[Darshan-commits] [Darshan] branch, dev-modular, updated. 7496c279aeb8003a655ee581145ecec6b4d18ddc
Service Account git at mcs.anl.gov
Wed Nov 12 16:01:45 CST 2014
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  7496c279aeb8003a655ee581145ecec6b4d18ddc (commit)
      from  37d68c1ea108118df1dfd259e96b7c6d33f32110 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 7496c279aeb8003a655ee581145ecec6b4d18ddc
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Wed Nov 12 15:57:35 2014 -0600
    More updates to facilitate runtime core shutdown
Summary of changes:
 darshan-runtime/darshan-core.h      |    5 +-
 darshan-runtime/darshan.h           |   19 ++-
 darshan-runtime/lib/darshan-core.c  |  345 ++++++++++++------------
 darshan-runtime/lib/darshan-posix.c |    1 +
 darshan-runtime/utlist.h            |  490 -----------------------------------
 5 files changed, 194 insertions(+), 666 deletions(-)
 delete mode 100644 darshan-runtime/utlist.h
Diff of changes:
diff --git a/darshan-runtime/darshan-core.h b/darshan-runtime/darshan-core.h
index c94ac9d..3729101 100644
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -22,22 +22,21 @@
 #define DARSHAN_MOD_NAME_LEN 31
 /* flags to indicate properties of file records */
-#define CP_FLAG_CONDENSED 1<<0
 #define CP_FLAG_NOTIMING 1<<1
 struct darshan_core_module
+    darshan_module_id id;
     char name[DARSHAN_MOD_NAME_LEN+1];
     struct darshan_module_funcs mod_funcs;
-    struct darshan_core_module *next;
 /* in memory structure to keep up with job level data */
 struct darshan_core_job_runtime
     struct darshan_job log_job;
+    struct darshan_core_module* mod_array[DARSHAN_MAX_MODS];
     char exe[CP_EXE_LEN+1];
-    struct darshan_core_module *mod_list_head;
     char comp_buf[CP_COMP_BUF_SIZE];
     int flags;
     double wtime_offset;
diff --git a/darshan-runtime/darshan.h b/darshan-runtime/darshan.h
index 34c0741..698616c 100644
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -25,9 +25,25 @@
 /* Environment variable to override __CP_MEM_ALIGNMENT */
 #define CP_MEM_ALIGNMENT_OVERRIDE "DARSHAN_MEMALIGN"
-/* TODO these go where ? */
+/* TODO where do each of the following macros make most sense ? */
 #define DARSHAN_MPI_CALL(func) func
+/* max length of module name string (not counting \0) */
+#define DARSHAN_MOD_NAME_LEN 31
+/* unique identifiers to distinguish between available darshan modules */
+/* NOTES: - valid ids range from [0...DARSHAN_MAX_MODS-1]
+ *        - order of ids control module shutdown order (first module shuts down first)
+#define DARSHAN_MAX_MODS 16
+typedef enum
+    DARSHAN_POSIX_MOD,
+    DARSHAN_MPIIO_MOD,
+    DARSHAN_HDF5_MOD,
+    DARSHAN_PNETCDF_MOD,
+} darshan_module_id;
 typedef uint64_t darshan_file_id;
@@ -41,6 +57,7 @@ struct darshan_module_funcs
 void darshan_core_register_module(
+    darshan_module_id id,
     char *name,
     struct darshan_module_funcs *funcs,
     int *runtime_mem_limit);
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index c20cee8..4076202 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -19,11 +19,9 @@
 #include <sys/types.h>
 #include <sys/stat.h>
 #include <sys/vfs.h>
 #include <mpi.h>
 #include "darshan-core.h"
-#include "utlist.h"
