[Darshan-commits] [Darshan] branch, dev-modular, updated. 5348600bd92eba9cf3d8935512b523a5232838f7
Service Account
git at mcs.anl.gov
Tue Feb 10 17:30:34 CST 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 5348600bd92eba9cf3d8935512b523a5232838f7 (commit)
from 721e5e5ca6ca0e14a530cef57d9bca47dbc94bc4 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 5348600bd92eba9cf3d8935512b523a5232838f7
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Tue Feb 10 17:30:04 2015 -0600
update runtime/util side with new index map def
Summary of changes:
darshan-log-format.h | 42 ++++-
darshan-runtime/darshan.h | 18 +--
darshan-runtime/lib/darshan-core.c | 315 ++++++++++++++++++-----------------
darshan-util/darshan-logutils.c | 91 +++++------
darshan-util/darshan-logutils.h | 2 +-
darshan-util/darshan-posix-parser.c | 8 +-
6 files changed, 241 insertions(+), 235 deletions(-)
Diff of changes:
diff --git a/darshan-log-format.h b/darshan-log-format.h
index 3014c46..f1d2c49 100644
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -30,26 +30,44 @@
/* max length of exe string within job record (not counting '\0') */
#define CP_EXE_LEN (CP_JOB_RECORD_SIZE - sizeof(struct darshan_job) - 1)
+/* max length of module name string (not counting '\0') */
+/* TODO */
+#define DARSHAN_MOD_NAME_LEN 31
typedef uint64_t darshan_record_id;
+/* unique identifiers to distinguish between available darshan modules */
+/* NOTES: - valid ids range from [0...DARSHAN_MAX_MODS-1]
+ * - order of ids control module shutdown order (and consequently, order in log file)
+#define DARSHAN_MAX_MODS 16
+typedef enum
+ DARSHAN_POSIX_MOD,
+ DARSHAN_MPIIO_MOD,
+ DARSHAN_HDF5_MOD,
+ DARSHAN_PNETCDF_MOD,
+} darshan_module_id;
enum darshan_comp_type
DARSHAN_GZ_COMP,
- DARSHAN_BZ2_COMP,
+ DARSHAN_BZ2_COMP, /* TODO: no bz2 support util side, yet */
-struct darshan_header
+struct darshan_log_map
- char version_string[8];
- int64_t magic_nr;
- uint8_t comp_type; /* TODO */
- uint8_t mod_count; /* TODO: */
+ uint64_t off;
+ uint64_t len;
-struct darshan_record
+struct darshan_header
- char* name;
- darshan_record_id id;
+ char version_string[8];
+ int64_t magic_nr;
+ unsigned char comp_type;
+ struct darshan_log_map rec_map;
+ struct darshan_log_map mod_map[DARSHAN_MAX_MODS];
/* statistics for the job as a whole */
@@ -64,4 +82,10 @@ struct darshan_job
char metadata[DARSHAN_JOB_METADATA_LEN]; /* TODO: what is this? */
+struct darshan_record
+ char* name;
+ darshan_record_id id;
#endif /* __DARSHAN_LOG_FORMAT_H */
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index 131d8de..87c6837 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -25,25 +25,9 @@
/* Environment variable to override __CP_MEM_ALIGNMENT */
#define CP_MEM_ALIGNMENT_OVERRIDE "DARSHAN_MEMALIGN"
-/* TODO where do each of the following macros make most sense ? */
+/* TODO where does this go? */
#define DARSHAN_MPI_CALL(func) func
-/* max length of module name string (not counting \0) */
-#define DARSHAN_MOD_NAME_LEN 31
-/* unique identifiers to distinguish between available darshan modules */
-/* NOTES: - valid ids range from [0...DARSHAN_MAX_MODS-1]
- * - order of ids control module shutdown order (first module shuts down first)
-#define DARSHAN_MAX_MODS 16
-typedef enum
- DARSHAN_POSIX_MOD,
- DARSHAN_MPIIO_MOD,
- DARSHAN_HDF5_MOD,
- DARSHAN_PNETCDF_MOD,
-} darshan_module_id;
struct darshan_module_funcs
