[Darshan-commits] [Darshan] branch, dev-modular, updated. 018122117ee9f50abaa2b5fd73b7d3133c09373c
Service Account
git at mcs.anl.gov
Wed Feb 11 13:10:49 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 018122117ee9f50abaa2b5fd73b7d3133c09373c (commit)
from 5348600bd92eba9cf3d8935512b523a5232838f7 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 018122117ee9f50abaa2b5fd73b7d3133c09373c
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Wed Feb 11 13:10:25 2015 -0600
revamped error handling runtime side
Summary of changes:
darshan-log-format.h | 15 ++-
darshan-runtime/darshan-core.h | 1 -
darshan-runtime/darshan.h | 1 -
darshan-runtime/lib/darshan-core.c | 236 ++++++++++++++++++----------------
darshan-runtime/lib/darshan-posix.c | 3 -
5 files changed, 135 insertions(+), 121 deletions(-)
Diff of changes:
diff --git a/darshan-log-format.h b/darshan-log-format.h
index f1d2c49..6f7d63d 100644
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -30,25 +30,30 @@
/* max length of exe string within job record (not counting '\0') */
#define CP_EXE_LEN (CP_JOB_RECORD_SIZE - sizeof(struct darshan_job) - 1)
-/* max length of module name string (not counting '\0') */
-/* TODO */
-#define DARSHAN_MOD_NAME_LEN 31
typedef uint64_t darshan_record_id;
/* unique identifiers to distinguish between available darshan modules */
/* NOTES: - valid ids range from [0...DARSHAN_MAX_MODS-1]
* - order of ids control module shutdown order (and consequently, order in log file)
+/* TODO: enforce maximum? */
#define DARSHAN_MAX_MODS 16
typedef enum
- DARSHAN_POSIX_MOD,
+ DARSHAN_POSIX_MOD = 0,
DARSHAN_MPIIO_MOD,
DARSHAN_HDF5_MOD,
DARSHAN_PNETCDF_MOD,
} darshan_module_id;
+static char *darshan_module_names[] =
+ "POSIX",
+ "MPI-IO",
+ "HDF5",
+ "PNETCDF"
enum darshan_comp_type
DARSHAN_GZ_COMP,
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index 835bb42..91f68b5 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -18,7 +18,6 @@
struct darshan_core_module
darshan_module_id id;
- char name[DARSHAN_MOD_NAME_LEN+1];
struct darshan_module_funcs mod_funcs;
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index 87c6837..7b57874 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -44,7 +44,6 @@ struct darshan_module_funcs
void darshan_core_register_module(
darshan_module_id id,
- char *name,
struct darshan_module_funcs *funcs,
int *runtime_mem_limit);
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index f33fded..ef03e4b 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -45,9 +45,11 @@ static void darshan_get_logfile_name(
char* logfile_name, int jobid, struct tm* start_tm);
static void darshan_log_record_hints_and_ver(
struct darshan_core_runtime* job);
-static int darshan_get_shared_record_ids(
+static void darshan_get_shared_record_ids(
struct darshan_core_runtime *job, darshan_record_id *shared_recs);
-static int darshan_log_write_record_map(
+static int darshan_log_coll_open(
+ char *logfile_name, MPI_File *log_fh);
+static int darshan_log_write_record_hash(
MPI_File log_fh, struct darshan_core_record_ref *rec_hash,
darshan_record_id *shared_recs, struct darshan_log_map *map);
static int darshan_log_coll_write(
@@ -197,13 +199,11 @@ static void darshan_core_shutdown()
int local_mod_use[DARSHAN_MAX_MODS] = {0};
int global_mod_use_count[DARSHAN_MAX_MODS] = {0};