 /* TODO is __progname_full needed here */
 extern char* __progname;
@@ -36,19 +34,11 @@ static int my_rank = -1;
 static void darshan_core_initialize(int *argc, char ***argv);
 static void darshan_core_shutdown(void);
 static void darshan_core_cleanup(struct darshan_core_job_runtime* job);
+static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* start_tm);
 #define DARSHAN_LOCK() pthread_mutex_lock(&darshan_mutex)
 #define DARSHAN_UNLOCK() pthread_mutex_unlock(&darshan_mutex)
-#define DARSHAN_MOD_REGISTER(__mod, __job) \
-    LL_PREPEND(__job->mod_list_head, __mod)
-#define DARSHAN_MOD_SEARCH(__mod, __tmp, __job) \
-    LL_SEARCH(__job->mod_list_head, __mod, __tmp, mod_cmp)
-#define DARSHAN_MOD_ITER(__mod, __tmp, __job) \
-    LL_FOREACH_SAFE(__job->mod_list_head, __mod, __tmp)
-#define DARSHAN_MOD_DELETE(__mod, __job) \
-   LL_DELETE(__job->mod_list_head, __mod)
 /* intercept MPI initialize and finalize to manage darshan core runtime */
 int MPI_Init(int *argc, char ***argv)
@@ -186,23 +176,17 @@ static void darshan_core_shutdown()
     struct darshan_core_job_runtime* final_job;
     struct darshan_core_module *mod, *tmp;
     int internal_timing_flag = 0;
-    int jobid;
-    char* jobid_str;
     char* envjobid;
-    char* logpath;
+    char* jobid_str;
+    int jobid;
+    struct tm* start_tm;
+    time_t start_time_tmp;
     int ret;
-    int local_ret = 0;
-    int all_ret = 0;
-    uint64_t hlevel;
-    char hname[HOST_NAME_MAX];
-    uint64_t logmod;
-    char* logpath_override = NULL;
-#ifdef __CP_LOG_ENV
-    char env_check[256];
-    char* env_tok;
-#endif
     int64_t first_start_time;
     int64_t last_end_time;
+    int local_mod_use[DARSHAN_MAX_MODS] = {0};
+    int global_mod_use_count[DARSHAN_MAX_MODS] = {0};
+    int i;
     if(getenv("DARSHAN_INTERNAL_TIMING"))
         internal_timing_flag = 1;
@@ -227,30 +211,16 @@ static void darshan_core_shutdown()
         return;
-    /* construct log file name */
+    /* set jobid and logfile name on rank 0 */
     if(my_rank == 0)
-        char cuser[L_cuserid] = {0};
-        struct tm* my_tm;
-        time_t start_time_tmp;
         /* Use CP_JOBID_OVERRIDE for the env var or CP_JOBID */
         envjobid = getenv(CP_JOBID_OVERRIDE);
-        if (!envjobid)
+        if(!envjobid)
             envjobid = CP_JOBID;
-        /* Use CP_LOG_PATH_OVERRIDE for the value or __CP_LOG_PATH */
-        logpath = getenv(CP_LOG_PATH_OVERRIDE);
-        if (!logpath)
-#ifdef __CP_LOG_PATH
-            logpath = __CP_LOG_PATH;
-#endif
-        /* find a job id */
         jobid_str = getenv(envjobid);
         if(jobid_str)
@@ -263,121 +233,15 @@ static void darshan_core_shutdown()
             jobid = getpid();
-        /* break out time into something human readable */
-        start_time_tmp = final_job->log_job.start_time;
-        my_tm = localtime(&start_time_tmp);
-        /* get the username for this job.  In order we will try each of the
-         * following until one of them succeeds:
-         * - cuserid()
-         * - getenv("LOGNAME")
-         * - snprintf(..., geteuid());
-         * Note that we do not use getpwuid() because it generally will not
-         * work in statically compiled binaries.
