[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-114-g7354153
Service Account git at mcs.anl.gov
Tue Jul 21 13:44:43 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  735415387319aa6e406800952327bf3aeef7e12c (commit)
      from  6406c8726d1fe664f9de8147248da121c642ec6a (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 735415387319aa6e406800952327bf3aeef7e12c
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Tue Jul 21 13:44:08 2015 -0500
    refactor and add common access counts to mpiio
Summary of changes:
 darshan-mpiio-log-format.h           |    1 -
 darshan-runtime/darshan-common.h     |  154 +++++++++-----
 darshan-runtime/lib/darshan-common.c |  103 +++++++++
 darshan-runtime/lib/darshan-mpiio.c  |  106 ++++++----
 darshan-runtime/lib/darshan-null.c   |    8 +-
 darshan-runtime/lib/darshan-posix.c  |  389 ++++++++++-----------------------
 6 files changed, 386 insertions(+), 375 deletions(-)
Diff of changes:
diff --git a/darshan-mpiio-log-format.h b/darshan-mpiio-log-format.h
index 433ad1e..2dd254d 100644
--- a/darshan-mpiio-log-format.h
+++ b/darshan-mpiio-log-format.h
@@ -10,7 +10,6 @@
 #include "darshan-log-format.h"
 /* TODO: slowest/fastest rank (f)counters */
-/* TODO: access size common counters */
 /* TODO: maybe use a counter to track cases in which a derived datatype is used? */
 #define MPIIO_COUNTERS \
diff --git a/darshan-runtime/darshan-common.h b/darshan-runtime/darshan-common.h
index 722aa31..c359b6e 100644
--- a/darshan-runtime/darshan-common.h
+++ b/darshan-runtime/darshan-common.h
@@ -7,54 +7,19 @@
 #ifndef __DARSHAN_COMMON_H
 #define __DARSHAN_COMMON_H
-/* simple macros for manipulating a module's counters
- * NOTE: These macros assume a module's record stores integer
- * and floating point counters in arrays, named counters and
- * fcounters, respectively. __rec_p is the a pointer to the
- * data record, __counter is the counter in question, and
- * __value is the corresponding data value.
-#define DARSHAN_COUNTER_SET(__rec_p, __counter, __value) do{ \
-    (__rec_p)->counters[__counter] = __value; \
-} while(0)
-#define DARSHAN_COUNTER_F_SET(__rec_p, __counter, __value) do{ \
-    (__rec_p)->fcounters[__counter] = __value; \
-} while(0)
-#define DARSHAN_COUNTER_INC(__rec_p, __counter, __value) do{ \
-    (__rec_p)->counters[__counter] += __value; \
-} while(0)
-#define DARSHAN_COUNTER_F_INC(__rec_p, __counter, __value) do{ \
-    (__rec_p)->fcounters[__counter] += __value; \
-} while(0)
-#define DARSHAN_COUNTER_VALUE(__rec_p, __counter) \
-    ((__rec_p)->counters[__counter])
-#define DARSHAN_COUNTER_F_VALUE(__rec_p, __counter) \
-    ((__rec_p)->fcounters[__counter])
-/* set __counter equal to the max of __counter or the passed in __value */
-#define DARSHAN_COUNTER_MAX(__rec_p, __counter, __value) do{ \
-    if((__rec_p)->counters[__counter] < __value) \
-} while(0)
 /* increment a timer counter, making sure not to account for overlap
  * with previous operations
- * NOTE: __tm1 is the start timestamp of the operation, __tm2 is the end
- * timestamp of the operation, and __last is the timestamp of the end of
- * the previous I/O operation (which we don't want to overlap with).
+ * NOTE: __timer is the corresponding timer counter variable, __tm1 is
+ * the start timestamp of the operation, __tm2 is the end timestamp of
+ * the operation, and __last is the timestamp of the end of the previous
+ * I/O operation (which we don't want to overlap with).
-#define DARSHAN_COUNTER_F_INC_NO_OVERLAP(__rec_p, __tm1, __tm2, __last, __counter) do{ \
+#define DARSHAN_TIMER_INC_NO_OVERLAP(__timer, __tm1, __tm2, __last) do{ \
     if(__tm1 > __last) \
-        DARSHAN_COUNTER_F_INC(__rec_p, __counter, (__tm2 - __tm1)); \
+        __timer += (__tm2 - __tm1); \
     else \
-        DARSHAN_COUNTER_F_INC(__rec_p, __counter, (__tm2 - __last)); \
+        __timer += (__tm2 - __last); \
     if(__tm2 > __last) \
         __last = __tm2; \
 } while(0)
@@ -63,7 +28,7 @@
  * NOTE: This macro can be used to build a histogram of access
  * sizes, offsets, etc. It assumes a 10-bucket histogram, with
- * __counter_base representing the first counter in the sequence
+ * __bucket_base_p pointing to the first counter in the sequence
  * of buckets (i.e., the smallest bucket). The size ranges of each
  * bucket are:
  *      * 0 - 100 bytes
@@ -77,29 +42,75 @@
  *      * 100 MiB - 1 GiB
  *      * 1 GiB+
-#define DARSHAN_BUCKET_INC(__rec_p, __counter_base, __value) do {\
+#define DARSHAN_BUCKET_INC(__bucket_base_p, __value) do {\
     if(__value < 101) \
-        (__rec_p)->counters[__counter_base] += 1; \
+        *(__bucket_base_p) += 1; \
     else if(__value < 1025) \
-        (__rec_p)->counters[__counter_base+1] += 1; \
+        *(__bucket_base_p + 1) += 1; \
     else if(__value < 10241) \
-        (__rec_p)->counters[__counter_base+2] += 1; \
+        *(__bucket_base_p + 2) += 1; \
     else if(__value < 102401) \
-        (__rec_p)->counters[__counter_base+3] += 1; \
+        *(__bucket_base_p + 3) += 1; \
     else if(__value < 1048577) \
-        (__rec_p)->counters[__counter_base+4] += 1; \
+        *(__bucket_base_p + 4) += 1; \
     else if(__value < 4194305) \
-        (__rec_p)->counters[__counter_base+5] += 1; \
+        *(__bucket_base_p + 5) += 1; \
     else if(__value < 10485761) \
-        (__rec_p)->counters[__counter_base+6] += 1; \
+        *(__bucket_base_p + 6) += 1; \
     else if(__value < 104857601) \
-        (__rec_p)->counters[__counter_base+7] += 1; \
+        *(__bucket_base_p + 7) += 1; \
     else if(__value < 1073741825) \
-        (__rec_p)->counters[__counter_base+8] += 1; \
+        *(__bucket_base_p + 8) += 1; \
     else \
-        (__rec_p)->counters[__counter_base+9] += 1; \
+        *(__bucket_base_p + 9) += 1; \
 } while(0)
+/* potentially set or increment a common value counter, depending on the __count
+ * for the given __value
+ * NOTE: This macro is hardcoded to expect that Darshan will only track the 4
+ * most common (i.e., frequently occuring) values. __val_p is a pointer to the
+ * base of the value counters (i.e., the first of 4 contiguous common value
+ * counters) and __cnt_p is a pointer to the base of the count counters (i.e.
