[Darshan-commits] [Git][darshan/darshan][dev-modular] update modules to print counter descriptions
Shane Snyder xgitlab at cels.anl.gov
Fri Dec 11 16:20:33 CST 2015
Shane Snyder pushed to branch dev-modular at darshan / darshan
Commits:
9b021c1b by Shane Snyder at 2015-12-11T16:20:12Z
9 changed files:
- darshan-bgq-log-format.h
- darshan-util/darshan-bgq-logutils.c
- darshan-util/darshan-hdf5-logutils.c
- darshan-util/darshan-logutils.h
- darshan-util/darshan-mpiio-logutils.c
- darshan-util/darshan-null-logutils.c
- darshan-util/darshan-parser.c
- darshan-util/darshan-pnetcdf-logutils.c
- darshan-util/darshan-posix-logutils.c
Changes:
--- a/darshan-bgq-log-format.h
+++ b/darshan-bgq-log-format.h
@@ -11,24 +11,38 @@
 #define DARSHAN_BGQ_VER 1
 #define BGQ_COUNTERS \
-    X(BGQ_CSJOBID, "control system jobid") \
-    X(BGQ_NNODES, "number of BGQ compute nodes") \
-    X(BGQ_RANKSPERNODE, "number of MPI ranks per node") \
-    X(BGQ_DDRPERNODE, "size in MB of DDR3 per node") \
-    X(BGQ_INODES, "number of i/o nodes") \
-    X(BGQ_ANODES, "dimension of A torus") \
-    X(BGQ_BNODES, "dimension of B torus") \
-    X(BGQ_CNODES, "dimension of C torus") \
-    X(BGQ_DNODES, "dimension of D torus") \
-    X(BGQ_ENODES, "dimension of E torus") \
-    X(BGQ_TORUSENABLED, "which dimensions are torus") \
-    X(BGQ_NUM_INDICES, "end of counters")
+    /* control system jobid*/\
+    X(BGQ_CSJOBID) \
+    /* number of BGQ compute nodes */\
+    X(BGQ_NNODES) \
+    /* number of MPI ranks per node */\
+    X(BGQ_RANKSPERNODE) \
+    /* size in MB of DDR3 per node */\
+    X(BGQ_DDRPERNODE) \
+    /* number of i/o nodes */\
+    X(BGQ_INODES) \
+    /* dimension of A torus */\
+    X(BGQ_ANODES) \
+    /* dimension of B torus */\
+    X(BGQ_BNODES) \
+    /* dimension of C torus */\
+    X(BGQ_CNODES) \
+    /* dimension of D torus */\
+    X(BGQ_DNODES) \
+    /* dimension of E torus */\
+    X(BGQ_ENODES) \
+    /* which dimensions are torus */\
+    X(BGQ_TORUSENABLED) \
+    /* end of counters */\
+    X(BGQ_NUM_INDICES)
 #define BGQ_F_COUNTERS \
-    X(BGQ_F_TIMESTAMP, "timestamp when data was collected") \
-    X(BGQ_F_NUM_INDICES, "end of counters")
+    /* timestamp when data was collected */\
+    X(BGQ_F_TIMESTAMP) \
+    X(BGQ_F_NUM_INDICES)
-#define X(a, b) a,
+#define X(a) a,
 /* integer counters for the "BGQ" example module */
 enum darshan_bgq_indices
--- a/darshan-util/darshan-bgq-logutils.c
+++ b/darshan-util/darshan-bgq-logutils.c
@@ -20,7 +20,7 @@
 #include "darshan-logutils.h"
 /* counter name strings for the POSIX module */
-#define X(a, b) #a,
+#define X(a) #a,
 char *bgq_counter_names[] = {
     BGQ_COUNTERS
@@ -35,12 +35,14 @@ static int darshan_log_get_bgq_rec(darshan_fd fd, void* bgq_buf,
 static int darshan_log_put_bgq_rec(darshan_fd fd, void* bgq_buf, int ver);
 static void darshan_log_print_bgq_rec(void *file_rec,
     char *file_name, char *mnt_pt, char *fs_type, int ver);
+static void darshan_log_print_bgq_description(void);
 struct darshan_mod_logutil_funcs bgq_logutils =
     .log_get_record = &darshan_log_get_bgq_rec,
     .log_put_record = &darshan_log_put_bgq_rec,
     .log_print_record = &darshan_log_print_bgq_rec,
+    .log_print_description = &darshan_log_print_bgq_description
@@ -112,6 +114,23 @@ static void darshan_log_print_bgq_rec(void *file_rec, char *file_name,