-#ifndef DARSHAN_DISABLE_CUSERID
-        cuserid(cuser);
-#endif
-        /* if cuserid() didn't work, then check the environment */
-        if (strcmp(cuser, "") == 0)
-            char* logname_string;
-            logname_string = getenv("LOGNAME");
-            if(logname_string)
-                strncpy(cuser, logname_string, (L_cuserid-1));
-        /* if cuserid() and environment both fail, then fall back to uid */
-            uid_t uid = geteuid();
-            snprintf(cuser, sizeof(cuser), "%u", uid);
-        /* generate a random number to help differentiate the log */
-        hlevel=DARSHAN_MPI_CALL(PMPI_Wtime)() * 1000000;
-        (void) gethostname(hname, sizeof(hname));
-        logmod = darshan_hash((void*)hname,strlen(hname),hlevel);
-        /* see if darshan was configured using the --with-logpath-by-env
-         * argument, which allows the user to specify an absolute path to
-         * place logs via an env variable.
-        /* just silently skip if the environment variable list is too big */
-        if(strlen(__CP_LOG_ENV) < 256)
-            /* copy env variable list to a temporary buffer */
-            strcpy(env_check, __CP_LOG_ENV);
-            /* tokenize the comma-separated list */
-            env_tok = strtok(env_check, ",");
-            if(env_tok)
-                do
-                    /* check each env variable in order */
-                    logpath_override = getenv(env_tok);
-                    if(logpath_override)
-                        /* stop as soon as we find a match */
-                        break;
-                }while((env_tok = strtok(NULL, ",")));
-#endif
+        /* add to darshan core job */
+        final_job->log_job.jobid = (int64_t)jobid;
-            ret = snprintf(logfile_name, PATH_MAX,
-                "%s/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
-                logpath_override,
-                cuser, __progname, jobid,
-                (my_tm->tm_mon+1),
-                my_tm->tm_mday,
-                (my_tm->tm_hour*60*60 + my_tm->tm_min*60 + my_tm->tm_sec),
-                logmod);
-            if(ret == (PATH_MAX-1))
-                /* file name was too big; squish it down */
-                snprintf(logfile_name, PATH_MAX,
-                    "%s/id%d.darshan_partial",
-                    logpath_override, jobid);
-        else if(logpath)
-                "%s/%d/%d/%d/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
-                logpath, (my_tm->tm_year+1900),
-                (my_tm->tm_mon+1), my_tm->tm_mday,
-                my_tm->tm_mday,
-                logmod);
-                    logpath, jobid);
-        else
-            logfile_name[0] = '\0';
+        /* use human readable start time format in log filename */
+        start_time_tmp = final_job->log_job.start_time;
+        start_tm = localtime(&start_time_tmp);
-        /* add jobid */
-        final_job->log_job.jobid = (int64_t)jobid;
+        /* construct log file name */
+        darshan_get_logfile_name(logfile_name, jobid, start_tm);
     /* broadcast log file name */
@@ -404,8 +268,17 @@ static void darshan_core_shutdown()
         final_job->log_job.end_time = last_end_time;
-    /* TODO: coordinate shutdown accross all registered modules */
-    DARSHAN_MOD_ITER(mod, tmp, final_job)
+    /* set which local modules were actually used */
+    for(i = 0; i < DARSHAN_MAX_MODS; i++)
+        if(final_job->mod_array[i])
+            local_mod_use[i] = 1;
+    /* reduce the number of times a module was opened globally and bcast to everyone */
+    DARSHAN_MPI_CALL(PMPI_Allreduce)(local_mod_use, global_mod_use_count, DARSHAN_MAX_MODS, MPI_INT, MPI_SUM, MPI_COMM_WORLD);
@@ -413,7 +286,7 @@ static void darshan_core_shutdown()
     free(logfile_name);
     darshan_core_cleanup(final_job);
-    if (internal_timing_flag)
+    if(internal_timing_flag)
         /* TODO: what do we want to time in new darshan version? */
@@ -423,12 +296,11 @@ static void darshan_core_shutdown()
-    struct darshan_core_module *mod, *tmp;
+    int i;
-    DARSHAN_MOD_ITER(mod, tmp, job)
-        DARSHAN_MOD_DELETE(mod, job);
-        free(mod);
     free(job);
@@ -436,44 +308,170 @@ static void darshan_core_cleanup(struct darshan_core_job_runtime* job)
     return;
-static int mod_cmp(struct darshan_core_module* a, struct darshan_core_module* b)
-    return strcmp(a->name, b->name);
+    char* logpath;
+    char* logname_string;
+    char* logpath_override = NULL;
+#ifdef __CP_LOG_ENV
+    char env_check[256];
+    char* env_tok;
+#endif
+    uint64_t hlevel;
+    char hname[HOST_NAME_MAX];
+    uint64_t logmod;
+    char cuser[L_cuserid] = {0};
+    int ret;
+    /* Use CP_LOG_PATH_OVERRIDE for the value or __CP_LOG_PATH */
+    logpath = getenv(CP_LOG_PATH_OVERRIDE);
+    if(!logpath)
+#ifdef __CP_LOG_PATH
+        logpath = __CP_LOG_PATH;
+#endif
+    /* get the username for this job.  In order we will try each of the
+     * following until one of them succeeds:
+     * - cuserid()
+     * - getenv("LOGNAME")
+     * - snprintf(..., geteuid());
+     * Note that we do not use getpwuid() because it generally will not
+     * work in statically compiled binaries.