void (*get_output_data)(
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 93d7823..f33fded 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -47,13 +47,11 @@ static void darshan_log_record_hints_and_ver(
struct darshan_core_runtime* job);
static int darshan_get_shared_record_ids(
struct darshan_core_runtime *job, darshan_record_id *shared_recs);
-static int darshan_log_write_header(
- MPI_File log_fh, int mod_count, int64_t rec_off, int64_t psx_off);
static int darshan_log_write_record_map(
- MPI_File log_fh, struct darshan_core_runtime *job,
- darshan_record_id *shared_recs, MPI_Offset *off);
-static int darshan_log_coll_append(MPI_File log_fh, MPI_Offset *off,
- void *buf, int count);
+ MPI_File log_fh, struct darshan_core_record_ref *rec_hash,
+ darshan_record_id *shared_recs, struct darshan_log_map *map);
+static int darshan_log_coll_write(
+ MPI_File log_fh, void *buf, int count, struct darshan_log_map *map);
#define DARSHAN_CORE_LOCK() pthread_mutex_lock(&darshan_core_mutex)
#define DARSHAN_CORE_UNLOCK() pthread_mutex_unlock(&darshan_core_mutex)
@@ -186,7 +184,6 @@ static void darshan_core_shutdown()
int i;
char *logfile_name;
struct darshan_core_runtime *final_job;
- struct darshan_core_module *mod, *tmp;
int internal_timing_flag = 0;
char *envjobid;
char *jobid_str;
@@ -200,19 +197,12 @@ static void darshan_core_shutdown()
int local_mod_use[DARSHAN_MAX_MODS] = {0};
int global_mod_use_count[DARSHAN_MAX_MODS] = {0};
darshan_record_id shared_recs[DARSHAN_CORE_MAX_RECORDS] = {0};
- char *key;
- char *value;
char *hints;
- char *tok_str;
- char *orig_tok_str;
- char *saveptr = NULL;
- char *mod_index;
- char *new_logfile_name;
double start_log_time;
- double end_log_time;
long offset;
+ struct darshan_header log_header;
MPI_File log_fh;
- MPI_Offset my_off = 0;
+ MPI_Offset tmp_off;
MPI_Info info;
MPI_Status status;
@@ -251,6 +241,7 @@ static void darshan_core_shutdown()
envjobid = CP_JOBID;
+ /* find a job id */
jobid_str = getenv(envjobid);
if(jobid_str)
@@ -265,10 +256,13 @@ static void darshan_core_shutdown()
final_job->log_job.jobid = (int64_t)jobid;
+/* TODO */
+#if 0
/* if we are using any hints to write the log file, then record those
- * hints in the log file header
+ * hints with the darshan job information
darshan_log_record_hints_and_ver(final_job);
+#endif
/* use human readable start time format in log filename */
start_time_tmp = final_job->log_job.start_time;
@@ -303,6 +297,10 @@ static void darshan_core_shutdown()
final_job->log_job.end_time = last_end_time;
+ /* XXX */
+ /* TODO: ensuing error checking...does MPI ensure collective I/O functions return the same error
+ * globally, or do I always need to allreduce????? */
/* set which local modules were actually used */
for(i = 0; i < DARSHAN_MAX_MODS; i++)
@@ -313,6 +311,23 @@ static void darshan_core_shutdown()
/* reduce the number of times a module was opened globally and bcast to everyone */
DARSHAN_MPI_CALL(PMPI_Allreduce)(local_mod_use, global_mod_use_count, DARSHAN_MAX_MODS, MPI_INT, MPI_SUM, MPI_COMM_WORLD);
+ /* get a list of records which are shared across all processes */
+ ret = darshan_get_shared_record_ids(final_job, shared_recs);
+ /* error out if unable to determine shared file records */
+ DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
+ MPI_LOR, MPI_COMM_WORLD);
+ if(all_ret != 0)
+ if(my_rank == 0)
