[Darshan-commits] [Git][darshan/darshan][dev-modular] 2 commits: cleanup a bunch of code and stale comments
Shane Snyder xgitlab at cels.anl.gov
Fri Dec 11 14:27:54 CST 2015
Shane Snyder pushed to branch dev-modular at darshan / darshan
Commits:
1c1a9baa by Shane Snyder at 2015-12-11T13:02:32Z
31e0fb03 by Shane Snyder at 2015-12-11T14:27:31Z
update runtime, util, and modularization docs
12 changed files:
- darshan-posix-log-format.h
- darshan-runtime/Makefile.in
- darshan-runtime/darshan.h
- darshan-runtime/doc/darshan-runtime.txt
- darshan-runtime/lib/darshan-bgq.c
- darshan-runtime/lib/darshan-posix.c
- darshan-util/Makefile.in
- darshan-util/darshan-logutils.h
- darshan-util/darshan-null-logutils.c
- darshan-util/darshan-parser.c
- darshan-util/doc/darshan-util.txt
- doc/darshan-modularization.txt
Changes:
--- a/darshan-posix-log-format.h
+++ b/darshan-posix-log-format.h
@@ -177,11 +177,4 @@ struct darshan_posix_file
     double fcounters[POSIX_F_NUM_INDICES];
-/* This macro can be used to identify files that have been opened using
- * pnetcdf, hdf5, or mpi-io, but were never opened at the posix level.  As a
- * result the record will not necessarily have all of the expected fields
- * populated.
-#define POSIX_FILE_PARTIAL(__file)((((__file)->counters[POSIX_OPENS] || (__file)->counters[POSIX_FOPENS] || (__file)->counters[POSIX_STATS]) ? 0 : 1))
 #endif /* __DARSHAN_POSIX_LOG_FORMAT_H */
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -33,12 +33,12 @@ CFLAGS_SHARED = -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I$(srcdir)
 LIBS = -lz @LIBBZ2@
-static-mod-objs = lib/darshan-posix.o lib/darshan-mpiio.o lib/darshan-hdf5.o lib/darshan-pnetcdf.o
-dynamic-mod-objs = lib/darshan-posix.po lib/darshan-mpiio.po lib/darshan-hdf5.po lib/darshan-pnetcdf.po
+DARSHAN_STATIC_MOD_OBJS = lib/darshan-posix.o lib/darshan-mpiio.o lib/darshan-hdf5.o lib/darshan-pnetcdf.o
+DARSHAN_DYNAMIC_MOD_OBJS = lib/darshan-posix.po lib/darshan-mpiio.po lib/darshan-hdf5.po lib/darshan-pnetcdf.po
 ifdef DARSHAN_USE_BGQ
-static-mod-objs += lib/darshan-bgq.o
-dynamic-mod-objs += lib/darshan-bgq.po
+DARSHAN_STATIC_MOD_OBJS += lib/darshan-bgq.o
+DARSHAN_DYNAMIC_MOD_OBJS += lib/darshan-bgq.po
 CFLAGS += -DDARSHAN_BGQ
 CFLAGS_SHARED += -DDARSHAN_BGQ
 endif
@@ -118,10 +118,10 @@ lib/lookup8.o: lib/lookup8.c
 lib/lookup8.po: lib/lookup8.c
 	$(CC) $(CFLAGS_SHARED) -c $< -o $@
-lib/libdarshan.a: lib/darshan-core-init-finalize.o lib/darshan-core.o lib/darshan-common.o $(static-mod-objs) lib/lookup3.o lib/lookup8.o
+lib/libdarshan.a: lib/darshan-core-init-finalize.o lib/darshan-core.o lib/darshan-common.o $(DARSHAN_STATIC_MOD_OBJS) lib/lookup3.o lib/lookup8.o
 	ar rcs $@ $^
-lib/libdarshan.so: lib/darshan-core-init-finalize.po lib/darshan-core.po lib/darshan-common.po $(dynamic-mod-objs) lib/lookup3.po lib/lookup8.po
+lib/libdarshan.so: lib/darshan-core-init-finalize.po lib/darshan-core.po lib/darshan-common.po $(DARSHAN_DYNAMIC_MOD_OBJS) lib/lookup3.po lib/lookup8.po
 	$(CC) $(CFLAGS_SHARED) $(LDFLAGS) -o $@ $^ -lpthread -lrt -lz -ldl
 lib/libdarshan-stubs.a: lib/darshan-hdf5-stubs.o lib/darshan-pnetcdf-stubs.o
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -115,17 +115,17 @@ void darshan_core_unregister_module(
 /* darshan_core_register_record()
- * Register the Darshan record given by 'name' with the darshan-core
- * runtime, allowing it to be properly tracked and (potentially)
- * correlated with records from other modules. 'len' is the size of
- * the name pointer (string length for string names), and 'printable_flag'
- * indicates whether the name is a string. 'mod_limit_flag' is set if
- * the calling module is out of memory (to prevent darshan-core from
- * creating new records and to just search existing records)  and 'mod_id'
- * is the identifier of the calling module. 'rec_id' is an output pointer
- * storing the correspoing Darshan record identifier and 'file_alignment'
- * is an output pointer storing the file system alignment value for the
- * given record.
