret;
ret = darshan_log_put_mod(fd, DARSHAN_HDF5_MOD, file,
- sizeof(struct darshan_hdf5_file), ver);
+ sizeof(struct darshan_hdf5_file), DARSHAN_HDF5_VER);
if(ret < 0)
return(-1);
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -586,22 +586,22 @@ int darshan_log_put_namehash(darshan_fd fd, struct darshan_name_record_ref *hash
struct darshan_fd_int_state *state = fd->state;
struct darshan_name_record_ref *ref, *tmp;
- struct darshan_name_record_ref *name_rec;
+ struct darshan_name_record *name_rec;
int name_rec_len;
int wrote;
assert(state);
/* allocate memory for largest possible hash record */
- name_rec = malloc(sizeof(struct darshan_name_record) + PATH_MAX);
+ name_rec = malloc(sizeof(darshan_record_id) + PATH_MAX + 1);
if(!name_rec)
return(-1);
- memset(name_rec, 0, sizeof(struct darshan_name_record) + PATH_MAX);
+ memset(name_rec, 0, sizeof(darshan_record_id) + PATH_MAX + 1);
/* individually serialize each hash record and write to log file */
HASH_ITER(hlink, hash, ref, tmp)
- name_rec_len = sizeof(struct darshan_name_record) + strlen(ref->name_record->name);
+ name_rec_len = sizeof(darshan_record_id) + strlen(ref->name_record->name) + 1;
memcpy(name_rec, ref->name_record, name_rec_len);
/* write this hash entry to log file */
--- a/darshan-util/darshan-lustre-logutils.c
+++ b/darshan-util/darshan-lustre-logutils.c
@@ -94,7 +94,7 @@ static int darshan_log_put_lustre_record(darshan_fd fd, void* lustre_buf, int ve
int ret;
ret = darshan_log_put_mod(fd, DARSHAN_LUSTRE_MOD, rec,
- LUSTRE_RECORD_SIZE(rec->counters[LUSTRE_STRIPE_WIDTH]), ver);
+ LUSTRE_RECORD_SIZE(rec->counters[LUSTRE_STRIPE_WIDTH]), DARSHAN_LUSTRE_VER);
if(ret < 0)
return(-1);
--- a/darshan-util/darshan-mpiio-logutils.c
+++ b/darshan-util/darshan-mpiio-logutils.c
@@ -85,7 +85,7 @@ static int darshan_log_put_mpiio_file(darshan_fd fd, void* mpiio_buf, int ver)
int ret;
ret = darshan_log_put_mod(fd, DARSHAN_MPIIO_MOD, file,
- sizeof(struct darshan_mpiio_file), ver);
+ sizeof(struct darshan_mpiio_file), DARSHAN_MPIIO_VER);
if(ret < 0)
return(-1);
--- a/darshan-util/darshan-null-logutils.c
+++ b/darshan-util/darshan-null-logutils.c
@@ -102,7 +102,7 @@ static int darshan_log_put_null_record(darshan_fd fd, void* null_buf, int ver)
/* append NULL record to darshan log file */
ret = darshan_log_put_mod(fd, DARSHAN_NULL_MOD, rec,
- sizeof(struct darshan_null_record), ver);
+ sizeof(struct darshan_null_record), DARSHAN_NULL_VER);
if(ret < 0)
return(-1);
--- a/darshan-util/darshan-pnetcdf-logutils.c
+++ b/darshan-util/darshan-pnetcdf-logutils.c
@@ -85,7 +85,7 @@ static int darshan_log_put_pnetcdf_file(darshan_fd fd, void* pnetcdf_buf, int ve
int ret;
ret = darshan_log_put_mod(fd, DARSHAN_PNETCDF_MOD, file,
- sizeof(struct darshan_pnetcdf_file), ver);
+ sizeof(struct darshan_pnetcdf_file), DARSHAN_PNETCDF_VER);
if(ret < 0)
return(-1);
--- a/darshan-util/darshan-posix-logutils.c
+++ b/darshan-util/darshan-posix-logutils.c
@@ -120,7 +120,7 @@ static int darshan_log_put_posix_file(darshan_fd fd, void* posix_buf, int ver)
int ret;
ret = darshan_log_put_mod(fd, DARSHAN_POSIX_MOD, file,
- sizeof(struct darshan_posix_file), ver);
+ sizeof(struct darshan_posix_file), DARSHAN_POSIX_VER);
if(ret < 0)
return(-1);
--- a/darshan-util/darshan-stdio-logutils.c
+++ b/darshan-util/darshan-stdio-logutils.c
@@ -99,7 +99,7 @@ static int darshan_log_put_stdio_record(darshan_fd fd, void* stdio_buf, int ver)
/* append STDIO record to darshan log file */
ret = darshan_log_put_mod(fd, DARSHAN_STDIO_MOD, rec,
- sizeof(struct darshan_stdio_file), ver);
+ sizeof(struct darshan_stdio_file), DARSHAN_STDIO_VER);
if(ret < 0)
return(-1);
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/0d1f6e805a97b998bd5ae3f74164f48a01f2cc7c...eadbecfd7cdc040c37d1cc9b16129344b63a7bc6
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160824/f8c28ba6/attachment-0001.html>
More information about the Darshan-commits