+ fprintf(stderr, "darshan library warning: unable to determine shared file records\n");
+ free(logfile_name);
+ darshan_core_cleanup(final_job);
+ return;
/* check environment variable to see if the default MPI file hints have
* been overridden
@@ -326,6 +341,12 @@ static void darshan_core_shutdown()
if(hints && strlen(hints) > 0)
+ char *tok_str;
+ char *orig_tok_str;
+ char *key;
+ char *value;
+ char *saveptr = NULL;
tok_str = strdup(hints);
if(tok_str)
@@ -353,27 +374,6 @@ static void darshan_core_shutdown()
- /* TODO: ensuing error checking...does MPI ensure collective I/O functions return the same error
- * globally, or do I always need to allreduce????? */
- /* get a list of records which are shared across all processes */
- ret = darshan_get_shared_record_ids(final_job, shared_recs);
- /* error out if unable to determine shared file records */
- DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
- MPI_LOR, MPI_COMM_WORLD);
- if(all_ret != 0)
- if(my_rank == 0)
- fprintf(stderr, "darshan library warning: unable to determine shared file records\n");
- free(logfile_name);
- darshan_core_cleanup(final_job);
- return;
/* open the darshan log file for writing */
ret = DARSHAN_MPI_CALL(PMPI_File_open)(MPI_COMM_WORLD, logfile_name,
MPI_MODE_CREATE | MPI_MODE_WRONLY | MPI_MODE_EXCL, info, &log_fh);
@@ -399,14 +399,12 @@ static void darshan_core_shutdown()
return;
+ /* rank 0 is responsible for writing the darshan job information */
if(my_rank == 0)
- my_off = sizeof(struct darshan_header);
- my_off += 2 * sizeof(int64_t); /* FIXME account for changes to index map */
- ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, my_off, &final_job->log_job,
- sizeof(struct darshan_job), MPI_BYTE, &status);
+ /* write the job information, making sure to prealloc space for the log header */
+ ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, sizeof(struct darshan_header),
+ &final_job->log_job, sizeof(struct darshan_job), MPI_BYTE, &status);
if(ret != MPI_SUCCESS)
int msg_len;
@@ -417,12 +415,13 @@ static void darshan_core_shutdown()
logfile_name, msg);
- my_off += sizeof(struct darshan_job);
+ /* TODO */
+ log_header.rec_map.off = sizeof(struct darshan_header) + sizeof(struct darshan_job);
- int64_t rec_off = my_off; /* TODO: get rid of this hack */
/* write the record name->id map to the log file */
- ret = darshan_log_write_record_map(log_fh, final_job, shared_recs, &my_off);
+ ret = darshan_log_write_record_map(log_fh, final_job->rec_hash,
+ shared_recs, &log_header.rec_map);
@@ -437,13 +436,12 @@ static void darshan_core_shutdown()
return;
- int64_t psx_off = my_off; /* TODO: get rid of this hack */
/* loop over globally used darshan modules and:
* - get final output buffer
* - compress (zlib) provided output buffer
* - append compressed buffer to log file
- * - shutdown the module
+ * - shutdown the module TODO
@@ -453,7 +451,12 @@ static void darshan_core_shutdown()
int mod_buf_size = 0;
if(!global_mod_use_count[i])
+ if(my_rank == 0)
+ log_header.mod_map[i].off = log_header.mod_map[i].len = 0;
continue;
/* create a communicator to use for shutting down the module */
if(global_mod_use_count[i] == nprocs)
@@ -472,13 +475,21 @@ static void darshan_core_shutdown()
this_mod->mod_funcs.get_output_data(mod_comm, &mod_buf, &mod_buf_size);
- /* append module data buffer to the darshan log file */
- ret = darshan_log_coll_append(log_fh, &my_off, mod_buf, mod_buf_size);