+ * the first of 4 contiguous common count counters). It is assumed your counters
+ * are stored as int64_t types.
+#define DARSHAN_COMMON_VAL_COUNTER_INC(__val_p, __cnt_p, __value, __count) do {\
+    int i; \
+    int set = 0; \
+    int64_t min = *(__cnt_p); \
+    int min_index = 0; \
+    if(__value == 0) break; \
+    for(i=0; i<4; i++) { \
+        /* increment bucket if already exists */ \
+        if(*(__val_p + i) == __value) { \
+            *(__cnt_p + i) += __count; \
+            set = 1; \
+            break; \
+        /* otherwise find the least frequently used bucket */ \
+        else if(*(__cnt_p + i) < min) { \
+            min = *(__cnt_p + i); \
+            min_index = i; \
+    if(!set && (__count > min)) { \
+        *(__cnt_p + min_index) = __count; \
+        *(__val_p + min_index) = __value; \
+} while(0)
+/* maximum number of common values that darshan will track per file at
+ * runtime; at shutdown time these will be reduced to the 4 most
+ * frequently occuring ones
+#define DARSHAN_COMMON_VAL_MAX_RUNTIME_COUNT 32
+struct darshan_common_val_counter
+    int64_t val;
+    int freq;
 /* i/o type (read or write) */
 enum darshan_io_type
@@ -118,6 +129,39 @@ enum darshan_io_type
  * to absolute paths and filters out some potential noise in the
  * path string.
-char* darshan_clean_file_path(const char* path);
+char* darshan_clean_file_path(
+    const char* path);
+/* darshan_common_val_counter()
+ * Potentially increment an existing common value counter or allocate
+ * a new one to keep track of commonly occuring values. Example use
+ * cases would be to track the most frequent access sizes or strides
+ * used by a specific module, for instance. 'common_val_root' is the
+ * root pointer for the tree which stores common value info,
+ * 'common_val_count' is a pointer to the number of nodes in the
+ * tree (i.e., the number of allocated common value counters), and
+ * 'val' is the new value to attempt to add.
+void darshan_common_val_counter(
+    void** common_val_root,
+    int* common_val_count,
+    int64_t val);
+/* darshan_walk_common_vals()
+ * Walks the tree of common value counters and determines the 4 most
+ * frequently occuring values, storing the common values in the
+ * appropriate counter fields of the given record. 'common_val_root'
+ * is the root of the tree which stores the common value info, 'val_p'
+ * is a pointer to the base counter (i.e., the first) of the common
+ * values (which are assumed to be 4 total and contiguous in memory),
+ * and 'cnt_p' is a pointer to the base counter of the common counts
+ * (which are again expected to be contiguous in memory).
+void darshan_walk_common_vals(
+    void* common_val_root,
+    int64_t* val_p,
+    int64_t* cnt_p);
 #endif /* __DARSHAN_COMMON_H */
diff --git a/darshan-runtime/lib/darshan-common.c b/darshan-runtime/lib/darshan-common.c
index 8b4cb7e..292e986 100644
--- a/darshan-runtime/lib/darshan-common.c
+++ b/darshan-runtime/lib/darshan-common.c
@@ -3,6 +3,8 @@
  * See COPYRIGHT notice in top-level directory.
+#define _XOPEN_SOURCE 500
+#define _GNU_SOURCE
 #include "darshan-runtime-config.h"
@@ -10,9 +12,15 @@
 #include <stdlib.h>
 #include <string.h>
 #include <limits.h>
+#include <search.h>
+#include <assert.h>
 #include "darshan.h"
+static int darshan_common_val_compare(const void* a_p, const void* b_p);
+static void darshan_common_val_walker(const void* nodep, const VISIT which,
+    const int depth);
     char* newpath = NULL;
@@ -70,6 +78,101 @@ char* darshan_clean_file_path(const char* path)
     return(newpath);
+/* HACK: global variables for determining 4 most common values */
+static int64_t* walker_val_p = NULL;
+static int64_t* walker_cnt_p = NULL;
+void darshan_common_val_counter(void **common_val_root, int *common_val_count,
+    int64_t val)
+    struct darshan_common_val_counter* counter;
+    struct darshan_common_val_counter* found;
+    struct darshan_common_val_counter tmp_counter;
+    void* tmp;
+    /* don't count any values of 0 */
+    if(val == 0)
+        return;
+    /* check to see if this val is already recorded */
+    tmp_counter.val = val;
+    tmp_counter.freq = 1;
+    tmp = tfind(&tmp_counter, common_val_root, darshan_common_val_compare);
+    if(tmp)
+        found = *(struct darshan_common_val_counter**)tmp;
+        found->freq++;
+        return;
+    /* we can add a new one as long as we haven't hit the limit */
+    if(*common_val_count < DARSHAN_COMMON_VAL_MAX_RUNTIME_COUNT)
+        counter = malloc(sizeof(*counter));
+        if(!counter)
+            return;
+        counter->val = val;
+        counter->freq = 1;
+        tmp = tsearch(counter, common_val_root, darshan_common_val_compare);
+        /* if we get a new answer out here we are in trouble; this was
+         * already checked with the tfind()
+        assert(found == counter);
+        (*common_val_count)++;
+    return;
+void darshan_walk_common_vals(void *common_val_root, int64_t* val_p,
+    int64_t* cnt_p)
+    walker_val_p = val_p;
+    walker_cnt_p = cnt_p;
+    twalk(common_val_root, darshan_common_val_walker);
