[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-87-g5c5918a
Service Account
git at mcs.anl.gov
Fri Apr 3 11:19:44 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via 5c5918aa36ddb95896ed547b726ed1432e5ca794 (commit)
from 90c39ea6cdd1abebd83fe7916a8434c151e82a9e (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 5c5918aa36ddb95896ed547b726ed1432e5ca794
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Thu Apr 2 23:39:24 2015 -0500
add LD_PRELOAD functionality
Summary of changes:
darshan-runtime/Makefile.in | 14 +-
darshan-runtime/configure | 13 -
darshan-runtime/darshan-core.h | 6 +-
darshan-runtime/darshan-dynamic.h | 19 +--
darshan-runtime/darshan-runtime-config.h.in | 4 -
darshan-runtime/darshan.h | 4 +-
darshan-runtime/lib/darshan-core-init-finalize.c | 262 ++++++++++++++++++++++
darshan-runtime/lib/darshan-core.c | 127 +++--------
darshan-runtime/lib/darshan-mpiio.c | 1 +
darshan-runtime/lib/darshan-posix.c | 18 +-
10 files changed, 331 insertions(+), 137 deletions(-)
create mode 100644 darshan-runtime/lib/darshan-core-init-finalize.c
Diff of changes:
diff --git a/darshan-runtime/Makefile.in b/darshan-runtime/Makefile.in
index 019bb51..791cac6 100644
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -33,10 +33,16 @@ LIBS = -lz @LIBBZ2@
lib::
@mkdir -p $@
-lib/darshan-core.o: lib/darshan-core.c darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-core-init-finalize.o: lib/darshan-core-init-finalize.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
$(CC) $(CFLAGS) -c $< -o $@
-lib/darshan-core.po: lib/darshan-core.c darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
+lib/darshan-core-init-finalize.po: lib/darshan-core-init-finalize.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
+ $(CC) $(CFLAGS_SHARED) -c $< -o $@
+lib/darshan-core.o: lib/darshan-core.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
+ $(CC) $(CFLAGS) -c $< -o $@
+lib/darshan-core.po: lib/darshan-core.c darshan.h darshan-core.h $(DARSHAN_LOG_FORMAT) | lib
lib/darshan-common.o: lib/darshan-common.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
@@ -72,10 +78,10 @@ lib/lookup8.po: lib/lookup8.c
#%.i: %.c
# $(CC) -E $(CFLAGS) -c $< -o $@
-lib/libdarshan.a: lib/darshan-posix.o lib/darshan-mpiio.o lib/darshan-core.o lib/darshan-common.o lib/lookup3.o lib/lookup8.o
+lib/libdarshan.a: lib/darshan-core-init-finalize.o lib/darshan-core.o lib/darshan-common.o lib/darshan-posix.o lib/darshan-mpiio.o lib/lookup3.o lib/lookup8.o
ar rcs $@ $^
-lib/libdarshan.so: lib/darshan-core.po lib/darshan-common.po lib/darshan-posix.po lib/darshan-mpiio.po lib/lookup3.po lib/lookup8.po
+lib/libdarshan.so: lib/darshan-core-init-finalize.po lib/darshan-core.po lib/darshan-common.po lib/darshan-posix.po lib/darshan-mpiio.po lib/lookup3.po lib/lookup8.po
$(CC) $(CFLAGS_SHARED) $(LDFLAGS) -o $@ $^ -lpthread -lrt -lz -ldl
install:: all
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index ce59089..0896cb7 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -687,7 +687,6 @@ with_zlib
enable_cuserid
enable_ld_preload
enable_group_readable_logs
-enable_stat_at_open
with_mem_align
with_log_path_by_env
with_log_hints
@@ -1315,7 +1314,6 @@ Optional Features:
--disable-cuserid Disables attempted use of cuserid() at run time
--disable-ld-preload Disables support for LD_PRELOAD library
--enable-group-readable-logs Set log files to be group readable
- --enable-stat-at-open Perform stat() call at open time to gather extra statistics
Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
@@ -3567,17 +3565,6 @@ fi
fi
-# Check whether --enable-stat-at-open was given.
