[codes-ross-users] how to use fattree static routing
Peixin Qiao
pqiao at hawk.iit.edu
Mon Mar 13 12:31:15 CDT 2017
Hi CODES,
When I run the command in README.fattree.txt, I cannot finish creating
static routing table. The third step cannot be finished as follows:
peixin at peixin:~/simulation/scripts/routing_folder$ ls
net.dot net.txt
peixin at peixin:~/simulation/scripts/routing_folder$ cd ..
peixin at peixin:~/simulation/scripts$
~/simulation/scripts/create_static_lft.sh
/home/peixin/simulation/scripts/routing_folder/ net
dot file already exists.
running createIBNet.py
Selected configuration:
Output: /home/peixin/simulation/scripts/routing_folder/topo.net
Topology: XGFT
Number of endpoints: 8
Number of ports per endpoints: 1
Number of switches: 4
Number of ports per switch: 36
Dimensions for Mesh/Torus: -1, -1, -1
k-ary-n Tree: -1 -ary- -1
Kautz K(b,n): K(-1; -1)
XGFT(h,m,w): XGFT(3; 18,18,36; 1,18,18)
Dragonfly(a,p,h) : Dragonfly(-1, -1, -1) with -1 groups
Cascade(a,p,h,g) : Cascade(96, 8, 10) with -1 groups
Tofu(d1,d2,d3) : Tofu(-1, -1, -1) with -1 groups
This program also writes an dot-file to plot the graph with Graphviz.
Try:
dot / neato /home/peixin/simulation/scripts/routing_folder/topo.dot -Tpng
running simulate.py
Run ibsim...
Run opensm...
^CTraceback (most recent call last):
File "/home/peixin/simulation/scripts/simulate.py", line 1140, in <module>
app = runSim(options.network, options.routing, options.pattern)
File "/home/peixin/simulation/scripts/simulate.py", line 826, in __init__
time.sleep(60)
KeyboardInterrupt
peixin at peixin:~/simulation/scripts$ cd routing_folder/
log.txt net.dot net.txt ofedout rootguids.conf topo.dot topo.net
How to create fat-tree static routing table with 36-ports switch?
Peixin
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170313/a17dc8fc/attachment.html>
More information about the codes-ross-users