+#ifndef DARSHAN_DISABLE_CUSERID
+    cuserid(cuser);
+#endif
+    /* if cuserid() didn't work, then check the environment */
+    if(strcmp(cuser, "") == 0)
+        logname_string = getenv("LOGNAME");
+        if(logname_string)
+            strncpy(cuser, logname_string, (L_cuserid-1));
+    /* if cuserid() and environment both fail, then fall back to uid */
+        uid_t uid = geteuid();
+        snprintf(cuser, sizeof(cuser), "%u", uid);
+    /* generate a random number to help differentiate the log */
+    hlevel=DARSHAN_MPI_CALL(PMPI_Wtime)() * 1000000;
+    (void)gethostname(hname, sizeof(hname));
+    logmod = darshan_hash((void*)hname,strlen(hname),hlevel);
+    /* see if darshan was configured using the --with-logpath-by-env
+     * argument, which allows the user to specify an absolute path to
+     * place logs via an env variable.
+    /* just silently skip if the environment variable list is too big */
+    if(strlen(__CP_LOG_ENV) < 256)
+        /* copy env variable list to a temporary buffer */
+        strcpy(env_check, __CP_LOG_ENV);
+        /* tokenize the comma-separated list */
+        env_tok = strtok(env_check, ",");
+        if(env_tok)
+            do
+                /* check each env variable in order */
+                logpath_override = getenv(env_tok);
+                if(logpath_override)
+                    /* stop as soon as we find a match */
+                    break;
+            }while((env_tok = strtok(NULL, ",")));
+#endif
+        ret = snprintf(logfile_name, PATH_MAX,
+            "%s/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
+            logpath_override,
+            cuser, __progname, jobid,
+            (start_tm->tm_mon+1),
+            start_tm->tm_mday,
+            (start_tm->tm_hour*60*60 + start_tm->tm_min*60 + start_tm->tm_sec),
+            logmod);
+        if(ret == (PATH_MAX-1))
+            /* file name was too big; squish it down */
+            snprintf(logfile_name, PATH_MAX,
+                "%s/id%d.darshan_partial",
+                logpath_override, jobid);
+    else if(logpath)
+            "%s/%d/%d/%d/%s_%s_id%d_%d-%d-%d-%" PRIu64 ".darshan_partial",
+            logpath, (start_tm->tm_year+1900),
+            (start_tm->tm_mon+1), start_tm->tm_mday,
+            logmod);
+                logpath, jobid);
+    else
+        logfile_name[0] = '\0';
+    return;
     char *name,
-    struct darshan_core_module tmp;
     struct darshan_core_module* mod;
     DARSHAN_LOCK();
     *runtime_mem_limit = 0;
-    if(!darshan_core_job)
+    if(!darshan_core_job || (id >= DARSHAN_MAX_MODS))
         DARSHAN_UNLOCK();
         return;
     /* see if this module is already registered */
-    strncpy(tmp.name, name, DARSHAN_MOD_NAME_LEN);
-    DARSHAN_MOD_SEARCH(mod, &tmp, darshan_core_job);
-    if(mod)
+    if(darshan_core_job->mod_array[id])
-        /* if module is already registered, update module_funcs and return */
+        /* if module is already registered just return */
         /* NOTE: we do not recalculate memory limit here, just set to 0 */
-        mod->mod_funcs = *funcs;
         DARSHAN_UNLOCK();
         return;
