[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-113-g6406c87
Service Account
git at mcs.anl.gov
Mon Jul 20 11:44:26 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 6406c8726d1fe664f9de8147248da121c642ec6a (commit)
from e0eb27be2b7827593b442e104af8b45cb585e876 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 6406c8726d1fe664f9de8147248da121c642ec6a
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Mon Jul 20 11:43:42 2015 -0500
header file cleanups & resolve some small todos
Summary of changes:
darshan-mpiio-log-format.h | 15 ++++-
darshan-posix-log-format.h | 3 +
darshan-runtime/darshan-common.h | 123 ++++++++++++++++++++++++++++++
darshan-runtime/darshan-core.h | 13 +++
darshan-runtime/darshan.h | 137 ++++++++++-----------------------
darshan-runtime/lib/darshan-common.c | 4 -
darshan-runtime/lib/darshan-core.c | 4 +
darshan-runtime/lib/darshan-mpiio.c | 7 +-
darshan-runtime/lib/darshan-null.c | 10 +--
darshan-runtime/lib/darshan-posix.c | 9 +--
10 files changed, 203 insertions(+), 122 deletions(-)
create mode 100644 darshan-runtime/darshan-common.h
Diff of changes:
diff --git a/darshan-mpiio-log-format.h b/darshan-mpiio-log-format.h
index 53e0f9e..433ad1e 100644
--- a/darshan-mpiio-log-format.h
+++ b/darshan-mpiio-log-format.h
@@ -10,7 +10,8 @@
#include "darshan-log-format.h"
/* TODO: slowest/fastest rank (f)counters */
-/* TODO: access size and extent common counters? */
+/* TODO: access size common counters */
+/* TODO: maybe use a counter to track cases in which a derived datatype is used? */
#define MPIIO_COUNTERS \
/* count of MPI independent opens */\
@@ -39,6 +40,8 @@
X(MPIIO_HINTS) \
/* count of MPI set view calls */\
X(MPIIO_VIEWS) \
+ /* MPI-IO access mode of the file */\
+ X(MPIIO_MODE) \
/* total bytes read at MPI-IO layer */\
X(MPIIO_BYTES_READ) \
/* total bytes written at MPI-IO layer */\
@@ -70,6 +73,16 @@
X(MPIIO_SIZE_WRITE_AGG_10M_100M) \
X(MPIIO_SIZE_WRITE_AGG_100M_1G) \
X(MPIIO_SIZE_WRITE_AGG_1G_PLUS) \
+ /* the four most frequently appearing MPI access sizes */\
+ X(MPIIO_ACCESS1_ACCESS) \
+ X(MPIIO_ACCESS2_ACCESS) \
+ X(MPIIO_ACCESS3_ACCESS) \
+ X(MPIIO_ACCESS4_ACCESS) \
+ /* count of each of the most frequent MPI access sizes */\
+ X(MPIIO_ACCESS1_COUNT) \
+ X(MPIIO_ACCESS2_COUNT) \
+ X(MPIIO_ACCESS3_COUNT) \
+ X(MPIIO_ACCESS4_COUNT) \
/* rank and number of bytes moved for fastest/slowest ranks */\
X(MPIIO_FASTEST_RANK) \
X(MPIIO_FASTEST_RANK_BYTES) \
diff --git a/darshan-posix-log-format.h b/darshan-posix-log-format.h
index 35457dc..c7c5503 100644
--- a/darshan-posix-log-format.h
+++ b/darshan-posix-log-format.h
@@ -110,6 +110,7 @@
X(POSIX_ACCESS2_COUNT) \
X(POSIX_ACCESS3_COUNT) \
X(POSIX_ACCESS4_COUNT) \
+ /* rank and number of bytes moved for fastest/slowest ranks */\
X(POSIX_FASTEST_RANK) \
X(POSIX_FASTEST_RANK_BYTES) \
X(POSIX_SLOWEST_RANK) \
@@ -136,7 +137,9 @@
X(POSIX_F_WRITE_TIME) \
/* cumulative posix meta time */\
X(POSIX_F_META_TIME) \
+ /* maximum posix read duration */\
X(POSIX_F_MAX_READ_TIME) \
+ /* maximum posix write duration */\
X(POSIX_F_MAX_WRITE_TIME) \
/* total i/o and meta time consumed for fastest/slowest ranks */\
X(POSIX_F_FASTEST_RANK_TIME) \
diff --git a/darshan-runtime/darshan-common.h b/darshan-runtime/darshan-common.h
new file mode 100644
index 0000000..722aa31
--- /dev/null
+++ b/darshan-runtime/darshan-common.h
@@ -0,0 +1,123 @@
+ * Copyright (C) 2015 University of Chicago.
