[codes-ross-users] Help with Storage Simulation
Harsh Khetawat
hkhetaw at ncsu.edu
Fri Jul 7 08:40:02 CDT 2017
Hi Misbah,
Thank you for the information. This seems perfect for what I want to do.
I'll try to set-up a simulation with replays of darshan logs and see how it
goes.
Thanks again.
Harsh Khetawat
On Thu, Jul 6, 2017 at 4:02 PM, Mubarak, Misbah <mmubarak at anl.gov> wrote:
> Hi Harsh,
> Have you looked at the codes-storage-server model? There is a wiki at:
> https://xgitlab.cels.anl.gov/codes/codes-storage-server/wikis/home
> The wiki has an example case study here that models storage nodes on the
> dragonfly network. The clients (compute nodes) interact with the storage
> nodes via an API that does RDMA style communication. You can find the
> example on the API usage in tests/test-client-checkpoint.c [Look for the
> function: send_req_to_store]. The API itself can be found at:
> codes-store-lp.h.
> The repo can be cloned from:
> The CODES storage model makes use of the local-storage-model in CODES.
> Attached is a diagram showing the sequence of steps for a write operation
> (read operation is also implemented, you have to specify a flag indicating
> whether it is a read or a write).
> Hope that helps.
> Regards,
> Misbah
> From: <codes-ross-users-bounces at lists.mcs.anl.gov> on behalf of Harsh
> Khetawat <hkhetaw at ncsu.edu>
> Date: Thursday, July 6, 2017 at 3:37 PM
> To: "codes-ross-users at lists.mcs.anl.gov" <codes-ross-users at lists.mcs.
> anl.gov>
> Cc: Harsh Khetawat <hkhetaw at ncsu.edu>
> Subject: [codes-ross-users] Help with Storage Simulation
> Hi,
> I have set-up CODES on my cluster and would like to use it to simulate
> different storage strategies.
> I wanted to use the darshan logs I have collected along with the
> local-storage-model in CODES to simulate I/O behavior of the application.
> My simulation involves not having just one global storage LP, but having:
> (i) one storage LP per terminal, or (ii) one storage LP per Modelnet_group,
> or (iii) other strategies.
> Would the local-storage-model be the correct choice for this?
> Should I write my own storage model for each scenario?
> How would I go about incorporating this with the fattree or dragonfly
> network models?
> Thanks for the help.
> Regards,
> Harsh Khetawat
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170707/0788f186/attachment.html>
More information about the codes-ross-users