     return;
+static void darshan_log_print_bgq_description()
+    printf("\n# desription of BGQ counters:\n");
+    printf("#   BGQ_CSJOBID: BGQ control system job ID.\n");
+    printf("#   BGQ_NNODES: number of BGQ compute nodes for this job.\n");
+    printf("#   BGQ_RANKSPERNODE: number of MPI ranks per compute node.\n");
+    printf("#   BGQ_DDRPERNODE: size in MB of DDR3 per compute node.\n");
+    printf("#   BGQ_INODES: number of BGQ I/O nodes for this job.\n");
+    printf("#   BGQ_*NODES: dimension of A, B, C, D, & E dimensions of torus.\n");
+    printf("#   BGQ_TORUSENABLED: which dimensions of the torus are enabled.\n");
+    printf("#   BGQ_F_TIMESTAMP: timestamp when the BGQ data was collected.\n");
+    DARSHAN_PRINT_HEADER();
+    return;
  * Local variables:
  *  c-indent-level: 4
--- a/darshan-util/darshan-hdf5-logutils.c
+++ b/darshan-util/darshan-hdf5-logutils.c
@@ -35,12 +35,14 @@ static int darshan_log_get_hdf5_file(darshan_fd fd, void* hdf5_buf,
 static int darshan_log_put_hdf5_file(darshan_fd fd, void* hdf5_buf, int ver);
 static void darshan_log_print_hdf5_file(void *file_rec,
+static void darshan_log_print_hdf5_description(void);
 struct darshan_mod_logutil_funcs hdf5_logutils =
     .log_get_record = &darshan_log_get_hdf5_file,
     .log_put_record = &darshan_log_put_hdf5_file,
     .log_print_record = &darshan_log_print_hdf5_file,
+    .log_print_description = &darshan_log_print_hdf5_description
@@ -112,6 +114,18 @@ static void darshan_log_print_hdf5_file(void *file_rec, char *file_name,
     return;
+static void darshan_log_print_hdf5_description()
+    printf("\n# desription of HDF5 counters:\n");
+    printf("#   HDF5_OPENS: HDF5 file open operation counts.\n");
+    printf("#   HDF5_F_OPEN_TIMESTAMP: timestamp of first HDF5 file open.\n");
+    printf("#   HDF5_F_CLOSE_TIMESTAMP: timestamp of last HDF5 file close.\n");
+    return;
  * Local variables:
  *  c-indent-level: 4
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -89,6 +89,8 @@ struct darshan_mod_logutil_funcs
         char *fs_type,
         int ver
+    /* print module-specific description of I/O characterization data */
+    void (*log_print_description)(void);
 extern struct darshan_mod_logutil_funcs *mod_logutils[];
--- a/darshan-util/darshan-mpiio-logutils.c
+++ b/darshan-util/darshan-mpiio-logutils.c
@@ -35,12 +35,14 @@ static int darshan_log_get_mpiio_file(darshan_fd fd, void* mpiio_buf,
 static int darshan_log_put_mpiio_file(darshan_fd fd, void* mpiio_buf, int ver);
 static void darshan_log_print_mpiio_file(void *file_rec,
+static void darshan_log_print_mpiio_description(void);
 struct darshan_mod_logutil_funcs mpiio_logutils =
     .log_get_record = &darshan_log_get_mpiio_file,
     .log_put_record = &darshan_log_put_mpiio_file,
     .log_print_record = &darshan_log_print_mpiio_file,
+    .log_print_description = &darshan_log_print_mpiio_description
@@ -112,6 +114,40 @@ static void darshan_log_print_mpiio_file(void *file_rec, char *file_name,
     return;
+static void darshan_log_print_mpiio_description()
+    printf("\n# desription of MPIIO counters:\n");
+    printf("#   MPIIO_INDEP_*: MPI independent operation counts.\n");
+    printf("#   MPIIO_COLL_*: MPI collective operation counts.\n");
+    printf("#   MPIIO_SPLIT_*: MPI split collective operation counts.\n");