-    /* this module has not been registered yet, allocate and register it */
+    /* this module has not been registered yet, allocate and initialize it */
     mod = malloc(sizeof(*mod));
     if(!mod)
@@ -482,9 +480,12 @@ void darshan_core_register_module(
     memset(mod, 0, sizeof(*mod));
+    mod->id = id;
     strncpy(mod->name, name, DARSHAN_MOD_NAME_LEN);
-    DARSHAN_MOD_REGISTER(mod, darshan_core_job);
+    /* register module with darshan */
+    darshan_core_job->mod_array[id] = mod;
     /* TODO: something smarter than just 2 MiB per module */
     *runtime_mem_limit = 2 * 1024 * 1024;
diff --git a/darshan-runtime/lib/darshan-posix.c b/darshan-runtime/lib/darshan-posix.c
index 06476fa..d35c2c2 100644
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -362,6 +362,7 @@ static void posix_runtime_initialize()
     /* register the posix module with darshan core */
         POSIX_MOD_NAME,
         &posix_mod_fns,
         &mem_limit);
diff --git a/darshan-runtime/utlist.h b/darshan-runtime/utlist.h
deleted file mode 100644
index 35fc9db..0000000
--- a/darshan-runtime/utlist.h
+++ /dev/null
@@ -1,490 +0,0 @@
-Copyright (c) 2007-2010, Troy D. Hanson   http://uthash.sourceforge.net
-All rights reserved.
-Redistribution and use in source and binary forms, with or without
-modification, are permitted provided that the following conditions are met:
-    * Redistributions of source code must retain the above copyright
-      notice, this list of conditions and the following disclaimer.
-THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
-IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
-TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
-PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER
-OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
-EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
-PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
-PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
-LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
-NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
-SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-#ifndef UTLIST_H
-#define UTLIST_H
-#define UTLIST_VERSION 1.9.1
- * This file contains macros to manipulate singly and doubly-linked lists.
- * 1. LL_ macros:  singly-linked lists.
- * 2. DL_ macros:  doubly-linked lists.
- * 3. CDL_ macros: circular doubly-linked lists.
- * To use singly-linked lists, your structure must have a "next" pointer.
- * To use doubly-linked lists, your structure must "prev" and "next" pointers.
- * Either way, the pointer to the head of the list must be initialized to NULL.
- * ----------------.EXAMPLE -------------------------
- * struct item {
- *      int id;
- *      struct item *prev, *next;
- * struct item *list = NULL:
- * int main() {
- *      struct item *item;
- *      ... allocate and populate item ...
- *      DL_APPEND(list, item);
- * For doubly-linked lists, the append and delete macros are O(1)
- * For singly-linked lists, append and delete are O(n) but prepend is O(1)
- * The sort macro is O(n log(n)) for all types of single/double/circular lists.
-/* These macros use decltype or the earlier __typeof GNU extension.