darshan_record_id shared_recs[DARSHAN_CORE_MAX_RECORDS] = {0};
- char *hints;
double start_log_time;
long offset;
struct darshan_header log_header;
MPI_File log_fh;
MPI_Offset tmp_off;
- MPI_Info info;
MPI_Status status;
if(getenv("DARSHAN_INTERNAL_TIMING"))
@@ -297,10 +297,6 @@ static void darshan_core_shutdown()
final_job->log_job.end_time = last_end_time;
- /* XXX */
- /* TODO: ensuing error checking...does MPI ensure collective I/O functions return the same error
- * globally, or do I always need to allreduce????? */
/* set which local modules were actually used */
for(i = 0; i < DARSHAN_MAX_MODS; i++)
@@ -312,72 +308,10 @@ static void darshan_core_shutdown()
DARSHAN_MPI_CALL(PMPI_Allreduce)(local_mod_use, global_mod_use_count, DARSHAN_MAX_MODS, MPI_INT, MPI_SUM, MPI_COMM_WORLD);
/* get a list of records which are shared across all processes */
- ret = darshan_get_shared_record_ids(final_job, shared_recs);
- /* error out if unable to determine shared file records */
- DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
- MPI_LOR, MPI_COMM_WORLD);
- if(all_ret != 0)
- if(my_rank == 0)
- fprintf(stderr, "darshan library warning: unable to determine shared file records\n");
- free(logfile_name);
- darshan_core_cleanup(final_job);
- return;
- /* check environment variable to see if the default MPI file hints have
- * been overridden
- MPI_Info_create(&info);
- hints = getenv(CP_LOG_HINTS_OVERRIDE);
- if(!hints)
- hints = __CP_LOG_HINTS;
- if(hints && strlen(hints) > 0)
- char *tok_str;
- char *orig_tok_str;
- char *key;
- char *value;
- char *saveptr = NULL;
- tok_str = strdup(hints);
- if(tok_str)
- orig_tok_str = tok_str;
- do
- /* split string on semicolon */
- key = strtok_r(tok_str, ";", &saveptr);
- if(key)
- tok_str = NULL;
- /* look for = sign splitting key/value pairs */
- value = index(key, '=');
- if(value)
- /* break key and value into separate null terminated strings */
- value[0] = '\0';
- value++;
- if(strlen(key) > 0)
- MPI_Info_set(info, key, value);
- }while(key != NULL);
- free(orig_tok_str);
+ darshan_get_shared_record_ids(final_job, shared_recs);
- /* open the darshan log file for writing */
- ret = DARSHAN_MPI_CALL(PMPI_File_open)(MPI_COMM_WORLD, logfile_name,
- MPI_MODE_CREATE | MPI_MODE_WRONLY | MPI_MODE_EXCL, info, &log_fh);
- MPI_Info_free(&info);
+ /* collectively open the darshan log file */
+ ret = darshan_log_coll_open(logfile_name, &log_fh);
/* error out if unable to open log file */
@@ -386,12 +320,8 @@ static void darshan_core_shutdown()
if(my_rank == 0)
- int msg_len;
- char msg[MPI_MAX_ERROR_STRING] = {0};
- MPI_Error_string(ret, msg, &msg_len);
- fprintf(stderr, "darshan library warning: unable to open log file %s: %s\n",
- logfile_name, msg);
+ fprintf(stderr, "darshan library warning: unable to open log file %s\n",
+ logfile_name);
unlink(logfile_name);
free(logfile_name);
@@ -403,26 +333,33 @@ static void darshan_core_shutdown()
if(my_rank == 0)
/* write the job information, making sure to prealloc space for the log header */
- ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, sizeof(struct darshan_header),
+ all_ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, sizeof(struct darshan_header),
&final_job->log_job, sizeof(struct darshan_job), MPI_BYTE, &status);
- if(ret != MPI_SUCCESS)