+    printf("#   MPIIO_NB_*: MPI non blocking operation counts.\n");
+    printf("#   READS,WRITES,and OPENS are types of operations.\n");
+    printf("#   MPIIO_SYNCS: MPI file sync operation counts.\n");
+    printf("#   MPIIO_HINTS: number of times MPI hints were used.\n");
+    printf("#   MPIIO_VIEWS: number of times MPI file views were used.\n");
+    printf("#   MPIIO_MODE: MPI-IO access mode that file was opened with.\n");
+    printf("#   MPIIO_BYTES_*: total bytes read and written at MPI-IO layer.\n");
+    printf("#   MPIIO_RW_SWITCHES: number of times access alternated between read and write.\n");
+    printf("#   MPIIO_MAX_*_TIME_SIZE: size of the slowest read and write operations.\n");
+    printf("#   MPIIO_SIZE_*_AGG_*: histogram of MPI datatype total sizes for read and write operations.\n");
+    printf("#   MPIIO_ACCESS*_ACCESS: the four most common total access sizes.\n");
+    printf("#   MPIIO_ACCESS*_COUNT: count of the four most common total access sizes.\n");
+    printf("#   MPIIO_*_RANK: rank of the processes that were the fastest and slowest at I/O (for shared files).\n");
+    printf("#   MPIIO_*_RANK_BYTES: total bytes transferred at MPI-IO layer by the fastest and slowest ranks (for shared files).\n");
+    printf("#   MPIIO_F_OPEN_TIMESTAMP: timestamp of first open.\n");
+    printf("#   MPIIO_F_*_START_TIMESTAMP: timestamp of first MPI-IO read/write.\n");
+    printf("#   MPIIO_F_*_END_TIMESTAMP: timestamp of last MPI-IO read/write.\n");
+    printf("#   MPIIO_F_CLOSE_TIMESTAMP: timestamp of last close.\n");
+    printf("#   MPIIO_F_READ/WRITE/META_TIME: cumulative time spent in MPI-IO read, write, or metadata operations.\n");
+    printf("#   MPIIO_F_MAX_*_TIME: duration of the slowest MPI-IO read and write operations.\n");
+    printf("#   MPIIO_F_*_RANK_TIME: fastest and slowest I/O time for a single rank (for shared files).\n");
+    printf("#   MPIIO_F_VARIANCE_RANK_*: variance of total I/O time and bytes moved for all ranks (for shared files).\n");
+    return;
  * Local variables:
  *  c-indent-level: 4
--- a/darshan-util/darshan-null-logutils.c
+++ b/darshan-util/darshan-null-logutils.c
@@ -37,6 +37,7 @@ static int darshan_log_get_null_record(darshan_fd fd, void* null_buf,
 static int darshan_log_put_null_record(darshan_fd fd, void* null_buf, int ver);
 static void darshan_log_print_null_record(void *file_rec,
+static void darshan_log_print_null_description(void);
 /* structure storing each function needed for implementing the darshan
  * logutil interface. these functions are used for reading, writing, and
@@ -47,6 +48,7 @@ struct darshan_mod_logutil_funcs null_logutils =
     .log_get_record = &darshan_log_get_null_record,
     .log_put_record = &darshan_log_put_null_record,
     .log_print_record = &darshan_log_print_null_record,
+    .log_print_description = &darshan_log_print_null_description
 /* retrieve a NULL record from log file descriptor 'fd', storing the
@@ -134,6 +136,18 @@ static void darshan_log_print_null_record(void *file_rec, char *file_name,
     return;
+/* print out a description of the NULL module record fields */
+static void darshan_log_print_null_description()
+    printf("\n# desription of NULL counters:\n");
+    printf("#   NULL_BARS: number of 'bar' function calls.\n");
