[Darshan-commits] [Darshan] branch, dev-modular, updated. da477e427153126228171de95ea8d9a3a78e0a1a
Service Account
git at mcs.anl.gov
Thu Nov 20 15:49:04 CST 2014
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
via da477e427153126228171de95ea8d9a3a78e0a1a (commit)
from 7496c279aeb8003a655ee581145ecec6b4d18ddc (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit da477e427153126228171de95ea8d9a3a78e0a1a
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date: Thu Nov 20 15:41:50 2014 -0600
Complete (first) implementation for darshan
-darshan-core:
- initializes darshan job data structures
- creates log file
- writes job info header
- reduces which modules were used locally/globally
- shut down and write out individual modules one by one
-darshan-posix:
- register w/ darshan-core and allocate allowed memory
- track open counter and timestamp for opened files
- provide file record buffer at shutdown
Major TODOs:
- shared file reductions (prefer reusable across modules)
- register handles with darshan file_ids (prefer reusable)
- generic compression of module buffers (zlib/bzip2)
- write out map of filenames to darshan ids
- modify darshan-util and add darshan-posix parser to read logs
Summary of changes:
darshan-modularization-design-notes.txt | 2 +
darshan-runtime/darshan-core.h | 15 +--
darshan-runtime/darshan.h | 8 +-
darshan-runtime/lib/darshan-core.c | 310 +++++++++++++++++++++++++++++--
darshan-runtime/lib/darshan-posix.c | 88 ++++++---
5 files changed, 365 insertions(+), 58 deletions(-)
Diff of changes:
diff --git a/darshan-modularization-design-notes.txt b/darshan-modularization-design-notes.txt
index 5b559ed..ef3f74e 100644
--- a/darshan-modularization-design-notes.txt
+++ b/darshan-modularization-design-notes.txt
@@ -121,3 +121,5 @@ TODO NOTES:
- would the posix module be the only one to leverage this info?
- it is used to correlate filenames with mount points, but not sure what is needed where
- test fortran and c apps to make sure command line args are handled properly (see email with Phil 11/4)
+ - how do we abstract shared file reduction so each module doesn't completely reimplement?
+ - when is DARSHAN_MPI_CALL macro needed? All MPI functions, or just those intercepted by darshan?
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index 3729101..ec853c0 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -12,18 +12,6 @@
#include "darshan.h"
-/* calculation of compression buffer size (defaults to 50% of the maximum
- * memory that Darshan is allowed to consume on a process)
-//#define CP_COMP_BUF_SIZE ((CP_MAX_FILES * sizeof(struct darshan_file))/2)
-#define CP_COMP_BUF_SIZE 0
-/* max length of module name string (not counting \0) */
-#define DARSHAN_MOD_NAME_LEN 31
-/* flags to indicate properties of file records */
-#define CP_FLAG_NOTIMING 1<<1
struct darshan_core_module
darshan_module_id id;
@@ -32,13 +20,12 @@ struct darshan_core_module
/* in memory structure to keep up with job level data */
+/* TODO: trailing data ? */
struct darshan_core_job_runtime
struct darshan_job log_job;
struct darshan_core_module* mod_array[DARSHAN_MAX_MODS];
char exe[CP_EXE_LEN+1];
- char comp_buf[CP_COMP_BUF_SIZE];
- int flags;
double wtime_offset;
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index 698616c..ee3ead6 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -48,8 +48,12 @@ typedef uint64_t darshan_file_id;
struct darshan_module_funcs
- void (*prepare_for_shutdown)(void);
- void (*get_output_data)(void **, int);
+ void (*get_output_data)(
+ MPI_Comm mod_comm, /* communicator to use for module shutdown */
+ void** buf, /* output parameter to save module buffer address */
+ int* size /* output parameter to save module buffer size */
+ void (*shutdown)(void);
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 4076202..27df73a 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -30,11 +30,13 @@ extern char* __progname;