+ if(all_ret != MPI_SUCCESS)
- int msg_len;
- fprintf(stderr, "darshan library warning: unable to write job data to log file %s: %s\n",
+ fprintf(stderr, "darshan library warning: unable to write job data to log file %s\n",
+ logfile_name);
+ unlink(logfile_name);
- /* TODO */
+ /* TODO: after compression is added, this should be fixed */
log_header.rec_map.off = sizeof(struct darshan_header) + sizeof(struct darshan_job);
- /* write the record name->id map to the log file */
- ret = darshan_log_write_record_map(log_fh, final_job->rec_hash,
+ /* error out if unable to write job information */
+ DARSHAN_MPI_CALL(PMPI_Bcast)(&all_ret, 1, MPI_INT, 0, MPI_COMM_WORLD);
+ if(all_ret != 0)
+ free(logfile_name);
+ darshan_core_cleanup(final_job);
+ return;
+ /* write the record name->id hash to the log file */
+ ret = darshan_log_write_record_hash(log_fh, final_job->rec_hash,
shared_recs, &log_header.rec_map);
+ /* error out if unable to write record hash */
if(all_ret != 0)
@@ -431,6 +368,7 @@ static void darshan_core_shutdown()
fprintf(stderr, "darshan library warning: unable to write record map to log file %s\n",
logfile_name);
free(logfile_name);
@@ -441,7 +379,8 @@ static void darshan_core_shutdown()
* - get final output buffer
* - compress (zlib) provided output buffer
* - append compressed buffer to log file
- * - shutdown the module TODO
+ * - add module index info (file offset/length) to log header
+ * - shutdown the module
@@ -483,9 +422,22 @@ static void darshan_core_shutdown()
/* write module data buffer to the darshan log file */
ret = darshan_log_coll_write(log_fh, mod_buf, mod_buf_size, &log_header.mod_map[i]);
- if(ret < 0)
+ /* error out if unable to write this module's data */
+ DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
+ MPI_LOR, MPI_COMM_WORLD);
+ if(all_ret != 0)
- /* TODO: */
+ if(my_rank == 0)
+ fprintf(stderr,
+ "darshan library warning: unable to write %s module data to log file %s\n",
+ darshan_module_names[i], logfile_name);
+ return;
tmp_off += log_header.mod_map[i].len;
@@ -508,20 +460,32 @@ static void darshan_core_shutdown()
log_header.magic_nr = CP_MAGIC_NR;
log_header.comp_type = DARSHAN_GZ_COMP;
- ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, 0, &log_header,
+ all_ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, 0, &log_header,
sizeof(struct darshan_header), MPI_BYTE, &status);
- /* TODO */
+ fprintf(stderr, "darshan library warning: unable to write header to log file %s\n",
+ logfile_name);
+ /* error out if unable to write log header */
+ if(all_ret != 0)
+ return;
DARSHAN_MPI_CALL(PMPI_File_close)(&log_fh);
/* if we got this far, there are no errors, so rename from *.darshan_partial
* to *-<logwritetime>.darshan.gz, which indicates that this log file is
* complete and ready for analysis
+ /* TODO: support user given logfile path/name */
if(my_rank == 0)
char* tmp_index;
@@ -758,12 +722,11 @@ static void darshan_log_record_hints_and_ver(struct darshan_core_runtime* job)
return;
-static int darshan_get_shared_record_ids(struct darshan_core_runtime *job,
+static void darshan_get_shared_record_ids(struct darshan_core_runtime *job,
int i;
int ndx;
- int ret;
struct darshan_core_record_ref *ref, *tmp;
darshan_record_id id_array[DARSHAN_CORE_MAX_RECORDS] = {0};
darshan_record_id mask_array[DARSHAN_CORE_MAX_RECORDS] = {0};