+ * Register a record with the darshan-core runtime, allowing it to be
+ * properly tracked and (potentially) correlated with records from other
+ * modules. 'name' is the the name of the Darshan record (e.g., the full
+ * file path) and 'len' is the size of the name pointer (string length
+ * for string names). 'mod_id' is the identifier of the calling module,
+ * 'printable_flag' indicates whether the name is a string, and
+ * 'mod_limit_flag' is set if the calling module is out of memory (to
+ * prevent darshan-core from creating new records and to just search
+ * through existing records). 'rec_id' is an output pointer storing the
+ * correspoing Darshan record identifier and 'file_alignment' is an output
+ * pointer storing the file system alignment value for the given record.
 void darshan_core_register_record(
     void *name,
--- a/darshan-runtime/doc/darshan-runtime.txt
+++ b/darshan-runtime/doc/darshan-runtime.txt
@@ -16,7 +16,10 @@ used by the application.
 The darshan-runtime instrumentation only instruments MPI applications (the
 application must at least call `MPI_Init()` and `MPI_Finalize()`).  However,
 it captures both MPI-IO and POSIX file access.  It also captures limited
-information about HDF5 and PnetCDF access.
+information about HDF5 and PnetCDF access. Darshan also exposes an API that
+can be used to develop and add new instrumentation modules (for other I/O library
+interfaces or to gather system-specific data, for instance), as detailed in
+http://www.mcs.anl.gov/research/projects/darshan/docs/darshan-modularization.html[this document].
 This document provides generic installation instructions, but "recipes" for
 several common HPC systems are provided at the end of the document as well.
@@ -311,7 +314,7 @@ Please set your environment to use the GNU programming environment before
 configuring or compiling Darshan.  Although Darshan can be built with a
 variety of compilers, the GNU compilers are recommended because it will
 produce a Darshan library that is interoperable with the widest range
-of compmilers and linkers.  On most Cray systems you can enable the GNU
+of compilers and linkers.  On most Cray systems you can enable the GNU
 programming environment with a command similar to "module swap PrgEnv-pgi
 PrgEnv-gnu".  Please see your site documentation for information about
 how to switch programming environments.
