[codes-ross-users] Simulation ends with events unprocessed
Gonsiorowski, Elsa
gonsiorowski1 at llnl.gov
Tue Feb 28 16:49:21 CST 2017
Hi Jian,
It looks like you have an end time set in you simulation. For ROSS models the end time can be changed with the `--end=` command line argument. I’m not sure if or how CODES modifies the end time of simulations.
Elsa Gonsiorowski
On Feb 28, 2017, at 14:36, Jian Peng <jpeng10 at hawk.iit.edu<mailto:jpeng10 at hawk.iit.edu>> wrote:
After some debugging, I found the reason of this issue was "tw_event_send()". I added some debugging code shown as "tw_event_send.png". Then I got debugging output as "debug1.png". Please notice the highlighted value of pointer "kp". Then I found this same "kp" value in previous context, shown in "debug2.png". Since the "last_time" is greater than "recv_ts", "tw_eventq_push()" rather than "tw_pq_enqueue()" is called. As I'm doing sequential simulation, "tw_scheduler_sequential()" in tw-shed.c should be used. "tw_pq_dequeue()" is used to read the event queue, shown in "tw_scheduler_sequential.png".
So here's the question. The events that called "tw_eventq_push()" seem not able to be retrieved by "tw_pq_dequeue()". So I'm wondering that either mapping multiple LPs to one KP or only using "tw_pq_dequeue()" in sequential scheduler is a bug? I haven't looked too much into both parts, just got this question in mind.
Thanks!
On Mon, Feb 27, 2017 at 1:20 PM, Jian Peng <jpeng10 at hawk.iit.edu<mailto:jpeng10 at hawk.iit.edu>> wrote:
I'm running some experiments on Dragonfly with CODES 5.0.2. Sometimes they end up with unsent messages remaining in terminals and routers. I think the reason is the events that carry these messages are not handled. I looked through my debugging information and confirmed it.
So, why does ROSS end when there are still events unprocessed? I'm running a sequential simulation. Thanks.
<image.png>
<debug2.png><debug3.png><tw_scheduler_sequential.png><tw_event_send.png>_______________________________________________
codes-ross-users mailing list
codes-ross-users at lists.mcs.anl.gov<mailto:codes-ross-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/codes-ross-users
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20170228/90a3caf0/attachment.html>
More information about the codes-ross-users
