[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-pre2-43-gddf5103
Service Account git at mcs.anl.gov
Mon Mar 2 14:32:03 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  ddf51033c75168a7930d47e5a2353cf56aaef255 (commit)
      from  f999603f0a66c729d7a3163c3060a48012f4de55 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit ddf51033c75168a7930d47e5a2353cf56aaef255
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Mon Mar 2 14:31:04 2015 -0600
    runtime support added for shared file reductions
Summary of changes:
 darshan-runtime/darshan-core.h      |    2 +
 darshan-runtime/darshan.h           |   22 ++++-
 darshan-runtime/lib/darshan-core.c  |  179 +++++++++++++++++++++++------------
 darshan-runtime/lib/darshan-posix.c |  144 +++++++++++++++++++++++++++-
 darshan-util/darshan-logutils.c     |    4 +-
 darshan-util/darshan-logutils.h     |    4 +-
 6 files changed, 287 insertions(+), 68 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index 8ecddaf..0a78eed 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -40,6 +40,8 @@ struct darshan_core_runtime
 struct darshan_core_record_ref
     struct darshan_record rec;
+    uint64_t mod_flags;
+    uint64_t global_mod_flags;
     UT_hash_handle hlink;
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index 9a4f480..8802b8d 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -30,12 +30,29 @@
 struct darshan_module_funcs
+    /* disable futher instrumentation within a module */
     void (*disable_instrumentation)(void);
+    /* TODO: */
+    void (*prepare_for_reduction)(
+        darshan_record_id *shared_recs,
+        int *shared_rec_count, /* in/out shared record count */
+        void **send_buf,
+        void **recv_buf,
+        int *rec_size
+    /* TODO: */
+    void (*reduce_record)(
+        void* infile_v,
+        void* inoutfile_v,
+        int *len,
+        MPI_Datatype *datatype
+    /* retrieve module data to write to log file */
     void (*get_output_data)(
-        MPI_Comm mod_comm, /* communicator to use for module shutdown */
         void** buf, /* output parameter to save module buffer address */
         int* size /* output parameter to save module buffer size */
+    /* shutdown module data structures */
     void (*shutdown)(void);
@@ -44,7 +61,7 @@ struct darshan_module_funcs
 void darshan_core_register_module(
-    darshan_module_id id,
+    darshan_module_id mod_id,
     struct darshan_module_funcs *funcs,
     int *runtime_mem_limit);
@@ -52,6 +69,7 @@ void darshan_core_lookup_record_id(
     void *name,
     int len,
     int printable_flag,
     darshan_record_id *id);
 double darshan_core_wtime(void);
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 419291f..c9f460f 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -65,7 +65,7 @@ static void darshan_get_exe_and_mounts_root(
     int space_left);
 static char* darshan_get_exe_and_mounts(
     struct darshan_core_runtime *core);
-static void darshan_get_shared_record_ids(
+static void darshan_get_shared_records(
     struct darshan_core_runtime *core, darshan_record_id *shared_recs);
 static int darshan_log_coll_open(
     char *logfile_name, MPI_File *log_fh);
@@ -73,7 +73,7 @@ static int darshan_compress_buffer(void **pointers, int *lengths,
     int count, char *comp_buf, int *comp_length);
 static int darshan_log_write_record_hash(
     MPI_File log_fh, struct darshan_core_runtime *core,
-    darshan_record_id *shared_recs, struct darshan_log_map *map);
+    struct darshan_log_map *map);
 static int darshan_log_coll_write(
     MPI_File log_fh, void *buf, int count, struct darshan_log_map *map);
@@ -335,7 +335,7 @@ static void darshan_core_shutdown()