-if test "${enable_stat_at_open+set}" = set; then :
- enableval=$enable_stat_at_open; if test "x$enableval" = "xyes" ; then
-$as_echo "#define __CP_STAT_AT_OPEN 1" >>confdefs.h
-fi
-fi
# Check whether --with-mem-align was given.
if test "${with_mem_align+set}" = set; then :
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index 1f53307..4f1cc83 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -11,7 +11,8 @@
#include <sys/types.h>
#include <stdint.h>
-#include "darshan.h"
+#include "uthash.h"
+#include "darshan-log-format.h"
#define DARSHAN_CORE_MAX_RECORDS 1024
@@ -50,6 +51,9 @@ struct darshan_core_record_ref
UT_hash_handle hlink;
+void darshan_core_initialize(int argc, char **argv);
+void darshan_core_shutdown(void);
uint32_t darshan_hashlittle(const void *key, size_t length, uint32_t initval);
uint64_t darshan_hash(const register unsigned char *k, register uint64_t length, register uint64_t level);
diff --git a/darshan-runtime/darshan-dynamic.h b/darshan-runtime/darshan-dynamic.h
index b488c6a..a73d75f 100644
--- a/darshan-runtime/darshan-dynamic.h
+++ b/darshan-runtime/darshan-dynamic.h
@@ -9,16 +9,10 @@
#ifdef DARSHAN_PRELOAD
-#include <dlfcn.h>
-#include <stdlib.h>
-#define DARSHAN_MPI_CALL(func) __real_ ## func
#define DARSHAN_EXTERN_DECL(name,ret,args) \
extern ret (*__real_ ## name)args;
DARSHAN_EXTERN_DECL(PMPI_File_close, int, (MPI_File *fh));
-DARSHAN_EXTERN_DECL(PMPI_File_set_size, int, (MPI_File fh, MPI_Offset size));
DARSHAN_EXTERN_DECL(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
DARSHAN_EXTERN_DECL(PMPI_File_iread, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
DARSHAN_EXTERN_DECL(PMPI_File_iread_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
@@ -105,7 +99,6 @@ DARSHAN_EXTERN_DECL(PMPI_File_write_shared, int, (MPI_File fh, void *buf, int co
DARSHAN_EXTERN_DECL(PMPI_Finalize, int, ());
DARSHAN_EXTERN_DECL(PMPI_Init, int, (int *argc, char ***argv));
DARSHAN_EXTERN_DECL(PMPI_Init_thread, int, (int *argc, char ***argv, int required, int *provided));
DARSHAN_EXTERN_DECL(PMPI_Wtime, double, ());
DARSHAN_EXTERN_DECL(PMPI_Allreduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
DARSHAN_EXTERN_DECL(PMPI_Bcast, int, (void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm));
@@ -117,16 +110,14 @@ DARSHAN_EXTERN_DECL(PMPI_Type_contiguous, int, (int count, MPI_Datatype oldtype,
DARSHAN_EXTERN_DECL(PMPI_Type_extent, int, (MPI_Datatype datatype, MPI_Aint *extent));
DARSHAN_EXTERN_DECL(PMPI_Type_free, int, (MPI_Datatype *datatype));
DARSHAN_EXTERN_DECL(PMPI_Type_hindexed, int, (int count, int *array_of_blocklengths, MPI_Aint *array_of_displacements, MPI_Datatype oldtype, MPI_Datatype *newtype));
+DARSHAN_EXTERN_DECL(PMPI_Type_get_envelope, int, (MPI_Datatype datatype, int *num_integers, int *num_addresses, int *num_datatypes, int *combiner));
+DARSHAN_EXTERN_DECL(PMPI_Type_size, int, (MPI_Datatype datatype, int *size));
DARSHAN_EXTERN_DECL(PMPI_Op_create, int, (MPI_User_function *function, int commute, MPI_Op *op));
DARSHAN_EXTERN_DECL(PMPI_Op_free, int, (MPI_Op *op));
DARSHAN_EXTERN_DECL(PMPI_Reduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm));
-DARSHAN_EXTERN_DECL(PMPI_Type_get_envelope, int, (MPI_Datatype datatype, int *num_integers, int *num_addresses, int *num_datatypes, int *combiner));
-DARSHAN_EXTERN_DECL(PMPI_Type_size, int, (MPI_Datatype datatype, int *size));
-#else
-#define DARSHAN_MPI_CALL(func) func
+DARSHAN_EXTERN_DECL(PMPI_Send, int, (void *buf, int count, MPI_Datatype datatype, int dest, int tag, MPI_Comm comm));