+ * See COPYRIGHT notice in top-level directory.
+#ifndef __DARSHAN_COMMON_H
+#define __DARSHAN_COMMON_H
+/* simple macros for manipulating a module's counters
+ * NOTE: These macros assume a module's record stores integer
+ * and floating point counters in arrays, named counters and
+ * fcounters, respectively. __rec_p is the a pointer to the
+ * data record, __counter is the counter in question, and
+ * __value is the corresponding data value.
+#define DARSHAN_COUNTER_SET(__rec_p, __counter, __value) do{ \
+ (__rec_p)->counters[__counter] = __value; \
+} while(0)
+#define DARSHAN_COUNTER_F_SET(__rec_p, __counter, __value) do{ \
+ (__rec_p)->fcounters[__counter] = __value; \
+} while(0)
+#define DARSHAN_COUNTER_INC(__rec_p, __counter, __value) do{ \
+ (__rec_p)->counters[__counter] += __value; \
+} while(0)
+#define DARSHAN_COUNTER_F_INC(__rec_p, __counter, __value) do{ \
+ (__rec_p)->fcounters[__counter] += __value; \
+} while(0)
+#define DARSHAN_COUNTER_VALUE(__rec_p, __counter) \
+ ((__rec_p)->counters[__counter])
+#define DARSHAN_COUNTER_F_VALUE(__rec_p, __counter) \
+ ((__rec_p)->fcounters[__counter])
+/* set __counter equal to the max of __counter or the passed in __value */
+#define DARSHAN_COUNTER_MAX(__rec_p, __counter, __value) do{ \
+ if((__rec_p)->counters[__counter] < __value) \
+} while(0)
+/* increment a timer counter, making sure not to account for overlap
+ * with previous operations
+ * NOTE: __tm1 is the start timestamp of the operation, __tm2 is the end
+ * timestamp of the operation, and __last is the timestamp of the end of
+ * the previous I/O operation (which we don't want to overlap with).
+#define DARSHAN_COUNTER_F_INC_NO_OVERLAP(__rec_p, __tm1, __tm2, __last, __counter) do{ \
+ if(__tm1 > __last) \
+ DARSHAN_COUNTER_F_INC(__rec_p, __counter, (__tm2 - __tm1)); \
+ else \
+ DARSHAN_COUNTER_F_INC(__rec_p, __counter, (__tm2 - __last)); \
+ if(__tm2 > __last) \
+ __last = __tm2; \
+} while(0)
+/* increment histogram bucket depending on the given __value
+ * NOTE: This macro can be used to build a histogram of access
+ * sizes, offsets, etc. It assumes a 10-bucket histogram, with
+ * __counter_base representing the first counter in the sequence
+ * of buckets (i.e., the smallest bucket). The size ranges of each
+ * bucket are:
+ * * 0 - 100 bytes
+ * * 100 - 1 KiB
+ * * 1 KiB - 10 KiB
+ * * 10 KiB - 100 KiB
+ * * 100 KiB - 1 MiB
+ * * 1 MiB - 4 MiB
+ * * 4 MiB - 10 MiB
+ * * 10 MiB - 100 MiB
+ * * 100 MiB - 1 GiB
+ * * 1 GiB+
+#define DARSHAN_BUCKET_INC(__rec_p, __counter_base, __value) do {\
+ if(__value < 101) \
+ (__rec_p)->counters[__counter_base] += 1; \
+ else if(__value < 1025) \
+ (__rec_p)->counters[__counter_base+1] += 1; \
+ else if(__value < 10241) \
+ (__rec_p)->counters[__counter_base+2] += 1; \
+ else if(__value < 102401) \
+ (__rec_p)->counters[__counter_base+3] += 1; \
+ else if(__value < 1048577) \
+ (__rec_p)->counters[__counter_base+4] += 1; \
+ else if(__value < 4194305) \
+ (__rec_p)->counters[__counter_base+5] += 1; \
+ else if(__value < 10485761) \
+ (__rec_p)->counters[__counter_base+6] += 1; \
+ else if(__value < 104857601) \
+ (__rec_p)->counters[__counter_base+7] += 1; \
+ else if(__value < 1073741825) \
+ (__rec_p)->counters[__counter_base+8] += 1; \
+ else \
+ (__rec_p)->counters[__counter_base+9] += 1; \
+} while(0)
+/* i/o type (read or write) */
+enum darshan_io_type
+ DARSHAN_IO_READ = 1,
+ DARSHAN_IO_WRITE = 2,
+* darshan-common functions for darshan modules *
+/* darshan_clean_file_path()
+ * Allocate a new string that contains a new cleaned-up version of
+ * the file path given in 'path' argument. Converts relative paths
+ * to absolute paths and filters out some potential noise in the
+ * path string.