     DARSHAN_MPI_CALL(PMPI_Allreduce)(local_mod_use, global_mod_use_count, DARSHAN_MAX_MODS, MPI_INT, MPI_SUM, MPI_COMM_WORLD);
     /* get a list of records which are shared across all processes */
-    darshan_get_shared_record_ids(final_core, shared_recs);
+    darshan_get_shared_records(final_core, shared_recs);
     /* collectively open the darshan log file */
     ret = darshan_log_coll_open(logfile_name, &log_fh);
@@ -399,7 +399,7 @@ static void darshan_core_shutdown()
     /* write the record name->id hash to the log file */
-    ret = darshan_log_write_record_hash(log_fh, final_core, shared_recs, &log_header.rec_map);
+    ret = darshan_log_write_record_hash(log_fh, final_core, &log_header.rec_map);
     /* error out if unable to write record hash */
     DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
@@ -418,6 +418,7 @@ static void darshan_core_shutdown()
     /* loop over globally used darshan modules and:
+     *      - perform shared file reductions, if possible
      *      - get final output buffer
      *      - compress (zlib) provided output buffer
      *      - append compressed buffer to log file
@@ -427,34 +428,77 @@ static void darshan_core_shutdown()
     for(i = 0; i < DARSHAN_MAX_MODS; i++)
         struct darshan_core_module* this_mod = final_core->mod_array[i];
-        MPI_Comm mod_comm;
+        darshan_record_id mod_shared_recs[DARSHAN_CORE_MAX_RECORDS];
+        struct darshan_core_record_ref *ref = NULL;
+        int shared_rec_cnt = 0;
         void* mod_buf = NULL;
         int mod_buf_sz = 0;
         int comp_buf_sz = 0;
+        int j;
-        if(!global_mod_use_count[i])
+        if(global_mod_use_count[i] == 0)
             if(my_rank == 0)
                 log_header.mod_map[i].off = log_header.mod_map[i].len = 0;
             continue;
-        /* create a communicator to use for shutting down the module */
-        if(global_mod_use_count[i] == nprocs)
-            DARSHAN_MPI_CALL(PMPI_Comm_dup)(MPI_COMM_WORLD, &mod_comm);
-        else
+        else if(global_mod_use_count[j] == nprocs)
-            DARSHAN_MPI_CALL(PMPI_Comm_split)(MPI_COMM_WORLD, local_mod_use[i], 0, &mod_comm);
+            int shared_rec_count = 0;
+            int rec_sz = 0;
+            void *red_send_buf = NULL, *red_recv_buf = NULL;
+            MPI_Datatype red_type;
+            MPI_Op red_op;
+            /* if all processes used this module, prepare to do a shared file reduction */
+            /* set the shared file list for this module */
+            memset(mod_shared_recs, 0, DARSHAN_CORE_MAX_RECORDS * sizeof(darshan_record_id));
+            for(j = 0; j < DARSHAN_CORE_MAX_RECORDS && shared_recs[j] != 0; j++)
+                HASH_FIND(hlink, final_core->rec_hash, &shared_recs[j],
+                    sizeof(darshan_record_id), ref);
+                assert(ref);
+                if(ref->global_mod_flags & (1 << i)) /* TODO: MACRO? */
+                    mod_shared_recs[shared_rec_count++] = shared_recs[j];
+            /* if there are globally shared files, do a shared file reduction */
+            if(shared_rec_count)
+                this_mod->mod_funcs.prepare_for_reduction(mod_shared_recs, &shared_rec_count,
+                    &red_send_buf, &red_recv_buf, &rec_sz);
+                    /* construct a datatype for a file record.  This is serving no purpose
+                     * except to make sure we can do a reduction on proper boundaries
+                    DARSHAN_MPI_CALL(PMPI_Type_contiguous)(rec_sz, MPI_BYTE, &red_type);
+                    DARSHAN_MPI_CALL(PMPI_Type_commit)(&red_type);
+                    /* register a reduction operator for this module */