static struct darshan_core_job_runtime *darshan_core_job = NULL;
static pthread_mutex_t darshan_mutex = PTHREAD_MUTEX_INITIALIZER;
static int my_rank = -1;
+static int nprocs = -1;
static void darshan_core_initialize(int *argc, char ***argv);
static void darshan_core_shutdown(void);
static void darshan_core_cleanup(struct darshan_core_job_runtime* job);
static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* start_tm);
+static void darshan_log_record_hints_and_ver(struct darshan_core_job_runtime* job);
#define DARSHAN_LOCK() pthread_mutex_lock(&darshan_mutex)
#define DARSHAN_UNLOCK() pthread_mutex_unlock(&darshan_mutex)
@@ -85,7 +87,6 @@ int MPI_Finalize(void)
int i;
- int nprocs;
int internal_timing_flag = 0;
double init_start, init_time, init_max;
char* truncate_string = "<TRUNCATED>";
@@ -110,11 +111,6 @@ static void darshan_core_initialize(int *argc, char ***argv)
memset(darshan_core_job, 0, sizeof(*darshan_core_job));
- if(getenv("DARSHAN_DISABLE_TIMING"))
- darshan_core_job->flags |= CP_FLAG_NOTIMING;
strcpy(darshan_core_job->log_job.version_string, CP_VERSION);
darshan_core_job->log_job.magic_nr = CP_MAGIC_NR;
darshan_core_job->log_job.uid = getuid();
@@ -181,12 +177,27 @@ static void darshan_core_shutdown()
int jobid;
struct tm* start_tm;
time_t start_time_tmp;
- int ret;
+ int ret = 0;
+ int all_ret = 0;
int64_t first_start_time;
int64_t last_end_time;
int local_mod_use[DARSHAN_MAX_MODS] = {0};
int global_mod_use_count[DARSHAN_MAX_MODS] = {0};
int i;
+ char* key;
+ char* value;
+ char* hints;
+ char* tok_str;
+ char* orig_tok_str;
+ char* saveptr = NULL;
+ char* mod_index;
+ char* new_logfile_name;
+ double start_log_time;
+ double end_log_time;
+ long offset;
+ MPI_File log_fh;
+ MPI_Info info;
+ MPI_Status status;
if(getenv("DARSHAN_INTERNAL_TIMING"))
internal_timing_flag = 1;
@@ -204,6 +215,8 @@ static void darshan_core_shutdown()
DARSHAN_UNLOCK();
+ start_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
logfile_name = malloc(PATH_MAX);
if(!logfile_name)
@@ -211,7 +224,7 @@ static void darshan_core_shutdown()
return;
- /* set jobid and logfile name on rank 0 */
+ /* set darshan job id/metadata and constuct log file name on rank 0 */
if(my_rank == 0)
/* Use CP_JOBID_OVERRIDE for the env var or CP_JOBID */
@@ -233,9 +246,13 @@ static void darshan_core_shutdown()
jobid = getpid();
- /* add to darshan core job */
final_job->log_job.jobid = (int64_t)jobid;
+ /* if we are using any hints to write the log file, then record those
+ * hints in the log file header
+ darshan_log_record_hints_and_ver(final_job);
/* use human readable start time format in log filename */
start_time_tmp = final_job->log_job.start_time;
start_tm = localtime(&start_time_tmp);
@@ -251,6 +268,7 @@ static void darshan_core_shutdown()
if(strlen(logfile_name) == 0)
/* failed to generate log file name */
+ free(logfile_name);
darshan_core_cleanup(final_job);
return;
@@ -278,9 +296,224 @@ static void darshan_core_shutdown()
/* reduce the number of times a module was opened globally and bcast to everyone */
DARSHAN_MPI_CALL(PMPI_Allreduce)(local_mod_use, global_mod_use_count, DARSHAN_MAX_MODS, MPI_INT, MPI_SUM, MPI_COMM_WORLD);
+ MPI_Info_create(&info);
+ /* check environment variable to see if the default MPI file hints have
+ * been overridden
+ hints = getenv(CP_LOG_HINTS_OVERRIDE);
+ if(!hints)
+ hints = __CP_LOG_HINTS;
+ if(hints && strlen(hints) > 0)
+ tok_str = strdup(hints);
+ if(tok_str)
+ orig_tok_str = tok_str;
+ do
+ /* split string on semicolon */
+ key = strtok_r(tok_str, ";", &saveptr);
+ if(key)
+ tok_str = NULL;
+ /* look for = sign splitting key/value pairs */
+ value = index(key, '=');
+ if(value)
+ /* break key and value into separate null terminated strings */
+ value[0] = '\0';
+ value++;
+ if(strlen(key) > 0)
+ MPI_Info_set(info, key, value);
+ }while(key != NULL);
+ free(orig_tok_str);
+ /* open the darshan log file for writing */
+ ret = DARSHAN_MPI_CALL(PMPI_File_open)(MPI_COMM_WORLD, logfile_name,