--- a/darshan-runtime/lib/darshan-bgq.c
+++ b/darshan-runtime/lib/darshan-bgq.c
@@ -50,7 +50,7 @@ static int instrumentation_disabled = 0;
 static int my_rank = -1;
 static int darshan_mem_alignment = 1;
-/* internal helper functions for the "NULL" module */
+/* internal helper functions for the BGQ module */
 void bgq_runtime_initialize(void);
 /* forward declaration for module functions needed to interface with darshan-core */
@@ -58,7 +58,7 @@ static void bgq_begin_shutdown(void);
 static void bgq_get_output_data(MPI_Comm mod_comm, darshan_record_id *shared_recs, int shared_rec_count, void **buffer, int *size);
 static void bgq_shutdown(void);
-/* macros for obtaining/releasing the "NULL" module lock */
+/* macros for obtaining/releasing the BGQ module lock */
 #define BGQ_LOCK() pthread_mutex_lock(&bgq_runtime_mutex)
 #define BGQ_UNLOCK() pthread_mutex_unlock(&bgq_runtime_mutex)
@@ -133,13 +133,15 @@ void bgq_runtime_initialize()
     if(mem_limit == 0)
         instrumentation_disabled = 1;
+        BGQ_UNLOCK();
         return;
-    /* no enough memory to fit bgq module */
+    /* not enough memory to fit bgq module */
     if (mem_limit < sizeof(*bgq_runtime))
+        BGQ_UNLOCK();
         return;
@@ -148,6 +150,7 @@ void bgq_runtime_initialize()
     if(!bgq_runtime)
+        BGQ_UNLOCK();
         return;
     memset(bgq_runtime, 0, sizeof(*bgq_runtime));
@@ -180,7 +183,7 @@ void bgq_runtime_initialize()
     return;
-/* Perform any necessary steps prior to shutting down for the "NULL" module. */
+/* Perform any necessary steps prior to shutting down for the BGQ module. */
 static void bgq_begin_shutdown()
     BGQ_LOCK();
@@ -204,7 +207,7 @@ static int cmpr(const void *p1, const void *p2)
     return ((*a == *b) ?  0 : ((*a < *b) ? -1 : 1));
-/* Pass output data for the "BGQ" module back to darshan-core to log to file. */
+/* Pass output data for the BGQ module back to darshan-core to log to file. */
     MPI_Comm mod_comm,
@@ -212,7 +215,7 @@ static void bgq_get_output_data(
     void **buffer,
     int *size)
-    /* Just set the output buffer to point at the array of the "BGQ" module's
+    /* Just set the output buffer to point at the array of the BGQ module's
      * I/O records, and set the output size according to the number of records
      * currently being tracked.
@@ -273,7 +276,7 @@ static void bgq_get_output_data(
     return;
-/* Shutdown the "BGQ" module by freeing up all data structures. */
+/* Shutdown the BGQ module by freeing up all data structures. */
 static void bgq_shutdown()
     BGQ_LOCK();
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -39,8 +39,6 @@ typedef int64_t off64_t;
 #define aiocb64 aiocb
 #endif
-/* TODO: more libc, fgetc, etc etc etc. */
 DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...));
 DARSHAN_FORWARD_DECL(open64, int, (const char *path, int flags, ...));
 DARSHAN_FORWARD_DECL(creat, int, (const char* path, mode_t mode));
@@ -1728,10 +1726,7 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
             tmp_file.counters[j] = infile->counters[j] + inoutfile->counters[j];
-        if(POSIX_FILE_PARTIAL(infile))
-            tmp_file.counters[POSIX_MODE] = inoutfile->counters[POSIX_MODE];
-        else
-            tmp_file.counters[POSIX_MODE] = infile->counters[POSIX_MODE];
+        tmp_file.counters[POSIX_MODE] = infile->counters[POSIX_MODE];
         /* sum */
         for(j=POSIX_BYTES_READ; j<=POSIX_BYTES_WRITTEN; j++)
@@ -1754,10 +1749,7 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
-            tmp_file.counters[POSIX_MEM_ALIGNMENT] = inoutfile->counters[POSIX_MEM_ALIGNMENT];
-        else
-            tmp_file.counters[POSIX_MEM_ALIGNMENT] = infile->counters[POSIX_MEM_ALIGNMENT];
+        tmp_file.counters[POSIX_MEM_ALIGNMENT] = infile->counters[POSIX_MEM_ALIGNMENT];
         /* sum */
         for(j=POSIX_FILE_NOT_ALIGNED; j<=POSIX_FILE_NOT_ALIGNED; j++)