+    printf("#   NULL_BAR_DAT: value set by last call to function 'bar'.\n");
+    printf("#   NULL_F_BAR_TIMESTAMP: timestamp of the first call to function 'bar'.\n");
+    printf("#   NULL_F_BAR_DURATION: duration of the last call to function 'bar'.\n");
+    return;
  * Local variables:
  *  c-indent-level: 4
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -321,6 +321,21 @@ int main(int argc, char **argv)
         printf("# mount entry:\t%s\t%s\n", mnt_pts[i], fs_types[i]);
+    if(mask & OPTION_BASE)
+        printf("\n# description of columns:\n");
+        printf("#   <module>: module responsible for this I/O record.\n");
+        printf("#   <rank>: MPI rank.  -1 indicates that the file is shared\n");
+        printf("#      across all processes and statistics are aggregated.\n");
+        printf("#   <record id>: hash of the record's file path\n");
+        printf("#   <counter name> and <counter value>: statistical counters.\n");
+        printf("#      A value of -1 indicates that Darshan could not monitor\n");
+        printf("#      that counter, and its value should be ignored.\n");
+        printf("#   <file name>: full file path for the record.\n");
+        printf("#   <mount pt>: mount point that the file resides on.\n");
+        printf("#   <fs type>: type of file system that the file resides on.\n");
     /* warn user if this log file is incomplete */
     pdata.rank_cumul_io_time = malloc(sizeof(double)*job.nprocs);
     pdata.rank_cumul_md_time = malloc(sizeof(double)*job.nprocs);
@@ -374,8 +389,9 @@ int main(int argc, char **argv)
-            /* TODO: does each module print header of what each counter means??? */
-            DARSHAN_PRINT_HEADER();
+            /* print a header describing the module's I/O characterization data */
+            if(mod_logutils[i]->log_print_description)
+                mod_logutils[i]->log_print_description();
         ret = mod_logutils[i]->log_get_record(fd, mod_buf, &rec_id);
--- a/darshan-util/darshan-pnetcdf-logutils.c
+++ b/darshan-util/darshan-pnetcdf-logutils.c
@@ -35,12 +35,14 @@ static int darshan_log_get_pnetcdf_file(darshan_fd fd, void* pnetcdf_buf,
 static int darshan_log_put_pnetcdf_file(darshan_fd fd, void* pnetcdf_buf, int ver);
 static void darshan_log_print_pnetcdf_file(void *file_rec,
+static void darshan_log_print_pnetcdf_description(void);
 struct darshan_mod_logutil_funcs pnetcdf_logutils =
     .log_get_record = &darshan_log_get_pnetcdf_file,
     .log_put_record = &darshan_log_put_pnetcdf_file,
     .log_print_record = &darshan_log_print_pnetcdf_file,
+    .log_print_description = &darshan_log_print_pnetcdf_description
@@ -112,6 +114,19 @@ static void darshan_log_print_pnetcdf_file(void *file_rec, char *file_name,
     return;
+static void darshan_log_print_pnetcdf_description()
+    printf("\n# desription of PNETCDF counters:\n");
+    printf("#   PNETCDF_INDEP_OPENS: PNETCDF independent file open operation counts.\n");
+    printf("#   PNETCDF_COLL_OPENS: PNETCDF collective file open operation counts.\n");
+    printf("#   PNETCDF_F_OPEN_TIMESTAMP: timestamp of first PNETCDF file open.\n");
+    printf("#   PNETCDF_F_CLOSE_TIMESTAMP: timestamp of last PNETCDF file close.\n");
+    return;
  * Local variables:
  *  c-indent-level: 4
--- a/darshan-util/darshan-posix-logutils.c
+++ b/darshan-util/darshan-posix-logutils.c