+ /* set the starting offset of this module */
+ if(tmp_off == 0)
+ tmp_off = log_header.rec_map.off + log_header.rec_map.len;
+ log_header.mod_map[i].off = tmp_off;
+ /* write module data buffer to the darshan log file */
+ ret = darshan_log_coll_write(log_fh, mod_buf, mod_buf_size, &log_header.mod_map[i]);
if(ret < 0)
/* TODO: */
+ tmp_off += log_header.mod_map[i].len;
/* shutdown module if registered locally */
if(local_mod_use[i])
@@ -489,10 +500,20 @@ static void darshan_core_shutdown()
MPI_Comm_free(&mod_comm);
- /* rank 0 is responsible for writing the log header and index map */
+ /* rank 0 is responsible for writing the log header */
if(my_rank == 0)
- ret = darshan_log_write_header(log_fh, 1, rec_off, psx_off);
+ /* initialize the remaining header fields */
+ strcpy(log_header.version_string, CP_VERSION);
+ log_header.magic_nr = CP_MAGIC_NR;
+ log_header.comp_type = DARSHAN_GZ_COMP;
+ ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, 0, &log_header,
+ sizeof(struct darshan_header), MPI_BYTE, &status);
+ if(ret != MPI_SUCCESS)
+ /* TODO */
DARSHAN_MPI_CALL(PMPI_File_close)(&log_fh);
@@ -501,26 +522,33 @@ static void darshan_core_shutdown()
* to *-<logwritetime>.darshan.gz, which indicates that this log file is
* complete and ready for analysis
- new_logfile_name = malloc(PATH_MAX);
- if(new_logfile_name)
+ if(my_rank == 0)
- new_logfile_name[0] = '\0';
- end_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
- strcat(new_logfile_name, logfile_name);
- mod_index = strstr(new_logfile_name, ".darshan_partial");
- sprintf(mod_index, "_%d.darshan.gz", (int)(end_log_time-start_log_time+1));
- rename(logfile_name, new_logfile_name);
- /* set permissions on log file */
+ char* tmp_index;
+ double end_log_time;
+ char* new_logfile_name;
+ new_logfile_name = malloc(PATH_MAX);
+ if(new_logfile_name)
+ new_logfile_name[0] = '\0';
+ end_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
+ strcat(new_logfile_name, logfile_name);
+ tmp_index = strstr(new_logfile_name, ".darshan_partial");
+ sprintf(tmp_index, "_%d.darshan.gz", (int)(end_log_time-start_log_time+1));
+ rename(logfile_name, new_logfile_name);
+ /* set permissions on log file */
#ifdef __CP_GROUP_READABLE_LOGS
- chmod(new_logfile_name, (S_IRUSR|S_IRGRP));
+ chmod(new_logfile_name, (S_IRUSR|S_IRGRP));
#else
- chmod(new_logfile_name, (S_IRUSR));
+ chmod(new_logfile_name, (S_IRUSR));
#endif
- free(new_logfile_name);
+ free(new_logfile_name);
free(logfile_name);
if(internal_timing_flag)
@@ -597,7 +625,6 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
strncpy(cuser, logname_string, (L_cuserid-1));
/* if cuserid() and environment both fail, then fall back to uid */
@@ -795,76 +822,32 @@ static int darshan_get_shared_record_ids(struct darshan_core_runtime *job,
return(0);
-static int darshan_log_write_header(MPI_File log_fh, int mod_count,
- int64_t rec_off, int64_t psx_off)
- struct darshan_header base_hdr;
- unsigned char *hdr_buf;
- unsigned char *tmp_p;
- int hdr_size;
- MPI_Status status;
- int i;
- int ret;
- /* set the fields of the darshan header */
- strcpy(base_hdr.version_string, CP_VERSION);
- base_hdr.magic_nr = CP_MAGIC_NR;
- base_hdr.comp_type = DARSHAN_GZ_COMP;
- base_hdr.mod_count = mod_count;
- hdr_size = sizeof(struct darshan_header) + (2 * sizeof(int64_t)); /* TODO: */
- hdr_buf = malloc(hdr_size);
