[codes-ross-users] Help with Storage Simulation
Harsh Khetawat
hkhetaw at ncsu.edu
Fri Jul 28 09:56:48 CDT 2017
I see. I had a feeling synchronization might be the culprit too.
I tried running the simulation with parallel optimistic mode as well, but
the darshan workload generator method does not have the get_next_rc or
get_next_rc2 function that the simulation uses in order to facilitate
reverse computation.
Is there any way I could do optimistic parallel simulation using darshan
workloads?
Harsh
On Fri, Jul 28, 2017 at 10:26 AM, Mubarak, Misbah <mmubarak at anl.gov> wrote:
> Hi Harsh,
> Parallel conservative mode has a faster performance with models that have
> a larger look ahead time. The network models typically have a small look
> ahead value, which causes conservative mode to do a lot of synchronization
> (that is why it is so slow).
> When running in parallel, we typically use optimistic mode (--sync=3). To
> have the simulations working correctly in optimistic mode, you will have to
> ensure that whenever you are modifying the model state in the simulation,
> you will have to provide methods to undo this state change by writing a
> reverse handler. Majority of our models already implement these reverse
> handlers. For details on how to write them, you can see _rc functions in
> the models or look at ROSS documentation:
> https://github.com/carothersc/ROSS/wiki/Constructing-the-Model
> Thanks,
> Misbah
> From: Harsh Khetawat <hkhetaw at ncsu.edu>
> Date: Friday, July 28, 2017 at 9:40 AM
> To: Misbah Mubarak <mmubarak at anl.gov>
> Cc: "codes-ross-users at lists.mcs.anl.gov" <codes-ross-users at lists.mcs.
> anl.gov>
> Subject: Re: [codes-ross-users] Help with Storage Simulation
> Hi,
> I have been working on the codes-storage-server simulation by replacing
> the checkpoint workload with a darshan workload. Things seem to be working
> fine, and I am getting the results that I expect but the simulation takes a
> long time to complete even for moderately sized darshan workloads.
> In fact, sequential simulation seems to be running faster than a parallel
> conservative simulation. For sync=1, I see that the simulation makes much
> faster progress than it does for sync=2 with 64 or even higher node count.
> I have tried other configurations as well but there's no observable
> speed-up. Any ideas on why that could be happening?
> Thanks,
> Harsh
> On Tue, Jul 11, 2017 at 9:32 AM, Mubarak, Misbah <mmubarak at anl.gov> wrote:
>> Great, thanks for the heads up!
>> Date: Monday, July 10, 2017 at 4:50 PM
>> Yes, it works now. Thank you.
>> I realized what the problem was, the inter and intra group connectivity
>> files paths needed to be absolute in the conf file in my case. It seemed to
>> have a problem picking it up from the environment variable for some reason.
>> Thanks,
>> Harsh
>> On Mon, Jul 10, 2017 at 4:26 PM, Mubarak, Misbah <mmubarak at anl.gov>
>> wrote:
>>> FYI I have updated the instructions to point to the right allocation
>>> file. I think the problem was that in your case, there was a mismatch
>>> between allocation file and the workloads file. You can give it a try and
>>> let me if that works.
>>> Thanks,
>>> Misbah
>>> From: Misbah Mubarak <mmubarak at anl.gov>
>>> Date: Monday, July 10, 2017 at 2:25 PM
>>> To: Harsh Khetawat <hkhetaw at ncsu.edu>
>>> Hi Harsh,
>>> The test-checkpoint-dfly-1T config file is actually in the repo:
>>> https://xgitlab.cels.anl.gov/codes/codes-storage-server/blob
>>> /master/tests/conf/test-checkpoint-dfly-1T.conf
>>> You will have to adjust the paths for the input network configuration
>>> files. The network config files are located in codes at the following path:
>>> codes/src/network-workloads/conf/dragonfly-custom/intra-9K-custom
>>> Thanks,
>>> Misbah
>>> Date: Monday, July 10, 2017 at 3:07 PM
>>> Cc: "codes-ross-users at lists.mcs.anl.gov" <codes-ross-users at lists.mcs.an
>>> l.gov>
>>> Hi,
>>> Thanks for the help with codes-storage-server.