+DARSHAN_EXTERN_DECL(PMPI_Recv, int, (void *buf, int count, MPI_Datatype datatype, int source, int tag, MPI_Comm comm, MPI_Status *status));
#endif
-#endif
+#endif /* __DARSHAN_DYNAMIC_H */
diff --git a/darshan-runtime/darshan-runtime-config.h.in b/darshan-runtime/darshan-runtime-config.h.in
index c7ec650..5ed35b4 100644
--- a/darshan-runtime/darshan-runtime-config.h.in
+++ b/darshan-runtime/darshan-runtime-config.h.in
@@ -105,9 +105,5 @@
/* Memory alignment in bytes */
#undef __CP_MEM_ALIGNMENT
-/* Define if Darshan should stat files at open time to collect extra
- statistics */
-#undef __CP_STAT_AT_OPEN
/* Generalized request type for MPI-IO */
#undef __D_MPI_REQUEST
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index 20829be..eff89b9 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -30,12 +30,12 @@
* consistently regardless of whether static or dynamic linking is used
-#define __USE_GNU
#include <dlfcn.h>
#include <stdlib.h>
#define DARSHAN_FORWARD_DECL(name,ret,args) \
- ret (*__real_ ## name)args = NULL;
+ ret (*__real_ ## name)args = NULL
#define DARSHAN_DECL(__name) __name
diff --git a/darshan-runtime/lib/darshan-core-init-finalize.c b/darshan-runtime/lib/darshan-core-init-finalize.c
new file mode 100644
index 0000000..a3bed07
--- /dev/null
+++ b/darshan-runtime/lib/darshan-core-init-finalize.c
@@ -0,0 +1,262 @@
+ * Copyright (C) 2015 University of Chicago.
+ * See COPYRIGHT notice in top-level directory.
+#define _XOPEN_SOURCE 500
+#define _GNU_SOURCE
+#include "darshan-runtime-config.h"
+#include <stdio.h>
+#include <stdlib.h>
+#include <mpi.h>
+#include "darshan.h"
+#include "darshan-core.h"
+#ifdef DARSHAN_PRELOAD
+DARSHAN_FORWARD_DECL(PMPI_File_close, int, (MPI_File *fh));
+DARSHAN_FORWARD_DECL(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+DARSHAN_FORWARD_DECL(PMPI_File_iread, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+DARSHAN_FORWARD_DECL(PMPI_File_iread_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#ifdef HAVE_MPIIO_CONST
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_iwrite_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_open, int, (MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_open, int, (MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_read_all_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
+DARSHAN_FORWARD_DECL(PMPI_File_read_all, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_read_at_all, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_read_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype));
+DARSHAN_FORWARD_DECL(PMPI_File_read_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_read, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_read_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
+DARSHAN_FORWARD_DECL(PMPI_File_read_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_read_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+DARSHAN_FORWARD_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, const char *datarep, MPI_Info info));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype, char *datarep, MPI_Info info));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_sync, int, (MPI_File fh));
+DARSHAN_FORWARD_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_all_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_all, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_all, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_ordered_begin, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_ordered, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_ordered, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_File_write_shared, int, (MPI_File fh, const void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#else
