[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-86-g90c39ea
Service Account git at mcs.anl.gov
Thu Apr 2 12:32:29 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  90c39ea6cdd1abebd83fe7916a8434c151e82a9e (commit)
      from  9ac0bd93aef0907e40850308c6467498f155cd03 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 90c39ea6cdd1abebd83fe7916a8434c151e82a9e
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Thu Apr 2 12:32:03 2015 -0500
    support for poisx mem and file alignment counters
Summary of changes:
 darshan-posix-log-format.h          |   10 ++---
 darshan-runtime/darshan.h           |    3 +-
 darshan-runtime/lib/darshan-core.c  |   60 ++++++++++++++++++++++---
 darshan-runtime/lib/darshan-mpiio.c |    6 ++-
 darshan-runtime/lib/darshan-posix.c |   84 ++++++++++++++++++++---------------
 darshan-util/darshan-posix-parser.c |   12 +++--
 6 files changed, 120 insertions(+), 55 deletions(-)
Diff of changes:
diff --git a/darshan-posix-log-format.h b/darshan-posix-log-format.h
index df8cf7a..68f2ecf 100644
--- a/darshan-posix-log-format.h
+++ b/darshan-posix-log-format.h
@@ -33,12 +33,10 @@ enum darshan_posix_indices
     POSIX_SEQ_READS,          /* count of sequential reads */
     POSIX_SEQ_WRITES,         /* count of sequential writes */
     POSIX_RW_SWITCHES,        /* number of times switched between read and write */
-#if 0
-    MEM_NOT_ALIGNED,          /* count of accesses not mem aligned */
-    MEM_ALIGNMENT,            /* mem alignment in bytes */
-    FILE_NOT_ALIGNED,         /* count of accesses not file aligned */
-    FILE_ALIGNMENT,           /* file alignment in bytes */
-#endif
+    POSIX_MEM_NOT_ALIGNED,    /* count of accesses not mem aligned */
+    POSIX_MEM_ALIGNMENT,      /* mem alignment in bytes */
+    POSIX_FILE_NOT_ALIGNED,   /* count of accesses not file aligned */
+    POSIX_FILE_ALIGNMENT,     /* file alignment in bytes */
     POSIX_MAX_READ_TIME_SIZE,
     POSIX_MAX_WRITE_TIME_SIZE,
 #if 0
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index d9ea161..20829be 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -152,7 +152,8 @@ void darshan_core_register_record(
     int len,
     int printable_flag,
     darshan_module_id mod_id,
-    darshan_record_id *rec_id);
+    darshan_record_id *rec_id,
+    int *file_alignment);
 void darshan_core_unregister_record(
     darshan_record_id rec_id,
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 2d074af..b37e341 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -62,7 +62,7 @@ NULL
 #define DARSHAN_MAX_MNT_TYPE 32
 struct mnt_data
-    int64_t block_size;
+    int block_size;
     char path[DARSHAN_MAX_MNT_PATH];
     char type[DARSHAN_MAX_MNT_TYPE];
@@ -85,6 +85,8 @@ static void darshan_get_exe_and_mounts_root(
     int space_left);
 static char* darshan_get_exe_and_mounts(
     struct darshan_core_runtime *core);
+static void darshan_block_size_from_path(
+    const char *path, int *block_size);
 static void darshan_get_shared_records(
     struct darshan_core_runtime *core, darshan_record_id *shared_recs);
 static int darshan_log_open_all(
@@ -163,9 +165,12 @@ static void darshan_core_initialize(int argc, char **argv)
     int i;
     int internal_timing_flag = 0;
     double init_start, init_time, init_max;
+    char *envstr;
     char* truncate_string = "<TRUNCATED>";
     int truncate_offset;
     int chars_left = 0;
+    int ret;
+    int tmpval;