-   As decltype is only available in newer compilers (VS2010 or gcc 4.3+
-   when compiling c++ code), this code uses whatever method is needed
-   or, for VS2008 where neither is available, uses casting workarounds. */
-#ifdef _MSC_VER            /* MS compiler */
-#if _MSC_VER >= 1600 && __cplusplus  /* VS2010 and newer in C++ mode */
-#define LDECLTYPE(x) decltype(x)
-#else                     /* VS2008 or older (or VS2010 in C mode) */
-#define NO_DECLTYPE
-#define LDECLTYPE(x) char*
-#endif
-#else                      /* GNU, Sun and other compilers */
-#define LDECLTYPE(x) __typeof(x)
-#endif
-/* for VS2008 we use some workarounds to get around the lack of decltype,
- * namely, we always reassign our tmp variable to the list head if we need
- * to dereference its prev/next pointers, and save/restore the real head.*/
-#ifdef NO_DECLTYPE
-#define _SV(elt,list) _tmp = (char*)(list); {char **_alias = (char**)&(list); *_alias = (elt); }
-#define _NEXT(elt,list) ((char*)((list)->next))
-#define _NEXTASGN(elt,list,to) { char **_alias = (char**)&((list)->next); *_alias=(char*)(to); }
-#define _PREV(elt,list) ((char*)((list)->prev))
-#define _PREVASGN(elt,list,to) { char **_alias = (char**)&((list)->prev); *_alias=(char*)(to); }
-#define _RS(list) { char **_alias = (char**)&(list); *_alias=_tmp; }
-#define _CASTASGN(a,b) { char **_alias = (char**)&(a); *_alias=(char*)(b); }
-#else
-#define _NEXT(elt,list) ((elt)->next)
-#define _NEXTASGN(elt,list,to) ((elt)->next)=(to)
-#define _PREV(elt,list) ((elt)->prev)
-#define _PREVASGN(elt,list,to) ((elt)->prev)=(to)
-#define _RS(list)
-#define _CASTASGN(a,b) (a)=(b)
-#endif
- * The sort macro is an adaptation of Simon Tatham's O(n log(n)) mergesort    *
- * Unwieldy variable names used here to avoid shadowing passed-in variables.  *
-#define LL_SORT(list, cmp)        \
-do {        \
-  LDECLTYPE(list) _ls_p;        \
-  LDECLTYPE(list) _ls_q;        \
-  LDECLTYPE(list) _ls_e;        \
-  LDECLTYPE(list) _ls_tail;        \
-  LDECLTYPE(list) _ls_oldhead;        \
-  LDECLTYPE(list) _tmp;        \
-  int _ls_insize, _ls_nmerges, _ls_psize, _ls_qsize, _ls_i, _ls_looping;                       \
-  if (list) {        \
-    _ls_insize = 1;        \
-    _ls_looping = 1;        \
-    while (_ls_looping) {        \
-      _CASTASGN(_ls_p,list);        \
-      _CASTASGN(_ls_oldhead,list);                                                             \
-      list = NULL;        \
-      _ls_tail = NULL;        \
-      _ls_nmerges = 0;        \
-      while (_ls_p) {        \
-        _ls_nmerges++;        \
-        _ls_q = _ls_p;        \
-        _ls_psize = 0;        \
-        for (_ls_i = 0; _ls_i < _ls_insize; _ls_i++) {                                         \
-          _ls_psize++;        \
-          _SV(_ls_q,list); _ls_q = _NEXT(_ls_q,list); _RS(list);                               \
-          if (!_ls_q) break;        \
-        _ls_qsize = _ls_insize;        \
-        while (_ls_psize > 0 || (_ls_qsize > 0 && _ls_q)) {                                    \
-          if (_ls_psize == 0) {        \
-            _ls_e = _ls_q; _SV(_ls_q,list); _ls_q = _NEXT(_ls_q,list); _RS(list); _ls_qsize--; \
-          } else if (_ls_qsize == 0 || !_ls_q) {                                               \
-            _ls_e = _ls_p; _SV(_ls_p,list); _ls_p = _NEXT(_ls_p,list); _RS(list); _ls_psize--; \
-          } else if (cmp(_ls_p,_ls_q) <= 0) {                                                  \
-          } else {        \
-          if (_ls_tail) {        \
-            _SV(_ls_tail,list); _NEXTASGN(_ls_tail,list,_ls_e); _RS(list);                     \
-          } else {        \
-            _CASTASGN(list,_ls_e);                                                             \
-          _ls_tail = _ls_e;        \
-        _ls_p = _ls_q;        \
-      _SV(_ls_tail,list); _NEXTASGN(_ls_tail,list,NULL); _RS(list);                            \
-      if (_ls_nmerges <= 1) {        \
-        _ls_looping=0;        \
-      _ls_insize *= 2;        \