+DARSHAN_FORWARD_DECL(PMPI_File_write_shared, int, (MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status));
+#endif
+DARSHAN_FORWARD_DECL(PMPI_Finalize, int, ());
+DARSHAN_FORWARD_DECL(PMPI_Init, int, (int *argc, char ***argv));
+DARSHAN_FORWARD_DECL(PMPI_Init_thread, int, (int *argc, char ***argv, int required, int *provided));
+DARSHAN_FORWARD_DECL(PMPI_Wtime, double, ());
+DARSHAN_FORWARD_DECL(PMPI_Allreduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
+DARSHAN_FORWARD_DECL(PMPI_Bcast, int, (void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm));
+DARSHAN_FORWARD_DECL(PMPI_Comm_rank, int, (MPI_Comm comm, int *rank));
+DARSHAN_FORWARD_DECL(PMPI_Comm_size, int, (MPI_Comm comm, int *size));
+DARSHAN_FORWARD_DECL(PMPI_Scan, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, MPI_Comm comm));
+DARSHAN_FORWARD_DECL(PMPI_Type_commit, int, (MPI_Datatype *datatype));
+DARSHAN_FORWARD_DECL(PMPI_Type_contiguous, int, (int count, MPI_Datatype oldtype, MPI_Datatype *newtype));
+DARSHAN_FORWARD_DECL(PMPI_Type_extent, int, (MPI_Datatype datatype, MPI_Aint *extent));
+DARSHAN_FORWARD_DECL(PMPI_Type_free, int, (MPI_Datatype *datatype));
+DARSHAN_FORWARD_DECL(PMPI_Type_hindexed, int, (int count, int *array_of_blocklengths, MPI_Aint *array_of_displacements, MPI_Datatype oldtype, MPI_Datatype *newtype));
+DARSHAN_FORWARD_DECL(PMPI_Type_get_envelope, int, (MPI_Datatype datatype, int *num_integers, int *num_addresses, int *num_datatypes, int *combiner));
+DARSHAN_FORWARD_DECL(PMPI_Type_size, int, (MPI_Datatype datatype, int *size));
+DARSHAN_FORWARD_DECL(PMPI_Op_create, int, (MPI_User_function *function, int commute, MPI_Op *op));
+DARSHAN_FORWARD_DECL(PMPI_Op_free, int, (MPI_Op *op));
+DARSHAN_FORWARD_DECL(PMPI_Reduce, int, (void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm));
+DARSHAN_FORWARD_DECL(PMPI_Send, int, (void *buf, int count, MPI_Datatype datatype, int dest, int tag, MPI_Comm comm));
+DARSHAN_FORWARD_DECL(PMPI_Recv, int, (void *buf, int count, MPI_Datatype datatype, int source, int tag, MPI_Comm comm, MPI_Status *status));
+void resolve_mpi_symbols (void)
+ * Overloaded functions
+ MAP_OR_FAIL(PMPI_File_close);
+ MAP_OR_FAIL(PMPI_File_iread_at);
+ MAP_OR_FAIL(PMPI_File_iread);
+ MAP_OR_FAIL(PMPI_File_iread_shared);
+ MAP_OR_FAIL(PMPI_File_iwrite_at);
+ MAP_OR_FAIL(PMPI_File_iwrite);
+ MAP_OR_FAIL(PMPI_File_iwrite_shared);
+ MAP_OR_FAIL(PMPI_File_open);
+ MAP_OR_FAIL(PMPI_File_read_all_begin);
+ MAP_OR_FAIL(PMPI_File_read_all);
+ MAP_OR_FAIL(PMPI_File_read_at_all_begin);
+ MAP_OR_FAIL(PMPI_File_read_at_all);
+ MAP_OR_FAIL(PMPI_File_read_at);
+ MAP_OR_FAIL(PMPI_File_read);
+ MAP_OR_FAIL(PMPI_File_read_ordered_begin);
+ MAP_OR_FAIL(PMPI_File_read_ordered);
+ MAP_OR_FAIL(PMPI_File_read_shared);
+ MAP_OR_FAIL(PMPI_File_set_view);
+ MAP_OR_FAIL(PMPI_File_sync);
+ MAP_OR_FAIL(PMPI_File_write_all_begin);
+ MAP_OR_FAIL(PMPI_File_write_all);
+ MAP_OR_FAIL(PMPI_File_write_at_all_begin);
+ MAP_OR_FAIL(PMPI_File_write_at_all);
+ MAP_OR_FAIL(PMPI_File_write_at);
+ MAP_OR_FAIL(PMPI_File_write);
+ MAP_OR_FAIL(PMPI_File_write_ordered_begin);
+ MAP_OR_FAIL(PMPI_File_write_ordered);
+ MAP_OR_FAIL(PMPI_File_write_shared);
+ MAP_OR_FAIL(PMPI_Finalize);
+ MAP_OR_FAIL(PMPI_Init);
+ MAP_OR_FAIL(PMPI_Init_thread);
+ * These function are not intercepted but are used
+ * by darshan itself.