     DARSHAN_MPI_CALL(PMPI_Comm_size)(MPI_COMM_WORLD, &nprocs);
     DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank);
@@ -179,7 +184,29 @@ static void darshan_core_initialize(int argc, char **argv)
     /* setup darshan runtime if darshan is enabled and hasn't been initialized already */
     if(!getenv("DARSHAN_DISABLE") && !darshan_core)
-        /* TODO: darshan mem alignment code? */
+        #if (__CP_MEM_ALIGNMENT < 1)
+            #error Darshan must be configured with a positive value for --with-mem-align
+        #endif
+        envstr = getenv("DARSHAN_MEMALIGN");
+        if(envstr)
+            ret = sscanf(envstr, "%d", &tmpval);
+            /* silently ignore if the env variable is set poorly */
+            if(ret == 1 && tmpval > 0)
+                darshan_mem_alignment = tmpval;
+        else
+            darshan_mem_alignment = __CP_MEM_ALIGNMENT;
+        /* avoid floating point errors on faulty input */
+        if (darshan_mem_alignment < 1)
+            darshan_mem_alignment = 1;
         /* allocate structure to track darshan_core_runtime information */
         darshan_core = malloc(sizeof(*darshan_core));
@@ -1147,6 +1174,23 @@ static char* darshan_get_exe_and_mounts(struct darshan_core_runtime *core)
     return(trailing_data);
+static void darshan_block_size_from_path(const char *path, int *block_size)
+    int i;
+    *block_size = -1;
+    for(i=0; i<mnt_data_count; i++)
+        if(!(strncmp(mnt_data_array[i].path, path, strlen(mnt_data_array[i].path))))
+            *block_size = mnt_data_array[i].block_size;
+            return;
+    return;
 static void darshan_get_shared_records(struct darshan_core_runtime *core,
@@ -1534,6 +1578,9 @@ void darshan_core_register_module(
     if(!darshan_core || (mod_id >= DARSHAN_MAX_MODS))
         return;
+    if(sys_mem_alignment)
+        *sys_mem_alignment = darshan_mem_alignment;
     /* see if this module is already registered */
     DARSHAN_CORE_LOCK();
     if(darshan_core->mod_array[mod_id])
@@ -1561,9 +1608,6 @@ void darshan_core_register_module(
     /* TODO: something smarter than just 2 MiB per module */
     *mod_mem_limit = 2 * 1024 * 1024;
-    if(sys_mem_alignment)
-        *sys_mem_alignment = darshan_mem_alignment;
     DARSHAN_CORE_UNLOCK();
     return;
@@ -1599,7 +1643,8 @@ void darshan_core_register_record(
     int len,
     int printable_flag,
     darshan_record_id tmp_rec_id;
     struct darshan_core_record_ref *ref;
@@ -1642,6 +1687,9 @@ void darshan_core_register_record(
     ref->mod_flags = DARSHAN_CORE_MOD_SET(ref->mod_flags, mod_id);
+    if(file_alignment)
+        darshan_block_size_from_path(name, file_alignment);
     *rec_id = tmp_rec_id;
     return;
diff --git a/darshan-runtime/lib/darshan-mpiio.c b/darshan-runtime/lib/darshan-mpiio.c
index 8f33800..94d2c5a 100644
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -309,7 +309,8 @@ static struct mpiio_file_runtime* mpiio_file_by_name(const char *name)
         strlen(newname),
         1,
         DARSHAN_MPIIO_MOD,
-        &file_id);
+        &file_id,
+        NULL);
     /* search the hash table for this file record, and return if found */
     HASH_FIND(hlink, mpiio_runtime->file_hash, &file_id, sizeof(darshan_record_id), file);
@@ -635,7 +636,8 @@ static struct posix_runtime_file* posix_file_by_name(const char *name)
         strlen(newname),
         1,
         DARSHAN_POSIX_MOD,
-        &file_id);