>>> I was trying to run the client-mul-wklds test on the cluster here using
>>> the instructions in the wiki. First I tried with the exact command from the
>>> wiki:
>>> ./client-mul-wklds --sync=1
>>> --workload-conf-file=/lustre/atlas/scratch/hkhetaw/gen008/CO
>>> DES-darshan/codes-storage-server/checkpoint-study/workload-f
>>> iles/workload-512.conf
>>> --rank-alloc-file=/lustre/atlas/scratch/hkhetaw/gen008/CODES
>>> -darshan/codes-storage-server/checkpoint-study/config-files/
>>> --codes-config=/lustre/atlas/scratch/hkhetaw/gen008/CODES-da
>>> rshan/codes-storage-server/checkpoint-study/config-files/tes
>>> t-checkpoint-dfly-1T-adap.conf
>>> --lp-io-dir=/lustre/atlas/scratch/hkhetaw/gen008/CODES-darshan/test-dir
>>> --lp-io-use-suffix=1
>>> But the rank-alloc-file is a directory in the wiki instructions, so I
>>> expectedly got an error.
>>> Then I tried passing the rank alloc file from the
>>> checkpoint-study/workload-files/allocations/contiguous/cont-alloc-8832-2048.conf,
>>> but I got this error:
>>> 512 instances of workload checkpoint node: 0: error:
>>> ../src/networks/model-net/dragonfly-custom.C:630: intra-group file not
>>> found
>>> Rank 0 [Mon Jul 10 13:58:50 2017] [c6-1c0s6n2] application called
>>> MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>> _pmiu_daemon(SIGCHLD): [NID 02348] [c6-1c0s6n2] [Mon Jul 10 13:58:50
>>> 2017] PE RANK 0 exit signal Aborted
>>> Application 15031648 exit codes: 134
>>> I have set the $HOME_CODES environment variable correctly as well.
>>> Also, the instructions in the wiki specifies the codes-config file as
>>> "test-checkpoint-dfly-1T.conf" but there isn't any such file there, so I've
>>> tried with both the "test-checkpoint-dfly-1T-adap.conf" and
>>> "test-checkpoint-dfly-1T-min.conf", but no luck.
>>> Thanks again for all the help.
>>> Thanks,
>>> Harsh
>>> On Fri, Jul 7, 2017 at 1:58 PM, Mubarak, Misbah <mmubarak at anl.gov>
>>> wrote:
>>>> Hi Harsh,
>>>> You can refer to the instructions at the wiki for running the
>>>> simulation:
>>>> https://xgitlab.cels.anl.gov/codes/codes-storage-server/wiki
>>>> s/checkpoint-study
>>>> The right config file to use is test-checkpoint-dfly-1T.conf. The one
>>>> you mentioned is dated so I have removed that to avoid confusion. For a
>>>> test run, you can reduce the parameter checkpoint_sz in the config (it is
>>>> currently set to 1TiB which takes some time to complete).
>>>> For using the Darshan workload generator, please use Darshan versions
>>>> 2.x (Darshan 3.0 and up are not supported right now).
>>>> Thanks,
>>>> Misbah
>>>> Date: Friday, July 7, 2017 at 1:36 PM
>>>> l.gov>
>>>> Hi,
>>>> I have been trying to run the tests/test-checkpoint.c simulation as you
>>>> had suggested, with the intention of building on top of it with darshan
>>>> workloads. But when I try to run the simulation (without any changes) with:
>>>> aprun -n4 ./test-checkpoint --sync=3 --codes-config=/lustre/atlas/s
>>>> cratch/hkhetaw/gen008/CODES-darshan/codes-storage-server/tests/conf/test-checkpoint.conf
>>>> --lp-io-dir=test-checkpoint-output-ser
>>>> I get the following error:
>>>> node: 0: error: ../src/util/codes_mapping.c:487: could not find LP
>>>> with type name "dragonfly_router", did you forget to register the LP?