+ MAP_OR_FAIL(PMPI_Wtime);
+ MAP_OR_FAIL(PMPI_Allreduce);
+ MAP_OR_FAIL(PMPI_Bcast);
+ MAP_OR_FAIL(PMPI_Comm_rank);
+ MAP_OR_FAIL(PMPI_Comm_size);
+ MAP_OR_FAIL(PMPI_Scan);
+ MAP_OR_FAIL(PMPI_Type_commit);
+ MAP_OR_FAIL(PMPI_Type_contiguous);
+ MAP_OR_FAIL(PMPI_Type_extent);
+ MAP_OR_FAIL(PMPI_Type_free);
+ MAP_OR_FAIL(PMPI_Type_hindexed);
+ MAP_OR_FAIL(PMPI_Type_get_envelope);
+ MAP_OR_FAIL(PMPI_Type_size);
+ MAP_OR_FAIL(PMPI_Op_create);
+ MAP_OR_FAIL(PMPI_Op_free);
+ MAP_OR_FAIL(PMPI_Reduce);
+ MAP_OR_FAIL(PMPI_Send);
+ MAP_OR_FAIL(PMPI_Recv);
+ return;
+#endif
+int MPI_Init(int *argc, char ***argv)
+ int ret;
+ resolve_mpi_symbols();
+#endif
+ ret = DARSHAN_MPI_CALL(PMPI_Init)(argc, argv);
+ if(ret != MPI_SUCCESS)
+ return(ret);
+ if(argc && argv)
+ darshan_core_initialize(*argc, *argv);
+ else
+ /* we don't see argc and argv here in fortran */
+ darshan_core_initialize(0, NULL);
+ return(ret);
+int MPI_Init_thread(int *argc, char ***argv, int required, int *provided)
+ int ret;
+#endif
+ ret = DARSHAN_MPI_CALL(PMPI_Init_thread)(argc, argv, required, provided);
+ return(ret);
+ if(argc && argv)
+ else
+ return(ret);
+int MPI_Finalize(void)
+ int ret;
+ darshan_core_shutdown();
+ ret = DARSHAN_MPI_CALL(PMPI_Finalize)();
+ return(ret);
+ * Local variables:
+ * c-indent-level: 4
+ * c-basic-offset: 4
+ * End:
+ * vim: ts=8 sts=4 sw=4 expandtab
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index b37e341..6ce6831 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -26,7 +26,9 @@
#include <assert.h>
#include "uthash.h"
+#include "darshan-dynamic.h"
extern char* __progname;
extern char* __progname_full;
@@ -70,12 +72,6 @@ static struct mnt_data mnt_data_array[DARSHAN_MAX_MNTS];
static int mnt_data_count = 0;
/* prototypes for internal helper functions */
-static void darshan_core_initialize(
- int argc, char **argv);
-static void darshan_core_shutdown(
- void);
-static void darshan_core_cleanup(
- struct darshan_core_runtime* core);
static void darshan_get_logfile_name(
char* logfile_name, int jobid, struct tm* start_tm);
static void darshan_log_record_hints_and_ver(
@@ -100,67 +96,12 @@ static int darshan_log_write_record_hash(
static int darshan_log_append_all(
MPI_File log_fh, struct darshan_core_runtime *core, void *buf,
int count, uint64_t *inout_off, uint64_t *agg_uncomp_sz);
-/* intercept MPI initialize and finalize to manage darshan core runtime */
-int MPI_Init(int *argc, char ***argv)
- int ret;
- ret = DARSHAN_MPI_CALL(PMPI_Init)(argc, argv);
- if(ret != MPI_SUCCESS)
- return(ret);
- if(argc && argv)
- darshan_core_initialize(*argc, *argv);
- else
- /* we don't see argc and argv here in fortran */
- darshan_core_initialize(0, NULL);
- return(ret);
-int MPI_Init_thread(int *argc, char ***argv, int required, int *provided)
- int ret;
- ret = DARSHAN_MPI_CALL(PMPI_Init_thread)(argc, argv, required, provided);
- return(ret);
- if(argc && argv)
- else
- return(ret);
-int MPI_Finalize(void)
- int ret;
- darshan_core_shutdown();
- ret = DARSHAN_MPI_CALL(PMPI_Finalize)();
- return(ret);
+static void darshan_core_cleanup(
+ struct darshan_core_runtime* core);
-static void darshan_core_initialize(int argc, char **argv)
int i;
int internal_timing_flag = 0;
@@ -270,7 +211,7 @@ static void darshan_core_initialize(int argc, char **argv)
return;
-static void darshan_core_shutdown()
+void darshan_core_shutdown()
int i;
char *logfile_name;
@@ -769,33 +710,7 @@ static void darshan_core_shutdown()
return;
-/* free darshan core data structures to shutdown */
-static void darshan_core_cleanup(struct darshan_core_runtime* core)
- struct darshan_core_record_ref *tmp, *ref;
- int i;
- HASH_ITER(hlink, core->rec_hash, ref, tmp)
- HASH_DELETE(hlink, core->rec_hash, ref);
- free(ref->rec.name);
- free(ref);
- for(i = 0; i < DARSHAN_MAX_MODS; i++)