@@ -780,13 +743,9 @@ static int darshan_get_shared_record_ids(struct darshan_core_runtime *job,
/* broadcast root's list of records to all other processes */
- ret = DARSHAN_MPI_CALL(PMPI_Bcast)(id_array,
+ DARSHAN_MPI_CALL(PMPI_Bcast)(id_array,
(DARSHAN_CORE_MAX_RECORDS * sizeof(darshan_record_id)),
MPI_BYTE, 0, MPI_COMM_WORLD);
- if(ret != 0)
- return(-1);
/* everyone looks to see if they opened the same records as root */
for(i=0; (i<DARSHAN_CORE_MAX_RECORDS && id_array[i] != 0); i++)
@@ -803,12 +762,8 @@ static int darshan_get_shared_record_ids(struct darshan_core_runtime *job,
/* now allreduce so everyone agrees which files are shared */
- ret = DARSHAN_MPI_CALL(PMPI_Allreduce)(mask_array, all_mask_array,
+ DARSHAN_MPI_CALL(PMPI_Allreduce)(mask_array, all_mask_array,
DARSHAN_CORE_MAX_RECORDS, MPI_INT, MPI_LAND, MPI_COMM_WORLD);
- if(ret != 0)
- return(-1);
ndx = 0;
@@ -819,13 +774,74 @@ static int darshan_get_shared_record_ids(struct darshan_core_runtime *job,
+ return;
+static int darshan_log_coll_open(char *logfile_name, MPI_File *log_fh)
+ char *hints;
+ char *tok_str;
+ char *orig_tok_str;
+ char *key;
+ char *value;
+ char *saveptr = NULL;
+ int ret;
+ MPI_Info info;
+ /* check environment variable to see if the default MPI file hints have
+ * been overridden
+ MPI_Info_create(&info);
+ hints = getenv(CP_LOG_HINTS_OVERRIDE);
+ if(!hints)
+ hints = __CP_LOG_HINTS;
+ if(hints && strlen(hints) > 0)
+ tok_str = strdup(hints);
+ if(tok_str)
+ orig_tok_str = tok_str;
+ do
+ /* split string on semicolon */
+ key = strtok_r(tok_str, ";", &saveptr);
+ if(key)
+ tok_str = NULL;
+ /* look for = sign splitting key/value pairs */
+ value = index(key, '=');
+ if(value)
+ /* break key and value into separate null terminated strings */
+ value[0] = '\0';
+ value++;
+ if(strlen(key) > 0)
+ MPI_Info_set(info, key, value);
+ }while(key != NULL);
+ free(orig_tok_str);
+ /* open the darshan log file for writing */
+ ret = DARSHAN_MPI_CALL(PMPI_File_open)(MPI_COMM_WORLD, logfile_name,
+ MPI_MODE_CREATE | MPI_MODE_WRONLY | MPI_MODE_EXCL, info, log_fh);
+ if(ret < 0)
+ return(-1);
+ MPI_Info_free(&info);
return(0);
/* NOTE: the map written to file may contain duplicate id->name entries if a
* record is opened by multiple ranks, but not all ranks
-static int darshan_log_write_record_map(MPI_File log_fh, struct darshan_core_record_ref *rec_hash,
+static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_record_ref *rec_hash,
int i;
@@ -983,7 +999,6 @@ static int darshan_log_coll_write(MPI_File log_fh, void *buf, int count,
- char *name,
@@ -1017,7 +1032,6 @@ void darshan_core_register_module(
memset(mod, 0, sizeof(*mod));
mod->id = id;
- strncpy(mod->name, name, DARSHAN_MOD_NAME_LEN);
mod->mod_funcs = *funcs;
/* register module with darshan */
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 269b8ab..1578b92 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -45,8 +45,6 @@ typedef int64_t off64_t;
#define MAP_OR_FAIL(func)
-#define POSIX_MOD_NAME "POSIX"
struct posix_runtime_file
struct darshan_posix_file* file_record;
@@ -245,7 +243,6 @@ static void posix_runtime_initialize()
/* register the posix module with darshan core */
DARSHAN_POSIX_MOD,
- POSIX_MOD_NAME,
&posix_mod_fns,
&mem_limit);
hooks/post-receive
More information about the Darshan-commits