>>>> node: 1: error: ../src/util/codes_mapping.c:487: could not find LP
>>>> node: 2: error: ../src/util/codes_mapping.c:487: could not find LP
>>>> Rank 0 [Fri Jul 7 13:12:24 2017] [c2-1c0s1n2] application called
>>>> I checked in the source code for the test and the LP seems to be
>>>> registered properly. Any idea why this could be happening?
>>>> And would it be the right way to go about it if I used the
>>>> darshan-workload-generator to issue I/O requests to the storage-model
>>>> instead of the checkpointing I/O being issued by the test case right now?
>>>> Thanks,
>>>> Harsh Khetawat
>>>> On Fri, Jul 7, 2017 at 9:40 AM, Harsh Khetawat <hkhetaw at ncsu.edu>
>>>> wrote:
>>>>> Hi Misbah,
>>>>> Thank you for the information. This seems perfect for what I want to
>>>>> do. I'll try to set-up a simulation with replays of darshan logs and see
>>>>> how it goes.
>>>>> Thanks again.
>>>>> Regards,
>>>>> Harsh Khetawat
>>>>> On Thu, Jul 6, 2017 at 4:02 PM, Mubarak, Misbah <mmubarak at anl.gov>
>>>>> wrote:
>>>>>> Hi Harsh,
>>>>>> Have you looked at the codes-storage-server model? There is a wiki at:
>>>>>> https://xgitlab.cels.anl.gov/codes/codes-storage-server/wikis/home
>>>>>> The wiki has an example case study here that models storage nodes on
>>>>>> the dragonfly network. The clients (compute nodes) interact with the
>>>>>> storage nodes via an API that does RDMA style communication. You can find
>>>>>> the example on the API usage in tests/test-client-checkpoint.c [Look for
>>>>>> the function: send_req_to_store]. The API itself can be found at:
>>>>>> codes-store-lp.h.
>>>>>> The repo can be cloned from:
>>>>>> The CODES storage model makes use of the local-storage-model in
>>>>>> CODES. Attached is a diagram showing the sequence of steps for a write
>>>>>> operation (read operation is also implemented, you have to specify a flag
>>>>>> indicating whether it is a read or a write).
>>>>>> Hope that helps.
>>>>>> Regards,
>>>>>> Misbah
>>>>>> From: <codes-ross-users-bounces at lists.mcs.anl.gov> on behalf of
>>>>>> Date: Thursday, July 6, 2017 at 3:37 PM
>>>>>> To: "codes-ross-users at lists.mcs.anl.gov" <
>>>>>> codes-ross-users at lists.mcs.anl.gov>
>>>>>> Cc: Harsh Khetawat <hkhetaw at ncsu.edu>
>>>>>> Subject: [codes-ross-users] Help with Storage Simulation
>>>>>> Hi,
>>>>>> I have set-up CODES on my cluster and would like to use it to
>>>>>> simulate different storage strategies.
>>>>>> I wanted to use the darshan logs I have collected along with the
>>>>>> local-storage-model in CODES to simulate I/O behavior of the application.
>>>>>> My simulation involves not having just one global storage LP, but
>>>>>> having: (i) one storage LP per terminal, or (ii) one storage LP per
>>>>>> Modelnet_group, or (iii) other strategies.
>>>>>> Would the local-storage-model be the correct choice for this?
>>>>>> Should I write my own storage model for each scenario?
>>>>>> How would I go about incorporating this with the fattree or dragonfly
>>>>>> network models?
>>>>>> Thanks for the help.
>>>>>> Regards,
>>>>>> Harsh Khetawat
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170728/b6bf00fa/attachment-0001.html>
More information about the codes-ross-users