- if(core->mod_array[i])
- free(core->mod_array[i]);
- core->mod_array[i] = NULL;
- free(core->trailing_data);
- free(core);
- return;
/* construct the darshan log file name */
static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* start_tm)
@@ -1564,6 +1479,34 @@ static int darshan_log_append_all(MPI_File log_fh, struct darshan_core_runtime *
return(0);
+/* free darshan core data structures to shutdown */
+static void darshan_core_cleanup(struct darshan_core_runtime* core)
+ struct darshan_core_record_ref *tmp, *ref;
+ int i;
+ HASH_ITER(hlink, core->rec_hash, ref, tmp)
+ HASH_DELETE(hlink, core->rec_hash, ref);
+ free(ref->rec.name);
+ free(ref);
+ for(i = 0; i < DARSHAN_MAX_MODS; i++)
+ if(core->mod_array[i])
+ free(core->mod_array[i]);
+ core->mod_array[i] = NULL;
+ free(core->trailing_data);
+ free(core);
+ return;
void darshan_core_register_module(
diff --git a/darshan-runtime/lib/darshan-mpiio.c b/darshan-runtime/lib/darshan-mpiio.c
index 94d2c5a..e467697 100644
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -27,6 +27,7 @@
#include "uthash.h"
#include "darshan-mpiio-log-format.h"
/* The mpiio_file_runtime structure maintains necessary runtime metadata
* for the MPIIO file record (darshan_mpiio_file structure, defined in
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 42053ac..2a97aff 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -35,6 +35,10 @@ typedef int64_t off64_t;
#define aiocb64 aiocb
#endif
+extern double (*__real_PMPI_Comm_rank)(MPI_Comm comm, int *rank);
+#endif
/* TODO: more libc, fgetc, etc etc etc. */
DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...));
@@ -215,7 +219,7 @@ static int darshan_mem_alignment = 1;
} while(0)
#define POSIX_RECORD_READ(__ret, __fd, __pread_flag, __pread_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
- size_t stride; \
+ /* size_t stride; */\
int64_t this_offset; \
struct posix_file_runtime* file; \
int64_t file_alignment; \
@@ -231,11 +235,11 @@ static int darshan_mem_alignment = 1;
DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_READS, 1); \
if(this_offset == (file->last_byte_read + 1)) \
DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_READS, 1); \
- if(this_offset > 0 && this_offset > file->last_byte_read \
+ /* if(this_offset > 0 && this_offset > file->last_byte_read \
&& file->last_byte_read != 0) \
stride = this_offset - file->last_byte_read - 1; \
else \
- stride = 0; \
+ stride = 0; */\
file->last_byte_read = this_offset + __ret - 1; \
file->offset = this_offset + __ret; \
DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_READ, (this_offset + __ret - 1)); \
@@ -265,7 +269,7 @@ static int darshan_mem_alignment = 1;
} while(0)
#define POSIX_RECORD_WRITE(__ret, __fd, __pwrite_flag, __pwrite_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
- size_t stride; \
@@ -281,11 +285,11 @@ static int darshan_mem_alignment = 1;
DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_WRITES, 1); \
if(this_offset == (file->last_byte_written + 1)) \
DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_WRITES, 1); \
- if(this_offset > 0 && this_offset > file->last_byte_written \
+ /* if(this_offset > 0 && this_offset > file->last_byte_written \
&& file->last_byte_written != 0) \
stride = this_offset - file->last_byte_written - 1; \
else \
- stride = 0; \
+ stride = 0; */\
file->last_byte_written = this_offset + __ret - 1; \
DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_WRITTEN, (this_offset + __ret - 1)); \
@@ -579,7 +583,7 @@ ssize_t DARSHAN_DECL(read)(int fd, void *buf, size_t count)
int aligned_flag = 0;
double tm1, tm2;
- MAP_OR_FAIL(write);
+ MAP_OR_FAIL(read);
if((unsigned long)buf % darshan_mem_alignment == 0) aligned_flag = 1;
hooks/post-receive
More information about the Darshan-commits