- if(!hdr_buf)
- return(-1);
- /* pack the header in buffer for writing */
- tmp_p = hdr_buf;
- *((struct darshan_header *)tmp_p) = base_hdr;
- tmp_p += sizeof(struct darshan_header);
- /* TODO: we need to have a way of identifying different modules in index map */
- *((int64_t *)tmp_p) = rec_off;
- tmp_p += sizeof(int64_t);
- *((int64_t *)tmp_p) = psx_off;
- ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, 0, hdr_buf, hdr_size,
- MPI_BYTE, &status);
- if(ret < 0)
- return(-1);
- return(0);
/* NOTE: the map written to file may contain duplicate id->name entries if a
* record is opened by multiple ranks, but not all ranks
-static int darshan_log_write_record_map(MPI_File log_fh, struct darshan_core_runtime *job,
+static int darshan_log_write_record_map(MPI_File log_fh, struct darshan_core_record_ref *rec_hash,
int i;
int ret;
struct darshan_core_record_ref *ref, *tmp;
uint32_t name_len;
size_t record_sz;
- size_t map_buf_sz = 0;
- unsigned char *map_buf;
- unsigned char *map_buf_off;
+ size_t hash_buf_sz = 0;
+ unsigned char *hash_buf;
+ unsigned char *hash_buf_off;
MPI_Status status;
- /* non-root ranks (rank 0) remove shared records from their map --
+ /* non-root ranks (rank > 0) remove shared records from their map --
* these records will be written by rank 0
if(my_rank > 0)
for(i=0; (i<DARSHAN_CORE_MAX_RECORDS && shared_recs[i]); i++)
- HASH_FIND(hlink, job->rec_hash, &shared_recs[i], sizeof(darshan_record_id), ref);
+ HASH_FIND(hlink, rec_hash, &shared_recs[i], sizeof(darshan_record_id), ref);
assert(ref); /* this id had better be in the hash ... */
- HASH_DELETE(hlink, job->rec_hash, ref);
+ HASH_DELETE(hlink, rec_hash, ref);
if(ref->rec.name) free(ref->rec.name);
free(ref);
@@ -872,66 +855,66 @@ static int darshan_log_write_record_map(MPI_File log_fh, struct darshan_core_run
/* allocate a buffer to store at most 64 bytes for each of a max number of records */
/* NOTE: this buffer may be reallocated if estimate is too small */
- map_buf_sz = DARSHAN_CORE_MAX_RECORDS * 64;
- map_buf = malloc(map_buf_sz);
- if(!map_buf)
+ hash_buf_sz = DARSHAN_CORE_MAX_RECORDS * 64;
+ hash_buf = malloc(hash_buf_sz);
+ if(!hash_buf)
return(-1);
/* serialize the record map into a buffer for writing */
- map_buf_off = map_buf;
- HASH_ITER(hlink, job->rec_hash, ref, tmp)
+ hash_buf_off = hash_buf;
+ HASH_ITER(hlink, rec_hash, ref, tmp)
name_len = strlen(ref->rec.name);
record_sz = sizeof(darshan_record_id) + sizeof(int) + name_len;
/* make sure there is room in the buffer for this record */
- if((map_buf_off + record_sz) > (map_buf + map_buf_sz))
+ if((hash_buf_off + record_sz) > (hash_buf + hash_buf_sz))
unsigned char *tmp_buf;
size_t old_buf_sz;
/* if no room, reallocate the map buffer at twice the current size */
- old_buf_sz = map_buf_off - map_buf;
- map_buf_sz *= 2;
- tmp_buf = malloc(map_buf_sz);
+ old_buf_sz = hash_buf_off - hash_buf;
+ hash_buf_sz *= 2;
+ tmp_buf = malloc(hash_buf_sz);
if(!tmp_buf)
- free(map_buf);
+ free(hash_buf);
return(-1);
- memcpy(tmp_buf, map_buf, old_buf_sz);
- free(map_buf);
- map_buf = tmp_buf;
- map_buf_off = map_buf + old_buf_sz;
+ memcpy(tmp_buf, hash_buf, old_buf_sz);
+ free(hash_buf);
+ hash_buf = tmp_buf;
+ hash_buf_off = hash_buf + old_buf_sz;
/* now serialize the record into the map buffer.
* NOTE: darshan record map serialization method:
* ... darshan_record_id | (uint32_t) path_len | path ...