-  } else _tmp=NULL; /* quiet gcc unused variable warning */                                    \
-} while (0)
-#define DL_SORT(list, cmp)        \
-do {        \
-  if (list) {        \
-    _ls_insize = 1;        \
-      list = NULL;        \
-      while (_ls_p) {        \
-        _ls_nmerges++;        \
-        _ls_q = _ls_p;        \
-        _ls_psize = 0;        \
-          _ls_psize++;        \
-          } else {        \
-          if (_ls_tail) {        \
-          } else {        \
-          _SV(_ls_e,list); _PREVASGN(_ls_e,list,_ls_tail); _RS(list);                          \
-        _ls_p = _ls_q;        \
-      _CASTASGN(list->prev, _ls_tail);                                                         \
-        _ls_looping=0;        \
-} while (0)
-#define CDL_SORT(list, cmp)        \
-do {        \
-  LDECLTYPE(list) _tmp2;        \
-  if (list) {        \
-    _ls_insize = 1;        \
-      list = NULL;        \
-      while (_ls_p) {        \
-        _ls_nmerges++;        \
-        _ls_q = _ls_p;        \
-        _ls_psize = 0;        \
-          _ls_psize++;        \
-          _SV(_ls_q,list);        \
-          if (_NEXT(_ls_q,list) == _ls_oldhead) {                                              \
-            _ls_q = NULL;        \
-          } else {        \
-            _ls_q = _NEXT(_ls_q,list);                                                         \
-          _RS(list);        \
-            if (_ls_q == _ls_oldhead) { _ls_q = NULL; }                                        \
-            if (_ls_p == _ls_oldhead) { _ls_p = NULL; }                                        \
-          } else {        \
-          if (_ls_tail) {        \
-          } else {        \
-        _ls_p = _ls_q;        \
-      _CASTASGN(list->prev,_ls_tail);                                                          \
-      _CASTASGN(_tmp2,list);        \
-      _SV(_ls_tail,list); _NEXTASGN(_ls_tail,list,_tmp2); _RS(list);                           \
-        _ls_looping=0;        \
-} while (0)
- * singly linked list macros (non-circular)                                   *
-#define LL_PREPEND(head,add)        \
-do {        \
-  (add)->next = head;        \
-  head = add;        \
-} while (0)
-#define LL_APPEND(head,add)        \
-do {        \
-  LDECLTYPE(head) _tmp;        \
-  (add)->next=NULL;        \
-  if (head) {        \
-    _tmp = head;        \
-    while (_tmp->next) { _tmp = _tmp->next; }                                                  \
-    _tmp->next=(add);        \
-  } else {        \
-    (head)=(add);        \
-} while (0)
-#define LL_DELETE(head,del)        \
-do {        \
-  if ((head) == (del)) {        \
-    (head)=(head)->next;        \
-  } else {        \
-    _tmp = head;        \
-    while (_tmp->next && (_tmp->next != (del))) {                                              \
-      _tmp = _tmp->next;        \
-    if (_tmp->next) {        \
-      _tmp->next = ((del)->next);                                                              \
-} while (0)
-/* Here are VS2008 replacements for LL_APPEND and LL_DELETE */
-#define LL_APPEND_VS2008(head,add)                                                             \
-do {        \
-  if (head) {        \
-    (add)->next = head;     /* use add->next as a temp variable */                             \
-    while ((add)->next->next) { (add)->next = (add)->next->next; }                             \
-    (add)->next->next=(add);        \
-  } else {        \
-    (head)=(add);        \
-} while (0)
-#define LL_DELETE_VS2008(head,del)                                                             \
-do {        \
-  } else {        \
-    char *_tmp = (char*)(head);        \
-    while (head->next && (head->next != (del))) {                                              \
-      head = head->next;        \
-    if (head->next) {        \
-      head->next = ((del)->next);                                                              \
-      char **_head_alias = (char**)&(head);                                                    \