+char* darshan_clean_file_path(const char* path);
+#endif /* __DARSHAN_COMMON_H */
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index 4f1cc83..7de647f 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -14,6 +14,19 @@
#include "uthash.h"
+/* TODO: drop CP_ and use DARSHAN_ */
+/* Environment variable to override CP_JOBID */
+#define CP_JOBID_OVERRIDE "DARSHAN_JOBID"
+/* Environment variable to override __CP_LOG_PATH */
+#define CP_LOG_PATH_OVERRIDE "DARSHAN_LOGPATH"
+#define CP_LOG_HINTS_OVERRIDE "DARSHAN_LOGHINTS"
+/* Environment variable to override __CP_MEM_ALIGNMENT */
+#define CP_MEM_ALIGNMENT_OVERRIDE "DARSHAN_MEMALIGN"
#define DARSHAN_CORE_MAX_RECORDS 1024
/* TODO: revisit this default size if we change memory per module */
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index 13bad59..4a15340 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -13,18 +13,7 @@
#include <mpi.h>
-/* Environment variable to override CP_JOBID */
-#define CP_JOBID_OVERRIDE "DARSHAN_JOBID"
-/* Environment variable to override __CP_LOG_PATH */
-#define CP_LOG_PATH_OVERRIDE "DARSHAN_LOGPATH"
-#define CP_LOG_HINTS_OVERRIDE "DARSHAN_LOGHINTS"
-/* Environment variable to override __CP_MEM_ALIGNMENT */
-#define CP_MEM_ALIGNMENT_OVERRIDE "DARSHAN_MEMALIGN"
+#include "darshan-common.h"
/* macros for declaring wrapper functions and calling MPI routines
* consistently regardless of whether static or dynamic linking is used
@@ -64,77 +53,6 @@
#endif
-/* macros for manipulating a module's counter variables */
-/* NOTE: These macros assume a module's record stores integer
- * and floating point counters in arrays, named counters and
- * fcounters, respectively. __rec_p is the a pointer to the
- * data record, __counter is the counter in question, and
- * __value is the corresponding data value.
-#define DARSHAN_COUNTER_SET(__rec_p, __counter, __value) do{ \
- (__rec_p)->counters[__counter] = __value; \
-} while(0)
-#define DARSHAN_COUNTER_F_SET(__rec_p, __counter, __value) do{ \
- (__rec_p)->fcounters[__counter] = __value; \
-} while(0)
-#define DARSHAN_COUNTER_INC(__rec_p, __counter, __value) do{ \
- (__rec_p)->counters[__counter] += __value; \
-} while(0)
-#define DARSHAN_COUNTER_F_INC(__rec_p, __counter, __value) do{ \
- (__rec_p)->fcounters[__counter] += __value; \
-} while(0)
-#define DARSHAN_COUNTER_F_INC_NO_OVERLAP(__rec_p, __tm1, __tm2, __last, __counter) do{ \
- if(__tm1 > __last) \
- DARSHAN_COUNTER_F_INC(__rec_p, __counter, (__tm2 - __tm1)); \
- else \
- DARSHAN_COUNTER_F_INC(__rec_p, __counter, (__tm2 - __last)); \
- if(__tm2 > __last) \
- __last = __tm2; \
-} while(0)
-#define DARSHAN_COUNTER_VALUE(__rec_p, __counter) \
- ((__rec_p)->counters[__counter])
-#define DARSHAN_COUNTER_F_VALUE(__rec_p, __counter) \
- ((__rec_p)->fcounters[__counter])
-#define DARSHAN_COUNTER_MAX(__rec_p, __counter, __value) do{ \
- if((__rec_p)->counters[__counter] < __value) \
-} while(0)
-/* NOTE: This macro is for storing histogram counters with 10
- * distinct buckets. For an example of how it is used, consult
- * the POSIX module implementation, which stores histograms of
- * access sizes for POSIX I/O functions.
