[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-pre2-45-gcb17024
Service Account
git at mcs.anl.gov
Tue Mar 3 15:10:59 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via cb17024a79ffee1c5521dabe1fcf67dc83ac2c26 (commit)
via e984a8b5ed52b9628040dcf28d33715241f235fb (commit)
from ddf51033c75168a7930d47e5a2353cf56aaef255 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit cb17024a79ffee1c5521dabe1fcf67dc83ac2c26
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Tue Mar 3 15:10:28 2015 -0600
add core shutdown instrumentation
commit e984a8b5ed52b9628040dcf28d33715241f235fb
Date: Mon Mar 2 16:38:05 2015 -0600
cleanup darshan runtime shutdown code
Summary of changes:
darshan-runtime/lib/darshan-core.c | 96 ++++++++++++++++++++++++++++++++---
darshan-runtime/lib/darshan-posix.c | 10 +++-
darshan-util/darshan-logutils.c | 2 +
3 files changed, 98 insertions(+), 10 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index c9f460f..e76f6dd 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -227,6 +227,13 @@ static void darshan_core_shutdown()
int global_mod_use_count[DARSHAN_MAX_MODS] = {0};
darshan_record_id shared_recs[DARSHAN_CORE_MAX_RECORDS] = {0};
double start_log_time;
+ double open1, open2;
+ double job1, job2;
+ double rec1, rec2;
+ double mod1[DARSHAN_MAX_MODS] = {0};
+ double mod2[DARSHAN_MAX_MODS] = {0};
+ double header1, header2;
+ double tm_end;
long offset;
struct darshan_header log_header;
MPI_File log_fh;
@@ -236,6 +243,8 @@ static void darshan_core_shutdown()
if(getenv("DARSHAN_INTERNAL_TIMING"))
internal_timing_flag = 1;
+ start_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
/* disable darhan-core while we shutdown */
DARSHAN_CORE_LOCK();
if(!darshan_core)
@@ -259,8 +268,6 @@ static void darshan_core_shutdown()
DARSHAN_CORE_UNLOCK();
- start_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
logfile_name = malloc(PATH_MAX);
if(!logfile_name)
@@ -337,8 +344,12 @@ static void darshan_core_shutdown()
/* get a list of records which are shared across all processes */
darshan_get_shared_records(final_core, shared_recs);
+ if(internal_timing_flag)
+ open1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
/* collectively open the darshan log file */
ret = darshan_log_coll_open(logfile_name, &log_fh);
+ open2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
/* error out if unable to open log file */
DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
@@ -356,13 +367,15 @@ static void darshan_core_shutdown()
return;
+ job1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
/* rank 0 is responsible for writing the compressed darshan job information */
if(my_rank == 0)
void *pointers[2] = {&final_core->log_job, final_core->trailing_data};
int lengths[2] = {sizeof(struct darshan_job), DARSHAN_EXE_LEN+1};
int comp_buf_sz = 0;
/* compress the job info and the trailing mount/exe data */
all_ret = darshan_compress_buffer(pointers, lengths, 2,
final_core->comp_buf, &comp_buf_sz);
@@ -397,9 +410,15 @@ static void darshan_core_shutdown()
darshan_core_cleanup(final_core);
return;
+ job2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
+ rec1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
/* write the record name->id hash to the log file */
ret = darshan_log_write_record_hash(log_fh, final_core, &log_header.rec_map);
+ rec2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
/* error out if unable to write record hash */
@@ -417,6 +436,7 @@ static void darshan_core_shutdown()
return;
+ /* TODO: would be nice to factor this out somehow ... a lot to look at */
/* loop over globally used darshan modules and:
* - perform shared file reductions, if possible
* - get final output buffer
@@ -443,7 +463,11 @@ static void darshan_core_shutdown()
continue;
- else if(global_mod_use_count[j] == nprocs)
+ mod1[i] = DARSHAN_MPI_CALL(PMPI_Wtime)();