@@ -1765,10 +1757,7 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
-            tmp_file.counters[POSIX_FILE_ALIGNMENT] = inoutfile->counters[POSIX_FILE_ALIGNMENT];
-        else
-            tmp_file.counters[POSIX_FILE_ALIGNMENT] = infile->counters[POSIX_FILE_ALIGNMENT];
+        tmp_file.counters[POSIX_FILE_ALIGNMENT] = infile->counters[POSIX_FILE_ALIGNMENT];
         /* skip POSIX_MAX_*_TIME_SIZE; handled in floating point section */
--- a/darshan-util/Makefile.in
+++ b/darshan-util/Makefile.in
@@ -15,6 +15,8 @@ pkgconfigdir = $(DESTDIR)$(libdir)/pkgconfig
 DARSHAN_LOG_FORMAT = $(srcdir)/../darshan-log-format.h
 DARSHAN_MOD_LOG_FORMATS = $(srcdir)/../darshan-posix-log-format.h $(srcdir)/../darshan-mpiio-log-format.h $(srcdir)/../darshan-hdf5-log-format.h $(srcdir)/../darshan-pnetcdf-log-format.h
 DARSHAN_MOD_LOGUTIL_HEADERS = darshan-posix-logutils.h darshan-mpiio-logutils.h darshan-hdf5-logutils.h darshan-pnetcdf-logutils.h
+DARSHAN_STATIC_MOD_OBJS = darshan-posix-logutils.o darshan-mpiio-logutils.o darshan-hdf5-logutils.o darshan-pnetcdf-logutils.o darshan-bgq-logutils.o
+DARSHAN_DYNAMIC_MOD_OBJS = darshan-posix-logutils.po darshan-mpiio-logutils.po darshan-hdf5-logutils.po darshan-pnetcdf-logutils.po darshan-bgq-logutils.po
 DARSHAN_ENABLE_SHARED=@DARSHAN_ENABLE_SHARED@
@@ -79,13 +81,12 @@ darshan-bgq-logutils.o: darshan-bgq-logutils.c darshan-logutils.h darshan-bgq-lo
 darshan-bgq-logutils.po: darshan-bgq-logutils.c darshan-logutils.h darshan-bgq-logutils.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-bgq-log-format.h | uthash-1.9.2
+libdarshan-util.a: darshan-logutils.o $(DARSHAN_STATIC_MOD_OBJS)
+	ar rcs libdarshan-util.a $^
-libdarshan-util.so: darshan-logutils.po darshan-posix-logutils.po darshan-mpiio-logutils.po darshan-hdf5-logutils.po darshan-pnetcdf-logutils.po darshan-bgq-logutils.po
+libdarshan-util.so: darshan-logutils.po $(DARSHAN_DYNAMIC_MOD_OBJS)
 	$(CC) $(CFLAGS_SHARED) $(LDFLAGS) -o $@ $^ $(LIBS)
-libdarshan-util.a: darshan-logutils.o darshan-posix-logutils.o darshan-mpiio-logutils.o darshan-hdf5-logutils.o darshan-pnetcdf-logutils.o darshan-bgq-logutils.o
-	ar rcs libdarshan-util.a $^
 jenkins-hash-gen: jenkins-hash-gen.c lookup3.o
 	$(CC) $(CFLAGS) $(LDFLAGS) $^ -o $@ $(LIBS)
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -55,6 +55,9 @@ struct darshan_mod_logutil_funcs
     /* retrieve a single module record from the log file.
      * return 1 on successful read of record, 0 on no more
      * module data, -1 on error
+     *      - 'fd' is the file descriptor to get record from
+     *      - 'buf' is the buffer to store the record in
+     *      - 'rec_id' is the corresponding darshan record id
     int (*log_get_record)(
         darshan_fd fd,
@@ -63,13 +66,22 @@ struct darshan_mod_logutil_funcs
     /* put a single module record into the log file.
      * return 0 on success, -1 on error
+     *      - 'fd' is the file descriptor to put record into
+     *      - 'buf' is the buffer containing the record data
     int (*log_put_record)(
         darshan_fd fd,
         void *buf,
         int ver
-    /* print the counters for a given log file record */
+    /* print the counters for a given log record
+     *      - 'file_rec' is the record's data buffer
+     *      - 'file_name' is the file path string for the record
+     *      - 'mnt-pt' is the file path mount point string
+     *      - 'fs_type' is the file system type string
+     *      - 'ver' is the version of the record
     void (*log_print_record)(
         void *file_rec,
         char *file_name,
--- a/darshan-util/darshan-null-logutils.c
+++ b/darshan-util/darshan-null-logutils.c
@@ -51,7 +51,8 @@ struct darshan_mod_logutil_funcs null_logutils =
 /* retrieve a NULL record from log file descriptor 'fd', storing the
  * buffer in 'null_buf' and the corresponding Darshan record id in
- * 'rec_id'. Return 1 on successful record read, .
