[codes-ross-users] how to use fattree static routing
Nikhil Jain nikhil.jain at acm.org
Mon Mar 13 13:52:32 CDT 2017
Did the script die or you killed it? If you killed it, after how long? What size system are you generating routing for?
Nikhil Jain
Postdoctoral Fellow, Lawrence Livermore National Laboratory
nikhil.jain at acm.org, http://nikhil-jain.github.io/
> On Mar 13, 2017, at 10:31, Peixin Qiao <pqiao at hawk.iit.edu> wrote:
> Hi CODES,
> When I run the command in README.fattree.txt, I cannot finish creating static routing table. The third step cannot be finished as follows:
> peixin at peixin:~/simulation/scripts/routing_folder$ ls
> net.dot  net.txt
> peixin at peixin:~/simulation/scripts/routing_folder$ cd ..
> peixin at peixin:~/simulation/scripts$ ~/simulation/scripts/create_static_lft.sh /home/peixin/simulation/scripts/routing_folder/ net
> dot file already exists.
> running createIBNet.py
> Selected configuration:
>   Output:  /home/peixin/simulation/scripts/routing_folder/topo.net <http://topo.net/>
>   Topology:  XGFT
>   Number of endpoints:  8
>   Number of ports per endpoints:  1
>   Number of switches:  4
>   Number of ports per switch:  36
>   Dimensions for Mesh/Torus: -1, -1, -1
>   k-ary-n Tree: -1 -ary- -1
>   Kautz K(b,n): K(-1; -1)
>   XGFT(h,m,w): XGFT(3; 18,18,36; 1,18,18)
>   Dragonfly(a,p,h) : Dragonfly(-1, -1, -1) with -1 groups
>   Cascade(a,p,h,g) : Cascade(96, 8, 10) with -1 groups
>   Tofu(d1,d2,d3) : Tofu(-1, -1, -1) with -1 groups
> This program also writes an dot-file to plot the graph with Graphviz.
> Try:
>   dot / neato /home/peixin/simulation/scripts/routing_folder/topo.dot -Tpng -o graph.png && evince graph.png
> running simulate.py
> Run ibsim...
> Run opensm...
> ^CTraceback (most recent call last):
>   File "/home/peixin/simulation/scripts/simulate.py", line 1140, in <module>
>     app = runSim(options.network, options.routing, options.pattern)
>   File "/home/peixin/simulation/scripts/simulate.py", line 826, in __init__
>     time.sleep(60)
> KeyboardInterrupt
> peixin at peixin:~/simulation/scripts$ cd routing_folder/
> log.txt  net.dot  net.txt  ofedout  rootguids.conf  topo.dot  topo.net <http://topo.net/>
> How to create fat-tree static routing table with 36-ports switch?
> Thanks,
> Peixin
> codes-ross-users mailing list
> codes-ross-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170313/cedeaff5/attachment.html>
More information about the codes-ross-users mailing list