+    tdestroy(common_val_root, free);
+    return;
+    const int depth)
+    switch (which)
+        case postorder:
+        case leaf:
+            counter = *(struct darshan_common_val_counter**)nodep;
+            DARSHAN_COMMON_VAL_COUNTER_INC(walker_val_p, walker_cnt_p,
+                counter->val, counter->freq);
+        default:
+            break;
+    return;
+    const struct darshan_common_val_counter* a = a_p;
+    const struct darshan_common_val_counter* b = b_p;
+    if(a->val < b->val)
+        return(-1);
+    if(a->val > b->val)
+        return(1);
+    return(0);
  * Local variables:
  *  c-indent-level: 4
diff --git a/darshan-runtime/lib/darshan-mpiio.c b/darshan-runtime/lib/darshan-mpiio.c
index 37ffc08..a8858dc 100644
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -60,6 +60,8 @@ struct mpiio_file_runtime
     double last_meta_end;
     double last_read_end;
     double last_write_end;
+    void *access_root;
+    int access_count;
     UT_hash_handle hlink;
@@ -141,20 +143,20 @@ static void mpiio_shutdown(void);
     if(!file) break; \
     DARSHAN_MPI_CALL(PMPI_Type_size)(__datatype, &size);  \
     size = size * __count; \
-    DARSHAN_BUCKET_INC(file->file_record, MPIIO_SIZE_READ_AGG_0_100, size); \
-    DARSHAN_COUNTER_INC(file->file_record, MPIIO_BYTES_READ, size); \
-    DARSHAN_COUNTER_INC(file->file_record, __counter, 1); \
+    DARSHAN_BUCKET_INC(&(file->file_record->counters[MPIIO_SIZE_READ_AGG_0_100]), size); \
+    darshan_common_val_counter(&file->access_root, &file->access_count, size); \
+    file->file_record->counters[MPIIO_BYTES_READ] += size; \
+    file->file_record->counters[__counter] += 1; \
     if(file->last_io_type == DARSHAN_IO_WRITE) \
-        DARSHAN_COUNTER_INC(file->file_record, MPIIO_RW_SWITCHES, 1); \
+        file->file_record->counters[MPIIO_RW_SWITCHES] += 1; \
     file->last_io_type = DARSHAN_IO_READ; \
-    DARSHAN_COUNTER_F_INC_NO_OVERLAP(file->file_record, __tm1, __tm2, \
-        file->last_read_end, MPIIO_F_READ_TIME); \
-    if(DARSHAN_COUNTER_F_VALUE(file->file_record, MPIIO_F_READ_START_TIMESTAMP) == 0) \
-        DARSHAN_COUNTER_F_SET(file->file_record, MPIIO_F_READ_START_TIMESTAMP, __tm1); \
-    DARSHAN_COUNTER_F_SET(file->file_record, MPIIO_F_READ_END_TIMESTAMP, __tm2); \
-    if(DARSHAN_COUNTER_F_VALUE(file->file_record, MPIIO_F_MAX_READ_TIME) < __elapsed) { \
-        DARSHAN_COUNTER_F_SET(file->file_record, MPIIO_F_MAX_READ_TIME, __elapsed); \
-        DARSHAN_COUNTER_SET(file->file_record, MPIIO_MAX_READ_TIME_SIZE, size); } \
+    if(file->file_record->fcounters[MPIIO_F_READ_START_TIMESTAMP] == 0) \
+        file->file_record->fcounters[MPIIO_F_READ_START_TIMESTAMP] = __tm1; \
+    file->file_record->fcounters[MPIIO_F_READ_END_TIMESTAMP] = __tm2; \
+    if(file->file_record->fcounters[MPIIO_F_MAX_READ_TIME] < __elapsed) { \
+        file->file_record->fcounters[MPIIO_F_MAX_READ_TIME] = __elapsed; \
+        file->file_record->counters[MPIIO_MAX_READ_TIME_SIZE] = size; } \
+    DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[MPIIO_F_READ_TIME], __tm1, __tm2, file->last_read_end); \
 } while(0)
 #define MPIIO_RECORD_WRITE(__ret, __fh, __count, __datatype, __counter, __tm1, __tm2) do { \
@@ -162,25 +164,24 @@ static void mpiio_shutdown(void);
     int size = 0; \
     double __elapsed = __tm2-__tm1; \
     if(__ret != MPI_SUCCESS) break; \
-    if(__ret != MPI_SUCCESS) break; \
     file = mpiio_file_by_fh(__fh); \
     if(!file) break; \
-    DARSHAN_BUCKET_INC(file->file_record, MPIIO_SIZE_WRITE_AGG_0_100, size); \
-    DARSHAN_COUNTER_INC(file->file_record, MPIIO_BYTES_WRITTEN, size); \
+    DARSHAN_BUCKET_INC(&(file->file_record->counters[MPIIO_SIZE_WRITE_AGG_0_100]), size); \
+    file->file_record->counters[MPIIO_BYTES_WRITTEN] += size; \
     if(file->last_io_type == DARSHAN_IO_READ) \
     file->last_io_type = DARSHAN_IO_WRITE; \
-        file->last_write_end, MPIIO_F_WRITE_TIME); \
-    if(DARSHAN_COUNTER_F_VALUE(file->file_record, MPIIO_F_WRITE_START_TIMESTAMP) == 0) \
-        DARSHAN_COUNTER_F_SET(file->file_record, MPIIO_F_WRITE_START_TIMESTAMP, __tm1); \
-    DARSHAN_COUNTER_F_SET(file->file_record, MPIIO_F_WRITE_END_TIMESTAMP, __tm2); \
-    if(DARSHAN_COUNTER_F_VALUE(file->file_record, MPIIO_F_MAX_WRITE_TIME) < __elapsed) { \
-        DARSHAN_COUNTER_F_SET(file->file_record, MPIIO_F_MAX_WRITE_TIME, __elapsed); \
-        DARSHAN_COUNTER_SET(file->file_record, MPIIO_MAX_WRITE_TIME_SIZE, size); } \
+    if(file->file_record->fcounters[MPIIO_F_WRITE_START_TIMESTAMP] == 0) \
+        file->file_record->fcounters[MPIIO_F_WRITE_START_TIMESTAMP] = __tm1; \
+    file->file_record->fcounters[MPIIO_F_WRITE_END_TIMESTAMP] = __tm2; \
+    if(file->file_record->fcounters[MPIIO_F_MAX_WRITE_TIME] < __elapsed) { \
+        file->file_record->fcounters[MPIIO_F_MAX_WRITE_TIME] = __elapsed; \
+        file->file_record->counters[MPIIO_MAX_WRITE_TIME_SIZE] = size; } \
+    DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[MPIIO_F_WRITE_TIME], __tm1, __tm2, file->last_write_end); \
 } while(0)
@@ -222,24 +223,25 @@ int MPI_File_open(MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_F