+ MPI_MODE_CREATE | MPI_MODE_WRONLY | MPI_MODE_EXCL, info, &log_fh);
+ MPI_Info_free(&info);
+ /* error out if unable to open log file */
+ DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
+ MPI_LOR, MPI_COMM_WORLD);
+ if(all_ret != 0)
+ if(my_rank == 0)
+ int msg_len;
+ char msg[MPI_MAX_ERROR_STRING] = {0};
+ MPI_Error_string(ret, msg, &msg_len);
+ fprintf(stderr, "darshan library warning: unable to open log file %s: %s\n",
+ logfile_name, msg);
+ unlink(logfile_name);
+ darshan_core_cleanup(final_job);
+ return;
+ /* TODO: is there another header, or is job info first data ? */
+ /* TODO: are MPI data types necessary or can we just write buffers of MPI_BYTEs? */
+ /* write the job info on rank 0 */
+ if(my_rank == 0)
+ ret = DARSHAN_MPI_CALL(PMPI_File_write_at)(log_fh, 0, &(final_job->log_job),
+ sizeof(struct darshan_job), MPI_BYTE, &status);
+ if(ret != MPI_SUCCESS)
+ int msg_len;
+ fprintf(stderr, "darshan library warning: unable to write job data to log file %s: %s\n",
+ return;
+ /* TODO: id->file name map write */
+ /* loop over globally used darshan modules and:
+ * - get final output buffer
+ * - compress (zlib/bzip2) provided output buffer
+ * - write compressed buffer to log file
+ * - shutdown the module
for(i = 0; i < DARSHAN_MAX_MODS; i++)
+ struct darshan_core_module* this_mod = final_job->mod_array[i];
+ MPI_Comm mod_comm;
+ void* mod_buf = NULL;
+ int mod_buf_size = 0;
+ void* comp_buf = NULL;
+ long comp_buf_size = 0;
+ long scan_offset = 0;
+ if(!global_mod_use_count[i])
+ continue;
+ /* create a communicator to use for shutting down the module */
+ if(global_mod_use_count[i] == nprocs)
+ MPI_Comm_dup(MPI_COMM_WORLD, &mod_comm);
+ else
+ MPI_Comm_split(MPI_COMM_WORLD, local_mod_use[i], 0, &mod_comm);
+ /* if module is registered locally, get the corresponding output buffer */
+ if(local_mod_use[i])
+ /* get output buffer from module */
+ this_mod->mod_funcs.get_output_data(mod_comm, &mod_buf, &mod_buf_size);
+ if(mod_buf_size > 0)
+ /* TODO generic compression */
+ comp_buf = mod_buf;
+ comp_buf_size = mod_buf_size;
+ /* get current file size on rank 0 so we can calculate offset correctly */
+ scan_offset = comp_buf_size;
+ if(my_rank == 0)
+ MPI_Offset tmp_off;
+ ret = MPI_File_get_size(log_fh, &tmp_off);
+ int msg_len;
+ fprintf(stderr, "darshan library warning: unable to write module data to log file %s: %s\n",
+ DARSHAN_MPI_CALL(PMPI_File_close)(&log_fh);
+ return;
+ scan_offset += tmp_off;
+ /* figure out everyone's offset using scan */
+ DARSHAN_MPI_CALL(PMPI_Scan)(&scan_offset, &offset, 1, MPI_LONG, MPI_SUM, MPI_COMM_WORLD);
+ offset -= comp_buf_size;
+ /* collectively write out each rank's contributing data (maybe nothing) */
+ ret = DARSHAN_MPI_CALL(PMPI_File_write_at_all)(log_fh, offset, comp_buf,
+ comp_buf_size, MPI_BYTE, &status);
+ /* error out if unable to write */
+ if(all_ret != 0)
+ if(my_rank == 0)
+ int msg_len;
+ return;
+ /* shutdown module if registered locally */
+ this_mod->mod_funcs.shutdown();
+ this_mod = NULL;
+ MPI_Comm_free(&mod_comm);
+ /* if we got this far, there are no errors, so rename from *.darshan_partial
+ * to *-<logwritetime>.darshan.gz, which indicates that this log file is
+ * complete and ready for analysis
+ new_logfile_name = malloc(PATH_MAX);
+ if(new_logfile_name)
+ new_logfile_name[0] = '\0';
+ end_log_time = DARSHAN_MPI_CALL(PMPI_Wtime)();
+ strcat(new_logfile_name, logfile_name);
+ mod_index = strstr(new_logfile_name, ".darshan_partial");
+ sprintf(mod_index, "_%d.darshan.gz", (int)(end_log_time-start_log_time+1));
+ rename(logfile_name, new_logfile_name);
+ /* set permissions on log file */
+#ifdef __CP_GROUP_READABLE_LOGS
+ chmod(new_logfile_name, (S_IRUSR|S_IRGRP));
+#else
+ chmod(new_logfile_name, (S_IRUSR));
+#endif
+ free(new_logfile_name);
free(logfile_name);
@@ -294,13 +527,18 @@ static void darshan_core_shutdown()
return;
+/* free darshan core data structures to shutdown */