- *((darshan_record_id *)map_buf_off) = ref->rec.id;
- map_buf_off += sizeof(darshan_record_id);
- *((uint32_t *)map_buf_off) = name_len;
- map_buf_off += sizeof(uint32_t);
- memcpy(map_buf_off, ref->rec.name, name_len);
- map_buf_off += name_len;
+ *((darshan_record_id *)hash_buf_off) = ref->rec.id;
+ hash_buf_off += sizeof(darshan_record_id);
+ *((uint32_t *)hash_buf_off) = name_len;
+ hash_buf_off += sizeof(uint32_t);
+ memcpy(hash_buf_off, ref->rec.name, name_len);
+ hash_buf_off += name_len;
/* collectively write out the record map to the darshan log */
- if(map_buf_off > map_buf)
+ if(hash_buf_off > hash_buf)
/* we have records to contribute to the collective write of the record map */
- ret = darshan_log_coll_append(log_fh, off, map_buf, (map_buf_off-map_buf));
+ ret = darshan_log_coll_write(log_fh, hash_buf, (hash_buf_off-hash_buf), map);
else
/* we have no data to write, but participate in the collective anyway */
- ret = darshan_log_coll_append(log_fh, off, NULL, 0);
+ ret = darshan_log_coll_write(log_fh, NULL, 0, map);
- free(map_buf);
+ free(hash_buf);
if(ret < 0)
return(-1);
@@ -939,22 +922,26 @@ static int darshan_log_write_record_map(MPI_File log_fh, struct darshan_core_run
return(0);
-/* NOTE: This function assumes that rank 0 passes in the log file offset
- * to start appending at, so the caller must make sure rank 0
- * has this info. After returning from this function, it is
- * guaranteed all ranks will have the ending log file offset.
+/* NOTE: The in/out param 'map' is only valid on rank 0 and is used
+ * to provide the starting offset of this collective write and
+ * to store the aggregate size of this write upon completion.
+ * This implies ONLY rank 0 can specify the starting offset
+ * and that only rank 0 knows the ending log file offset upon
+ * return from this function (starting off + aggregate size).
+static int darshan_log_coll_write(MPI_File log_fh, void *buf, int count,
+ struct darshan_log_map *map)
MPI_Offset send_off, my_off;
MPI_Status status;
int ret;
- /* figure out where everyone is writing */
+ /* figure out where everyone is writing using scan */
send_off = count;
if(my_rank == 0)
- send_off += *off; /* rank 0 knows the beginning offset */
+ send_off += map->off; /* rank 0 knows the beginning offset */
DARSHAN_MPI_CALL(PMPI_Scan)(&send_off, &my_off, 1, MPI_OFFSET,
@@ -967,9 +954,27 @@ static int darshan_log_coll_append(MPI_File log_fh, MPI_Offset *off,
if(ret < 0)
return(-1);
- *off = my_off + count;
- /* broadcast the final offset so everyone knows */
- DARSHAN_MPI_CALL(PMPI_Bcast)(off, 1, MPI_OFFSET, (nprocs-1), MPI_COMM_WORLD);
+ /* send the ending offset from rank (n-1) to rank 0 */
+ if(nprocs > 1)
+ if(my_rank == (nprocs-1))
+ my_off += count;
+ DARSHAN_MPI_CALL(PMPI_Send)(&my_off, 1, MPI_OFFSET, 0, 0,
+ MPI_COMM_WORLD);
+ else if(my_rank == 0)
+ DARSHAN_MPI_CALL(PMPI_Recv)(&my_off, 1, MPI_OFFSET, (nprocs-1), 0,
+ MPI_COMM_WORLD, &status);
+ map->len = my_off - map->off;
+ else
+ map->len = my_off + count - map->off;
return(0);
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index 76fe85e..7633049 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -31,11 +31,9 @@ struct darshan_fd_s
int swap_flag;
char version[8];
char* name;
- int mod_count;
- int64_t job_off;
- int64_t rec_off;
- int64_t mod_off;
- int64_t end_off;
+ struct darshan_log_map job_map;
static int darshan_log_seek(darshan_fd fd, off_t offset);