-      *_head_alias = _tmp;        \
-} while (0)
-#ifdef NO_DECLTYPE
-#undef LL_APPEND
-#define LL_APPEND LL_APPEND_VS2008
-#undef LL_DELETE
-#define LL_DELETE LL_DELETE_VS2008
-#endif
-/* end VS2008 replacements */
-#define LL_FOREACH(head,el)        \
-    for(el=head;el;el=el->next)
-#define LL_FOREACH_SAFE(head,el,tmp)                                                           \
-  for((el)=(head);(el) && (tmp = (el)->next, 1); (el) = tmp)
-#define LL_SEARCH_SCALAR(head,out,field,val)                                                   \
-do {        \
-    LL_FOREACH(head,out) {        \
-      if ((out)->field == (val)) break;                                                        \
-} while(0)
-#define LL_SEARCH(head,out,elt,cmp)                                                            \
-do {        \
-      if ((cmp(out,elt))==0) break;                                                            \
-} while(0)
- * doubly linked list macros (non-circular)                                   *
-#define DL_PREPEND(head,add)        \
-do {        \
- if (head) {        \
-   (add)->prev = (head)->prev;        \
-   (head)->prev = (add);        \
- } else {        \
-   (add)->prev = (add);        \
- (head) = (add);        \
-} while (0)
-#define DL_APPEND(head,add)        \
-do {        \
-  if (head) {        \
-      (head)->prev->next = (add);                                                              \
-      (add)->next = NULL;        \
-  } else {        \
-      (head)=(add);        \
-      (head)->prev = (head);        \
-      (head)->next = NULL;        \
-} while (0);
-#define DL_DELETE(head,del)        \
-do {        \
-  if ((del)->prev == (del)) {        \
-      (head)=NULL;        \
-  } else if ((del)==(head)) {        \
-      (del)->next->prev = (del)->prev;                                                         \
-      (head) = (del)->next;        \
-  } else {        \
-      (del)->prev->next = (del)->next;                                                         \
-      if ((del)->next) {        \
-      } else {        \
-          (head)->prev = (del)->prev;                                                          \
-} while (0);
-#define DL_FOREACH(head,el)        \
-/* this version is safe for deleting the elements during iteration */
-#define DL_FOREACH_SAFE(head,el,tmp)                                                           \
-/* these are identical to their singly-linked list counterparts */
-#define DL_SEARCH_SCALAR LL_SEARCH_SCALAR
-#define DL_SEARCH LL_SEARCH
- * circular doubly linked list macros                                         *
-#define CDL_PREPEND(head,add)        \
-do {        \
- if (head) {        \
-   (add)->next = (head);        \
-   (add)->prev->next = (add);        \
- } else {        \
-   (add)->next = (add);        \
-(head)=(add);        \
-} while (0)
-#define CDL_DELETE(head,del)        \
-do {        \
-  if ( ((head)==(del)) && ((head)->next == (head))) {                                          \
-      (head) = 0L;        \
-  } else {        \
-     if ((del) == (head)) (head)=(del)->next;                                                  \
-} while (0);
-#define CDL_FOREACH(head,el)        \
-    for(el=head;el;el=(el->next==head ? 0L : el->next))
-#define CDL_FOREACH_SAFE(head,el,tmp1,tmp2)                                                    \
-  for((el)=(head), ((tmp1)=(head)?((head)->prev):NULL);                                        \
-      (el) && ((tmp2)=(el)->next, 1);                                                          \
-      ((el) = (((el)==(tmp1)) ? 0L : (tmp2))))
-#define CDL_SEARCH_SCALAR(head,out,field,val)                                                  \
-do {        \
-    CDL_FOREACH(head,out) {        \
-} while(0)
-#define CDL_SEARCH(head,out,elt,cmp)                                                           \
-do {        \
-} while(0)
-#endif /* UTLIST_H */
hooks/post-receive
More information about the Darshan-commits mailing list