+ * 'rec_id'. Return 1 on successful record read, 0 on no more data,
+ * and -1 on error.
 static int darshan_log_get_null_record(darshan_fd fd, void* null_buf,
     darshan_record_id* rec_id)
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -690,8 +690,7 @@ void posix_accum_file(struct darshan_posix_file *pfile,
         case POSIX_MODE:
         case POSIX_MEM_ALIGNMENT:
         case POSIX_FILE_ALIGNMENT:
-            if(POSIX_FILE_PARTIAL(tmp))
-                tmp->counters[i] = pfile->counters[i];
+            tmp->counters[i] = pfile->counters[i];
             break;
         case POSIX_MAX_BYTE_READ:
         case POSIX_MAX_BYTE_WRITTEN:
--- a/darshan-util/doc/darshan-util.txt
+++ b/darshan-util/doc/darshan-util.txt
@@ -66,12 +66,16 @@ application will likely be found in a centralized directory, with the path
 and log file name in the following format:
-<YEAR>/<MONTH>/<DAY>/<USERNAME>_<BINARY_NAME>_<JOB_ID>_<DATE>_<UNIQUE_ID>_<TIMING>.darshan.gz
+<YEAR>/<MONTH>/<DAY>/<USERNAME>_<BINARY_NAME>_<JOB_ID>_<DATE>_<UNIQUE_ID>_<TIMING>.darshan
 This is a binary format file that summarizes I/O activity. As of version
 2.0.0 of Darshan, this file is portable and does not have to be analyzed on
-the same system that executed the job.
+the same system that executed the job. Also, note that Darshan logs generated
+with Darshan versions preceding version 3.0 will have the extension `darshan.gz`
+(or `darshan.bz2` if compressed using bzip2 format). These logs are not compatible
+with Darshan 3.0 utilities, and thus must be analyzed using an appropriate version
+(2.x) of the darshan-util package.
 === darshan-job-summary.pl
@@ -462,9 +466,9 @@ Byte and for the aggregate performance is MiB/s (1024*1024 Bytes/s).
 ===== Files
 Use the `--file` option to get totals based on file usage.
-The first column is the count of files for that type, the second column is
-number of bytes for that type and the third column is the maximum offset
-accessed.
+Each line has 3 columns. The first column is the count of files for that
+type of file, the second column is number of bytes for that type, and the third
+column is the maximum offset accessed.
 * total: All files
 * read_only: Files that were only read from
@@ -473,9 +477,6 @@ accessed.
 * unique: Files that were opened on only one rank
 * shared: File that were opened by more than one rank
-Each line has 3 columns. The first column is the count of files for that
-type of file, the second column is number of bytes for that type, and the third
-column is the maximum offset accessed.
 .Example output
@@ -557,8 +558,6 @@ If the `--bzip2` flag is given, then the output file will be re-compressed in
 bzip2 format rather than libz format.  It also has command line options for
 anonymizing personal data, adding metadata annotation to the log header, and
 restricting the output to a specific instrumented file.
-* darshan-diff: compares two darshan log files and shows counters that
-differ.
 * darshan-analyzer: walks an entire directory tree of Darshan log files and
 produces a summary of the types of access methods used in those log files.
 * darshan-logutils*: this is a library rather than an executable, but it
--- a/doc/darshan-modularization.txt
+++ b/doc/darshan-modularization.txt
@@ -32,8 +32,8 @@ cd darshan
 git checkout dev-modular
-For details on configuring and building the Darshan runtime and utility repositories,
-consult the documentation from previous versions
+For details on configuring, building, and using the Darshan runtime and utility
+repositories, consult the documentation from previous versions
 (http://www.mcs.anl.gov/research/projects/darshan/docs/darshan-runtime.html[darshan-runtime] and
 http://www.mcs.anl.gov/research/projects/darshan/docs/darshan-util.html[darshan-util]) -- the
 necessary steps for building these repositories should not have changed in the new version of
@@ -121,13 +121,13 @@ component so it is included in the output I/O characterization.