@@ -97,8 +95,7 @@ darshan_fd darshan_log_open(const char *name, const char *mode)
int darshan_log_getheader(darshan_fd fd, struct darshan_header *header)
- struct stat sbuf;
- int64_t ndx_buf[2];
+ int i;
int ret;
ret = darshan_log_seek(fd, 0);
@@ -131,6 +128,15 @@ int darshan_log_getheader(darshan_fd fd, struct darshan_header *header)
if(header->magic_nr == CP_MAGIC_NR)
fd->swap_flag = 1;
+ /* swap the log map variables in the header */
+ DARSHAN_BSWAP64(&header->rec_map.off);
+ DARSHAN_BSWAP64(&header->rec_map.len);
+ for(i=0;i<DARSHAN_MAX_MODS;i++)
+ DARSHAN_BSWAP64(&header->mod_map[i].off);
+ DARSHAN_BSWAP64(&header->mod_map[i].len);
else
@@ -140,22 +146,11 @@ int darshan_log_getheader(darshan_fd fd, struct darshan_header *header)
- /* read index map from log file */
- ret = darshan_log_read(fd, ndx_buf, (2*sizeof(int64_t)));
- if(ret < (2 * sizeof(int64_t)))
- fprintf(stderr, "Error: invalid darshan log file (failed to read header indexes).\n");
- return(-1);
- /* fill index info into darshan file descriptor */
- fd->job_off = sizeof(struct darshan_header) + (2 * sizeof(int64_t)); /* TODO: */
- fd->rec_off = ndx_buf[0];
- fd->mod_off = ndx_buf[1];
- /* use stat to get log file size -- used to help index the log */
- fstat(fd->pf, &sbuf);
- fd->end_off = sbuf.st_size;
+ /* save the mapping of data within log file to this file descriptor */
+ fd->job_map.off = sizeof(struct darshan_header);
+ fd->job_map.len = header->rec_map.off - fd->job_map.off;
+ memcpy(&fd->rec_map, &header->rec_map, sizeof(struct darshan_log_map));
+ memcpy(&fd->mod_map, &header->mod_map, DARSHAN_MAX_MODS * sizeof(struct darshan_log_map));
return(0);
@@ -170,7 +165,7 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
int ret;
- ret = darshan_log_seek(fd, fd->job_off);
+ ret = darshan_log_seek(fd, fd->job_map.off);
if(ret < 0)
fprintf(stderr, "Error: unable to seek in darshan log file.\n");
@@ -178,8 +173,8 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
/* read the job data from the log file */
- ret = darshan_log_read(fd, job, sizeof(*job));
- if(ret < sizeof(*job))
+ ret = darshan_log_read(fd, job, fd->job_map.len);
+ if(ret < fd->job_map.len)
fprintf(stderr, "Error: invalid darshan log file (failed to read job data).\n");
return(-1);
@@ -198,16 +193,15 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
return(0);
-/* darshan_log_getjob()
+/* darshan_log_gethash()
- * read job level metadata from the darshan log file
+ * read the hash of records from the darshan log file
* returns 0 on success, -1 on failure
-int darshan_log_getmap(darshan_fd fd, struct darshan_record_ref **map)
+int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
- int map_size;
unsigned char *buf_ptr;
darshan_record_id *rec_id_ptr;
uint32_t *path_len_ptr;
@@ -215,33 +209,32 @@ int darshan_log_getmap(darshan_fd fd, struct darshan_record_ref **map)
struct darshan_record_ref *ref;
int ret;
- ret = darshan_log_seek(fd, fd->rec_off);
+ ret = darshan_log_seek(fd, fd->rec_map.off);
if(ret < 0)
return(ret);
- /* allocate a buffer to store the (serialized) darshan record map */
- map_size = fd->mod_off - fd->rec_off;
- map_buf = malloc(map_size);
- if(!map_buf)
+ /* allocate a buffer to store the (serialized) darshan record hash */
+ hash_buf = malloc(fd->rec_map.len);
+ if(!hash_buf)
return(-1);
/* read the record map from the log file */
- ret = darshan_log_read(fd, map_buf, map_size);
- if(ret < map_size)
