[codes-ross-users] Help with Storage Simulation
Harsh Khetawat
hkhetaw at ncsu.edu
Fri Jul 7 12:36:31 CDT 2017
I have been trying to run the tests/test-checkpoint.c simulation as you had
suggested, with the intention of building on top of it with darshan
workloads. But when I try to run the simulation (without any changes) with:
aprun -n4 ./test-checkpoint --sync=3
--codes-config=/lustre/atlas/scratch/hkhetaw/gen008/CODES-darshan/codes-storage-server/tests/conf/test-checkpoint.conf
--lp-io-dir=test-checkpoint-output-ser
I get the following error:
node: 0: error: ../src/util/codes_mapping.c:487: could not find LP with
type name "dragonfly_router", did you forget to register the LP?
node: 1: error: ../src/util/codes_mapping.c:487: could not find LP with
node: 2: error: ../src/util/codes_mapping.c:487: could not find LP with
Rank 0 [Fri Jul 7 13:12:24 2017] [c2-1c0s1n2] application called
MPI_Abort(MPI_COMM_WORLD, 1) - process 0
I checked in the source code for the test and the LP seems to be registered
properly. Any idea why this could be happening?
And would it be the right way to go about it if I used the
darshan-workload-generator to issue I/O requests to the storage-model
instead of the checkpointing I/O being issued by the test case right now?
Harsh Khetawat
On Fri, Jul 7, 2017 at 9:40 AM, Harsh Khetawat <hkhetaw at ncsu.edu> wrote:
> Hi Misbah,
> Thank you for the information. This seems perfect for what I want to do.
> I'll try to set-up a simulation with replays of darshan logs and see how it
> goes.
> Thanks again.
> Regards,
> Harsh Khetawat
> On Thu, Jul 6, 2017 at 4:02 PM, Mubarak, Misbah <mmubarak at anl.gov> wrote:
>> Hi Harsh,
>> Have you looked at the codes-storage-server model? There is a wiki at:
>> https://xgitlab.cels.anl.gov/codes/codes-storage-server/wikis/home
>> The wiki has an example case study here that models storage nodes on the
>> dragonfly network. The clients (compute nodes) interact with the storage
>> nodes via an API that does RDMA style communication. You can find the
>> example on the API usage in tests/test-client-checkpoint.c [Look for the
>> function: send_req_to_store]. The API itself can be found at:
>> codes-store-lp.h.
>> The repo can be cloned from:
>> The CODES storage model makes use of the local-storage-model in CODES.
>> Attached is a diagram showing the sequence of steps for a write operation
>> (read operation is also implemented, you have to specify a flag indicating
>> whether it is a read or a write).
>> Hope that helps.
>> Regards,
>> Misbah
>> From: <codes-ross-users-bounces at lists.mcs.anl.gov> on behalf of Harsh
>> Date: Thursday, July 6, 2017 at 3:37 PM
>> To: "codes-ross-users at lists.mcs.anl.gov" <codes-ross-users at lists.mcs.an
>> l.gov>
>> Cc: Harsh Khetawat <hkhetaw at ncsu.edu>
>> Subject: [codes-ross-users] Help with Storage Simulation
>> Hi,
>> I have set-up CODES on my cluster and would like to use it to simulate
>> different storage strategies.
>> I wanted to use the darshan logs I have collected along with the
>> local-storage-model in CODES to simulate I/O behavior of the application.
>> My simulation involves not having just one global storage LP, but having:
>> (i) one storage LP per terminal, or (ii) one storage LP per Modelnet_group,
>> or (iii) other strategies.
>> Would the local-storage-model be the correct choice for this?
>> Should I write my own storage model for each scenario?
>> How would I go about incorporating this with the fattree or dragonfly
>> network models?
>> Thanks for the help.
>> Regards,
>> Harsh Khetawat
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170707/1e2cafdd/attachment-0001.html>
More information about the codes-ross-users
