[codes-ross-users] codes model net problems
于雷(Yu Lei) yulei at buaa.edu.cn
Sat Aug 6 22:58:04 CDT 2016
Hi John,
Thanks for your response.
For the first question, the configuration is as follows:
LPGROUPS {
     ## cluster foo
     FOO_CLUSTER {
         repetitions="12";
         node="1";
         modelnet_simplenet at foo="1";
     FOO_FORWARDERS {
         repetitions="4";
         forwarder="1";
     ## cluster bar
     BAR_CLUSTER {
         repetitions="12";
         node="1";
         modelnet_simplenet at bar="1";
     BAR_FORWARDERS {
         repetitions="4";
         forwarder="1";
PARAMS {
     ## ROSS parameters
     message_size="352";
     ## global modelnet parameters
     modelnet_order=("simplenet");
     ## foo cluster network parameters
     packet_size at foo="8192";
     modelnet_scheduler at foo="fcfs";
     net_startup_ns at foo="1.5";
     net_bw_mbps at foo="10000";
     ## bar cluster network parameters
     packet_size at bar="2048";
     modelnet_scheduler at bar="round-robin";
     net_startup_ns at bar="3.0";
     net_bw_mbps at bar="15000";
     ## forwarding network parameters
     packet_size="4096";
     modelnet_scheduler="fcfs";
     net_startup_ns="8.0";
     net_bw_mbps="5000";
run_params {
     num_reqs="5";
     payload_sz="16384";
FOO_FORWARDERS and BAR_FORWARDERS are two groups. The lps in these
groups have the same type but have different annotations. we call
model_net_event_annotated(
         int net_id,//SIMPLENET(0)
         char const * annotation,
         char const * category,
         tw_lpid final_dest_lp, //sender->gid is 26,final_dest_lp is 58
         uint64_t message_size,
         tw_stime offset,
         int remote_event_size,
         void const * remote_event,
         int self_event_size,
         void const * self_event,
         tw_lp *sender);
Then we can achieve the communication between lp26 and lp58.
For the second questions, is it possible that we use model_net_event()
to establish a simple point-to-point connection and we send messages 1M
times and take the average?
Lei
在 2016/8/5 21:40, Jenkins, Jonathan P. 写道:
> Hi Yu,
> You are correct that modelnet LPs with different annotations shouldn't
> be able to communicate through the modelnet interface. Can you send us
> the configuration file you are using, along with the net_id,
> annotation, final_dest_lp, and sender->gid values for the call that
> misbehaves? We'll try to reproduce on our end.
> The startup parameter in simplenet represents local sender-side
> overhead on a packet granularity. So one way to estimate the startup
> is to get an average per-call time (on the sender side) of very small
> (word-sized) messages. I.e. measure calling send(fd, buf, 8, flags) 1M
> times and take the average.
> Thanks,
> John
> *From: *<codes-ross-users-bounces at lists.mcs.anl.gov> on behalf of
> 于雷(Yu Lei)<yulei at buaa.edu.cn>
> *Date: *Thursday, August 4, 2016 at 10:34 PM
> *To: *"codes-ross-users at lists.mcs.anl.gov"
> <codes-ross-users at lists.mcs.anl.gov>
> *Subject: *[codes-ross-users] codes model net problems
>     1/for the method:
>     model_net_event_return model_net_event_annotated(
>             int net_id,
>             tw_stime offset,
>             tw_lp *sender);
>     we think that two lps with same network type but with different
>     annotation can not communicate with this method. But we do some
>     tests which prove that the communication can be established. We
>     don't know why?
>     2/for simplenet model, it needs a parameter "start_up". How can we
>     obtain this parameter?
>     Thanks,
>     Lei
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20160807/e14efb5c/attachment.html>
More information about the codes-ross-users mailing list