         if(file)
             file->file_record->rank = my_rank;
-            DARSHAN_COUNTER_SET(file->file_record, MPIIO_MODE, amode);
+            file->file_record->counters[MPIIO_MODE] = amode;
             DARSHAN_MPI_CALL(PMPI_Comm_size)(comm, &comm_size);
             if(comm_size == 1)
-                DARSHAN_COUNTER_INC(file->file_record, MPIIO_INDEP_OPENS, 1);
+                file->file_record->counters[MPIIO_INDEP_OPENS] += 1;
             else
-                DARSHAN_COUNTER_INC(file->file_record, MPIIO_COLL_OPENS, 1);
+                file->file_record->counters[MPIIO_COLL_OPENS] += 1;
             if(info != MPI_INFO_NULL)
-                DARSHAN_COUNTER_INC(file->file_record, MPIIO_HINTS, 1);
+                file->file_record->counters[MPIIO_HINTS] += 1;
-            if(DARSHAN_COUNTER_F_VALUE(file->file_record, MPIIO_F_OPEN_TIMESTAMP) == 0)
-                DARSHAN_COUNTER_F_SET(file->file_record, MPIIO_F_OPEN_TIMESTAMP, tm1);
-            DARSHAN_COUNTER_F_INC_NO_OVERLAP(file->file_record, tm1, tm2,
-                file->last_meta_end, MPIIO_F_META_TIME);
+            if(file->file_record->fcounters[MPIIO_F_OPEN_TIMESTAMP] == 0)
+                file->file_record->fcounters[MPIIO_F_OPEN_TIMESTAMP] = tm1;
+                file->file_record->fcounters[MPIIO_F_META_TIME],
+                tm1, tm2, file->last_meta_end);
         MPIIO_UNLOCK();
@@ -738,9 +740,10 @@ int MPI_File_sync(MPI_File fh)
         file = mpiio_file_by_fh(fh);
         if(file)
-            DARSHAN_COUNTER_INC(file->file_record, MPIIO_SYNCS, 1);
+            file->file_record->counters[MPIIO_SYNCS] += 1;
+                file->file_record->fcounters[MPIIO_F_WRITE_TIME],
+                tm1, tm2, file->last_write_end);
         MPIIO_UNLOCK();
@@ -772,12 +775,13 @@ int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
         if(file)
-            DARSHAN_COUNTER_INC(file->file_record, MPIIO_VIEWS, 1);
+            file->file_record->counters[MPIIO_VIEWS] += 1;
         MPIIO_UNLOCK();
@@ -802,10 +806,11 @@ int MPI_File_close(MPI_File *fh)
     file = mpiio_file_by_fh(tmp_fh);
     if(file)
-        DARSHAN_COUNTER_F_SET(file->file_record, MPIIO_F_CLOSE_TIMESTAMP,
-            darshan_core_wtime());
+        file->file_record->fcounters[MPIIO_F_CLOSE_TIMESTAMP] =
+            darshan_core_wtime();
         mpiio_file_close_fh(tmp_fh);
     MPIIO_UNLOCK();
@@ -1023,10 +1028,23 @@ static int mpiio_file_compare(const void* a_p, const void* b_p)
 static void mpiio_begin_shutdown()
+    int i;
+    struct mpiio_file_runtime* tmp;
     assert(mpiio_runtime);
     MPIIO_LOCK();
     instrumentation_disabled = 1;
+    /* go through and set the 4 most common access sizes for MPI-IO */
+    for(i = 0; i < mpiio_runtime->file_array_ndx; i++)
+        tmp = &(mpiio_runtime->file_runtime_array[i]);
+        darshan_walk_common_vals(tmp->access_root,
+            &(tmp->file_record->counters[MPIIO_ACCESS1_ACCESS]),
+            &(tmp->file_record->counters[MPIIO_ACCESS1_COUNT]));
     MPIIO_UNLOCK();
     return;
diff --git a/darshan-runtime/lib/darshan-null.c b/darshan-runtime/lib/darshan-null.c
index 7618e8f..cfa8e6b 100644
--- a/darshan-runtime/lib/darshan-null.c
+++ b/darshan-runtime/lib/darshan-null.c
@@ -139,13 +139,13 @@ static void null_shutdown(void);
     rec = null_record_by_name(__name); \
     if(!rec) break; \
     /* increment counter indicating number of calls to 'bar' */ \
-    DARSHAN_COUNTER_INC(rec->record_p, NULL_BARS, 1); \
+    rec->record_p->counters[NULL_BARS] += 1; \
     /* store data value for most recent call to 'bar' */ \
-    DARSHAN_COUNTER_SET(rec->record_p, NULL_BAR_DAT, __dat); \
+    rec->record_p->counters[NULL_BAR_DAT] = __dat; \
     /* store timestamp of most recent call to 'bar' */ \
-    DARSHAN_COUNTER_F_SET(rec->record_p, NULL_F_BAR_TIMESTAMP, __tm1); \
+    rec->record_p->fcounters[NULL_F_BAR_TIMESTAMP] = __tm1; \
     /* store duration of most recent call to 'bar' */ \
-    DARSHAN_COUNTER_F_SET(rec->record_p, NULL_F_BAR_DURATION, elapsed); \
+    rec->record_p->fcounters[NULL_F_BAR_DURATION] = elapsed; \
 } while(0)
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 2ef29b9..a1b310e 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -85,24 +85,6 @@ DARSHAN_FORWARD_DECL(aio_return64, ssize_t, (struct aiocb64 *aiocbp));
 DARSHAN_FORWARD_DECL(lio_listio, int, (int mode, struct aiocb *const aiocb_list[], int nitems, struct sigevent *sevp));
 DARSHAN_FORWARD_DECL(lio_listio64, int, (int mode, struct aiocb64 *const aiocb_list[], int nitems, struct sigevent *sevp));
-/* maximum number of access sizes and stride sizes that darshan will track
- * per file at runtime; at log time they will be reduced into the 4 most
- * frequently occurring ones
-#define POSIX_MAX_ACCESS_COUNT_RUNTIME 32
-enum posix_counter_type
-    POSIX_COUNTER_ACCESS,
-    POSIX_COUNTER_STRIDE
-struct posix_access_counter
-    int64_t size;
-    int freq;
 /* struct to track information about aio operations in flight */
 struct posix_aio_tracker
@@ -204,22 +186,12 @@ static int instrumentation_disabled = 0;