 The static initialization approach is useful for modules that do not have function calls
 that can be intercepted and instead can just grab all I/O characterization data at Darshan
 startup or shutdown time. A module can be statically initialized at Darshan startup time
-by adding it to the `mod_static_init_fns` list at the top of the `lib/darshan-core.c`
-source file.
+by adding its initializatin routine to the `mod_static_init_fns` list at the top of the
+`lib/darshan-core.c` source file.
-*NOTE*: Modules which require static initialization should typically provide a corresponding
-configure option to prevent the module from being built and capturing I/O data. The ability
-to disable a module using a configure option is especially necessary for system-specific
-modules which can not be built or used on other systems.
+*NOTE*: Modules may wish to add a corresponding configure option to disable the module
+from attempting to gather I/O data. The ability to disable a module using a configure
+option is especially necessary for system-specific modules which can not be built or
+used on other systems.
 Most instrumentation modules can just bootstrap themselves within wrapper functions during
 normal application execution. Each of Darshan's current I/O library instrumentation modules
@@ -197,7 +197,7 @@ Within darshan-runtime, the darshan-core component manages the initialization an
 Darshan environment, provides an interface for modules to register themselves and their data
 records with Darshan, and manages the compressing and the writing of the resultant I/O
 characterization. As illustrated in Figure 1, the darshan-core runtime environment intercepts
-`MPI_Init` and `MPI_Finalize` routines to initialize and shutdown the darshan runtime environment,
+`MPI_Init` and `MPI_Finalize` routines to initialize and shutdown the Darshan runtime environment,
 respectively.
 Each of the functions provided by `darshan-core` to interface with instrumentation modules are
@@ -212,8 +212,8 @@ void darshan_core_register_module(
     int *sys_mem_alignment);
 The `darshan_core_register_module` function registers Darshan instrumentation modules with the
-`darshan-core` runtime environment. This function needs to be called at least once for any module
-that will contribute data to Darshan's final I/O characterization.
+`darshan-core` runtime environment. This function needs to be called once for any module that
+will contribute data to Darshan's final I/O characterization.
 * _mod_id_ is a unique identifier for the given module, which is defined in the Darshan log
 format header file (`darshan-log-format.h`).
@@ -398,8 +398,8 @@ struct darshan_record_ref *, which should be initialized to `NULL` for reading).
 is defined by the `uthash` hash table implementation and includes corresponding macros for
 searching, iterating, and deleting records from the hash. For detailed documentation on using this
 hash table, consult `uthash` documentation in `darshan-util/uthash-1.9.2/doc/txt/userguide.txt`.
-The `darshan-posix-parser` utility (for parsing POSIX module information out of a Darshan log)
-provides an example of how this hash table may be used. Returns `0` on success, `-1` on failure.
+The `darshan-parser` utility (for parsing module information out of a Darshan log) provides an
+example of how this hash table may be used. Returns `0` on success, `-1` on failure.
 [source,c]
 int darshan_log_getmod(darshan_fd fd, darshan_module_id mod_id, void *mod_buf, int mod_buf_sz);
@@ -448,9 +448,10 @@ the module's record structure:
 * Add a module identifier to the `DARSHAN_MODULE_IDS` macro at the top of the `darshan-log-format.h`
 header. In this macro, the first field is a corresponding enum value that can be used to
-identify the module, the second field is a string name for the module, and the third field
-is a corresponding pointer to a Darshan log utility implementation for this module (which
-can be set to `NULL` until the module has its own log utility implementation).
+identify the module, the second field is a string name for the module, the third field is the
+current version number of the given module's log format, and the fourth field is a corresponding
+pointer to a Darshan log utility implementation for this module (which can be set to `NULL`
+until the module has its own log utility implementation).
 * Add a top-level header that defines an I/O data record structure for the module. Consider
 the "NULL" module and POSIX module log format headers for examples (`darshan-null-log-format.h`
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/c371cdea3257003237f12c63ff688c35934a3464...31e0fb031c8a3e45f894f5fdeeb431cdf5c237c0
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20151211/9f5580e1/attachment-0001.html>
More information about the Darshan-commits mailing list