+                    DARSHAN_MPI_CALL(PMPI_Op_create)(this_mod->mod_funcs.reduce_record,
+                        1, &red_op);
+                    /* reduce shared file records for this module */
+                    DARSHAN_MPI_CALL(PMPI_Reduce)(red_send_buf, red_recv_buf,
+                        shared_rec_count, red_type, red_op, 0, MPI_COMM_WORLD);
+                    DARSHAN_MPI_CALL(PMPI_Type_free)(&red_type);
+                    DARSHAN_MPI_CALL(PMPI_Op_free)(&red_op);
         /* if module is registered locally, get the corresponding output buffer */
-        if(local_mod_use[i])
+        if(this_mod)
             /* get output buffer from module */
-            this_mod->mod_funcs.get_output_data(mod_comm, &mod_buf, &mod_buf_sz);
+            this_mod->mod_funcs.get_output_data(&mod_buf, &mod_buf_sz);
         /* compress the module buffer */
@@ -500,13 +544,10 @@ static void darshan_core_shutdown()
         tmp_off += log_header.mod_map[i].len;
         /* shutdown module if registered locally */
+        if(this_mod)
             this_mod->mod_funcs.shutdown();
-            this_mod = NULL;
-        DARSHAN_MPI_CALL(PMPI_Comm_free)(&mod_comm);
     /* rank 0 is responsible for writing the log header */
@@ -584,6 +625,8 @@ static void darshan_core_cleanup(struct darshan_core_runtime* core)
     int i;
+    /* TODO: destroy record hash */
         if(core->mod_array[i])
@@ -593,6 +636,7 @@ static void darshan_core_cleanup(struct darshan_core_runtime* core)
+    free(core->trailing_data);
     free(core);
     return;
@@ -955,15 +999,15 @@ static char* darshan_get_exe_and_mounts(struct darshan_core_runtime *core)
     return(trailing_data);
-static void darshan_get_shared_record_ids(struct darshan_core_runtime *core,
+static void darshan_get_shared_records(struct darshan_core_runtime *core,
     int i;
     int ndx;
-    struct darshan_core_record_ref *ref, *tmp;
+    struct darshan_core_record_ref *tmp, *ref;
     darshan_record_id id_array[DARSHAN_CORE_MAX_RECORDS] = {0};
-    darshan_record_id mask_array[DARSHAN_CORE_MAX_RECORDS] = {0};
-    darshan_record_id all_mask_array[DARSHAN_CORE_MAX_RECORDS] = {0};
+    uint64_t mod_flags[DARSHAN_CORE_MAX_RECORDS] = {0};
+    uint64_t global_mod_flags[DARSHAN_CORE_MAX_RECORDS] = {0};
     /* first, determine list of records root process has opened */
     if(my_rank == 0)
@@ -983,27 +1027,35 @@ static void darshan_get_shared_record_ids(struct darshan_core_runtime *core,
     /* everyone looks to see if they opened the same records as root */
     for(i=0; (i<DARSHAN_CORE_MAX_RECORDS && id_array[i] != 0); i++)
-        HASH_ITER(hlink, core->rec_hash, ref, tmp)
+        HASH_FIND(hlink, core->rec_hash, &id_array[i], sizeof(darshan_record_id), ref);
+        if(ref)
-            if(id_array[i] == ref->rec.id)
-                /* we opened that record too */
-                mask_array[i] = 1;
-                break;
+            /* we opened that record too, save the mod_flags */
+            mod_flags[i] = ref->mod_flags;
+            break;
-    /* now allreduce so everyone agrees which files are shared */
-    DARSHAN_MPI_CALL(PMPI_Allreduce)(mask_array, all_mask_array,
-        DARSHAN_CORE_MAX_RECORDS, MPI_INT, MPI_LAND, MPI_COMM_WORLD);
+    /* now allreduce so everyone agrees which files are shared and
+     * which modules accessed them collectively
+    DARSHAN_MPI_CALL(PMPI_Allreduce)(mod_flags, global_mod_flags,
+        DARSHAN_CORE_MAX_RECORDS, MPI_UINT64_T, MPI_LAND, MPI_COMM_WORLD);
     ndx = 0;
-        if(all_mask_array[i] != 0)
+        if(global_mod_flags[i] != 0)
             shared_recs[ndx++] = id_array[i];
+            /* set global_mod_flags so we know which modules collectively