+ /* if all processes used this module, prepare to do a shared file reduction */
+ if(global_mod_use_count[j] == nprocs)
int shared_rec_count = 0;
int rec_sz = 0;
@@ -451,8 +475,6 @@ static void darshan_core_shutdown()
MPI_Datatype red_type;
MPI_Op red_op;
- /* if all processes used this module, prepare to do a shared file reduction */
/* set the shared file list for this module */
memset(mod_shared_recs, 0, DARSHAN_CORE_MAX_RECORDS * sizeof(darshan_record_id));
for(j = 0; j < DARSHAN_CORE_MAX_RECORDS && shared_recs[j] != 0; j++)
@@ -548,8 +570,12 @@ static void darshan_core_shutdown()
this_mod->mod_funcs.shutdown();
+ mod2[i] = DARSHAN_MPI_CALL(PMPI_Wtime)();
+ header1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
/* rank 0 is responsible for writing the log header */
if(my_rank == 0)
@@ -576,6 +602,8 @@ static void darshan_core_shutdown()
return;
+ header2 = DARSHAN_MPI_CALL(PMPI_Wtime)();
DARSHAN_MPI_CALL(PMPI_File_close)(&log_fh);
@@ -614,7 +642,53 @@ static void darshan_core_shutdown()
- /* TODO: what do we want to time in new darshan version? */
+ double open_tm, open_slowest;
+ double header_tm, header_slowest;
+ double job_tm, job_slowest;
+ double rec_tm, rec_slowest;
+ double mod_tm[DARSHAN_MAX_MODS], mod_slowest[DARSHAN_MAX_MODS];
+ double all_tm, all_slowest;
+ tm_end = DARSHAN_MPI_CALL(PMPI_Wtime)();
+ open_tm = open2 - open1;
+ header_tm = header2 - header1;
+ job_tm = job2 - job1;
+ rec_tm = rec2 - rec1;
+ all_tm = tm_end - start_log_time;
+ for(i = 0;i < DARSHAN_MAX_MODS; i++)
+ mod_tm[i] = mod2[i] - mod1[i];
+ DARSHAN_MPI_CALL(PMPI_Reduce)(&open_tm, &open_slowest, 1,
+ MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD);
+ DARSHAN_MPI_CALL(PMPI_Reduce)(&header_tm, &header_slowest, 1,
+ DARSHAN_MPI_CALL(PMPI_Reduce)(&job_tm, &job_slowest, 1,
+ DARSHAN_MPI_CALL(PMPI_Reduce)(&rec_tm, &rec_slowest, 1,
+ DARSHAN_MPI_CALL(PMPI_Reduce)(&all_tm, &all_slowest, 1,
+ DARSHAN_MPI_CALL(PMPI_Reduce)(mod_tm, mod_slowest, DARSHAN_MAX_MODS,
+ if(my_rank == 0)
+ printf("#darshan:<op>\t<nprocs>\t<time>\n");
+ printf("darshan:log_open\t%d\t%f\n", nprocs, open_slowest);
+ printf("darshan:job_write\t%d\t%f\n", nprocs, job_slowest);
+ printf("darshan:hash_write\t%d\t%f\n", nprocs, rec_slowest);
+ printf("darshan:header_write\t%d\t%f\n", nprocs, rec_slowest);
+ for(i = 0; i < DARSHAN_MAX_MODS; i++)
+ if(global_mod_use_count[i])
+ printf("darshan:%s_shutdown\t%d\t%f\n", darshan_module_names[i],
+ nprocs, rec_slowest);
+ printf("darshan:core_shutdown\t%d\t%f\n", nprocs, all_slowest);
return;
@@ -623,9 +697,15 @@ static void darshan_core_shutdown()
/* free darshan core data structures to shutdown */
static void darshan_core_cleanup(struct darshan_core_runtime* core)
+ struct darshan_core_record_ref *tmp, *ref;
int i;
- /* TODO: destroy record hash */
+ HASH_ITER(hlink, core->rec_hash, ref, tmp)
+ HASH_DELETE(hlink, core->rec_hash, ref);
+ free(ref->rec.name);
+ free(ref);
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 84553b5..c1e05ea 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -604,9 +604,15 @@ static void posix_get_output_data(
static void posix_shutdown()
- assert(posix_runtime);
+ struct posix_runtime_file_ref *ref, *tmp;
+ HASH_ITER(hlink, posix_runtime->fd_hash, ref, tmp)
+ HASH_DELETE(hlink, posix_runtime->fd_hash, ref);
+ free(ref);
- /* TODO destroy hash tables ?? */
+ HASH_CLEAR(hlink, posix_runtime->file_hash); /* these entries are freed all at once below */
free(posix_runtime->file_runtime_array);
free(posix_runtime->file_record_array);
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index 428202a..2df035f 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -475,6 +475,8 @@ int darshan_log_getmod(darshan_fd fd, darshan_module_id mod_id,
*mod_buf = tmp_buf;
*mod_buf_sz = tmp_buf_sz;
+ /* TODO: bswaps */
return(0);
hooks/post-receive
More information about the Darshan-commits