@@ -35,12 +35,14 @@ static int darshan_log_get_posix_file(darshan_fd fd, void* posix_buf,
 static int darshan_log_put_posix_file(darshan_fd fd, void* posix_buf, int ver);
 static void darshan_log_print_posix_file(void *file_rec,
+static void darshan_log_print_posix_description(void);
 struct darshan_mod_logutil_funcs posix_logutils =
     .log_get_record = &darshan_log_get_posix_file,
     .log_put_record = &darshan_log_put_posix_file,
     .log_print_record = &darshan_log_print_posix_file,
+    .log_print_description = &darshan_log_print_posix_description
@@ -112,6 +114,41 @@ static void darshan_log_print_posix_file(void *file_rec, char *file_name,
     return;
+static void darshan_log_print_posix_description()
+    printf("\n# desription of POSIX counters:\n");
+    printf("#   POSIX_*: posix operation counts.\n");
+    printf("#   READS,WRITES,OPENS,SEEKS,STATS, and MMAPS are types of operations.\n");
+    printf("#   POSIX_MODE: mode that file was opened in.\n");
+    printf("#   POSIX_BYTES_*: total bytes read and written.\n");
+    printf("#   POSIX_MAX_BYTE_*: highest offset byte read and written.\n");
+    printf("#   POSIX_CONSEC_*: number of exactly adjacent reads and writes.\n");
+    printf("#   POSIX_SEQ_*: number of reads and writes from increasing offsets.\n");
+    printf("#   POSIX_RW_SWITCHES: number of times access alternated between read and write.\n");
+    printf("#   POSIX_*_ALIGNMENT: memory and file alignment.\n");
+    printf("#   POSIX_*_NOT_ALIGNED: number of reads and writes that were not aligned.\n");
+    printf("#   POSIX_MAX_*_TIME_SIZE: size of the slowest read and write operations.\n");
+    printf("#   POSIX_SIZE_*_*: histogram of read and write access sizes.\n");
+    printf("#   POSIX_STRIDE*_STRIDE: the four most common strides detected.\n");
+    printf("#   POSIX_STRIDE*_COUNT: count of the four most common strides.\n");
+    printf("#   POSIX_ACCESS*_ACCESS: the four most common access sizes.\n");
+    printf("#   POSIX_ACCESS*_COUNT: count of the four most common access sizes.\n");
+    printf("#   POSIX_*_RANK: rank of the processes that were the fastest and slowest at I/O (for shared files).\n");
+    printf("#   POSIX_*_RANK_BYTES: bytes transferred by the fastest and slowest ranks (for shared files).\n");
+    printf("#   POSIX_F_OPEN_TIMESTAMP: timestamp of first open.\n");
+    printf("#   POSIX_F_*_START_TIMESTAMP: timestamp of first read/write.\n");
+    printf("#   POSIX_F_*_END_TIMESTAMP: timestamp of last read/write.\n");
+    printf("#   POSIX_F_CLOSE_TIMESTAMP: timestamp of last close.\n");
+    printf("#   POSIX_F_READ/WRITE/META_TIME: cumulative time spent in read, write, or metadata operations.\n");
+    printf("#   POSIX_F_MAX_*_TIME: duration of the slowest read and write operations.\n");
+    printf("#   POSIX_F_*_RANK_TIME: fastest and slowest I/O time for a single rank (for shared files).\n");
+    printf("#   POSIX_F_VARIANCE_RANK_*: variance of total I/O time and bytes moved for all ranks (for shared files).\n");
+    return;
  * Local variables:
  *  c-indent-level: 4
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/9b021c1bba1f7a7f7889333fa1f07cba5df159a4
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20151211/6e49ece8/attachment-0001.html>
More information about the Darshan-commits mailing list