+             * accessed this module. we need this info to support shared
+             * file reductions
+            assert(ref);
+            ref->global_mod_flags = global_mod_flags[i];
@@ -1079,6 +1131,21 @@ static int darshan_compress_buffer(void **pointers, int *lengths, int count,
     int total_target = 0;
     z_stream tmp_stream;
+    /* just return if there is no data */
+    for(i = 0; i < count; i++)
+        total_target += lengths[i];
+    if(total_target)
+        total_target = 0;
+    else
+        *comp_length = 0;
+        return(0);
     memset(&tmp_stream, 0, sizeof(tmp_stream));
     tmp_stream.zalloc = Z_NULL;
     tmp_stream.zfree = Z_NULL;
@@ -1146,7 +1213,7 @@ static int darshan_compress_buffer(void **pointers, int *lengths, int count,
  *       record is opened by multiple ranks, but not all ranks
 static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_runtime *core,
     int i;
     int ret;
@@ -1158,21 +1225,6 @@ static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_ru
     char *hash_buf_off;
     MPI_Status status;
-    /* non-root ranks (rank > 0) remove shared records from their hash --
-     * these records will be written by rank 0
-    if(my_rank > 0)
-        for(i=0; (i<DARSHAN_CORE_MAX_RECORDS && shared_recs[i]); i++)
-            HASH_FIND(hlink, core->rec_hash, &shared_recs[i], sizeof(darshan_record_id), ref);
-            assert(ref); /* this id had better be in the hash ... */
-            HASH_DELETE(hlink, core->rec_hash, ref);
-            if(ref->rec.name) free(ref->rec.name);
-            free(ref);
     /* allocate a buffer to store at most 64 bytes for each of a max number of records */
     /* NOTE: this buffer may be reallocated if estimate is too small */
     hash_buf_sz = DARSHAN_CORE_MAX_RECORDS * 64;
@@ -1186,8 +1238,12 @@ static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_ru
     hash_buf_off = hash_buf;
+        /* to avoid duplicate records, only rank 0 will write shared records */
+        if(my_rank > 0 && ref->global_mod_flags)
+            continue;
         name_len = strlen(ref->rec.name);
-        record_sz = sizeof(darshan_record_id) + sizeof(int) + name_len;
+        record_sz = sizeof(darshan_record_id) + sizeof(uint32_t) + name_len;
         /* make sure there is room in the buffer for this record */
         if((hash_buf_off + record_sz) > (hash_buf + hash_buf_sz))
@@ -1361,13 +1417,15 @@ void darshan_core_register_module(
     return;
+/* TODO: RENAME */
     void *name,
     int len,
     int printable_flag,
-    darshan_record_id *id)
+    darshan_record_id *rec_id)
-    darshan_record_id tmp_id;
+    darshan_record_id tmp_rec_id;
     struct darshan_core_record_ref* ref;
     if(!darshan_core)
@@ -1376,28 +1434,31 @@ void darshan_core_lookup_record_id(
     /* TODO: what do you do with printable flag? */
     /* hash the input name to get a unique id for this record */
-    tmp_id = darshan_hash(name, len, 0);
+    tmp_rec_id = darshan_hash(name, len, 0);
     /* check to see if we've already stored the id->name mapping for this record */
     DARSHAN_CORE_LOCK();
-    HASH_FIND(hlink, darshan_core->rec_hash, &tmp_id, sizeof(darshan_record_id), ref);
+    HASH_FIND(hlink, darshan_core->rec_hash, &tmp_rec_id, sizeof(darshan_record_id), ref);
     if(!ref)
         /* if not, add this record to the hash */
         ref = malloc(sizeof(struct darshan_core_record_ref));
         if(ref)
-            ref->rec.id = tmp_id;
+            ref->mod_flags = ref->global_mod_flags = 0;
+            ref->rec.id = tmp_rec_id;
             ref->rec.name = malloc(strlen(name) + 1);
             if(ref->rec.name)