 static int my_rank = -1;
 static int darshan_mem_alignment = 1;
-/* global variables for determining 4 most common accesses/strides */
-static struct posix_file_runtime* walker_file = NULL;
-static int walker_validx;
-static int walker_cntidx;
 static void posix_runtime_initialize(void);
 static struct posix_file_runtime* posix_file_by_name(const char *name);
 static struct posix_file_runtime* posix_file_by_name_setfd(const char* name, int fd);
 static struct posix_file_runtime* posix_file_by_fd(int fd);
 static void posix_file_close_fd(int fd);
-static void posix_access_counter(struct posix_file_runtime* file, ssize_t size,
-    enum posix_counter_type type);
-static void posix_access_walker(const void* nodep, const VISIT which, const int depth);
-static void posix_walk_file_accesses(void);
-static int posix_access_compare(const void* a_p, const void* b_p);
-static int posix_file_compare(const void* a, const void* b);
+static int posix_record_compare(const void* a, const void* b);
 static void posix_aio_tracker_add(int fd, void *aiocbp);
 static struct posix_aio_tracker* posix_aio_tracker_del(int fd, void *aiocbp);
@@ -234,31 +206,6 @@ static void posix_shutdown(void);
 #define POSIX_LOCK() pthread_mutex_lock(&posix_runtime_mutex)
 #define POSIX_UNLOCK() pthread_mutex_unlock(&posix_runtime_mutex)
-#define POSIX_COMMON_COUNTER_INC(__rec_p, __value, __count, __validx, __cntidx) do {\
-    int i; \
-    int set = 0; \
-    int64_t min = DARSHAN_COUNTER_VALUE(__rec_p, __cntidx); \
-    int min_index = 0; \
-    if(__value == 0) break; \
-    for(i=0; i<4; i++) { \
-        /* increment bucket if already exists */ \
-        if(DARSHAN_COUNTER_VALUE(__rec_p, __validx + i) == __value) { \
-            DARSHAN_COUNTER_INC(__rec_p, __cntidx + i, __count); \
-            set = 1; \
-            break; \
-        /* otherwise find the least frequently used bucket */ \
-        else if(DARSHAN_COUNTER_VALUE(__rec_p, __cntidx + i) < min) { \
-            min = DARSHAN_COUNTER_VALUE(__rec_p, __cntidx + i); \
-            min_index = i; \
-    if(!set && (__count > min)) { \
-        DARSHAN_COUNTER_SET(__rec_p, __cntidx+min_index, __count); \
-        DARSHAN_COUNTER_SET(__rec_p, __validx+min_index, __value); \
-} while(0)
 #define POSIX_RECORD_OPEN(__ret, __path, __mode, __stream_flag, __tm1, __tm2) do { \
     struct posix_file_runtime* file; \
     char* exclude; \
@@ -274,17 +221,17 @@ static void posix_shutdown(void);
     if(!file) break; \
     file->file_record->rank = my_rank; \
     if(__mode) \
-        DARSHAN_COUNTER_SET(file->file_record, POSIX_MODE, __mode); \
+        file->file_record->counters[POSIX_MODE] = __mode; \
     file->offset = 0; \
     file->last_byte_written = 0; \
     file->last_byte_read = 0; \
     if(__stream_flag)\
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_FOPENS, 1); \
+        file->file_record->counters[POSIX_FOPENS] += 1; \
     else \
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_OPENS, 1); \
-    if(DARSHAN_COUNTER_F_VALUE(file->file_record, POSIX_F_OPEN_TIMESTAMP) == 0) \
-        DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_OPEN_TIMESTAMP, __tm1); \
-    DARSHAN_COUNTER_F_INC_NO_OVERLAP(file->file_record, __tm1, __tm2, file->last_meta_end, POSIX_F_META_TIME); \
+        file->file_record->counters[POSIX_OPENS] += 1; \
+    if(file->file_record->fcounters[POSIX_F_OPEN_TIMESTAMP] == 0) \
+        file->file_record->fcounters[POSIX_F_OPEN_TIMESTAMP] = __tm1; \
+    DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[POSIX_F_META_TIME], __tm1, __tm2, file->last_meta_end); \
 } while(0)
 #define POSIX_RECORD_READ(__ret, __fd, __pread_flag, __pread_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
@@ -301,9 +248,9 @@ static void posix_shutdown(void);
     else \
         this_offset = file->offset; \
     if(this_offset > file->last_byte_read) \
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_READS, 1); \
+        file->file_record->counters[POSIX_SEQ_READS] += 1;  \
     if(this_offset == (file->last_byte_read + 1)) \
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_READS, 1); \
+        file->file_record->counters[POSIX_CONSEC_READS] += 1;  \
     if(this_offset > 0 && this_offset > file->last_byte_read \
         && file->last_byte_read != 0) \
         stride = this_offset - file->last_byte_read - 1; \
@@ -311,30 +258,31 @@ static void posix_shutdown(void);
         stride = 0; \
     file->last_byte_read = this_offset + __ret - 1; \
     file->offset = this_offset + __ret; \
-    DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_READ, (this_offset + __ret - 1)); \
-    DARSHAN_COUNTER_INC(file->file_record, POSIX_BYTES_READ, __ret); \
-    if(__stream_flag)\
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_FREADS, 1); \
-    else\
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_READS, 1); \
-    DARSHAN_BUCKET_INC(file->file_record, POSIX_SIZE_READ_0_100, __ret); \
-    posix_access_counter(file, __ret, POSIX_COUNTER_ACCESS); \
-    posix_access_counter(file, stride, POSIX_COUNTER_STRIDE); \