+        &file_id,
+        NULL);
     HASH_FIND(hlink, posix_runtime->file_hash, &file_id, sizeof(darshan_record_id), file);
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 3c77887..42053ac 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -215,10 +215,10 @@ static int darshan_mem_alignment = 1;
 } while(0)
 #define POSIX_RECORD_READ(__ret, __fd, __pread_flag, __pread_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
-    /* size_t stride; */\
+    size_t stride; \
     int64_t this_offset; \
     struct posix_file_runtime* file; \
-    /* int64_t file_alignment; */ \
+    int64_t file_alignment; \
     double __elapsed = __tm2-__tm1; \
     if(__ret < 0) break; \
     file = posix_file_by_fd(__fd); \
@@ -227,16 +227,15 @@ static int darshan_mem_alignment = 1;
         this_offset = __pread_offset; \
     else \
         this_offset = file->offset; \
-    /* file_alignment = CP_VALUE(file, CP_FILE_ALIGNMENT); */\
     if(this_offset > file->last_byte_read) \
         DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_READS, 1); \
     if(this_offset == (file->last_byte_read + 1)) \
         DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_READS, 1); \
-    /* if(this_offset > 0 && this_offset > file->last_byte_read \
+    if(this_offset > 0 && this_offset > file->last_byte_read \
         && file->last_byte_read != 0) \
         stride = this_offset - file->last_byte_read - 1; \
     else \
-        stride = 0; */\
+        stride = 0; \
     file->last_byte_read = this_offset + __ret - 1; \
     file->offset = this_offset + __ret; \
     DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_READ, (this_offset + __ret - 1)); \
@@ -246,12 +245,13 @@ static int darshan_mem_alignment = 1;
     else\
         DARSHAN_COUNTER_INC(file->file_record, POSIX_READS, 1); \
     /* CP_BUCKET_INC(file, CP_SIZE_READ_0_100, __ret); \
-    cp_access_counter(file, stride, CP_COUNTER_STRIDE); \
+    cp_access_counter(file, __ret, CP_COUNTER_ACCESS); \
+    cp_access_counter(file, stride, CP_COUNTER_STRIDE); */\
     if(!__aligned) \
-        CP_INC(file, CP_MEM_NOT_ALIGNED, 1); \
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_MEM_NOT_ALIGNED, 1); \
+    file_alignment = DARSHAN_COUNTER_VALUE(file->file_record, POSIX_FILE_ALIGNMENT); \
     if(file_alignment > 0 && (this_offset % file_alignment) != 0) \
-        CP_INC(file, CP_FILE_NOT_ALIGNED, 1); \
-    cp_access_counter(file, __ret, CP_COUNTER_ACCESS); */\
+        DARSHAN_COUNTER_INC(file->file_record, POSIX_FILE_NOT_ALIGNED, 1); \
     if(file->last_io_type == POSIX_WRITE) \
         DARSHAN_COUNTER_INC(file->file_record, POSIX_RW_SWITCHES, 1); \
     file->last_io_type = POSIX_READ; \
@@ -265,10 +265,10 @@ static int darshan_mem_alignment = 1;
 } while(0)
 #define POSIX_RECORD_WRITE(__ret, __fd, __pwrite_flag, __pwrite_offset, __aligned, __stream_flag, __tm1, __tm2) do{ \
+    size_t stride; \
@@ -277,16 +277,15 @@ static int darshan_mem_alignment = 1;
         this_offset = __pwrite_offset; \
     else \
     if(this_offset > file->last_byte_written) \
         DARSHAN_COUNTER_INC(file->file_record, POSIX_SEQ_WRITES, 1); \
     if(this_offset == (file->last_byte_written + 1)) \
         DARSHAN_COUNTER_INC(file->file_record, POSIX_CONSEC_WRITES, 1); \
-    /* if(this_offset > 0 && this_offset > file->last_byte_written \
+    if(this_offset > 0 && this_offset > file->last_byte_written \