                 strcpy(ref->rec.name, name);
             HASH_ADD(hlink, darshan_core->rec_hash, rec.id, sizeof(darshan_record_id), ref);
+    /* TODO: we need a function to disassociate a module with a record id, probably */
+    ref->mod_flags |= (1 << mod_id); /* TODO: MACRO? */
     DARSHAN_CORE_UNLOCK();
-    *id = tmp_id;
+    *rec_id = tmp_rec_id;
     return;
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 73278fa..84553b5 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -66,6 +66,8 @@ struct posix_runtime
     int file_array_ndx;
     struct posix_runtime_file* file_hash;
     struct posix_runtime_file_ref* fd_hash;
+    void *red_buf;
+    int shared_rec_count;
 static struct posix_runtime *posix_runtime = NULL;
@@ -100,7 +102,11 @@ static struct posix_runtime_file* posix_file_by_fd(int fd);
 static void posix_file_close_fd(int fd);
 static void posix_disable_instrumentation(void);
-static void posix_get_output_data(MPI_Comm comm, void **buffer, int *size);
+static void posix_prepare_for_reduction(darshan_record_id *shared_recs,
+    int *shared_rec_count, void **send_buf, void **recv_buf, int *rec_size);
+static void posix_reduce_record(void* infile_v, void* inoutfile_v,
+    int *len, MPI_Datatype *datatype);
+static void posix_get_output_data(void **buffer, int *size);
 static void posix_shutdown(void);
 #define POSIX_LOCK() pthread_mutex_lock(&posix_runtime_mutex)
@@ -276,6 +282,8 @@ static void posix_runtime_initialize()
     struct darshan_module_funcs posix_mod_fns =
         .disable_instrumentation = &posix_disable_instrumentation,
+        .prepare_for_reduction = &posix_prepare_for_reduction,
+        .reduce_record = &posix_reduce_record,
         .get_output_data = &posix_get_output_data,
         .shutdown = &posix_shutdown
@@ -342,6 +350,7 @@ static struct posix_runtime_file* posix_file_by_name(const char *name)
         (void*)newname,
         strlen(newname),
         1,
+        DARSHAN_POSIX_MOD,
         &file_id);
     /* search the hash table for this file record, and return if found */
@@ -445,10 +454,25 @@ static void posix_file_close_fd(int fd)
     return;
+static int posix_file_compare(const void* a, const void* b)
+    const struct darshan_posix_file* f_a = a;
+    const struct darshan_posix_file* f_b = b;
+    if(f_a->rank < f_b->rank)
+        return 1;
+    if(f_a->rank > f_b->rank)
+        return -1;
+    return 0;
 static void posix_disable_instrumentation()
+    assert(posix_runtime);
     POSIX_LOCK();
     instrumentation_disabled = 1;
     POSIX_UNLOCK();
@@ -456,9 +480,121 @@ static void posix_disable_instrumentation()
     return;
+    void **send_buf,
+    void **recv_buf,
+    int *rec_size)
+    struct posix_runtime_file *file;
+    struct darshan_posix_file *tmp_array;
+    int i;
+    /* necessary initialization of shared records (e.g., change rank to -1) */
+    for(i = 0; i < *shared_rec_count; i++)
+        HASH_FIND(hlink, posix_runtime->file_hash, &shared_recs[i],
+            sizeof(darshan_record_id), file);
+        assert(file);
+        /* TODO: any initialization before reduction */
+        file->file_record->rank = -1;
+    /* sort the array of files descending by rank so that we get all of the
+     * shared files (marked by rank -1) in a contiguous portion at end
+     * of the array
+    qsort(posix_runtime->file_record_array, posix_runtime->file_array_ndx,
+        sizeof(struct darshan_posix_file), posix_file_compare);
+    /* make *send_buf point to the shared files at the end of sorted array */
+    *send_buf =
+        &(posix_runtime->file_record_array[posix_runtime->file_array_ndx-(*shared_rec_count)]);
+    /* allocate memory for the reduction output on rank 0 */