+    if(file->file_record->counters[POSIX_MAX_BYTE_READ] < (this_offset + __ret - 1)) \
+        file->file_record->counters[POSIX_MAX_BYTE_READ] = (this_offset + __ret - 1); \
+    file->file_record->counters[POSIX_BYTES_READ] += __ret; \
+    if(__stream_flag) \
+        file->file_record->counters[POSIX_FREADS] += 1; \
+    else \
+        file->file_record->counters[POSIX_READS] += 1; \
+    DARSHAN_BUCKET_INC(&(file->file_record->counters[POSIX_SIZE_READ_0_100]), __ret); \
+    darshan_common_val_counter(&file->access_root, &file->access_count, __ret); \
+    darshan_common_val_counter(&file->stride_root, &file->stride_count, stride); \
     if(!__aligned) \
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_MEM_NOT_ALIGNED, 1); \
-    file_alignment = DARSHAN_COUNTER_VALUE(file->file_record, POSIX_FILE_ALIGNMENT); \
+        file->file_record->counters[POSIX_MEM_NOT_ALIGNED] += 1; \
+    file_alignment = file->file_record->counters[POSIX_FILE_ALIGNMENT]; \
     if(file_alignment > 0 && (this_offset % file_alignment) != 0) \
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_FILE_NOT_ALIGNED, 1); \
+        file->file_record->counters[POSIX_FILE_NOT_ALIGNED] += 1; \
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_RW_SWITCHES, 1); \
+        file->file_record->counters[POSIX_RW_SWITCHES] += 1; \
-    DARSHAN_COUNTER_F_INC_NO_OVERLAP(file->file_record, __tm1, __tm2, file->last_read_end, POSIX_F_READ_TIME); \
-    if(DARSHAN_COUNTER_F_VALUE(file->file_record, POSIX_F_READ_START_TIMESTAMP) == 0) \
-        DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_READ_START_TIMESTAMP, __tm1); \
-    DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_READ_END_TIMESTAMP, __tm2); \
-    if(DARSHAN_COUNTER_F_VALUE(file->file_record, POSIX_F_MAX_READ_TIME) < __elapsed){ \
-        DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_MAX_READ_TIME, __elapsed); \
-        DARSHAN_COUNTER_SET(file->file_record, POSIX_MAX_READ_TIME_SIZE, __ret); } \
+    if(file->file_record->fcounters[POSIX_F_READ_START_TIMESTAMP] == 0) \
+        file->file_record->fcounters[POSIX_F_READ_START_TIMESTAMP] = __tm1; \
+    file->file_record->fcounters[POSIX_F_READ_END_TIMESTAMP] = __tm2; \
+    if(file->file_record->fcounters[POSIX_F_MAX_READ_TIME] < __elapsed) { \
+        file->file_record->fcounters[POSIX_F_MAX_READ_TIME] = __elapsed; \
+        file->file_record->counters[POSIX_MAX_READ_TIME_SIZE] = __ret; } \
+    DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[POSIX_F_READ_TIME], __tm1, __tm2, file->last_read_end); \
 } while(0)
 #define POSIX_RECORD_WRITE(__ret, __fd, __pwrite_flag, __pwrite_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
@@ -351,9 +299,9 @@ static void posix_shutdown(void);
     else \
     if(this_offset > file->last_byte_written) \
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_WRITES, 1); \
+        file->file_record->counters[POSIX_SEQ_WRITES] += 1; \
     if(this_offset == (file->last_byte_written + 1)) \
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_WRITES, 1); \
+        file->file_record->counters[POSIX_CONSEC_WRITES] += 1; \
     if(this_offset > 0 && this_offset > file->last_byte_written \
         && file->last_byte_written != 0) \
         stride = this_offset - file->last_byte_written - 1; \
@@ -361,30 +309,31 @@ static void posix_shutdown(void);
         stride = 0; \
     file->last_byte_written = this_offset + __ret - 1; \
-    DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_WRITTEN, (this_offset + __ret - 1)); \
-    DARSHAN_COUNTER_INC(file->file_record, POSIX_BYTES_WRITTEN, __ret); \
+    if(file->file_record->counters[POSIX_MAX_BYTE_WRITTEN] < (this_offset + __ret - 1)) \
+        file->file_record->counters[POSIX_MAX_BYTE_WRITTEN] = (this_offset + __ret - 1); \
+    file->file_record->counters[POSIX_BYTES_WRITTEN] += __ret; \
     if(__stream_flag) \
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_FWRITES, 1); \
+        file->file_record->counters[POSIX_FWRITES] += 1; \
     else \
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_WRITES, 1); \
-    DARSHAN_BUCKET_INC(file->file_record, POSIX_SIZE_WRITE_0_100, __ret); \
+        file->file_record->counters[POSIX_WRITES] += 1; \
+    DARSHAN_BUCKET_INC(&(file->file_record->counters[POSIX_SIZE_WRITE_0_100]), __ret); \
     if(!__aligned) \
-    DARSHAN_COUNTER_F_INC_NO_OVERLAP(file->file_record, __tm1, __tm2, file->last_write_end, POSIX_F_WRITE_TIME); \
-    if(DARSHAN_COUNTER_F_VALUE(file->file_record, POSIX_F_WRITE_START_TIMESTAMP) == 0) \
-        DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_WRITE_START_TIMESTAMP, __tm1); \
-    DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_WRITE_END_TIMESTAMP, __tm2); \
-    if(DARSHAN_COUNTER_F_VALUE(file->file_record, POSIX_F_MAX_WRITE_TIME) < __elapsed){ \
-        DARSHAN_COUNTER_F_SET(file->file_record, POSIX_F_MAX_WRITE_TIME, __elapsed); \
-        DARSHAN_COUNTER_SET(file->file_record, POSIX_MAX_WRITE_TIME_SIZE, __ret); } \
+    if(file->file_record->fcounters[POSIX_F_WRITE_START_TIMESTAMP] == 0) \
+        file->file_record->fcounters[POSIX_F_WRITE_START_TIMESTAMP] = __tm1; \