         && file->last_byte_written != 0) \
         stride = this_offset - file->last_byte_written - 1; \
     else \
-        stride = 0; */\
+        stride = 0; \
     file->last_byte_written = this_offset + __ret - 1; \
     DARSHAN_COUNTER_MAX(file->file_record, POSIX_MAX_BYTE_WRITTEN, (this_offset + __ret - 1)); \
@@ -296,12 +295,13 @@ static int darshan_mem_alignment = 1;
     else \
         DARSHAN_COUNTER_INC(file->file_record, POSIX_WRITES, 1); \
     /* CP_BUCKET_INC(file, CP_SIZE_WRITE_0_100, __ret); \
+    cp_access_counter(file, stride, CP_COUNTER_STRIDE); */ \
     if(!__aligned) \
     if(file->last_io_type == POSIX_READ) \
     file->last_io_type = POSIX_WRITE; \
@@ -581,7 +581,7 @@ ssize_t DARSHAN_DECL(read)(int fd, void *buf, size_t count)
     MAP_OR_FAIL(write);
-    /* if((unsigned long)buf % darshan_mem_alignment == 0) aligned_flag = 1; */
+    if((unsigned long)buf % darshan_mem_alignment == 0) aligned_flag = 1;
     tm1 = darshan_core_wtime();
     ret = __real_read(fd, buf, count);
@@ -603,7 +603,7 @@ ssize_t DARSHAN_DECL(write)(int fd, const void *buf, size_t count)
     MAP_OR_FAIL(write);
     ret = __real_write(fd, buf, count);
@@ -625,7 +625,7 @@ ssize_t DARSHAN_DECL(pread)(int fd, void *buf, size_t count, off_t offset)
     MAP_OR_FAIL(pread);
     ret = __real_pread(fd, buf, count, offset);
@@ -647,7 +647,7 @@ ssize_t DARSHAN_DECL(pwrite)(int fd, const void *buf, size_t count, off_t offset
     MAP_OR_FAIL(pwrite);
     ret = __real_pwrite(fd, buf, count, offset);
@@ -669,7 +669,7 @@ ssize_t DARSHAN_DECL(pread64)(int fd, void *buf, size_t count, off64_t offset)
     MAP_OR_FAIL(pread64);
     ret = __real_pread64(fd, buf, count, offset);
@@ -691,7 +691,7 @@ ssize_t DARSHAN_DECL(pwrite64)(int fd, const void *buf, size_t count, off64_t of
     MAP_OR_FAIL(pwrite64);
     ret = __real_pwrite64(fd, buf, count, offset);
@@ -708,18 +708,17 @@ ssize_t DARSHAN_DECL(pwrite64)(int fd, const void *buf, size_t count, off64_t of
 ssize_t DARSHAN_DECL(readv)(int fd, const struct iovec *iov, int iovcnt)
     ssize_t ret;
-    int aligned_flag = 0;
-    /* int aligned_flag = 1; */
+    int aligned_flag = 1;
     int i;
     double tm1, tm2;
     MAP_OR_FAIL(readv);
     for(i=0; i<iovcnt; i++)
         if(((unsigned long)iov[i].iov_base % darshan_mem_alignment) != 0)
             aligned_flag = 0;
     ret = __real_readv(fd, iov, iovcnt);
@@ -736,18 +735,17 @@ ssize_t DARSHAN_DECL(readv)(int fd, const struct iovec *iov, int iovcnt)
 ssize_t DARSHAN_DECL(writev)(int fd, const struct iovec *iov, int iovcnt)
     ssize_t ret;
     int i;
     double tm1, tm2;
     MAP_OR_FAIL(writev);
             aligned_flag = 0;
     ret = __real_writev(fd, iov, iovcnt);
@@ -769,7 +767,7 @@ size_t DARSHAN_DECL(fread)(void *ptr, size_t size, size_t nmemb, FILE *stream)
     MAP_OR_FAIL(fread);
-    /* if((unsigned long)ptr % darshan_mem_alignment == 0) aligned_flag = 1; */
+    if((unsigned long)ptr % darshan_mem_alignment == 0) aligned_flag = 1;
     ret = __real_fread(ptr, size, nmemb, stream);
@@ -800,7 +798,7 @@ size_t DARSHAN_DECL(fwrite)(const void *ptr, size_t size, size_t nmemb, FILE *st
     MAP_OR_FAIL(fwrite);
     ret = __real_fwrite(ptr, size, nmemb, stream);
@@ -1292,6 +1290,7 @@ static struct posix_file_runtime* posix_file_by_name(const char *name)
     struct posix_file_runtime *file = NULL;
     char *newname = NULL;
     darshan_record_id file_id;