+    if(my_rank == 0)
+        *recv_buf = malloc(*shared_rec_count * sizeof(struct darshan_posix_file));
+        if(!(*recv_buf))
+            return;
+    *rec_size = sizeof(struct darshan_posix_file);
+    /* TODO: HACK-Y -- how can we do this in a cleaner way?? */
+    if(my_rank == 0)
+        posix_runtime->red_buf = *recv_buf;
+    posix_runtime->shared_rec_count = *shared_rec_count;
+    return;
+    void* infile_v,
+    int *len,
+    MPI_Datatype *datatype)
-    /* TODO: shared file reduction */
+    struct darshan_posix_file tmp_file;
+    struct darshan_posix_file *infile = infile_v;
+    struct darshan_posix_file *inoutfile = inoutfile_v;
+    int i;
+    for(i = 0; i < *len; i++)
+        memset(&tmp_file, 0, sizeof(struct darshan_posix_file));
+        tmp_file.f_id = infile->f_id;
+        tmp_file.rank = -1;
+        tmp_file.counters[CP_POSIX_OPENS] = infile->counters[CP_POSIX_OPENS] +
+            inoutfile->counters[CP_POSIX_OPENS];
+        if((infile->fcounters[CP_F_OPEN_TIMESTAMP] > inoutfile->fcounters[CP_F_OPEN_TIMESTAMP]) &&
+            (inoutfile->fcounters[CP_F_OPEN_TIMESTAMP] > 0))
+            tmp_file.fcounters[CP_F_OPEN_TIMESTAMP] = inoutfile->fcounters[CP_F_OPEN_TIMESTAMP];
+        else
+            tmp_file.fcounters[CP_F_OPEN_TIMESTAMP] = infile->fcounters[CP_F_OPEN_TIMESTAMP];
+        if(infile->fcounters[CP_F_CLOSE_TIMESTAMP] > inoutfile->fcounters[CP_F_CLOSE_TIMESTAMP])
+            tmp_file.fcounters[CP_F_CLOSE_TIMESTAMP] = infile->fcounters[CP_F_CLOSE_TIMESTAMP];
+        else
+            tmp_file.fcounters[CP_F_CLOSE_TIMESTAMP] = inoutfile->fcounters[CP_F_CLOSE_TIMESTAMP];
+        /* update pointers */
+        *inoutfile = tmp_file;
+        inoutfile++;
+        infile++;
+    return;
+    void **buffer,
+    int *size)
+    /* clean up reduction state */
+    if(my_rank == 0)
+        int tmp_ndx = posix_runtime->file_array_ndx - posix_runtime->shared_rec_count;
+        memcpy(&(posix_runtime->file_record_array[tmp_ndx]), posix_runtime->red_buf,
+            posix_runtime->shared_rec_count * sizeof(struct darshan_posix_file));
+        free(posix_runtime->red_buf);
+    else
+        posix_runtime->file_array_ndx -= posix_runtime->shared_rec_count;
     *buffer = (void *)(posix_runtime->file_record_array);
     *size = posix_runtime->file_array_ndx * sizeof(struct darshan_posix_file);
@@ -468,6 +604,8 @@ static void posix_get_output_data(MPI_Comm comm, void **buffer, int *size)
 static void posix_shutdown()
     /* TODO destroy hash tables ?? */
     free(posix_runtime->file_runtime_array);
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index 0853730..428202a 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -407,8 +407,8 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
     return(0);
-int darshan_log_getmod(darshan_fd fd, int mod_id, void **mod_buf,
-    int *mod_buf_sz)
+int darshan_log_getmod(darshan_fd fd, darshan_module_id mod_id,
+    void **mod_buf, int *mod_buf_sz)
     char *comp_buf;
     char *tmp_buf;
diff --git a/darshan-util/darshan-logutils.h b/darshan-util/darshan-logutils.h
index d1d2ee3..223f8c0 100644
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -25,8 +25,8 @@ int darshan_log_gethash(darshan_fd file, struct darshan_record_ref **hash);
 int darshan_log_getexe(darshan_fd fd, char *buf);
 int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
     char*** fs_types, int* count);
-    int *mod_buf_sz);
+    void **mod_buf, int *mod_buf_sz);
 void darshan_log_close(darshan_fd file);
 /* convenience macros for printing out counters */
hooks/post-receive
More information about the Darshan-commits mailing list