int i;
+ if(job->mod_array[i])
+ free(job->mod_array[i]);
+ job->mod_array[i] = NULL;
free(job);
@@ -308,6 +546,7 @@ static void darshan_core_cleanup(struct darshan_core_job_runtime* job)
return;
+/* construct the darshan log file name */
char* logpath;
@@ -443,6 +682,52 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
return;
+/* record any hints used to write the darshan log in the log header */
+ char* hints;
+ char* header_hints;
+ int meta_remain = 0;
+ char* m;
+ * been overridden
+ if(!hints)
+ if(!hints || strlen(hints) < 1)
+ return;
+ header_hints = strdup(hints);
+ if(!header_hints)
+ return;
+ meta_remain = DARSHAN_JOB_METADATA_LEN -
+ strlen(job->log_job.metadata) - 1;
+ if(meta_remain >= (strlen(PACKAGE_VERSION) + 9))
+ sprintf(job->log_job.metadata, "lib_ver=%s\n", PACKAGE_VERSION);
+ meta_remain -= (strlen(PACKAGE_VERSION) + 9);
+ if(meta_remain >= (3 + strlen(header_hints)))
+ m = job->log_job.metadata + strlen(job->log_job.metadata);
+ /* We have room to store the hints in the metadata portion of
+ * the job header. We just prepend an h= to the hints list. The
+ * metadata parser will ignore = characters that appear in the value
+ * portion of the metadata key/value pair.
+ sprintf(m, "h=%s\n", header_hints);
+ free(header_hints);
+ return;
void darshan_core_register_module(
@@ -519,13 +804,12 @@ void darshan_core_lookup_id(
double darshan_core_wtime()
- /* TODO since NOTIMING is the only flag (currently), maybe we just drop 'flags' */
- if(!darshan_core_job || darshan_core_job->flags & CP_FLAG_NOTIMING)
+ if(!darshan_core_job)
return(0);
- return DARSHAN_MPI_CALL(PMPI_Wtime)();
+ return(DARSHAN_MPI_CALL(PMPI_Wtime)() - darshan_core_job->wtime_offset);
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index d35c2c2..cbf3fd3 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -167,7 +167,7 @@ struct darshan_posix_file
struct posix_runtime_file
- struct darshan_posix_file file_record;
+ struct darshan_posix_file* file_record;
UT_hash_handle hlink;
@@ -180,9 +180,10 @@ struct posix_runtime_file_ref
- struct posix_runtime_file* file_array;
+ struct posix_runtime_file* file_runtime_array;
+ struct darshan_posix_file* file_record_array;
int file_array_size;
- int file_count;
+ int file_array_ndx;
struct posix_runtime_file* file_hash;
struct posix_runtime_file_ref* fd_hash;
@@ -216,26 +217,26 @@ static struct posix_runtime_file* posix_file_by_name(const char *name);
static struct posix_runtime_file* posix_file_by_name_setfd(const char* name, int fd);
static void posix_file_close_fd(int fd);
-static void posix_prepare_for_shutdown(void);
-static void posix_get_output_data(void **buffer, int size);
+static void posix_get_output_data(MPI_Comm comm, void **buffer, int *size);
+static void posix_shutdown(void);
#define POSIX_LOCK() pthread_mutex_lock(&posix_runtime_mutex)
#define POSIX_UNLOCK() pthread_mutex_unlock(&posix_runtime_mutex)
#define POSIX_SET(__file, __counter, __value) do {\
- (__file)->file_record.counters[__counter] = __value; \
+ (__file)->file_record->counters[__counter] = __value; \
} while(0)
#define POSIX_F_SET(__file, __counter, __value) do {\
- (__file)->file_record.fcounters[__counter] = __value; \
+ (__file)->file_record->fcounters[__counter] = __value; \
} while(0)
#define POSIX_INC(__file, __counter, __value) do {\
- (__file)->file_record.counters[__counter] += __value; \
+ (__file)->file_record->counters[__counter] += __value; \
} while(0)
#define POSIX_F_INC(__file, __counter, __value) do {\
- (__file)->file_record.fcounters[__counter] += __value; \
+ (__file)->file_record->fcounters[__counter] += __value; \
} while(0)
#define POSIX_F_INC_NO_OVERLAP(__file, __tm1, __tm2, __last, __counter) do { \
@@ -248,15 +249,15 @@ static void posix_get_output_data(void **buffer, int size);
} while(0)
#define POSIX_VALUE(__file, __counter) \
- ((__file)->file_record.counters[__counter])
+ ((__file)->file_record->counters[__counter])