-#define DARSHAN_BUCKET_INC(__rec_p, __counter_base, __value) do {\
- if(__value < 101) \
- (__rec_p)->counters[__counter_base] += 1; \
- else if(__value < 1025) \
- (__rec_p)->counters[__counter_base+1] += 1; \
- else if(__value < 10241) \
- (__rec_p)->counters[__counter_base+2] += 1; \
- else if(__value < 102401) \
- (__rec_p)->counters[__counter_base+3] += 1; \
- else if(__value < 1048577) \
- (__rec_p)->counters[__counter_base+4] += 1; \
- else if(__value < 4194305) \
- (__rec_p)->counters[__counter_base+5] += 1; \
- else if(__value < 10485761) \
- (__rec_p)->counters[__counter_base+6] += 1; \
- else if(__value < 104857601) \
- (__rec_p)->counters[__counter_base+7] += 1; \
- else if(__value < 1073741825) \
- (__rec_p)->counters[__counter_base+8] += 1; \
- else \
- (__rec_p)->counters[__counter_base+9] += 1; \
-} while(0)
/* module developers provide the following functions to darshan-core */
struct darshan_module_funcs
@@ -172,12 +90,6 @@ struct darshan_module_funcs
-enum darshan_io_type
- DARSHAN_IO_READ = 1,
- DARSHAN_IO_WRITE = 2,
/* paths that darshan will not trace */
extern char* darshan_path_exclusions[]; /* defined in lib/darshan-core.c */
@@ -185,15 +97,44 @@ extern char* darshan_path_exclusions[]; /* defined in lib/darshan-core.c */
* darshan-core functions exported to darshan modules *
+/* darshan_core_register_module()
+ * Register module identifier 'mod_id' with the darshan-core runtime
+ * environment, allowing the module to store I/O characterization data.
+ * 'funcs' is a pointer to a structure containing each of the function
+ * pointers required by darshan-core to shut down the module. The function
+ * returns the following integers passed in as pointers: 'my_rank' is the
+ * MPI rank of the calling process, 'mod_mem_limit' is the maximum amount
+ * of memory the module may use, and 'sys_mem_alignment' is the configured
+ * memory alignment value Darshan was configured with.
void darshan_core_register_module(
darshan_module_id mod_id,
struct darshan_module_funcs *funcs,
+ int *my_rank,
int *mod_mem_limit,
int *sys_mem_alignment);
+/* darshan_core_unregister_module()
+ * Unregisters module identifier 'mod_id' with the darshan-core runtime,
+ * removing the given module from the resulting I/O characterization log.
void darshan_core_unregister_module(
darshan_module_id mod_id);
+/* darshan_core_register_record()
+ * Register the Darshan record given by 'name' with the darshan-core
+ * runtime, allowing it to be properly tracked and (potentially)
+ * correlated with records from other modules. 'len' is the size of
+ * the name pointer (string length for string names), 'printable_flag'
+ * indicates whether the name is a string, and 'mod_id' is the identifier
+ * of the calling module. 'rec_id' is an output pointer storing the
+ * correspoing Darshan record identifier and 'file_alignment' is an
+ * output pointer storing the file system alignment value for the given
+ * record.
void darshan_core_register_record(
void *name,
int len,
@@ -202,16 +143,22 @@ void darshan_core_register_record(
darshan_record_id *rec_id,
int *file_alignment);
+/* darshan_core_unregister_record()
+ * Unregister record identifier 'rec_id' in the darshan-core runtime.
+ * This unregister is only in the context of module identifier 'mod_id',
+ * meaning that if the file record has other module's associated with
+ * it, then the record won't be completely removed.
void darshan_core_unregister_record(
darshan_record_id rec_id,
+/* darshan_core_wtime()
+ * Returns the elapsed time relative to (roughly) the start of
+ * the application.
double darshan_core_wtime(void);
-* darshan-common functions for darshan modules *
-char* darshan_clean_file_path(const char* path);
#endif /* __DARSHAN_H */
diff --git a/darshan-runtime/lib/darshan-common.c b/darshan-runtime/lib/darshan-common.c
index e9ce0d0..8b4cb7e 100644
--- a/darshan-runtime/lib/darshan-common.c
+++ b/darshan-runtime/lib/darshan-common.c
@@ -13,10 +13,6 @@
#include "darshan.h"
-/* Allocate a new string that contains a cleaned-up version of the path
- * passed in as an argument. Converts relative paths to absolute paths and
- * filters out some potential noise in the path string.