+    int file_alignment;
     if(!posix_runtime || instrumentation_disabled)
         return(NULL);
@@ -1306,7 +1305,8 @@ static struct posix_file_runtime* posix_file_by_name(const char *name)
         strlen(newname),
         1,
         DARSHAN_POSIX_MOD,
-        &file_id);
+        &file_id,
+        &file_alignment);
@@ -1323,6 +1323,8 @@ static struct posix_file_runtime* posix_file_by_name(const char *name)
         file = &(posix_runtime->file_runtime_array[posix_runtime->file_array_ndx]);
         file->file_record = &(posix_runtime->file_record_array[posix_runtime->file_array_ndx]);
         file->file_record->f_id = file_id;
+        DARSHAN_COUNTER_SET(file->file_record, POSIX_MEM_ALIGNMENT, darshan_mem_alignment);
+        DARSHAN_COUNTER_SET(file->file_record, POSIX_FILE_ALIGNMENT, file_alignment);
         /* add new record to file hash table */
         HASH_ADD(hlink, posix_runtime->file_hash, file_record->f_id, sizeof(darshan_record_id), file);
@@ -1565,7 +1567,17 @@ static void posix_record_reduction_op(
         /* sum */
-        for(j=POSIX_CONSEC_READS; j<=POSIX_RW_SWITCHES; j++)
+        for(j=POSIX_CONSEC_READS; j<=POSIX_MEM_NOT_ALIGNED; j++)
+            tmp_file.counters[j] = infile->counters[j] +
+                inoutfile->counters[j];
+        tmp_file.counters[POSIX_MEM_ALIGNMENT] = infile->counters[POSIX_MEM_ALIGNMENT];
+        tmp_file.counters[POSIX_FILE_ALIGNMENT] = infile->counters[POSIX_FILE_ALIGNMENT];
+        /* sum */
+        for(j=POSIX_FILE_NOT_ALIGNED; j<=POSIX_FILE_NOT_ALIGNED; j++)
diff --git a/darshan-util/darshan-posix-parser.c b/darshan-util/darshan-posix-parser.c
index 1a16ec0..1a9638c 100644
--- a/darshan-util/darshan-posix-parser.c
+++ b/darshan-util/darshan-posix-parser.c
@@ -192,10 +192,12 @@ int main(int argc, char **argv)
             "\t\tPOSIX_SEQ_READS:\t%"PRIu64"\n"
             "\t\tPOSIX_SEQ_WRITES:\t%"PRIu64"\n"
             "\t\tPOSIX_RW_SWITCHES:\t%"PRIu64"\n"
-            "\t\tFILE_ALIGNMENT:\t%"PRIu64"\n"
+            "\t\tPOSIX_MEM_NOT_ALIGNED:\t%"PRIu64"\n"
+            "\t\tPOSIX_MEM_ALIGNMENT:\t%"PRIu64"\n"
+            "\t\tPOSIX_FILE_NOT_ALIGNED:\t%"PRIu64"\n"
+            "\t\tPOSIX_FILE_ALIGNMENT:\t%"PRIu64"\n"
             "\t\tPOSIX_MAX_READ_TIME_SIZE:\t%"PRIu64"\n"
             "\t\tPOSIX_MAX_WRITE_TIME_SIZE:\t%"PRIu64"\n"
-            "\t\tSIZE_AT_OPEN:\t%"PRIu64"\n"
             "\t\tPOSIX_FASTEST_RANK:\t%"PRIu64"\n"
             "\t\tPOSIX_FASTEST_RANK_BYTES:\t%"PRIu64"\n"
             "\t\tPOSIX_SLOWEST_RANK:\t%"PRIu64"\n"
@@ -235,10 +237,12 @@ int main(int argc, char **argv)
             next_file.counters[POSIX_SEQ_READS],
             next_file.counters[POSIX_SEQ_WRITES],
             next_file.counters[POSIX_RW_SWITCHES],
-            next_file.counters[FILE_ALIGNMENT],
+            next_file.counters[POSIX_MEM_NOT_ALIGNED],
+            next_file.counters[POSIX_MEM_ALIGNMENT],
+            next_file.counters[POSIX_FILE_NOT_ALIGNED],
+            next_file.counters[POSIX_FILE_ALIGNMENT],
             next_file.counters[POSIX_MAX_READ_TIME_SIZE],
             next_file.counters[POSIX_MAX_WRITE_TIME_SIZE],
-            next_file.counters[SIZE_AT_OPEN],
             next_file.counters[POSIX_FASTEST_RANK],
             next_file.counters[POSIX_FASTEST_RANK_BYTES],
             next_file.counters[POSIX_SLOWEST_RANK],
hooks/post-receive
More information about the Darshan-commits mailing list