+    file->file_record->fcounters[POSIX_F_WRITE_END_TIMESTAMP] = __tm2; \
+    if(file->file_record->fcounters[POSIX_F_MAX_WRITE_TIME] < __elapsed) { \
+        file->file_record->fcounters[POSIX_F_MAX_WRITE_TIME] = __elapsed; \
+        file->file_record->counters[POSIX_MAX_WRITE_TIME_SIZE] = __ret; } \
+    DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[POSIX_F_WRITE_TIME], __tm1, __tm2, file->last_write_end); \
 } while(0)
 #define POSIX_LOOKUP_RECORD_STAT(__path, __statbuf, __tm1, __tm2) do { \
@@ -406,8 +355,8 @@ static void posix_shutdown(void);
 #define POSIX_RECORD_STAT(__file, __statbuf, __tm1, __tm2) do { \
     (__file)->file_record->rank = my_rank; \
-    DARSHAN_COUNTER_F_INC_NO_OVERLAP((__file)->file_record, __tm1, __tm2, (__file)->last_meta_end, POSIX_F_META_TIME); \
-    DARSHAN_COUNTER_INC((__file)->file_record, POSIX_STATS, 1); \
+    DARSHAN_TIMER_INC_NO_OVERLAP((__file)->file_record->fcounters[POSIX_F_META_TIME], __tm1, __tm2, (__file)->last_meta_end); \
+    (__file)->file_record->counters[POSIX_STATS] += 1; \
 } while(0)
@@ -914,9 +863,10 @@ off_t DARSHAN_DECL(lseek)(int fd, off_t offset, int whence)
         if(file)
             file->offset = ret;
-                tm1, tm2, file->last_meta_end, POSIX_F_META_TIME);
-            DARSHAN_COUNTER_INC(file->file_record, POSIX_SEEKS, 1);
+                file->file_record->fcounters[POSIX_F_META_TIME],
+            file->file_record->counters[POSIX_SEEKS] += 1;
         POSIX_UNLOCK();
@@ -944,9 +894,10 @@ off_t DARSHAN_DECL(lseek64)(int fd, off_t offset, int whence)
         if(file)
             file->offset = ret;
         POSIX_UNLOCK();
@@ -974,9 +925,10 @@ int DARSHAN_DECL(fseek)(FILE *stream, long offset, int whence)
         if(file)
             file->offset = ftell(stream);
-            DARSHAN_COUNTER_INC(file->file_record, POSIX_FSEEKS, 1);
+            file->file_record->counters[POSIX_FSEEKS] += 1;
         POSIX_UNLOCK();
@@ -1143,7 +1095,7 @@ void* DARSHAN_DECL(mmap)(void *addr, size_t length, int prot, int flags,
     file = posix_file_by_fd(fd);
     if(file)
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_MMAPS, 1);
+        file->file_record->counters[POSIX_MMAPS] += 1;
     POSIX_UNLOCK();
@@ -1167,7 +1119,7 @@ void* DARSHAN_DECL(mmap64)(void *addr, size_t length, int prot, int flags,
     if(file)
     POSIX_UNLOCK();
@@ -1194,9 +1146,10 @@ int DARSHAN_DECL(fsync)(int fd)
     if(file)
-            tm1, tm2, file->last_write_end, POSIX_F_WRITE_TIME);
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_FSYNCS, 1);
+            file->file_record->fcounters[POSIX_F_WRITE_TIME],
+        file->file_record->counters[POSIX_FSYNCS] += 1;
     POSIX_UNLOCK();
@@ -1223,9 +1176,10 @@ int DARSHAN_DECL(fdatasync)(int fd)
     if(file)
-        DARSHAN_COUNTER_INC(file->file_record, POSIX_FDSYNCS, 1);
+        file->file_record->counters[POSIX_FDSYNCS] += 1;
     POSIX_UNLOCK();
@@ -1251,10 +1205,11 @@ int DARSHAN_DECL(close)(int fd)
-            POSIX_F_CLOSE_TIMESTAMP, darshan_core_wtime());
+        file->file_record->fcounters[POSIX_F_CLOSE_TIMESTAMP] =
         posix_file_close_fd(fd);
     POSIX_UNLOCK();
@@ -1282,10 +1237,11 @@ int DARSHAN_DECL(fclose)(FILE *fp)
     POSIX_UNLOCK();
@@ -1588,8 +1544,8 @@ static struct posix_file_runtime* posix_file_by_name(const char *name)
         file = &(posix_runtime->file_runtime_array[posix_runtime->file_array_ndx]);
         file->file_record = &(posix_runtime->file_record_array[posix_runtime->file_array_ndx]);
         file->file_record->f_id = file_id;
-        DARSHAN_COUNTER_SET(file->file_record, POSIX_MEM_ALIGNMENT, darshan_mem_alignment);
-        DARSHAN_COUNTER_SET(file->file_record, POSIX_FILE_ALIGNMENT, file_alignment);
+        file->file_record->counters[POSIX_MEM_ALIGNMENT] = darshan_mem_alignment;
+        file->file_record->counters[POSIX_FILE_ALIGNMENT] = file_alignment;
         /* add new record to file hash table */
         HASH_ADD(hlink, posix_runtime->file_hash, file_record->f_id, sizeof(darshan_record_id), file);
@@ -1681,136 +1637,8 @@ static void posix_file_close_fd(int fd)
     return;
-    struct posix_access_counter* counter;
-    struct posix_access_counter* found;
-    void* tmp;
-    void** root;
-    int* count;
-    struct posix_access_counter tmp_counter;
-    /* don't count sizes or strides of 0 */
-    if(size == 0)
-        return;
-    switch(type)
-        case POSIX_COUNTER_ACCESS:
-            root = &file->access_root;
-            count = &file->access_count;
-            break;
-        case POSIX_COUNTER_STRIDE:
-            root = &file->stride_root;
-            count = &file->stride_count;
-            break;
-        default:
-            return;
-    /* check to see if this size is already recorded */
-    tmp_counter.size = size;
-    tmp_counter.freq = 1;
-    tmp = tfind(&tmp_counter, root, posix_access_compare);
-    if(tmp)
-        found = *(struct posix_access_counter**)tmp;
-        found->freq++;
-        return;
-    /* we can add a new one as long as we haven't hit the limit */
-    if(*count < POSIX_MAX_ACCESS_COUNT_RUNTIME)