#define POSIX_F_VALUE(__file, __counter) \
- ((__file)->file_record.fcounters[__counter])
+ ((__file)->file_record->fcounters[__counter])
#define POSIX_MAX(__file, __counter, __value) do {\
- if((__file)->file_record.counters[__counter] < __value) \
+ if((__file)->file_record->counters[__counter] < __value) \
} while(0)
@@ -273,7 +274,7 @@ static void posix_get_output_data(void **buffer, int size);
if(exclude) break; \
file = posix_file_by_name_setfd(__path, __ret); \
if(!file) break; \
- file->file_record.rank = my_rank; \
+ file->file_record->rank = my_rank; \
if(__mode) \
POSIX_SET(file, CP_MODE, __mode); \
if(__stream_flag)\
@@ -353,8 +354,8 @@ static void posix_runtime_initialize()
int mem_limit;
struct darshan_module_funcs posix_mod_fns =
- .prepare_for_shutdown = &posix_prepare_for_shutdown,
.get_output_data = &posix_get_output_data,
+ .shutdown = &posix_shutdown
if(posix_runtime)
@@ -379,17 +380,22 @@ static void posix_runtime_initialize()
/* set maximum number of file records according to max memory limit */
/* NOTE: maximum number of records is based on the size of a posix file record */
posix_runtime->file_array_size = mem_limit / sizeof(struct darshan_posix_file);
+ posix_runtime->file_array_ndx = 0;
/* allocate array of runtime file records */
- posix_runtime->file_array = malloc(sizeof(struct posix_runtime_file) *
- posix_runtime->file_array_size);
- if(!posix_runtime->file_array)
+ posix_runtime->file_runtime_array = malloc(posix_runtime->file_array_size *
+ sizeof(struct posix_runtime_file));
+ posix_runtime->file_record_array = malloc(posix_runtime->file_array_size *
+ sizeof(struct darshan_posix_file));
+ if(!posix_runtime->file_runtime_array || !posix_runtime->file_record_array)
posix_runtime->file_array_size = 0;
return;
- memset(posix_runtime->file_array, 0, sizeof(struct posix_runtime_file) *
+ memset(posix_runtime->file_runtime_array, 0, posix_runtime->file_array_size *
+ memset(posix_runtime->file_record_array, 0, posix_runtime->file_array_size *
DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank);
@@ -452,14 +458,18 @@ static struct posix_runtime_file* posix_file_by_name(const char *name)
return(file);
- /* no existing record, assign a new file record from the global array */
- file = &posix_runtime->file_array[posix_runtime->file_count];
- file->file_record.f_id = file_id;
+ if(posix_runtime->file_array_ndx < posix_runtime->file_array_size);
+ /* no existing record, assign a new file record from the global array */
+ file = &(posix_runtime->file_runtime_array[posix_runtime->file_array_ndx]);
+ file->file_record = &(posix_runtime->file_record_array[posix_runtime->file_array_ndx]);
+ file->file_record->f_id = file_id;
- /* add new record to file hash table */
- HASH_ADD(hlink, posix_runtime->file_hash, file_record.f_id, sizeof(darshan_file_id), file);
+ /* add new record to file hash table */
+ HASH_ADD(hlink, posix_runtime->file_hash, file_record->f_id, sizeof(darshan_file_id), file);
- posix_runtime->file_count++;
+ posix_runtime->file_array_ndx++;
if(newname != name)
free(newname);
@@ -527,16 +537,36 @@ static void posix_file_close_fd(int fd)
-static void posix_prepare_for_shutdown()
+ int comm_cmp;
+ MPI_Comm_compare(MPI_COMM_WORLD, comm, &comm_cmp);
+ /* only do shared file reductions if this communicator includes _everyone_ */
+ if((comm_cmp == MPI_IDENT) || (comm_cmp == MPI_CONGRUENT))
+ /* don't reduce shared files if that feature is disabled, either */
+ if(!getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
+ /* TODO reduction code */
+ *buffer = (void *)(posix_runtime->file_record_array);
+ *size = posix_runtime->file_array_ndx * sizeof(struct darshan_posix_file);
return;
+static void posix_shutdown()
+ /* TODO destroy hash tables ?? */
+ free(posix_runtime->file_runtime_array);
+ free(posix_runtime->file_record_array);
+ free(posix_runtime);
+ posix_runtime = NULL;
return;
hooks/post-receive
More information about the Darshan-commits