char* newpath = NULL;
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index aee8c6f..42e81f6 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -1513,6 +1513,7 @@ static void darshan_core_cleanup(struct darshan_core_runtime* core)
+ int *my_rank,
int *mod_mem_limit,
@@ -1549,6 +1550,9 @@ void darshan_core_register_module(
/* register module with darshan */
darshan_core->mod_array[mod_id] = mod;
+ /* get the calling process's rank */
+ DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, my_rank);
/* TODO: something smarter than just 2 MiB per module */
*mod_mem_limit = 2 * 1024 * 1024;
diff --git a/darshan-runtime/lib/darshan-mpiio.c b/darshan-runtime/lib/darshan-mpiio.c
index 8fd7f13..37ffc08 100644
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -129,8 +129,6 @@ static void mpiio_record_reduction_op(void* infile_v, void* inoutfile_v,
static void mpiio_get_output_data(void **buffer, int *size);
static void mpiio_shutdown(void);
-/* TODO: maybe use a counter to track cases in which a derived datatype is used? */
#define MPIIO_LOCK() pthread_mutex_lock(&mpiio_runtime_mutex)
#define MPIIO_UNLOCK() pthread_mutex_unlock(&mpiio_runtime_mutex)
@@ -224,6 +222,7 @@ int MPI_File_open(MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_F
if(file)
file->file_record->rank = my_rank;
+ DARSHAN_COUNTER_SET(file->file_record, MPIIO_MODE, amode);
DARSHAN_MPI_CALL(PMPI_Comm_size)(comm, &comm_size);
if(comm_size == 1)
@@ -839,6 +838,7 @@ static void mpiio_runtime_initialize()
DARSHAN_MPIIO_MOD,
&mpiio_mod_fns,
+ &my_rank,
&mem_limit,
NULL);
@@ -871,9 +871,6 @@ static void mpiio_runtime_initialize()
memset(mpiio_runtime->file_record_array, 0, mpiio_runtime->file_array_size *
sizeof(struct darshan_mpiio_file));
- /* TODO: can we move this out of here? perhaps register_module returns rank? */
- DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank);
return;
diff --git a/darshan-runtime/lib/darshan-null.c b/darshan-runtime/lib/darshan-null.c
index 0a864e2..7618e8f 100644
--- a/darshan-runtime/lib/darshan-null.c
+++ b/darshan-runtime/lib/darshan-null.c
@@ -28,18 +28,12 @@
* that may be reused and expanded on by developers adding new instrumentation modules.
-/* TODO: this probably shouldn't be here -- LD_PRELOADing POSIX wrappers will cause MPI linker dependency */
-#ifdef DARSHAN_PRELOAD
-extern double (*__real_PMPI_Comm_rank)(MPI_Comm comm, int *rank);
-#endif
/* The DARSHAN_FORWARD_DECL macro (defined in darshan.h) is used to provide forward
* declarations for wrapped funcions, regardless if Darshan is used with statically
* or dynamically linked executables.
DARSHAN_FORWARD_DECL(foo, int, (const char *name, int arg1, int arg2));
/* The null_record_runtime structure maintains necessary runtime metadata
* for a "NULL" module data record (darshan_null_record structure, defined
* in darshan-null-log-format.h). This metadata assists with the instrumenting
@@ -224,6 +218,7 @@ static void null_runtime_initialize()
DARSHAN_NULL_MOD, /* Darshan module identifier, defined in darshan-log-format.h */
&null_mod_fns,
+ &my_rank,
&mem_limit,
NULL);
@@ -262,9 +257,6 @@ static void null_runtime_initialize()
memset(null_runtime->record_array, 0, null_runtime->rec_array_size *
sizeof(struct darshan_null_record));
- /* TODO: we should move this out of here.. perhaps register_module returns rank? */
return;
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 3646a30..2ef29b9 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -39,11 +39,6 @@ typedef int64_t off64_t;
#define aiocb64 aiocb
#endif
-/* TODO: this probably shouldn't be here long term -- MPI symbols mess up LD_PRELOAD */
-#endif
/* TODO: more libc, fgetc, etc etc etc. */
DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...));
@@ -1517,6 +1512,7 @@ static void posix_runtime_initialize()
DARSHAN_POSIX_MOD,
&posix_mod_fns,
+ &my_rank,
&mem_limit,
&darshan_mem_alignment);
@@ -1550,9 +1546,6 @@ static void posix_runtime_initialize()
memset(posix_runtime->file_record_array, 0, posix_runtime->file_array_size *
sizeof(struct darshan_posix_file));
return;
hooks/post-receive
More information about the Darshan-commits