+ ret = darshan_log_read(fd, hash_buf, fd->rec_map.len);
+ if(ret < fd->rec_map.len)
- fprintf(stderr, "Error: invalid darshan log file (failed to read record map).\n");
- free(map_buf);
+ fprintf(stderr, "Error: invalid darshan log file (failed to read record hash).\n");
+ free(hash_buf);
return(-1);
- buf_ptr = map_buf;
- while(buf_ptr < (map_buf + map_size))
+ buf_ptr = hash_buf;
+ while(buf_ptr < (hash_buf + fd->rec_map.len))
/* get pointers for each field of this darshan record */
- /* NOTE: darshan record map serialization method:
+ /* NOTE: darshan record hash serialization method:
rec_id_ptr = (darshan_record_id *)buf_ptr;
@@ -254,13 +247,13 @@ int darshan_log_getmap(darshan_fd fd, struct darshan_record_ref **map)
ref = malloc(sizeof(*ref));
if(!ref)
- free(map_buf);
+ free(hash_buf);
return(-1);
ref->rec.name = malloc(*path_len_ptr + 1);
if(!ref->rec.name)
- free(map_buf);
+ free(hash_buf);
free(ref);
return(-1);
@@ -278,10 +271,10 @@ int darshan_log_getmap(darshan_fd fd, struct darshan_record_ref **map)
ref->rec.name[*path_len_ptr] = '\0';
/* add this record to the hash */
- HASH_ADD(hlink, *map, rec.id, sizeof(darshan_record_id), ref);
+ HASH_ADD(hlink, *hash, rec.id, sizeof(darshan_record_id), ref);
- free(map_buf);
+ free(hash_buf);
return(0);
@@ -295,9 +288,9 @@ int darshan_log_getfile(darshan_fd fd, struct darshan_posix_file *file)
const char* err_string;
int i;
- if(fd->pos < fd->mod_off)
+ if(fd->pos < fd->mod_map[0].off)
- ret = darshan_log_seek(fd, fd->mod_off);
+ ret = darshan_log_seek(fd, fd->mod_map[0].off);
if(ret < 0)
diff --git a/darshan-util/darshan-logutils.h b/darshan-util/darshan-logutils.h
index 07c92a5..ec5842b 100644
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -21,7 +21,7 @@ struct darshan_record_ref
darshan_fd darshan_log_open(const char *name, const char* mode);
int darshan_log_getheader(darshan_fd file, struct darshan_header *header);
int darshan_log_getjob(darshan_fd file, struct darshan_job *job);
-int darshan_log_getmap(darshan_fd file, struct darshan_record_ref **map);
+int darshan_log_gethash(darshan_fd file, struct darshan_record_ref **hash);
#if 0
struct darshan_job* job,
diff --git a/darshan-util/darshan-posix-parser.c b/darshan-util/darshan-posix-parser.c
index a5def34..9f07d4f 100644
--- a/darshan-util/darshan-posix-parser.c
+++ b/darshan-util/darshan-posix-parser.c
@@ -26,7 +26,7 @@ int main(int argc, char **argv)
darshan_fd file;
struct darshan_header header;
struct darshan_job job;
- struct darshan_record_ref *rec_map = NULL;
+ struct darshan_record_ref *rec_hash = NULL;
struct darshan_record_ref *ref, *tmp;
struct darshan_posix_file next_rec;
time_t tmp_time = 0;
@@ -79,8 +79,8 @@ int main(int argc, char **argv)
printf("# nprocs: %" PRId64 "\n", job.nprocs);
printf("# run time: %" PRId64 "\n", job.end_time - job.start_time + 1);
- /* read record map */
- ret = darshan_log_getmap(file, &rec_map);
+ /* read hash of darshan records */
+ ret = darshan_log_gethash(file, &rec_hash);
if(ret < 0)
fprintf(stderr, "darshan_log_getmap() failed to read record map.\n");
@@ -111,7 +111,7 @@ int main(int argc, char **argv)
/* get the pathname for this record */
- HASH_FIND(hlink, rec_map, &next_rec.f_id, sizeof(darshan_record_id), ref);
+ HASH_FIND(hlink, rec_hash, &next_rec.f_id, sizeof(darshan_record_id), ref);
assert(ref);
printf("\tRecord %d: id=%"PRIu64" (path=%s, rank=%"PRId64")\n",
hooks/post-receive
More information about the Darshan-commits