-        counter = malloc(sizeof(*counter));
-        if(!counter)
-            return;
-        counter->size = size;
-        counter->freq = 1;
-        tmp = tsearch(counter, root, posix_access_compare);
-        /* if we get a new answer out here we are in trouble; this was
-         * already checked with the tfind()
-        assert(found == counter);
-        (*count)++;
-    return;
-    switch (which)
-        case postorder:
-        case leaf:
-            counter = *(struct posix_access_counter**)nodep;
-            POSIX_COMMON_COUNTER_INC(walker_file->file_record, counter->size, counter->freq,
-                walker_validx, walker_cntidx);
-        default:
-            break;
-    return;
-/* posix_walk_file_accesses()
- * goes through runtime collections of accesses sizes and chooses the 4 most
- * common for logging
-static void posix_walk_file_accesses()
-    int i;
-    for(i=0; i<posix_runtime->file_array_ndx; i++)
-        /* walk trees for both access sizes and stride sizes to pick 4 most
-         * common of each
-        /* NOTE: setting global variables here for cp_access_walker() */
-        walker_file = &posix_runtime->file_runtime_array[i];
-        walker_validx = POSIX_ACCESS1_ACCESS;
-        walker_cntidx = POSIX_ACCESS1_COUNT;
-        twalk(walker_file->access_root,
-            posix_access_walker);
-        tdestroy(walker_file->access_root, free);
-        walker_validx = POSIX_STRIDE1_STRIDE;
-        walker_cntidx = POSIX_STRIDE1_COUNT;
-        twalk(walker_file->stride_root,
-        tdestroy(walker_file->stride_root, free);
-    return;
-    const struct posix_access_counter* a = a_p;
-    const struct posix_access_counter* b = b_p;
-    if(a->size < b->size)
-        return(-1);
-    if(a->size > b->size)
-        return(1);
-    return(0);
 /* compare function for sorting file records by descending rank */
-static int posix_file_compare(const void* a_p, const void* b_p)
+static int posix_record_compare(const void* a_p, const void* b_p)
     const struct darshan_posix_file* a = a_p;
     const struct darshan_posix_file* b = b_p;
@@ -1877,17 +1705,32 @@ static struct posix_aio_tracker* posix_aio_tracker_del(int fd, void *aiocbp)
 static void posix_begin_shutdown()
+    int i;
+    struct posix_file_runtime* tmp;
     assert(posix_runtime);
     POSIX_LOCK();
+    instrumentation_disabled = 1;
     /* go through file access data for each record and set the 4 most common
      * stride/access size counters.
-    posix_walk_file_accesses();
+    for(i = 0; i < posix_runtime->file_array_ndx; i++)
+        tmp = &(posix_runtime->file_runtime_array[i]);
+        /* common accesses */
+            &(tmp->file_record->counters[POSIX_ACCESS1_ACCESS]),
+            &(tmp->file_record->counters[POSIX_ACCESS1_COUNT]));
+        /* common strides */
+        darshan_walk_common_vals(tmp->stride_root,
+            &(tmp->file_record->counters[POSIX_STRIDE1_STRIDE]),
+            &(tmp->file_record->counters[POSIX_STRIDE1_COUNT]));
     /* disable further instrumentation while Darshan shuts down */
-    instrumentation_disabled = 1;
     POSIX_UNLOCK();
     return;
@@ -1946,7 +1789,7 @@ static void posix_setup_reduction(
      * of the array
     qsort(posix_runtime->file_record_array, posix_runtime->file_array_ndx,
-        sizeof(struct darshan_posix_file), posix_file_compare);
+        sizeof(struct darshan_posix_file), posix_record_compare);
     /* make *send_buf point to the shared files at the end of sorted array */
     *send_buf =
@@ -2054,14 +1897,16 @@ static void posix_record_reduction_op(
         /* first set */
         for(j=POSIX_STRIDE1_STRIDE; j<=POSIX_STRIDE4_STRIDE; j++)
-            POSIX_COMMON_COUNTER_INC(&tmp_file, infile->counters[j],
-                infile->counters[j+4], POSIX_STRIDE1_STRIDE, POSIX_STRIDE1_COUNT);
+            DARSHAN_COMMON_VAL_COUNTER_INC(&(tmp_file.counters[POSIX_STRIDE1_STRIDE]),
+                &(tmp_file.counters[POSIX_STRIDE1_COUNT]), infile->counters[j],
+                infile->counters[j+4]);
         /* second set */
-            POSIX_COMMON_COUNTER_INC(&tmp_file, inoutfile->counters[j],
-                inoutfile->counters[j+4], POSIX_STRIDE1_STRIDE, POSIX_STRIDE1_COUNT);
+                &(tmp_file.counters[POSIX_STRIDE1_COUNT]), inoutfile->counters[j],
+                inoutfile->counters[j+4]);
         /* same for access counts */
@@ -2083,14 +1928,16 @@ static void posix_record_reduction_op(
         /* first set */
         for(j=POSIX_ACCESS1_ACCESS; j<=POSIX_ACCESS4_ACCESS; j++)
-                infile->counters[j+4], POSIX_ACCESS1_ACCESS, POSIX_ACCESS1_COUNT);
+            DARSHAN_COMMON_VAL_COUNTER_INC(&(tmp_file.counters[POSIX_ACCESS1_ACCESS]),
+                &(tmp_file.counters[POSIX_ACCESS1_COUNT]), infile->counters[j],
         /* second set */
-                inoutfile->counters[j+4], POSIX_ACCESS1_ACCESS, POSIX_ACCESS1_COUNT);
+                &(tmp_file.counters[POSIX_ACCESS1_COUNT]), inoutfile->counters[j],
         /* min non-zero (if available) value */
hooks/post-receive
More information about the Darshan-commits mailing list
